  3. MQTT GW with RFM69 on RPi
25 Posts 4 Posters 2.3k Views 4 Watching
  • fritsF frits
    I'm getting those MCO:PRO's on the node, the AVR gateway, the raspberry pi gateway, with NRF24 and RFM69 and I'm pretty sure not only on MQTT gateway but also Ethernet gateway. Could test it.
    https://forum.mysensors.org/topic/11310
    For me it seems to be related to a) signing and b) MY_TRANSPORT_WAIT_READY_MS.
    The log looks bad, but node and gateway are working, after all.
    I got used to it.
    TimO
    @frits Thank you for your input. My gateway definitely becomes unreliable after a while.
    Maybe your hint regarding signing is worth some investigation. My sensors (temperature / humidity) which don't use signing seem to work fine over time. My actuators are using signing and become unreliable after a time. Currently I'm using a 2.2.0 gateway with 2.3.2 nodes and the suspicious debug message hasn't appeared yet. Maybe I will disable signing at all and test again.
    • T TimO
      @TimO you are both using rfm69, only one uses signing. I'm using nrf24 mostly with mqtt gw, no signing, and can't recollect seeing it.
      I would start looking in the direction of the nrf69 driver /transport
      • fritsF
        fritsF
        frits
        just a quick test with nrf24 node and nrf24 mqtt gateway with signing:
        0 MCO:BGN:INIT GW,CP=RNNGAA--,FQ=8,REL=255,VER=2.3.2
        38 TSM:INIT
        40 TSF:WUR:MS=0
        47 TSM:INIT:TSP OK
        49 TSM:INIT:GW MODE
        51 TSM:READY:ID=0,PAR=0,DIS=0
        55 MCO:REG:NOT NEEDED
        618 GWT:TPC:IP=192.168.99.13
        1622 MCO:BGN:STP
        MySensors W5100 Gateway
        Version 0.2
        own mac address: DE:AD:BA:BE:99:13
        own network address: 192.168.99.13
        Gateway type: mqtt
        mqtt controller address: 192.168.99.20
        mqtt controller port: 1883
        mqtt client id: mysgw1
        mqtt publish prefix: mysgw1-out
        mqtt subscribe prefix: mysgw1-in
        Radio type: NRF24
        signing: yes
        2150 MCO:BGN:INIT OK,TSP=1
        2160 GWT:TPC:IP=192.168.99.13
        3164 GWT:RMQ:CONNECTING...
        3373 GWT:RMQ:OK
        3375 GWT:TPS:TOPIC=mysgw1-out/0/255/0/0/18,MSG SENT
        3383 TSM:READY:NWD REQ
        3387 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
        8976 TSF:MSG:READ,123-123-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        8982 TSF:MSG:BC
        8984 TSF:MSG:FPAR REQ,ID=123
        8988 TSF:CKU:OK,FCTRL
        8990 TSF:MSG:GWL OK
        9795 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        11005 TSF:MSG:READ,123-123-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
        11012 TSF:MSG:PINGED,ID=123,HP=1
        11018 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
        11044 TSF:MSG:READ,123-123-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
        11053 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
        11075 TSF:MSG:READ,123-123-0,s=255,c=3,t=16,pt=0,l=0,sg=0:
        11159 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
        11331 TSF:MSG:READ,123-123-0,s=255,c=0,t=17,pt=0,l=5,sg=1:2.3.2
        11446 GWT:TPS:TOPIC=mysgw1-out/123/255/0/0/17,MSG SENT
        11454 TSF:MSG:READ,123-123-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
        11542 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
        11712 TSF:MSG:READ,123-123-0,s=255,c=3,t=6,pt=1,l=1,sg=1:0
        11827 GWT:TPS:TOPIC=mysgw1-out/123/255/3/0/6,MSG SENT
        13703 TSF:MSG:READ,123-123-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
        13787 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
        13957 TSF:MSG:READ,123-123-0,s=255,c=3,t=11,pt=0,l=20,sg=1:Hello MySensors 328P
        14077 GWT:TPS:TOPIC=mysgw1-out/123/255/3/0/11,MSG SENT
        14086 TSF:MSG:READ,123-123-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
        14170 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
        14340 TSF:MSG:READ,123-123-0,s=255,c=3,t=12,pt=0,l=3,sg=1:1.3
        14452 GWT:TPS:TOPIC=mysgw1-out/123/255/3/0/12,MSG SENT
        14460 TSF:MSG:READ,123-123-0,s=0,c=3,t=16,pt=0,l=0,sg=1:
        14546 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
        14716 TSF:MSG:READ,123-123-0,s=0,c=0,t=36,pt=0,l=6,sg=1:system
        14833 GWT:TPS:TOPIC=mysgw1-out/123/0/0/0/36,MSG SENT
        14841 TSF:MSG:READ,123-123-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
        14925 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
        15095 TSF:MSG:READ,123-123-0,s=1,c=0,t=36,pt=0,l=9,sg=1:timestamp
        15212 GWT:TPS:TOPIC=mysgw1-out/123/1/0/0/36,MSG SENT
        15220 TSF:MSG:READ,123-123-0,s=2,c=3,t=16,pt=0,l=0,sg=1:
        15302 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
        15472 TSF:MSG:READ,123-123-0,s=2,c=0,t=3,pt=0,l=3,sg=1:led
        15589 GWT:TPS:TOPIC=mysgw1-out/123/2/0/0/3,MSG SENT
        15597 TSF:MSG:READ,123-123-0,s=255,c=3,t=26,pt=1,l=1,sg=1:2
        15605 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
        15613 !MCO:PRO:RC=1
        15616 !MCO:PRO:RC=1
        15618 !MCO:PRO:RC=1
        15620 !MCO:PRO:RC=1
        15624 !MCO:PRO:RC=1
        15626 !MCO:PRO:RC=1
        15628 !MCO:PRO:RC=1
        15630 !MCO:PRO:RC=1
        15634 !MCO:PRO:RC=1
        15636 !MCO:PRO:RC=1
        15638 !MCO:PRO:RC=1
        15640 !MCO:PRO:RC=1
        15644 !MCO:PRO:RC=1
        15646 !MCO:PRO:RC=1
        15648 !MCO:PRO:RC=1
        15650 !MCO:PRO:RC=1
        15654 !MCO:PRO:RC=1
        15656 !MCO:PRO:RC=1
        15659 !MCO:PRO:RC=1
        15661 !MCO:PRO:RC=1
        15665 !MCO:PRO:RC=1
        15667 !MCO:PRO:RC=1
        15669 !MCO:PRO:RC=1
        15671 !MCO:PRO:RC=1
        15673 !MCO:PRO:RC=1
        15677 !MCO:PRO:RC=1
        15679 !MCO:PRO:RC=1
        15681 !MCO:PRO:RC=1
        15683 !MCO:PRO:RC=1
        15687 !MCO:PRO:RC=1
        15689 !MCO:PRO:RC=1
        15691 !MCO:PRO:RC=1
        15693 !MCO:PRO:RC=1
        15697 !MCO:PRO:RC=1
        15699 !MCO:PRO:RC=1
        15702 !MCO:PRO:RC=1
        15704 !MCO:PRO:RC=1
        15708 !MCO:PRO:RC=1
        15710 !MCO:PRO:RC=1
        15712 !MCO:PRO:RC=1
        15714 !MCO:PRO:RC=1
        15718 !MCO:PRO:RC=1
        15720 !MCO:PRO:RC=1
        15722 !MCO:PRO:RC=1
        15724 !MCO:PRO:RC=1
        15728 !MCO:PRO:RC=1
        15730 !MCO:PRO:RC=1
        15732 !MCO:PRO:RC=1
        15734 TSF:MSG:READ,123-123-0,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
        15855 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=27,pt=1,l=1,sg=1,ft=0,st=OK:1
        • fritsF frits
          38 TSM:INIT
          40 TSF:WUR:MS=0
          47 TSM:INIT:TSP OK
          49 TSM:INIT:GW MODE
          1622 MCO:BGN:STP
          Version 0.2
          Gateway type: mqtt
          Radio type: NRF24
          signing: yes
          3373 GWT:RMQ:OK
          8982 TSF:MSG:BC
          8990 TSF:MSG:GWL OK
          15613 !MCO:PRO:RC=1
          15616 !MCO:PRO:RC=1
          15618 !MCO:PRO:RC=1
          15620 !MCO:PRO:RC=1
          15624 !MCO:PRO:RC=1
          15626 !MCO:PRO:RC=1
          15628 !MCO:PRO:RC=1
          15630 !MCO:PRO:RC=1
          15634 !MCO:PRO:RC=1
          15636 !MCO:PRO:RC=1
          15638 !MCO:PRO:RC=1
          15640 !MCO:PRO:RC=1
          15644 !MCO:PRO:RC=1
          15646 !MCO:PRO:RC=1
          15648 !MCO:PRO:RC=1
          15650 !MCO:PRO:RC=1
          15654 !MCO:PRO:RC=1
          15656 !MCO:PRO:RC=1
          15659 !MCO:PRO:RC=1
          15661 !MCO:PRO:RC=1
          15665 !MCO:PRO:RC=1
          15667 !MCO:PRO:RC=1
          15669 !MCO:PRO:RC=1
          15671 !MCO:PRO:RC=1
          15673 !MCO:PRO:RC=1
          15677 !MCO:PRO:RC=1
          15679 !MCO:PRO:RC=1
          15681 !MCO:PRO:RC=1
          15683 !MCO:PRO:RC=1
          15687 !MCO:PRO:RC=1
          15689 !MCO:PRO:RC=1
          15691 !MCO:PRO:RC=1
          15693 !MCO:PRO:RC=1
          15697 !MCO:PRO:RC=1
          15699 !MCO:PRO:RC=1
          15702 !MCO:PRO:RC=1
          15704 !MCO:PRO:RC=1
          15708 !MCO:PRO:RC=1
          15710 !MCO:PRO:RC=1
          15712 !MCO:PRO:RC=1
          15714 !MCO:PRO:RC=1
          15718 !MCO:PRO:RC=1
          15720 !MCO:PRO:RC=1
          15722 !MCO:PRO:RC=1
          15724 !MCO:PRO:RC=1
          15728 !MCO:PRO:RC=1
          15730 !MCO:PRO:RC=1
          15732 !MCO:PRO:RC=1
          @frits and without signing?
