  3. OpenHAB
  4. OH2.5.9 / ethernet gateway / autodiscovery?
10 Posts 3 Posters 1.7k Views 5 Watching
  • S Offline
    Stefferd
    Hi Mind hive,
    I have put in my mind to migrate my home automation from Souliss to MySensors, and i am setting up a testlab. I have a RS485 line running through my house, and i want to re-use it.
    In my test setup i have installed a clean OH 2.5.9 (on windows).
    i've built an ethernet gateway on a mega2560 with RS485 shield (built myself, based on SN75176 transceiver)
    The ethernet gateway compiled without errors. this is the sketch (grabbed from examples and edited to the needs of an ethernet/RS485 network)
    //#define MY_DEBUG_HWSERIAL Serial1 // = Serial0 / Rx0 & Tx0 to programming & debug
    // Enable RS485 transport layer
    #define MY_RS485
    // Define this to enables DE-pin management on defined pin
    #define MY_RS485_DE_PIN 2
    // Set RS485 baud rate to use
    // Enable this if RS485 is connected to a hardware serial port
    #define MY_RS485_HWSERIAL Serial3
    #define MY_GATEWAY_W5100
    #define MY_W5100_SPI_EN 4
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
    #define MY_IP_ADDRESS 192,168,80,185
    #define MY_IP_GATEWAY_ADDRESS 192,168,80,1
    #define MY_PORT 5003
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 80, 190
    //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
    // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
    #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xF1, 0x00
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    I hope that's well done for an ethernet to RS485 gateway.
    The debug output of the GW says this:
    17:21:03.768 -> 0 MCO:BGN:INIT GW,CP=RSNGA---,FQ=16,REL=255,VER=2.3.2
    17:21:03.803 -> 4 TSM:INIT
    17:21:03.803 -> 5 TSF:WUR:MS=0
    17:21:03.803 -> 7 TSM:INIT:TSP OK
    17:21:03.803 -> 8 TSM:INIT:GW MODE
    17:21:03.803 -> 10 TSM:READY:ID=0,PAR=0,DIS=0
    17:21:03.803 -> 12 MCO:REG:NOT NEEDED
    17:21:04.370 -> 575 GWT:TIN:IP=192.168.80.185
    17:21:06.386 -> 2580 !GWT:TIN:ETH FAIL
    17:21:06.386 -> 2582 MCO:BGN:STP
    17:21:06.386 -> 2584 MCO:BGN:INIT OK,TSP=1
    17:21:07.410 -> 3588 !GWT:TSA:ETH FAIL
    17:21:07.410 -> 3590 TSM:READY:NWD REQ
    17:21:07.410 -> 3608 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    17:21:08.428 -> 4616 !GWT:TSA:ETH FAIL
    17:21:09.448 -> 5619 !GWT:TSA:ETH FAIL
    17:21:10.447 -> 6623 !GWT:TSA:ETH FAIL
    Which also doesn't seem wrong to me since the gateway doesn't find a controller.
    Enter the controller: Openhab 2.5.9.
    Installed the binding by adding it in the addons folder.
    openhab> bundle:list | grep MySensors
    210 │ Installed │  80 │ 2.5.0.202002161928      │ openHAB Add-ons :: Bundles :: MySensors Binding
    Binding shows as installed - but not active.
    I added a demo.things file in the things folder:
    Bridge mysensors:bridge-eth:gateway [ ipAddress="192.168.80.185", tcpPort=5003, sendDelay=200 ] {
    And that's where i am stuck.
    Q1: how to get the binding 'active' ? any ideas?
    Q2: how to get autodiscovery working once the binding is active? Is this actually implemented? I only see examples with textual configuration.
    openhab.log shows this, by the way:
    2020-10-20 17:04:29.689 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'demo.things'
    2020-10-20 17:04:30.659 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
    2020-10-20 17:04:31.224 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.80.190:8080
    2020-10-20 17:04:31.299 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.80.190:8443
    2020-10-20 17:04:31.643 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
    2020-10-20 17:04:31.674 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
    2020-10-20 17:04:31.708 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
    2020-10-20 17:04:33.910 [WARN ] [org.apache.felix.fileinstall        ] - Error while starting bundle: file:/C:/OH25/addons/org.openhab.binding.mysensors-2.5.0-SNAPSHOT%20(1).jar
    org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.mysensors [210]
      Unresolved requirement: Import-Package: org.eclipse.smarthome.io.transport.mqtt
    	at org.eclipse.osgi.container.Module.start(Module.java:444) ~[org.eclipse.osgi-3.12.100.jar:?]
