  3. 💬 Minimal LiPo powered Arduino Pro Mini + RFM95 MySensors node
rfm95pro minibme280mysensors
24 Posts 6 Posters 4.0k Views 5 Watching
  • J Joost
    HI, I'll try to get back to you this weekend and re-measure my power consumption (you're correct, these are unmodified 8MHz/3.3V Pro Minis, no modified bootloader or anything). The consumption was measured with two relatively cheap multimeters, giving the same result (in comparison to your link without the DS18B20 and with a RFM95), though I'm pretty confident this would be kind of correct.
    Btw. you mean the thickness of the radio module on its own?
    E
    E
    evb
    @Joost thanks :-)
    I mean the total dimensions and thickness :
    • Pro Mini + breakout with radio
    • Pro Mini + breakout with radio + sensor
    I'm very limited in high and width, so this is important in order to assess its usefulness.
    • J
      J
      Joost
      Hi, with a newer, potentially better DMM I found 12.4µA at 3.3V for a Pro Mini (3.3/8MHz, regulator and power LED removed, stock bootloader) with a BME280 (which has an additional, in this 3.3V setting unneeded, power regulator on board that could be removed) and a RFM95/96, at deep sleep.
      Also I got you some pic of the dimensions for that older version of the board I had lying around.
      Cheers, Joost
      PXL_20201121_121708555.jpg PXL_20201121_121643304.jpg ProMini-BME280-RFM95.jpg
      J 1 Reply Last reply
      • J Joost
        Cheers, Joost
        J
        J
        Joost
        wrote on last edited by Joost
        Or am I measuring nonsense/inaccurately? Just a hobbyist...
        If so, sorry for that
        • J
          J
          Joost
          Maybe we are comparing deep sleep current vs. a "mix" of deep sleep and wake times added together and averaged? See differences between those approaches in the first
          See "calculation"
          vs. these last two links:
          See table "The Simple @ 8Mhz"
          Sparkfun article
          • E
            E
            evb
            Thanks for the dimensions :-)
            That will work in my setup!
            I have read also these links with results much better then my 133µA.
            I have tested my pro mini with the lowpower sketch to get the pro mini in deep sleep and I measure 133µA. My multimeter is already 30 years old and his last calibration was 20 years ago? But the voltage measurements are still correct, so I don't know...
            LowpowerLab has a Current Sense Amplifier device, but for 141 euros it is bit expensive ;-)
            You didn't mention where you did buy your Pro Mini's? I'm thinking about the quality of the used electronics...
            O J 3 Replies Last reply
            • E
              E
              evb
              @Joost I wanted to order your created breakoutboard, but there is no option to buy them on the openhardware.io website.
              Is that something you don't want or is it something that you must activate in your profile on OpenHardware?
              • E evb
                O
                O
                olka
                @evb 133uA is a lot. Why do you use the lowpower sketch? There are lots of ways to reduce consumption in deep sleep, and the Mysensors library sleep function does a pretty good job of it. For best results you should use a bootloader with fuse settings for 8mhz internal resonator and no BOD. 1mhz is even lower, but not so much to gain from it.
                E 1 Reply Last reply
                • O olka
                  E
                  E
                  evb
                  Hi @olka, on the topic https://forum.mysensors.org/topic/4796/battery-powered-sensors/243 you can read the whole story :-)
                  The lowpower sketch is just used for measurement of the deepsleep power consumption to have an equivalent software sketch when comparing the results with the results from the given links like See table "The Simple @ 8Mhz"
                  It was done with only the Pro Mini with no regulator and no power led.
                  The only difference I see now is the build quality of the Pro Mini itself.
                  Do you use also Pro Mini with these low currents in deepsleep?
                  If yes, from where did you get them?
                  O 1 Reply Last reply
                  • E evb
                    O
                    O
                    olka
                    @evb, I really don't know why you get that high consumption of 133uA, but there is defenently someting wrong. Sorry that I cant help.