          • fritsF
            fritsF
            frits
            not a single MCO:PRO
            0 MCO:BGN:INIT GW,CP=RNNGA---,FQ=8,REL=255,VER=2.3.2
            4 TSM:INIT
            6 TSF:WUR:MS=0
            12 TSM:INIT:TSP OK
            14 TSM:INIT:GW MODE
            16 TSM:READY:ID=0,PAR=0,DIS=0
            20 MCO:REG:NOT NEEDED
            583 GWT:TPC:IP=192.168.99.13
            1587 MCO:BGN:STP
            Version 0.2
            Gateway type: mqtt
            Radio type: NRF24
            signing: no
            2115 MCO:BGN:INIT OK,TSP=1
            2125 GWT:TPC:IP=192.168.99.13
            3129 GWT:RMQ:CONNECTING...
            3338 GWT:RMQ:OK
            3340 GWT:TPS:TOPIC=mysgw1-out/0/255/0/0/18,MSG SENT
            3348 TSM:READY:NWD REQ
            3352 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
            11919 TSF:MSG:READ,123-123-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            11925 TSF:MSG:BC
            11927 TSF:MSG:FPAR REQ,ID=123
            11931 TSF:PNG:SEND,TO=0
            11933 TSF:CKU:OK
            11935 TSF:MSG:GWL OK
            12613 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
            13942 TSF:MSG:READ,123-123-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            13948 TSF:MSG:PINGED,ID=123,HP=1
            13955 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
            13971 TSF:MSG:READ,123-123-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            13981 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
            13989 TSF:MSG:READ,123-123-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.2
            13998 GWT:TPS:TOPIC=mysgw1-out/123/255/0/0/17,MSG SENT
            14006 TSF:MSG:READ,123-123-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
            14012 GWT:TPS:TOPIC=mysgw1-out/123/255/3/0/6,MSG SENT
            16017 TSF:MSG:READ,123-123-0,s=255,c=3,t=11,pt=0,l=20,sg=0:Hello MySensors 328P
            16027 GWT:TPS:TOPIC=mysgw1-out/123/255/3/0/11,MSG SENT
            16033 TSF:MSG:READ,123-123-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.3
            16041 GWT:TPS:TOPIC=mysgw1-out/123/255/3/0/12,MSG SENT
            16050 TSF:MSG:READ,123-123-0,s=0,c=0,t=36,pt=0,l=6,sg=0:system
            16056 GWT:TPS:TOPIC=mysgw1-out/123/0/0/0/36,MSG SENT
            16064 TSF:MSG:READ,123-123-0,s=1,c=0,t=36,pt=0,l=9,sg=0:timestamp
            16072 GWT:TPS:TOPIC=mysgw1-out/123/1/0/0/36,MSG SENT
            16078 TSF:MSG:READ,123-123-0,s=2,c=0,t=3,pt=0,l=3,sg=0:led
            16087 GWT:TPS:TOPIC=mysgw1-out/123/2/0/0/3,MSG SENT
            16093 TSF:MSG:READ,123-123-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
            16101 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
            16117 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=10,sg=0:Hello 6258
            16125 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
            18132 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=10,sg=0:Hello 8269
            18141 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
            20152 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=0:Hello 10283
            20160 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
            22169 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=0:Hello 12294
            22177 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
            24186 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=0:Hello 14305
            24195 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
            26202 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=0:Hello 16316
            26210 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
            28219 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=0:Hello 18327
            28227 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
            30236 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=0:Hello 20338
            30244 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
            32251 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=0:Hello 22349
            32260 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
            34271 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=0:Hello 24363
            34279 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
            36288 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=0:Hello 26374
            36294 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
            38303 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=0:Hello 28385
            38311 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
            39231 GWT:IMQ:TOPIC=mysgw1-in/123/3/0/0/1, MSG RECEIVED
            39239 TSF:MSG:SEND,0-0-123-123,s=3,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
            40321 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=0:Hello 30396
            40329 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
            42338 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=0:Hello 32407
            42346 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
            44353 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=0:Hello 34418
            44361 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
            46370 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=0:Hello 36429
            46379 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
            48390 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=0:Hello 38443
            48398 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
            50405 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=0:Hello 40454
            50413 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
            51738 GWT:IMQ:TOPIC=mysgw1-in/123/3/0/0/1, MSG RECEIVED
            51744 TSF:MSG:SEND,0-0-123-123,s=3,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
            52422 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=0:Hello 42465
            52430 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
            53186 GWT:IMQ:TOPIC=mysgw1-in/123/3/0/0/1, MSG RECEIVED
            53194 TSF:MSG:SEND,0-0-123-123,s=3,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
            54439 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=0:Hello 44476
            54448 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
            56455 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=0:Hello 46487
            56463 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
            58472 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=0:Hello 48498
            58480 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
            • fritsF
              fritsF
              frits
              same results on EthernetGateway instead of MQTT Gateway: MCO:PRO only with signing, only on gateway
              • fritsF frits
                @frits ah, now I see @TimO is also using singing!
                Found the smoking :gun: !
                • YveauxY Yveaux
                  @TimO @frits could one of you build & run with MY_DEBUG_VERBOSE_SIGNING defined, and post the output?
                  fritsF 1 Reply Last reply
                  • YveauxY Yveaux
                    fritsF
                    fritsF
                    frits
                    @Yveaux I have a raspi gw with debug signatures ready:
                    pi@zerogwtest:~/MySensors $ sudo ./mysgw.nrf24
                    Dec 04 05:02:10 INFO  Starting gateway...
                    Dec 04 05:02:10 INFO  Protocol version - 2.3.2
                    Dec 04 05:02:10 DEBUG MCO:BGN:INIT GW,CP=RNNGLS--,FQ=NA,REL=255,VER=2.3.2
                    Dec 04 05:02:10 DEBUG SGN:PER:OK
                    Dec 04 05:02:10 DEBUG SGN:INI:BND OK
                    Dec 04 05:02:10 DEBUG TSF:LRT:OK
                    Dec 04 05:02:10 DEBUG TSM:INIT
                    Dec 04 05:02:10 DEBUG TSF:WUR:MS=0
                    Dec 04 05:02:10 DEBUG TSM:INIT:TSP OK
                    Dec 04 05:02:10 DEBUG TSM:INIT:GW MODE
                    Dec 04 05:02:10 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
                    Dec 04 05:02:10 DEBUG MCO:REG:NOT NEEDED
                    Dec 04 05:02:10 DEBUG MCO:BGN:STP
                    MY_BAUD_RATE=(115200ul)
                    MY_CONTROLLER_IP_ADDRESS=127.0.0.1
                    MY_DEBUG=true
                    MY_DEBUG_VERBOSE_SIGNING=true
                    MY_GATEWAY_LINUX=true
                    MY_GATEWAY_MQTT_CLIENT=true
                    MY_MQTT_CLIENT_ID="mys-nrf-gw"
                    MY_MQTT_PASSWORD=__null
                    MY_MQTT_PUBLISH_TOPIC_PREFIX="mys-nrf-out"
                    MY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mys-nrf-in"
                    MY_MQTT_USER=__null
                    MY_LINUX_CONFIG_FILE="/etc/mysensors.conf"
                    MY_NODE_ID=((255u))
                    MY_PORT=1883
                    MY_RADIO_RF24=true
                    MY_RF24_CE_PIN=((22))
                    MY_RF24_CHANNEL=(76)
                    MY_RF24_CS_PIN=((SS))
                    MY_RF24_PA_LEVEL=((2))
                    MY_SIGNING_REQUEST_SIGNATURES=true
                    MY_SIGNING_SOFT=true
                    MY_VERIFICATION_TIMEOUT_MS=(5*1000ul)
                    SPI_SPIDEV_DEVICE="/dev/spidev1.1"
                    Dec 04 05:02:10 DEBUG MCO:BGN:INIT OK,TSP=1
                    Dec 04 05:02:10 DEBUG GWT:RMQ:CONNECTING...