    	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[org.eclipse.osgi-3.12.100.jar:?]
    	at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.6.4]
    	at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.6.4]
    	at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) [bundleFile:3.6.4]
    	at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) [bundleFile:3.6.4]
    	at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.6.4]
    	at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.6.4]
    Thanks People :)
    • T Offline
      T Offline
      tssk
      wrote on last edited by tssk
      Hello, also beginner here so take my advice with some reserve.
      1 - It seems to me that your ethernet connection does not work - https://www.mysensors.org/apidocs/group__MyGatewayTransportgrp.html
      Can you ping the gateway?
      2 - I am also using openHab but with MQTT gateway and MQTT binding as I did not find mysensors binding in the official list. But there is no autodiscovery - but I prefer to configure it manually anyway.
      S 1 Reply Last reply
      • T tssk
        Stefferd
        @tssk
        Thanks for the reply,
        PS C:\Windows\system32> ping 192.168.80.185
        Pinging 192.168.80.185 with 32 bytes of data:
        Reply from 192.168.80.185: bytes=32 time<1ms TTL=128
        Ping statistics for 192.168.80.185:
            Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
        Approximate round trip times in milli-seconds:
            Minimum = 0ms, Maximum = 0ms, Average = 0ms
        The gateway is very pingeable, from what i found on other threads the problem could be that the controller is unavailable. That actually makes sense since the binding doesn't show "active'.
        • S Stefferd
          @tssk
          T Offline
          T Offline
          TimO
          @Stefferd Please fulfill the requirement for mqtt of the binding:
          feature:install openhab-transport-serial
          and
          feature:install openhab-core-io-transport-mqtt
          If you're starting from the scratch please consider using the MQTT Gateway instead of the binding. I've developed the binding and I am currently not quite sure if I'm able to maintain support for the binding, especially because OpenHAB3 is on its way.
          • T TimO
            and
            Stefferd
            @TimO Thanks for the reply. I've done the steps you provided, and the binding is active now in OH.
            but still no luck. OH logfile says it cannot connect to the bridge.
            2020-10-21 14:30:00.521 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
            2020-10-21 14:30:00.521 [ERROR] [al.protocol.ip.MySensorsIpConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:5)
            2020-10-21 14:30:00.521 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Disconnecting from IP bridge ...
            2020-10-21 14:30:10.537 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [192.168.80.185:5003]
            2020-10-21 14:30:31.616 [ERROR] [al.protocol.ip.MySensorsIpConnection] - Error while trying to connect InputStreamReader
            java.net.ConnectException: Connection timed out: connect
            	at java.net.DualStackPlainSocketImpl.connect0(Native Method) ~[?:1.8.0_265]
            	at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:79) ~[?:1.8.0_265]
            	at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) ~[?:1.8.0_265]
            	at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[?:1.8.0_265]
            	at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[?:1.8.0_265]
            	at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172) ~[?:1.8.0_265]
            	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:1.8.0_265]
            	at java.net.Socket.connect(Socket.java:607) ~[?:1.8.0_265]
            	at java.net.Socket.connect(Socket.java:556) ~[?:1.8.0_265]
            	at java.net.Socket.<init>(Socket.java:452) ~[?:1.8.0_265]
            	at java.net.Socket.<init>(Socket.java:229) ~[?:1.8.0_265]
            	at org.openhab.binding.mysensors.internal.protocol.ip.MySensorsIpConnection.establishConnection(MySensorsIpConnection.java:50) [bundleFile:?]
            	at org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection.connect(MySensorsAbstractConnection.java:152) [bundleFile:?]
            	at org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection.run(MySensorsAbstractConnection.java:131) [bundleFile:?]