                    I use my own pcb design but it's basically the same as a mini pro without reg and led + RFM69HW. All my 328 chips is sourced from china and working fine.
                    I just measured on of my older designs with 8mhz/no BOD and I get about 6.7uA in timed sleep (WDT active), including 1M/470k voltage divider.
                    With the same setup without 1M/470k voltage divider and with external interrupt wake-up (sleep forever) I have about 0.8uA.
                    This was measured with two different multimeters with uA range. Sure, in this range a multimeter is not as accurate as the uCurrent or similar instruments, but IMO more than good enough for this kind of measurement.
                    If you are able to solve your main problem, I have a few other tips for further tweeking:
                    • Don't use bootloader with BOD, you don't need it for a sensor that is continous connected to the battery. Saves 20-25uA.
                    • If you power from 3V battery, don't use the suggested 1M/470k voltage divider for battery monitoring, you can do battery monitoring with code only (search here on the forum for it). Saves 2uA.
                    • You could perhaps gain a tiny bit more by setting all unused pins to LOW OUTPUT or LOW INPUT.
                    Some very good info on ATmega 328 power consumption here: https://www.gammon.com.au/forum/?id=11497
                    YveauxY E 2 Replies Last reply
                    • O olka
                      @olka said in 💬 Minimal LiPo powered Arduino Pro Mini + RFM95 MySensors node:
                      @evb I wrote a small library for it: https://github.com/Yveaux/Arduino_Vcc
                      • E evb
                        J
                        J
                        Joost
                        • E evb
                          J
                          J
                          Joost
                          @evb said in 💬 Minimal LiPo powered Arduino Pro Mini + RFM95 MySensors node:
                          @evb I don't have a specific source for my Pro Minis. Some are from Ali, some from Ebay international - I don't even know which one is from where. I just keep sure to always order the same layout/design, as can be seen in the photos.
                          Also, when the regulator and LED are removed, there is not that much left besides the ATMega328 itself, is there? Some resonators, but not any questionable parts AFAICS.
                          Perhaps you should really give another multimeter a try?
                          • YveauxY Yveaux
                            E
                            E
                            evb
                            @Yveaux I'm already using your VCC library :-)
                            • O olka
                              E
                              E
                              evb
                              @olka Thanks for the tips. I'm already doing the last 2 tips.
                              Concerning the first tip, you mean to program directly the sketch via the ISP and not the normal way to upload via the bootloader?
                              Didn't know that this also saves some power.
                              • J Joost
                                E
                                E
                                evb
                                @Joost I measured the current with another, even older, analog type of multimeter, a type where you need to read the needle using an integrated mirror :-)
                                It is measuring approximately the same deep sleep current: 141µA
                                Maybe the two multimeters are not correct, but they all give the same order of magnitude.
                                Next weekend, I will redo a measuring:
                                • a new Pro Mini + sketch deepsleep from lowpowerlab
                                • the same Pro Mini without the power led + sketch deepsleep from lowpowerlab
                                • the same Pro Mini without the power led and regulator + sketch deepsleep from lowpowerlab
                                To be continued
                                PS: @Joost, did you see my message about your breakout pcb to be able to order it via openhardware.io?
                                • E evb
                                  To be continued
                                  E
                                  E
                                  evb
                                  @Joost, bumping :-)
                                  • C
                                    C
                                    chey
                                    @evb Did you ever figure this out?
                                    • C chey
                                      E
                                      E
                                      evb
                                      Hi @chey, no, with the pro minis and MySensors lib I couldn't get less.
                                      Didn't measure with yet another multimeter though...
                                      My battery sensors are working now for about a year and the battery levels are between 65% and 70%.
                                      The sensor furthest from the gateway is at 65% and the 3 others at 70%.
                                      Not bad I think.
                                      https://forum.mysensors.org/topic/11499/checking-mechanical-locked-doors-by-a-battery-based-windows-door-sensor-node