                    Dec 04 05:02:10 DEBUG connected to 127.0.0.1
                    Dec 04 05:02:10 DEBUG GWT:RMQ:OK
                    Dec 04 05:02:10 DEBUG GWT:TPS:TOPIC=mys-nrf-out/0/255/0/0/18,MSG SENT
                    Dec 04 05:02:10 DEBUG TSM:READY:NWD REQ
                    Dec 04 05:02:10 DEBUG SGN:SGN:NREQ=255
                    Dec 04 05:02:10 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                    Dec 04 05:02:21 DEBUG TSF:MSG:READ,123-123-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                    Dec 04 05:02:21 DEBUG TSF:MSG:BC
                    Dec 04 05:02:21 DEBUG TSF:MSG:FPAR REQ,ID=123
                    Dec 04 05:02:21 DEBUG TSF:PNG:SEND,TO=0
                    Dec 04 05:02:21 DEBUG TSF:CKU:OK
                    Dec 04 05:02:21 DEBUG TSF:MSG:GWL OK
                    Dec 04 05:02:21 DEBUG SGN:SKP:MSG CMD=3,TYPE=8
                    Dec 04 05:02:21 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                    Dec 04 05:02:23 DEBUG TSF:MSG:READ,123-123-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                    Dec 04 05:02:23 DEBUG SGN:SKP:MSG CMD=3,TYPE=24
                    Dec 04 05:02:23 DEBUG TSF:MSG:PINGED,ID=123,HP=1
                    Dec 04 05:02:23 DEBUG SGN:SKP:MSG CMD=3,TYPE=25
                    Dec 04 05:02:23 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                    Dec 04 05:02:23 DEBUG TSF:MSG:READ,123-123-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                    Dec 04 05:02:23 DEBUG SGN:SKP:MSG CMD=3,TYPE=15
                    Dec 04 05:02:23 DEBUG SGN:PRE:SGN REQ,FROM=123
                    Dec 04 05:02:23 DEBUG SGN:PRE:SGN REQ,TO=123
                    Dec 04 05:02:23 DEBUG SGN:PRE:WHI NREQ,TO=123
                    Dec 04 05:02:23 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                    Dec 04 05:02:23 DEBUG SGN:PRE:XMT,TO=123
                    Dec 04 05:02:23 DEBUG TSF:MSG:READ,123-123-0,s=255,c=3,t=16,pt=0,l=0,sg=0:
                    Dec 04 05:02:23 DEBUG SGN:SKP:MSG CMD=3,TYPE=16
                    Dec 04 05:02:23 DEBUG SGN:SKP:MSG CMD=3,TYPE=17
                    Dec 04 05:02:23 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
                    Dec 04 05:02:23 DEBUG SGN:NCE:XMT,TO=0
                    Dec 04 05:02:23 DEBUG TSF:MSG:READ,123-123-0,s=255,c=0,t=17,pt=0,l=5,sg=1:2.3.2
                    Dec 04 05:02:23 DEBUG SGN:BND:NONCE=4B6126A21920FCBC12BE70183533C27C49AE3CD55094914800AAAAAAAAAAAAAA
                    Dec 04 05:02:23 DEBUG SGN:BND:HMAC=ECDD094309264B891BBA3E2D142B2E08B79784B79A1816D53B26361EBABCF446
                    Dec 04 05:02:23 DEBUG SGN:VER:OK
                    Dec 04 05:02:23 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/255/0/0/17,MSG SENT
                    Dec 04 05:02:23 DEBUG TSF:MSG:READ,123-123-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                    Dec 04 05:02:23 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                    Dec 04 05:02:23 DEBUG TSF:MSG:READ,123-123-0,s=255,c=3,t=6,pt=1,l=1,sg=1:0
                    Dec 04 05:02:23 DEBUG SGN:BND:NONCE=F07B9A2B93327E5130177F095042D6954B202A130B2A72B9E5AAAAAAAAAAAAAA
                    Dec 04 05:02:23 DEBUG SGN:BND:HMAC=C34C02E0990FE19990C11FA97D9A55931AF2D99A5890186E877C3C1669FCBDA7
                    Dec 04 05:02:23 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/255/3/0/6,MSG SENT
                    Dec 04 05:02:25 DEBUG TSF:MSG:READ,123-123-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                    Dec 04 05:02:25 DEBUG SGN:SKP:MSG CMD=3,TYPE=16
                    Dec 04 05:02:25 DEBUG SGN:SKP:MSG CMD=3,TYPE=17
                    Dec 04 05:02:25 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                    Dec 04 05:02:25 DEBUG SGN:NCE:XMT,TO=0
                    Dec 04 05:02:26 DEBUG TSF:MSG:READ,123-123-0,s=255,c=3,t=11,pt=0,l=20,sg=1:Hello MySensors 328P
                    Dec 04 05:02:26 DEBUG SGN:BND:NONCE=4A08E36D23F76E6A0940B8C980652ECF7C335F4144209DF1E1AAAAAAAAAAAAAA
                    Dec 04 05:02:26 DEBUG SGN:BND:HMAC=001176474590821EE608440B7639881860DC1ECA9C17868B947D06756C71B105
                    Dec 04 05:02:26 DEBUG SGN:VER:OK
                    Dec 04 05:02:26 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/255/3/0/11,MSG SENT
                    Dec 04 05:02:26 DEBUG TSF:MSG:READ,123-123-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                    Dec 04 05:02:26 DEBUG SGN:SKP:MSG CMD=3,TYPE=16
                    Dec 04 05:02:26 DEBUG SGN:SKP:MSG CMD=3,TYPE=17
                    Dec 04 05:02:26 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                    Dec 04 05:02:26 DEBUG SGN:NCE:XMT,TO=0
                    Dec 04 05:02:26 DEBUG TSF:MSG:READ,123-123-0,s=255,c=3,t=12,pt=0,l=3,sg=1:1.3
                    Dec 04 05:02:26 DEBUG SGN:BND:NONCE=A542EE79921BC3744AD323286768428EE8D7FDED63887EC112AAAAAAAAAAAAAA
                    Dec 04 05:02:26 DEBUG SGN:BND:HMAC=A4E56BED2C58CA5A332B7CC03EE08556550A804F8A0F042CDB58C012779276B6
                    Dec 04 05:02:26 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/255/3/0/12,MSG SENT
                    Dec 04 05:02:26 DEBUG TSF:MSG:READ,123-123-0,s=0,c=3,t=16,pt=0,l=0,sg=1:
                    Dec 04 05:02:26 DEBUG TSF:MSG:READ,123-123-0,s=0,c=0,t=36,pt=0,l=6,sg=1:system
                    Dec 04 05:02:26 DEBUG SGN:BND:NONCE=172B88ACF73CC49618472C3A3AA83FF5A6E0D8805211F8D965AAAAAAAAAAAAAA
                    Dec 04 05:02:26 DEBUG SGN:BND:HMAC=5D6E3EE95F86B335218C5FC90CB11D4EC141301DA071AEBEA16F4D6FD5038CFE
                    Dec 04 05:02:26 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/0/0/0/36,MSG SENT
                    Dec 04 05:02:26 DEBUG TSF:MSG:READ,123-123-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
                    Dec 04 05:02:26 DEBUG TSF:MSG:READ,123-123-0,s=1,c=0,t=36,pt=0,l=9,sg=1:timestamp
                    Dec 04 05:02:26 DEBUG SGN:BND:NONCE=A621A9A841141437693FA157CC6D115EB1EA732165F7FF1958AAAAAAAAAAAAAA
                    Dec 04 05:02:26 DEBUG SGN:BND:HMAC=42CBC8BF5AEB45E21DE5FE86482F6A9CDF5349A6960E407844BF2E06509B80A6
                    Dec 04 05:02:26 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/1/0/0/36,MSG SENT
                    Dec 04 05:02:26 DEBUG TSF:MSG:READ,123-123-0,s=2,c=3,t=16,pt=0,l=0,sg=1:
                    Dec 04 05:02:26 DEBUG TSF:MSG:READ,123-123-0,s=2,c=0,t=3,pt=0,l=3,sg=1:led
                    Dec 04 05:02:26 DEBUG SGN:BND:NONCE=4B1909C8A7DBDABFAF157943AB0AAB1D322123A2B8177F2732AAAAAAAAAAAAAA
                    Dec 04 05:02:26 DEBUG SGN:BND:HMAC=0F31776B1B67825DA94409AF8B220FE9BCB5E4BB9FB1CD618FBD086D51C4D598
                    Dec 04 05:02:26 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/2/0/0/3,MSG SENT
                    Dec 04 05:02:26 DEBUG TSF:MSG:READ,123-123-0,s=255,c=3,t=26,pt=1,l=1,sg=1:2
                    Dec 04 05:02:26 DEBUG SGN:SKP:MSG CMD=3,TYPE=26
                    Dec 04 05:02:26 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                    Dec 04 05:02:26 DEBUG SGN:SGN:NCE REQ,TO=123
                    Dec 04 05:02:26 DEBUG !MCO:PRO:RC=1
                    Dec 04 05:02:27 DEBUG !MCO:PRO:RC=1
                    Dec 04 05:02:27 DEBUG TSF:MSG:READ,123-123-0,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