            	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_265]
            	at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:1.8.0_265]
            	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_265]
            	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:1.8.0_265]
            	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_265]
            	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_265]
            	at java.lang.Thread.run(Thread.java:748) [?:1.8.0_265]
            2020-10-21 14:30:31.616 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
            2020-10-21 14:30:31.616 [ERROR] [al.protocol.ip.MySensorsIpConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:6)
            2020-10-21 14:30:31.616 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Disconnecting from IP bridge ...
            and the bridge's debug output now gives this:
            14:23:09.688 -> 0 MCO:BGN:INIT GW,CP=RSNGA---,FQ=16,REL=255,VER=2.3.2
            14:23:09.688 -> 4 TSM:INIT
            14:23:09.688 -> 5 TSF:WUR:MS=0
            14:23:09.688 -> 7 TSM:INIT:TSP OK
            14:23:09.688 -> 8 TSM:INIT:GW MODE
            14:23:09.688 -> 10 TSM:READY:ID=0,PAR=0,DIS=0
            14:23:09.722 -> 12 MCO:REG:NOT NEEDED
            14:23:10.282 -> 575 GWT:TIN:IP=192.168.80.185
            14:23:11.294 -> 1579 MCO:BGN:STP
            14:23:11.294 -> 1580 MCO:BGN:INIT OK,TSP=1
            14:23:11.294 -> 1583 TSM:READY:NWD REQ
            14:23:11.294 -> 1586 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
            but it stays stuck there. I must say i just outcommented the line
            AFAIK the MQTT gateway does not provide autodiscovery? That's a very important one to me since i'm not the only one configuring OH.
            Is there actually anexisting way to make OpenHAB discover my nodes and children? Or am i wrong?
            Stef
            • S Stefferd
              Stef
              T Offline
              T Offline
              TimO
              @Stefferd Don't use UDP for the connection between the gateway and Openhab, it is not supported by the binding.
              Are you able to log into the gateway via telnet?
              telnet  192.168.80.185 5003
              • T TimO
                Stefferd
                @TimO Ok, i've outcommented the UDP line again in my sketch.
                gateway debug output gives me this again:
                15:14:50.371 -> 150168 !GWT:TSA:ETH FAIL
                15:14:51.389 -> 151172 !GWT:TSA:ETH FAIL
                15:14:52.386 -> 152176 !GWT:TSA:ETH FAIL
                15:14:53.409 -> 153180 !GWT:TSA:ETH FAIL
                15:14:54.421 -> 154183 !GWT:TSA:ETH FAIL
                15:14:55.438 -> 155187 !GWT:TSA:ETH FAIL
                infinitely.
                and telnet to the GW on port 5003 doesn't work (in putty telnet client)
                Thanks for your support by the way, i really appreciate it.
                • S Stefferd
                  infinitely.
                  Stefferd
                  @TimO Ok, found it. This was the problem:
                  After disabling UDP in the sketch, this UDP-specific line should have been outcommented too.
                  Openhab log looks fine:
                  2020-10-21 15:23:15.294 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'demo.things'
                  2020-10-21 15:23:15.872 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
                  2020-10-21 15:23:16.277 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.80.190:8080
                  2020-10-21 15:23:16.308 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.80.190:8443
                  2020-10-21 15:23:16.606 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
                  2020-10-21 15:23:16.621 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
                  2020-10-21 15:23:16.637 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
                  2020-10-21 15:23:16.918 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
                  2020-10-21 15:23:16.949 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                  2020-10-21 15:23:16.949 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache (given_ids) content: []
                  2020-10-21 15:23:16.949 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Enabling connection watchdog
                  2020-10-21 15:23:16.949 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                  2020-10-21 15:23:16.949 [DEBUG] [.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
                  2020-10-21 15:23:16.965 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [192.168.80.185:5003]
                  2020-10-21 15:23:17.262 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                  2020-10-21 15:23:17.292 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;14;Gateway startup complete.