                    Dec 04 05:02:27 DEBUG SGN:SKP:MSG CMD=3,TYPE=17
                    Dec 04 05:02:27 DEBUG SGN:NCE:FROM=123
                    Dec 04 05:02:27 DEBUG SGN:BND:NONCE=E38476176C1B713F454358240E2C6B5829BAD90CAFA6338EBDAAAAAAAAAAAAAA
                    Dec 04 05:02:27 DEBUG SGN:BND:HMAC=4FEBFCAC5421A7C4DEDD52420E613A7FB2A90BB1E241EF432339ADDE659E4DE3
                    Dec 04 05:02:27 DEBUG SGN:SGN:SGN
                    Dec 04 05:02:27 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=27,pt=1,l=1,sg=1,ft=0,st=OK:1
                    Dec 04 05:02:27 DEBUG TSF:MSG:READ,123-123-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
                    Dec 04 05:02:27 DEBUG SGN:SKP:MSG CMD=3,TYPE=16
                    Dec 04 05:02:27 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                    Dec 04 05:02:27 DEBUG SGN:NCE:XMT,TO=0
                    Dec 04 05:02:27 DEBUG TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=1:Hello 43943
                    Dec 04 05:02:27 DEBUG SGN:BND:NONCE=2FE7F6139888428C3569C3CBFE107F05BC536100175C1EAAD7AAAAAAAAAAAAAA
                    Dec 04 05:02:27 DEBUG SGN:BND:HMAC=B438045B3C7E2D079455F57A41E8E4B1843E1092ABA7C5FA7EF3F41EFC839553
                    Dec 04 05:02:27 DEBUG SGN:VER:OK
                    Dec 04 05:02:27 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/1/1/0/2,MSG SENT
                    Dec 04 05:02:29 DEBUG TSF:MSG:READ,123-123-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
                    Dec 04 05:02:29 DEBUG SGN:SKP:MSG CMD=3,TYPE=16
                    Dec 04 05:02:29 DEBUG SGN:SKP:MSG CMD=3,TYPE=17
                    Dec 04 05:02:29 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                    Dec 04 05:02:29 DEBUG SGN:NCE:XMT,TO=0
                    Dec 04 05:02:29 DEBUG TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=1:Hello 46123
                    Dec 04 05:02:29 DEBUG SGN:BND:NONCE=E1F6BDB4CA7CE0D4F22C87B5048315DF07DE183E8C8D63EA75AAAAAAAAAAAAAA
                    Dec 04 05:02:29 DEBUG SGN:BND:HMAC=642100E6D0897056526EC99F89D789C0484DAAAD0AF2FD5060B66F3E8F32595A
                    Dec 04 05:02:29 DEBUG SGN:VER:OK
                    Dec 04 05:02:29 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/1/1/0/2,MSG SENT
                    Dec 04 05:02:31 DEBUG TSF:MSG:READ,123-123-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
                    Dec 04 05:02:31 DEBUG SGN:SKP:MSG CMD=3,TYPE=16
                    Dec 04 05:02:31 DEBUG SGN:SKP:MSG CMD=3,TYPE=17
                    Dec 04 05:02:31 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                    Dec 04 05:02:31 DEBUG SGN:NCE:XMT,TO=0
                    Dec 04 05:02:31 DEBUG TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=1:Hello 48289
                    Dec 04 05:02:31 DEBUG SGN:BND:NONCE=412EE0D22B09C2FE6E249A6C5003C0B43EE85404CBFD8EF401AAAAAAAAAAAAAA
                    Dec 04 05:02:31 DEBUG SGN:BND:HMAC=B170CB1D43214203A4EDF0AFD7BB137C7D4104E715E1A2632E79E9768FE1CBDF
                    Dec 04 05:02:31 DEBUG SGN:VER:OK
                    Dec 04 05:02:31 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/1/1/0/2,MSG SENT
                    Dec 04 05:02:33 DEBUG TSF:MSG:READ,123-123-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
                    Dec 04 05:02:33 DEBUG SGN:SKP:MSG CMD=3,TYPE=16
                    Dec 04 05:02:33 DEBUG SGN:SKP:MSG CMD=3,TYPE=17
                    Dec 04 05:02:33 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                    Dec 04 05:02:33 DEBUG SGN:NCE:XMT,TO=0
                    Dec 04 05:02:34 DEBUG TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=1:Hello 50462
                    Dec 04 05:02:34 DEBUG SGN:BND:NONCE=83B523911127AC20C1DDFAFFD9A497A55A2A6796B500696B67AAAAAAAAAAAAAA
                    Dec 04 05:02:34 DEBUG SGN:BND:HMAC=D9E09B4F4075AA96C5DAAF507A59D5C9654E704081CCFFFA954B09608DA1A2CA
                    Dec 04 05:02:34 DEBUG SGN:VER:OK
                    Dec 04 05:02:34 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/1/1/0/2,MSG SENT
                    Dec 04 05:02:36 DEBUG TSF:MSG:READ,123-123-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
                    Dec 04 05:02:36 DEBUG SGN:SKP:MSG CMD=3,TYPE=16
                    Dec 04 05:02:36 DEBUG SGN:SKP:MSG CMD=3,TYPE=17
                    Dec 04 05:02:36 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                    Dec 04 05:02:36 DEBUG SGN:NCE:XMT,TO=0
                    Dec 04 05:02:36 DEBUG TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=1:Hello 52633
                    Dec 04 05:02:36 DEBUG SGN:BND:NONCE=E8082AB2925ACA106C9678E6996D6E73CF02A1774AC79B2832AAAAAAAAAAAAAA
                    Dec 04 05:02:36 DEBUG SGN:BND:HMAC=743DC22EDFC15ADB6050A2DD29E011D826F2F037F531A4D656837EB1DB2294F6
                    Dec 04 05:02:36 DEBUG SGN:VER:OK
                    Dec 04 05:02:36 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/1/1/0/2,MSG SENT
                    Dec 04 05:02:38 DEBUG TSF:MSG:READ,123-123-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
                    Dec 04 05:02:38 DEBUG SGN:SKP:MSG CMD=3,TYPE=16
                    Dec 04 05:02:38 DEBUG SGN:SKP:MSG CMD=3,TYPE=17
                    Dec 04 05:02:38 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                    Dec 04 05:02:38 DEBUG SGN:NCE:XMT,TO=0
                    Dec 04 05:02:38 DEBUG TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=1:Hello 54804
                    Dec 04 05:02:38 DEBUG SGN:BND:NONCE=E7C42737D780B3319EB7819458767BFDE334A2D51F920DA0C6AAAAAAAAAAAAAA
                    Dec 04 05:02:38 DEBUG SGN:BND:HMAC=1C4DECD661E66CC435798821B45994D74791AEECD0672F5CF7D84614D5A889C0
                    Dec 04 05:02:38 DEBUG SGN:VER:OK
                    Dec 04 05:02:38 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/1/1/0/2,MSG SENT
                    Dec 04 05:02:40 DEBUG TSF:MSG:READ,123-123-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
                    Dec 04 05:02:40 DEBUG SGN:SKP:MSG CMD=3,TYPE=16
                    Dec 04 05:02:40 DEBUG SGN:SKP:MSG CMD=3,TYPE=17
                    Dec 04 05:02:40 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                    Dec 04 05:02:40 DEBUG SGN:NCE:XMT,TO=0
                    Dec 04 05:02:40 DEBUG TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=1:Hello 56973
                    Dec 04 05:02:40 DEBUG SGN:BND:NONCE=9C249B35BC8ADDC86AC91ACDFE417520340D6E09DE5B21C965AAAAAAAAAAAAAA
                    Dec 04 05:02:40 DEBUG SGN:BND:HMAC=D213FB0411871CE08611BF608FF2A490403C2A4CDAB73D38589FC5E16CD59DA3
                    Dec 04 05:02:40 DEBUG SGN:VER:OK
                    Dec 04 05:02:40 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/1/1/0/2,MSG SENT
                    ^CDec 04 05:02:44 NOTICE Received SIGINT
                    • fritsF
                      fritsF
                      frits
                      @frits said in MQTT GW with RFM69 on RPi:
                      here's the logging on arduino hardware (both gateway and node on arduino pro micro + nrf24).
                      Summary:
                      • MCO:PRO on gateway only
                      • only after node boot
                      • or message sent from gateway to node
                      gw boot:
                      16 SGN:PER:OK
                      40 SGN:INI:BND OK
                      43 TSM:INIT
                      43 TSF:WUR:MS=0
                      51 TSM:INIT:TSP OK
                      53 TSM:INIT:GW MODE
                      55 TSM:READY:ID=0,PAR=0,DIS=0
                      57 MCO:REG:NOT NEEDED
                      622 GWT:TPC:IP=192.168.99.13
                      1626 MCO:BGN:STP
                      2127 MCO:BGN:INIT OK,TSP=1
                      2129 GWT:TPC:IP=192.168.99.13
                      3133 GWT:RMQ:CONNECTING...
                      3342 GWT:RMQ:OK
                      3344 GWT:TPS:TOPIC=mysgw1-out/0/255/0/0/18,MSG SENT
                      3352 TSM:READY:NWD REQ
                      3354 SGN:SGN:NREQ=255
                      3360 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                      node boot (gw log):
                      40278 TSF:MSG:READ,123-123-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      40284 TSF:MSG:BC
                      40286 TSF:MSG:FPAR REQ,ID=123
                      40290 TSF:PNG:SEND,TO=0
                      40292 TSF:CKU:OK
                      40294 TSF:MSG:GWL OK
                      40656 SGN:SKP:MSG CMD=3,TYPE=8
                      40660 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                      42303 TSF:MSG:READ,123-123-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                      42311 SGN:SKP:MSG CMD=3,TYPE=24
                      42313 TSF:MSG:PINGED,ID=123,HP=1
                      42317 SGN:SKP:MSG CMD=3,TYPE=25
                      42323 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                      42350 TSF:MSG:READ,123-123-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                      42356 SGN:SKP:MSG CMD=3,TYPE=15
                      42360 SGN:PRE:SGN REQ,FROM=123
                      42364 SGN:PRE:SGN REQ,TO=123
                      42366 SGN:PRE:WHI NREQ,TO=123
                      42371 SGN:SKP:MSG CMD=3,TYPE=15
                      42375 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                      42383 SGN:PRE:XMT,TO=123
                      42393 TSF:MSG:READ,123-123-0,s=255,c=3,t=16,pt=0,l=0,sg=0:
                      42399 SGN:SKP:MSG CMD=3,TYPE=16
                      42475 SGN:SKP:MSG CMD=3,TYPE=17
                      42481 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
                      42491 SGN:NCE:XMT,TO=0
                      42653 TSF:MSG:READ,123-123-0,s=255,c=0,t=17,pt=0,l=5,sg=1:2.3.2
                      42659 SGN:BND:NONCE=5D05EE8DE2E5DB1DF14E37C1927A97E1415B5A171E0A64E5DFAAAAAAAAAAAAAA
                      42774 SGN:BND:HMAC=F03795009783A00B1CBA3AB0CABCCE11BA9F5F6050B407B3B50FAADE5B558925
                      42782 SGN:VER:OK
                      42786 GWT:TPS:TOPIC=mysgw1-out/123/255/0/0/17,MSG SENT
                      42792 TSF:MSG:READ,123-123-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                      42801 SGN:SKP:MSG CMD=3,TYPE=16
                      42878 SGN:SKP:MSG CMD=3,TYPE=17
                      42885 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                      42893 SGN:NCE:XMT,TO=0
                      43055 TSF:MSG:READ,123-123-0,s=255,c=3,t=6,pt=1,l=1,sg=1:0
                      43061 SGN:BND:NONCE=6A5BC212192AAC2D25FDAFE2B626B8216A01D1FA44E1032D42AAAAAAAAAAAAAA
                      43180 SGN:BND:HMAC=FFF58B3C02F477E9ACCF36614E05769E8952C76692035368A8A41604F6459073
                      43188 SGN:VER:OK
                      43190 GWT:TPS:TOPIC=mysgw1-out/123/255/3/0/6,MSG SENT
                      45049 TSF:MSG:READ,123-123-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                      45056 SGN:SKP:MSG CMD=3,TYPE=16
                      45131 SGN:SKP:MSG CMD=3,TYPE=17
                      45137 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                      45148 SGN:NCE:XMT,TO=0
                      45309 TSF:MSG:READ,123-123-0,s=255,c=3,t=11,pt=0,l=20,sg=1:Hello MySensors 328P
                      45318 SGN:BND:NONCE=736CF35C52747BC27A10F246D0E5162640F4843111755C3A1CAAAAAAAAAAAAAA
                      45432 SGN:BND:HMAC=2D5615BD24252A9F704CE90933F7B6ED89EB891ECCC0BF7EB6021CCFB3B6432D
                      45441 SGN:VER:OK
                      45445 GWT:TPS:TOPIC=mysgw1-out/123/255/3/0/11,MSG SENT
                      45453 TSF:MSG:READ,123-123-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                      45459 SGN:SKP:MSG CMD=3,TYPE=16
                      45537 SGN:SKP:MSG CMD=3,TYPE=17
                      45543 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                      45551 SGN:NCE:XMT,TO=0
                      45713 TSF:MSG:READ,123-123-0,s=255,c=3,t=12,pt=0,l=3,sg=1:1.3
                      45721 SGN:BND:NONCE=7394AB63F58F7181E65175A747357A73B72DA775ECD44D795BAAAAAAAAAAAAAA
                      45836 SGN:BND:HMAC=7913D96974B91F551F698BBAB914AE79BC871569DF05977FF18A07836CFDDA2B
                      45844 SGN:VER:OK
                      45848 GWT:TPS:TOPIC=mysgw1-out/123/255/3/0/12,MSG SENT
                      45854 TSF:MSG:READ,123-123-0,s=0,c=3,t=16,pt=0,l=0,sg=1:
                      45860 SGN:SKP:MSG CMD=3,TYPE=16
                      45942 SGN:SKP:MSG CMD=3,TYPE=17
                      45948 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                      45957 SGN:NCE:XMT,TO=0
                      46118 TSF:MSG:READ,123-123-0,s=0,c=0,t=36,pt=0,l=6,sg=1:system
                      46125 SGN:BND:NONCE=369A5D4D44C839C07EF2041459B7AF64B8322FC35570B09EE2AAAAAAAAAAAAAA
                      46243 SGN:BND:HMAC=2E022D2A34A359DF46021E5A7D197B92ABBA56B1B6DB1D9FC2661FFBA8B031EE
                      46252 SGN:VER:OK
                      46254 GWT:TPS:TOPIC=mysgw1-out/123/0/0/0/36,MSG SENT
                      46262 TSF:MSG:READ,123-123-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
                      46268 SGN:SKP:MSG CMD=3,TYPE=16
                      46344 SGN:SKP:MSG CMD=3,TYPE=17
                      46350 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                      46360 SGN:NCE:XMT,TO=0
                      46522 TSF:MSG:READ,123-123-0,s=1,c=0,t=36,pt=0,l=9,sg=1:timestamp
                      46528 SGN:BND:NONCE=16E88FB58D621C0047CD38142BDCA4303719F0F8D670C6BEA5AAAAAAAAAAAAAA
                      46643 SGN:BND:HMAC=1AF56FBB3CF5C705B4C3E5210DE5CB912FF25F84F8152C51CA053A78ABEA63FC
                      46653 SGN:VER:OK
                      46655 GWT:TPS:TOPIC=mysgw1-out/123/1/0/0/36,MSG SENT
                      46663 TSF:MSG:READ,123-123-0,s=2,c=3,t=16,pt=0,l=0,sg=1:
                      46669 SGN:SKP:MSG CMD=3,TYPE=16
                      46747 SGN:SKP:MSG CMD=3,TYPE=17
                      46753 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                      46761 SGN:NCE:XMT,TO=0
                      46923 TSF:MSG:READ,123-123-0,s=2,c=0,t=3,pt=0,l=3,sg=1:led
                      46931 SGN:BND:NONCE=F63BD3325089CAC4DA5F679EA9E334D19E07FB52DFC54C7901AAAAAAAAAAAAAA
                      47048 SGN:BND:HMAC=CAF49ED58A0F6D78FA8E2C99C24682D83558017E56F147619CFFD5F56C4CF40C
                      47056 SGN:VER:OK
                      47058 GWT:TPS:TOPIC=mysgw1-out/123/2/0/0/3,MSG SENT
                      47067 TSF:MSG:READ,123-123-0,s=3,c=3,t=16,pt=0,l=0,sg=1:
                      47073 SGN:SKP:MSG CMD=3,TYPE=16
                      47149 SGN:SKP:MSG CMD=3,TYPE=17
                      47155 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                      47165 SGN:NCE:XMT,TO=0
                      47325 TSF:MSG:READ,123-123-0,s=3,c=0,t=3,pt=0,l=6,sg=1:button
                      47333 SGN:BND:NONCE=70E6B1C050BD5A8A2F03F3C345E801FE73237CF22F11196795AAAAAAAAAAAAAA
                      47448 SGN:BND:HMAC=F5202D42D87CA81DC0D0E032F54189868EEB4FE462598C6AD8B3307A4A043F4D
                      47456 SGN:VER:OK
                      47460 GWT:TPS:TOPIC=mysgw1-out/123/3/0/0/3,MSG SENT
                      47466 TSF:MSG:READ,123-123-0,s=255,c=3,t=26,pt=1,l=1,sg=1:2
                      47474 SGN:SKP:MSG CMD=3,TYPE=26
                      47476 SGN:SKP:MSG CMD=3,TYPE=16
                      47482 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                      47491 SGN:SGN:NCE REQ,TO=123
                      47493 !MCO:PRO:RC=1
                      47495 !MCO:PRO:RC=1
                      47499 !MCO:PRO:RC=1
                      47501 !MCO:PRO:RC=1
                      47503 !MCO:PRO:RC=1
                      47505 !MCO:PRO:RC=1
                      47509 !MCO:PRO:RC=1
                      47511 !MCO:PRO:RC=1
                      47513 !MCO:PRO:RC=1
                      47515 !MCO:PRO:RC=1
                      47519 !MCO:PRO:RC=1
                      47521 !MCO:PRO:RC=1
                      47523 !MCO:PRO:RC=1
                      47525 !MCO:PRO:RC=1
                      47529 !MCO:PRO:RC=1
                      47532 !MCO:PRO:RC=1
                      47534 !MCO:PRO:RC=1
                      47536 !MCO:PRO:RC=1
                      47540 !MCO:PRO:RC=1
                      47542 !MCO:PRO:RC=1
                      47544 !MCO:PRO:RC=1