                  2020-10-21 15:23:17.309 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;0;0;18;2.3.2
                  2020-10-21 15:23:17.309 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Presentation Message received
                  2020-10-21 15:23:17.309 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: [0]
                  2020-10-21 15:23:17.309 [WARN ] [.discovery.MySensorsDiscoveryService] - Cannot automatic discover thing node: 0, child: 255 please insert it manually
                  2020-10-21 15:23:17.309 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;2;2.3.2
                  2020-10-21 15:23:17.309 [DEBUG] [rsAbstractConnection$MySensorsReader] - Good,Gateway is up and running! (Ver:2.3.2)
                  2020-10-21 15:23:17.309 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
                  and the gateway's debug output also looks fine:
                  15:22:53.667 -> 0 MCO:BGN:INIT GW,CP=RSNGA---,FQ=16,REL=255,VER=2.3.2
                  15:22:53.667 -> 4 TSM:INIT
                  15:22:53.667 -> 5 TSF:WUR:MS=0
                  15:22:53.667 -> 7 TSM:INIT:TSP OK
                  15:22:53.667 -> 8 TSM:INIT:GW MODE
                  15:22:53.667 -> 10 TSM:READY:ID=0,PAR=0,DIS=0
                  15:22:53.667 -> 12 MCO:REG:NOT NEEDED
                  15:22:54.236 -> 575 GWT:TIN:IP=192.168.80.185
                  15:22:55.257 -> 1579 MCO:BGN:STP
                  15:22:55.257 -> 1580 MCO:BGN:INIT OK,TSP=1
                  15:22:55.257 -> 1583 TSM:READY:NWD REQ
                  15:22:55.257 -> 1586 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                  15:23:17.292 -> 23449 GWT:TSA:ETH OK
                  15:23:17.292 -> 23453 GWT:RFC:MSG=0;0;3;0;2;
                  15:23:17.292 -> 23457 GWT:RFC:MSG=
                  15:23:17.292 -> 23459 GWT:RFC:MSG=
                  Thanks for your time and patience to a newbie!
                  • S Offline
                    Stefferd
                    @TimO so, i have set up a RS485 node. Communication from the node to the gateway works - the gateway sees the messages, and forwards the to OpenHAB.
                    But Openhab does not autodiscover it (it's a motion sensor, from the examples). Even though it's mentioned in the openhab logs.
                    2020-10-22 14:14:19.110 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'demo.things'
                    2020-10-22 14:14:20.235 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
                    2020-10-22 14:14:20.640 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.80.190:8080
                    2020-10-22 14:14:20.687 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.80.190:8443
                    2020-10-22 14:14:21.031 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
                    2020-10-22 14:14:21.046 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
                    2020-10-22 14:14:21.093 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
                    2020-10-22 14:14:21.327 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
                    2020-10-22 14:14:21.437 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached not exist.
                    2020-10-22 14:14:21.437 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached not exist. Default passed, creating it...
                    2020-10-22 14:14:21.437 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
                    2020-10-22 14:14:21.437 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache (given_ids) content: []
                    2020-10-22 14:14:21.437 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Enabling connection watchdog
                    2020-10-22 14:14:21.452 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                    2020-10-22 14:14:21.452 [DEBUG] [.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
                    2020-10-22 14:14:21.452 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [192.168.80.185:5003]
                    2020-10-22 14:14:21.468 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                    2020-10-22 14:14:21.483 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;14;Gateway startup complete.
                    2020-10-22 14:14:21.499 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;0;0;18;2.3.2
                    2020-10-22 14:14:21.499 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Presentation Message received
                    2020-10-22 14:14:21.499 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: [0]
                    2020-10-22 14:14:21.499 [WARN ] [.discovery.MySensorsDiscoveryService] - Cannot automatic discover thing node: 0, child: 255 please insert it manually
                    2020-10-22 14:14:21.499 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;2;2.3.2
                    2020-10-22 14:14:21.499 [DEBUG] [rsAbstractConnection$MySensorsReader] - Good,Gateway is up and running! (Ver:2.3.2)
                    2020-10-22 14:14:21.499 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
                    2020-10-22 14:14:59.078 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;16;0
                    2020-10-22 14:15:49.735 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;16;0
                    2020-10-22 14:15:49.782 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;16;0
                    2020-10-22 14:15:49.828 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;16;0
                    2020-10-22 14:15:49.859 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;16;0
                    2020-10-22 14:15:49.905 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;16;0
                    2020-10-22 14:15:49.937 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;16;0
                    2020-10-22 14:15:49.986 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;16;0
                    2020-10-22 14:16:15.189 [DEBUG] [.discovery.MySensorsDiscoveryService] - Stopping MySensors discovery scan
                    2020-10-22 14:16:15.189 [DEBUG] [.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
                    2020-10-22 14:17:59.262 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;16;0
                    Is there something i'm still missing?
                    • S Stefferd
                      Stefferd
                      @TimO No Sweat, found it :D - it was because the node was powered on before the gateway and presentation didn't go well...
                      12.1k