                      47546 !MCO:PRO:RC=1
                      47548 !MCO:PRO:RC=1
                      47552 !MCO:PRO:RC=1
                      47554 !MCO:PRO:RC=1
                      47556 !MCO:PRO:RC=1
                      47558 !MCO:PRO:RC=1
                      47562 !MCO:PRO:RC=1
                      47564 !MCO:PRO:RC=1
                      47566 !MCO:PRO:RC=1
                      47568 !MCO:PRO:RC=1
                      47572 !MCO:PRO:RC=1
                      47575 !MCO:PRO:RC=1
                      47577 !MCO:PRO:RC=1
                      47579 !MCO:PRO:RC=1
                      47583 !MCO:PRO:RC=1
                      47585 !MCO:PRO:RC=1
                      47587 !MCO:PRO:RC=1
                      47589 !MCO:PRO:RC=1
                      47593 !MCO:PRO:RC=1
                      47595 !MCO:PRO:RC=1
                      47597 !MCO:PRO:RC=1
                      47599 !MCO:PRO:RC=1
                      47603 !MCO:PRO:RC=1
                      47605 !MCO:PRO:RC=1
                      47607 !MCO:PRO:RC=1
                      47609 !MCO:PRO:RC=1
                      47613 TSF:MSG:READ,123-123-0,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
                      47620 SGN:SKP:MSG CMD=3,TYPE=17
                      47624 SGN:NCE:FROM=123
                      47626 SGN:BND:NONCE=52C791A2F3FD084BB05D52CBA6079339BCBC85FC48E952A91DAAAAAAAAAAAAAA
                      47747 SGN:BND:HMAC=3CCB39326B05220FEED535CC8304FE46A6544C69ED9C2D943725F8E38FA19C50
                      47755 SGN:SGN:SGN
                      47761 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=27,pt=1,l=1,sg=1,ft=0,st=OK:1
                      47935 TSF:MSG:READ,123-123-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
                      47943 SGN:SKP:MSG CMD=3,TYPE=16
                      48023 SGN:SKP:MSG CMD=3,TYPE=17
                      48029 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                      48037 SGN:NCE:XMT,TO=0
                      48199 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=1:Hello 10031
                      48207 SGN:BND:NONCE=399F6855334A59FF5A2B512738EF6B8C70BB2EE4A8FAD758E8AAAAAAAAAAAAAA
                      48322 SGN:BND:HMAC=6CCD4905231C9F55C61B23922DAC166A8B20610B150F491FAA11E1C4B9FBB7D4
                      48332 SGN:VER:OK
                      48334 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
                      node send message (node log):
                      58513 SGN:SKP:MSG CMD=3,TYPE=16
                      58519 TSF:MSG:SEND,123-123-0-0,s=3,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                      58525 SGN:SGN:NCE REQ,TO=0
                      58650 TSF:MSG:READ,0-0-123,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                      58656 SGN:SKP:MSG CMD=3,TYPE=17
                      58660 SGN:NCE:FROM=0
                      58662 SGN:BND:NONCE=B06B498BB6AED7756B7C19D7D3E677464FE8E6D1823E37A818AAAAAAAAAA
                      AAAA
                      58779 SGN:BND:HMAC=03123A4791D8BD0DB61B6C15604A847FA875D53790F9CAED906E57CF85C95
                      571
                      58789 SGN:SGN:SGN
                      58793 TSF:MSG:SEND,123-123-0-0,s=3,c=1,t=2,pt=2,l=2,sg=1,ft=0,st=OK:1
                      button pressed
                      58814 SGN:SKP:MSG CMD=3,TYPE=16
                      58820 TSF:MSG:SEND,123-123-0-0,s=3,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                      58826 SGN:SGN:NCE REQ,TO=0
                      59095 TSF:MSG:READ,0-0-123,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                      59101 SGN:SKP:MSG CMD=3,TYPE=17
                      59105 SGN:NCE:FROM=0
                      59107 SGN:BND:NONCE=24228D2780F459C3469D1BDD01BAB9128D31C32B3FF806BA2DAAAAAAAAAA
                      AAAA
                      59222 SGN:BND:HMAC=FF9C0AD707200F63C0A93BABF019B137C3F1FD54AD224291F83C16BFC6644
                      E8C
                      59232 SGN:SGN:SGN
                      59236 TSF:MSG:SEND,123-123-0-0,s=3,c=1,t=2,pt=2,l=2,sg=1,ft=0,st=OK:0
                      button released
                      node send message (gw log):
                      96430 TSF:MSG:READ,123-123-0,s=3,c=3,t=16,pt=0,l=0,sg=1:
                      96436 SGN:SKP:MSG CMD=3,TYPE=16
                      96512 SGN:SKP:MSG CMD=3,TYPE=17
                      96518 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                      96528 SGN:NCE:XMT,TO=0
                      96690 TSF:MSG:READ,123-123-0,s=3,c=1,t=2,pt=2,l=2,sg=1:1
                      96696 SGN:BND:NONCE=B06B498BB6AED7756B7C19D7D3E677464FE8E6D1823E37A818AAAAAAAAAAAAAA
                      96811 SGN:BND:HMAC=03123A4791D8BD0DB61B6C15604A847FA875D53790F9CAED906E57CF85C95571
                      96821 SGN:VER:OK
                      96823 GWT:TPS:TOPIC=mysgw1-out/123/3/1/0/2,MSG SENT
                      96829 TSF:MSG:READ,123-123-0,s=3,c=3,t=16,pt=0,l=0,sg=1:
                      96837 SGN:SKP:MSG CMD=3,TYPE=16
                      96917 SGN:SKP:MSG CMD=3,TYPE=17
                      96923 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                      96931 SGN:NCE:XMT,TO=0
                      97093 TSF:MSG:READ,123-123-0,s=3,c=1,t=2,pt=2,l=2,sg=1:0
                      97101 SGN:BND:NONCE=24228D2780F459C3469D1BDD01BAB9128D31C32B3FF806BA2DAAAAAAAAAAAAAA
                      97216 SGN:BND:HMAC=FF9C0AD707200F63C0A93BABF019B137C3F1FD54AD224291F83C16BFC6644E8C
                      97224 SGN:VER:OK
                      97228 GWT:TPS:TOPIC=mysgw1-out/123/3/1/0/2,MSG SENT
                      gw send message (gw log):
                      206145 GWT:IMQ:TOPIC=mysgw1-in/123/2/1/0/2, MSG RECEIVED
                      206151 SGN:SKP:MSG CMD=3,TYPE=16
                      206157 TSF:MSG:SEND,0-0-123-123,s=2,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                      206166 SGN:SGN:NCE REQ,TO=123
                      206168 !MCO:PRO:RC=1
                      206172 !MCO:PRO:RC=1
                      206174 !MCO:PRO:RC=1
                      206176 !MCO:PRO:RC=1
                      206180 !MCO:PRO:RC=1
                      206182 !MCO:PRO:RC=1
                      206184 !MCO:PRO:RC=1
                      206186 !MCO:PRO:RC=1
                      206190 !MCO:PRO:RC=1
                      206192 !MCO:PRO:RC=1
                      206194 !MCO:PRO:RC=1
                      206198 !MCO:PRO:RC=1
                      206200 !MCO:PRO:RC=1
                      206202 !MCO:PRO:RC=1
                      206206 !MCO:PRO:RC=1
                      206209 !MCO:PRO:RC=1
                      206211 !MCO:PRO:RC=1
                      206215 !MCO:PRO:RC=1
                      206217 !MCO:PRO:RC=1
                      206219 !MCO:PRO:RC=1
                      206223 !MCO:PRO:RC=1
                      206225 !MCO:PRO:RC=1
                      206227 !MCO:PRO:RC=1
                      206231 !MCO:PRO:RC=1
                      206233 !MCO:PRO:RC=1
                      206235 !MCO:PRO:RC=1
                      206239 !MCO:PRO:RC=1
                      206241 !MCO:PRO:RC=1
                      206243 !MCO:PRO:RC=1
                      206247 !MCO:PRO:RC=1
                      206249 !MCO:PRO:RC=1
                      206252 !MCO:PRO:RC=1
                      206256 !MCO:PRO:RC=1
                      206258 !MCO:PRO:RC=1
                      206260 !MCO:PRO:RC=1
                      206262 !MCO:PRO:RC=1
                      206266 !MCO:PRO:RC=1
                      206268 !MCO:PRO:RC=1
                      206272 TSF:MSG:READ,123-123-0,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                      206278 SGN:SKP:MSG CMD=3,TYPE=17
                      206282 SGN:NCE:FROM=123
                      206284 SGN:BND:NONCE=40E78847070231061F13FBD56014E185E1FC7651EDC52ABFD3AAAAAAAAAAAAAA
                      206399 SGN:BND:HMAC=4A48E4CF691C24205050B2ECB0C4C9B5F0CB4A67D9E9A43A5FFA03A8F7288F1A
                      206409 SGN:SGN:SGN
                      206415 TSF:MSG:SEND,0-0-123-123,s=2,c=1,t=2,pt=0,l=1,sg=1,ft=0,st=OK:1
                      gw send message (node log):
                      168019 !SGN:BND:TMR
                      168024 TSF:MSG:READ,0-0-123,s=2,c=3,t=16,pt=0,l=0,sg=1:
                      168030 SGN:SKP:MSG CMD=3,TYPE=16
                      168085 SGN:SKP:MSG CMD=3,TYPE=17
                      168091 TSF:MSG:SEND,123-123-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=1,st=OK:<NONCE>
                      168101 SGN:NCE:XMT,TO=123
                      168263 TSF:MSG:READ,0-0-123,s=2,c=1,t=2,pt=0,l=1,sg=1:1
                      168269 SGN:BND:NONCE=40E78847070231061F13FBD56014E185E1FC7651EDC52ABFD3AAAAAAAAA
                      AAAAA
                      168384 SGN:BND:HMAC=4A48E4CF691C24205050B2ECB0C4C9B5F0CB4A67D9E9A43A5FFA03A8F728
                      8F1A
                      168394 SGN:VER:OK
                      received message for sensor 2, type 2, value 1
                      switching LED on
                      • T
                        TimO
                        I've disabled the signing feature and the !MCO:PRO:RC=1 issn't occuring anymore.
                        • joaoabsJ
                          joaoabsJ
                          joaoabs
                          Also happening in nodes:
                           __  __       ____
                                  |___/                      2.3.2
                          16 MCO:BGN:INIT NODE,CP=RPNNAA-X,FQ=8,REL=255,VER=2.3.2
                          40 SGN:PER:OK
                          69 SGN:INI:BND OK
                          71 TSM:INIT
                          71 TSF:WUR:MS=0
                          75 TSM:INIT:TSP OK
                          77 TSM:INIT:STATID=33
                          79 TSF:SID:OK,ID=33
                          81 TSM:FPAR
                          83 SGN:SGN:NREQ=255
                          90 ?TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          212 TSF:MSG:READ,0-0-33,s=255,c=3,t=8,pt=1,l=1,sg=1:0
                          219 SGN:SKP:MSG CMD=3,TYPE=8
                          221 TSF:MSG:FPAR OK,ID=0,D=1
                          2099 TSM:FPAR:OK
                          2099 TSM:ID
                          2101 TSM:ID:OK
                          2103 TSM:UPL
                          2105 SGN:SKP:MSG CMD=3,TYPE=24
                          3133 !TSF:MSG:SEND,33-33-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                          3811 TSF:MSG:READ,0-0-33,s=255,c=3,t=25,pt=1,l=1,sg=1:1
                          3817 SGN:SKP:MSG CMD=3,TYPE=25
                          3821 TSF:MSG:PONG RECV,HP=1
                          3823 TSM:UPL:OK
                          3825 TSM:READY:ID=33,PAR=0,DIS=1
                          3829 SGN:PRE:SGN REQ
                          3831 SGN:PRE:WHI NREQ
                          3833 SGN:SKP:MSG CMD=3,TYPE=15
                          3872 TSF:MSG:SEND,33-33-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                          3880 SGN:PRE:XMT,TO=0
                          3883 SGN:PRE:WAIT GW
                          4837 TSF:MSG:READ,0-0-33,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                          4843 SGN:SKP:MSG CMD=3,TYPE=15
                          4847 SGN:PRE:SGN REQ,FROM=0
                          4851 SGN:SKP:MSG CMD=3,TYPE=16
                          4925 TSF:MSG:SEND,33-33-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                          4933 SGN:SGN:NCE REQ,TO=0
                          6141 TSF:MSG:READ,0-0-33,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
                          6148 SGN:SKP:MSG CMD=3,TYPE=17
                          6152 SGN:NCE:FROM=0
                          6154 SGN:BND:NONCE=F1D60B20DB00FF5950A64E8FFA7DEDE90956E7505DA37EF4DBAAAAAAAAAAAAAA
                          6273 SGN:BND:HMAC=FC296959CE1E51BF6EB60BD781CF1C003FA4E32AF2160D0F813160CCBF1B7095
                          6283 SGN:SGN:SGN
                          6404 TSF:MSG:SEND,33-33-0-0,s=255,c=0,t=17,pt=0,l=5,sg=1,ft=0,st=OK:2.3.2
                          6412 SGN:SKP:MSG CMD=3,TYPE=16
                          7460 !TSF:MSG:SEND,33-33-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=NACK:
                          7467 !SGN:SGN:NCE REQ,TO=0 FAIL
                          7471 !TSF:MSG:SIGN FAIL
                          8058 TSF:MSG:READ,0-0-33,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                          8065 SGN:SKP:MSG CMD=3,TYPE=17
                          8069 SGN:NCE:FROM=0
                          8071 SGN:BND:NONCE=DE60142AA1B91F73CB35274D2B050BB8B51D4578E9F32D75CBAAAAAAAAAAAAAA
                          8189 SGN:BND:HMAC=AC6BCA42658012BFD9A118AC2F347756D6EB2B3BB5EDB9D6CEE5E5271A136ACB
                          8513 TSF:MSG:READ,0-0-33,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                          8519 SGN:SKP:MSG CMD=3,TYPE=17
                          8523 SGN:NCE:FROM=0
                          8525 SGN:BND:NONCE=DE60142AA1B91F73CB35274D2B050BB8B51D4578E9F32D75CBAAAAAAAAAAAAAA
                          8644 SGN:BND:HMAC=AC6BCA42658012BFD9A118AC2F347756D6EB2B3BB5EDB9D6CEE5E5271A136ACB
                          9474 SGN:SKP:MSG CMD=3,TYPE=16
                          10524 !TSF:MSG:SEND,33-33-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=2,st=NACK:
                          10530 !SGN:SGN:NCE REQ,TO=0 FAIL
                          10534 !TSF:MSG:SIGN FAIL
                          10536 SGN:SKP:MSG CMD=3,TYPE=16
                          11587 !TSF:MSG:SEND,33-33-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=4,st=NACK:
                          11593 !SGN:SGN:NCE REQ,TO=0 FAIL
                          11597 !TSF:MSG:SIGN FAIL
                          11599 SGN:SKP:MSG CMD=3,TYPE=16
                          12650 !TSF:MSG:SEND,33-33-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=6,st=NACK:
                          12656 !SGN:SGN:NCE REQ,TO=0 FAIL
                          12660 !TSF:MSG:SIGN FAIL
                          12662 SGN:SKP:MSG CMD=3,TYPE=16
                          13713 !TSF:MSG:SEND,33-33-0-0,s=2,c=3,t=16,pt=0,l=0,sg=1,ft=8,st=NACK:
                          13719 !SGN:SGN:NCE REQ,TO=0 FAIL
                          13723 !TSF:MSG:SIGN FAIL
                          13725 MCO:REG:REQ
                          13727 SGN:SKP:MSG CMD=3,TYPE=26
                          14467 !TSF:MSG:SEND,33-33-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=10,st=NACK:2
                          14475 !TSM:READY:UPL FAIL,SNP
                          14477 TSM:FPAR
                          14479 SGN:SGN:NREQ=255
                          14487 ?TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=11,st=OK:
                          15235 TSF:MSG:READ,0-0-33,s=255,c=3,t=16,pt=0,l=0,sg=1:
                          15241 SGN:SKP:MSG CMD=3,TYPE=16
                          15321 !TSF:SND:TNR
                          15323 !SGN:NCE:XMT,TO=33 FAIL
                          16476 !TSF:SND:TNR
                          16496 !TSM:FPAR:NO REPLY
                          16498 TSM:FPAR
                          16500 SGN:SGN:NREQ=255
                          16508 ?TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          16805 TSF:MSG:READ,0-0-33,s=255,c=3,t=8,pt=1,l=1,sg=1:0
                          16812 SGN:SKP:MSG CMD=3,TYPE=8
                          16816 TSF:MSG:FPAR OK,ID=0,D=1
                          18479 !TSF:SND:TNR
                          18518 TSM:FPAR:OK
                          18520 TSM:ID
                          18520 TSM:ID:OK
                          18522 TSM:UPL
                          18524 SGN:SKP:MSG CMD=3,TYPE=24
                          19552 !TSF:MSG:SEND,33-33-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                          20289 TSF:MSG:READ,0-0-33,s=255,c=3,t=25,pt=1,l=1,sg=1:1
                          20295 SGN:SKP:MSG CMD=3,TYPE=25
                          20297 TSF:MSG:PONG RECV,HP=1
                          20301 TSM:UPL:OK
                          20303 TSM:READY:ID=33,PAR=0,DIS=1
                          20307 SGN:PRE:SGN REQ
                          20310 SGN:PRE:WHI NREQ
                          20312 SGN:SKP:MSG CMD=3,TYPE=15
                          20416 TSF:MSG:SEND,33-33-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                          20424 SGN:PRE:XMT,TO=0
                          20426 SGN:PRE:WAIT GW
                          20430 !MCO:WAI:RC=1
                          20432 !MCO:PRO:RC=1
                          20434 !MCO:PRO:RC=1
                          20436 !MCO:PRO:RC=1
                          20439 !MCO:PRO:RC=1
                          20441 !MCO:PRO:RC=1
                          20443 !MCO:PRO:RC=1
                          20445 !MCO:PRO:RC=1
                          20447 !MCO:PRO:RC=1
                          20449 !MCO:PRO:RC=1
                          20451 !MCO:PRO:RC=1
                          20455 !MCO:PRO:RC=1
                          20457 !MCO:PRO:RC=1
                          20459 !MCO:PRO:RC=1
                          20461 !MCO:PRO:RC=1
                          20463 !MCO:PRO:RC=1
                          20465 !MCO:PRO:RC=1
                          20467 !MCO:PRO:RC=1
                          20469 !MCO:PRO:RC=1
                          20471 !MCO:PRO:RC=1
                          20473 !MCO:PRO:RC=1
                          20477 !MCO:PRO:RC=1
                          20480 !MCO:PRO:RC=1
                          20482 !MCO:PRO:RC=1
                          20484 !MCO:PRO:RC=1
                          20486 !MCO:PRO:RC=1
                          20488 !MCO:PRO:RC=1
                          20490 !MCO:PRO:RC=1
                          20492 !MCO:PRO:RC=1
                          20494 !MCO:PRO:RC=1
                          20496 !MCO:PRO:RC=1
                          20498 !MCO:PRO:RC=1
                          20502 !MCO:PRO:RC=1
                          20504 !MCO:PRO:RC=1
                          20506 !MCO:PRO:RC=1
                          20508 !MCO:PRO:RC=1
                          20510 !MCO:PRO:RC=1
                          20512 !MCO:PRO:RC=1
                          20514 !MCO:PRO:RC=1
                          20516 !MCO:PRO:RC=1
                          20518 !MCO:PRO:RC=1
                          20520 !MCO:PRO:RC=1
                          20523 !MCO:PRO:RC=1
                          20527 !MCO:PRO:RC=1
                          20529 !MCO:PRO:RC=1
                          20531 !MCO:PRO:RC=1
                          20533 !MCO:PRO:RC=1
                          20535 !MCO:PRO:RC=1
                          20537 !MCO:PRO:RC=1
                          20539 !MCO:PRO:RC=1
                          20541 !MCO:PRO:RC=1
                          20543 !MCO:PRO:RC=1
                          20545 !MCO:PRO:RC=1
                          20549 !MCO:PRO:RC=1
                          20551 !MCO:PRO:RC=1
                          20553 !MCO:PRO:RC=1
                          20555 !MCO:PRO:RC=1
                          20557 !MCO:PRO:RC=1
                          20559 !MCO:PRO:RC=1
                          20561 !MCO:PRO:RC=1
                          20563 !MCO:PRO:RC=1
                          20566 !MCO:PRO:RC=1
                          20568 !MCO:PRO:RC=1
                          20570 !MCO:PRO:RC=1
                          20574 !MCO:PRO:RC=1
                          20576 !MCO:PRO:RC=1
                          20578 !MCO:PRO:RC=1
                          20580 !MCO:PRO:RC=1
                          20582 !MCO:PRO:RC=1
                          20584 !MCO:PRO:RC=1
                          20586 !MCO:PRO:RC=1
                          20588 !MCO:PRO:RC=1
                          20590 !MCO:PRO:RC=1
                          20592 !MCO:PRO:RC=1
                          20594 !MCO:PRO:RC=1
                          20598 !MCO:PRO:RC=1
                          20600 !MCO:PRO:RC=1
                          20602 !MCO:PRO:RC=1
                          20604 !MCO:PRO:RC=1
                          20606 !MCO:PRO:RC=1
                          20609 !MCO:PRO:RC=1
                          20611 !MCO:PRO:RC=1
                          20613 !MCO:PRO:RC=1
                          20615 !MCO:PRO:RC=1
                          20617 !MCO:PRO:RC=1
                          20621 !MCO:PRO:RC=1
                          20623 !MCO:PRO:RC=1
                          20625 !MCO:PRO:RC=1
                          20627 !MCO:PRO:RC=1
                          20629 !MCO:PRO:RC=1
                          20631 !MCO:PRO:RC=1
                          20633 !MCO:PRO:RC=1
                          20635 !MCO:PRO:RC=1
                          20637 !MCO:PRO:RC=1
                          20639 !MCO:PRO:RC=1
                          20641 !MCO:PRO:RC=1
                          20645 !MCO:PRO:RC=1
                          20647 !MCO:PRO:RC=1
                          20649 !MCO:PRO:RC=1
                          20652 !MCO:PRO:RC=1
                          20654 !MCO:PRO:RC=1
                          20656 !MCO:PRO:RC=1
                          20658 !MCO:PRO:RC=1
                          20660 !MCO:PRO:RC=1
                          20662 !MCO:PRO:RC=1
                          20664 !MCO:PRO:RC=1
                          20666 !MCO:PRO:RC=1
                          20670 !MCO:PRO:RC=1
                          20672 !MCO:PRO:RC=1
                          20674 !MCO:PRO:RC=1
                          20676 !MCO:PRO:RC=1
                          20678 !MCO:PRO:RC=1
                          20680 !MCO:PRO:RC=1
                          20682 !MCO:PRO:RC=1
                          20684 !MCO:PRO:RC=1
                          20686 !MCO:PRO:RC=1
                          20688 !MCO:PRO:RC=1
                          20692 !MCO:PRO:RC=1
                          20695 !MCO:PRO:RC=1
                          20697 !MCO:PRO:RC=1
                          20699 !MCO:PRO:RC=1
                          20701 !MCO:PRO:RC=1
                          20703 !MCO:PRO:RC=1
                          20705 !MCO:PRO:RC=1
                          20707 !MCO:PRO:RC=1
                          20709 !MCO:PRO:RC=1
                          20711 !MCO:PRO:RC=1
                          20713 !MCO:PRO:RC=1
                          20717 !MCO:PRO:RC=1
                          20719 !MCO:PRO:RC=1
                          20721 !MCO:PRO:RC=1
                          20723 !MCO:PRO:RC=1
                          20725 !MCO:PRO:RC=1
                          20727 !MCO:PRO:RC=1
                          20729 !MCO:PRO:RC=1
                          20731 !MCO:PRO:RC=1
                          20733 !MCO:PRO:RC=1
                          20736 !MCO:PRO:RC=1
                          20738 !MCO:PRO:RC=1
                          20742 !MCO:PRO:RC=1
                          20744 !MCO:PRO:RC=1
                          20746 !MCO:PRO:RC=1
                          20748 !MCO:PRO:RC=1
                          20750 !MCO:PRO:RC=1
                          20752 !MCO:PRO:RC=1
                          20754 !MCO:PRO:RC=1
                          20756 !MCO:PRO:RC=1
                          20758 !MCO:PRO:RC=1
                          20760 !MCO:PRO:RC=1
                          20764 !MCO:PRO:RC=1
                          20766 !MCO:PRO:RC=1
                          20768 !MCO:PRO:RC=1
                          20770 !MCO:PRO:RC=1
                          20772 !MCO:PRO:RC=1
                          20774 !MCO:PRO:RC=1
                          20776 !MCO:PRO:RC=1
                          20779 !MCO:PRO:RC=1
                          20781 !MCO:PRO:RC=1
                          20783 !MCO:PRO:RC=1
                          20785 !MCO:PRO:RC=1
                          20789 !MCO:PRO:RC=1
                          20791 !MCO:PRO:RC=1
                          20793 !MCO:PRO:RC=1
                          20795 !MCO:PRO:RC=1
                          20797 !MCO:PRO:RC=1
                          20799 !MCO:PRO:RC=1
                          20801 !MCO:PRO:RC=1
                          20803 !MCO:PRO:RC=1
                          20805 !MCO:PRO:RC=1
                          20807 !MCO:PRO:RC=1
                          20809 !MCO:PRO:RC=1
                          20813 !MCO:PRO:RC=1
                          20815 !MCO:PRO:RC=1
                          20817 !MCO:PRO:RC=1
                          20819 !MCO:PRO:RC=1
                          20822 !MCO:PRO:RC=1
                          20824 !MCO:PRO:RC=1
                          20826 !MCO:PRO:RC=1
                          20828 !MCO:PRO:RC=1
                          20830 !MCO:PRO:RC=1
                          20832 !MCO:PRO:RC=1
                          20836 !MCO:PRO:RC=1
                          20838 !MCO:PRO:RC=1
                          20840 !MCO:PRO:RC=1
                          20842 !MCO:PRO:RC=1
                          20844 !MCO:PRO:RC=1
                          20846 !MCO:PRO:RC=1
                          20848 !MCO:PRO:RC=1
                          20850 !MCO:PRO:RC=1
                          20852 !MCO:PRO:RC=1
                          20854 !MCO:PRO:RC=1
                          20856 !MCO:PRO:RC=1
                          20860 !MCO:PRO:RC=1
                          20862 !MCO:PRO:RC=1
                          20865 !MCO:PRO:RC=1
                          20867 !MCO:PRO:RC=1
                          20869 !MCO:PRO:RC=1
                          20871 !MCO:PRO:RC=1
                          20873 !MCO:PRO:RC=1
                          20875 !MCO:PRO:RC=1
                          20877 !MCO:PRO:RC=1
                          20879 !MCO:PRO:RC=1
                          20881 !MCO:PRO:RC=1
                          20885 !MCO:PRO:RC=1
                          20887 !MCO:PRO:RC=1
                          20889 !MCO:PRO:RC=1
                          20891 !MCO:PRO:RC=1
                          20893 !MCO:PRO:RC=1
                          20895 !MCO:PRO:RC=1
                          20897 !MCO:PRO:RC=1
                          20899 !MCO:PRO:RC=1
                          20901 !MCO:PRO:RC=1
                          20903 !MCO:PRO:RC=1
                          20908 !MCO:PRO:RC=1
                          20910 !MCO:PRO:RC=1
                          20912 !MCO:PRO:RC=1
                          20914 !MCO:PRO:RC=1
                          20916 !MCO:PRO:RC=1
                          20918 !MCO:PRO:RC=1
                          20920 !MCO:PRO:RC=1
                          20922 !MCO:PRO:RC=1
                          20924 !MCO:PRO:RC=1
                          20926 !MCO:PRO:RC=1
                          20928 !MCO:PRO:RC=1
                          20932 !MCO:PRO:RC=1
                          20934 !MCO:PRO:RC=1
                          20936 !MCO:PRO:RC=1
                          20938 !MCO:PRO:RC=1
                          20940 !MCO:PRO:RC=1
                          20942 !MCO:PRO:RC=1
                          20944 !MCO:PRO:RC=1
                          20946 !MCO:PRO:RC=1
                          20948 !MCO:PRO:RC=1
                          20951 !MCO:PRO:RC=1
                          20953 !MCO:PRO:RC=1
                          20957 !MCO:PRO:RC=1
                          20959 !MCO:PRO:RC=1
                          20961 !MCO:PRO:RC=1
                          20963 !MCO:PRO:RC=1
                          20965 !MCO:PRO:RC=1
                          20967 !MCO:PRO:RC=1
                          20969 !MCO:PRO:RC=1
                          20971 !MCO:PRO:RC=1
                          20973 !MCO:PRO:RC=1
                          20975 !MCO:PRO:RC=1
                          20979 !MCO:PRO:RC=1
                          20981 !MCO:PRO:RC=1
                          20983 !MCO:PRO:RC=1
                          20985 !MCO:PRO:RC=1
                          20987 !MCO:PRO:RC=1
                          20989 !MCO:PRO:RC=1
                          20992 !MCO:PRO:RC=1
                          20994 !MCO:PRO:RC=1
                          20996 !MCO:PRO:RC=1
                          20998 !MCO:PRO:RC=1
                          21000 !MCO:PRO:RC=1
                          21004 !MCO:PRO:RC=1
                          21006 !MCO:PRO:RC=1
                          21008 !MCO:PRO:RC=1
                          21010 !MCO:PRO:RC=1
                          21012 !MCO:PRO:RC=1
                          21014 !MCO:PRO:RC=1
                          21016 !MCO:PRO:RC=1
                          21018 !MCO:PRO:RC=1
                          21020 !MCO:PRO:RC=1
                          21022 !MCO:PRO:RC=1
                          21024 !MCO:PRO:RC=1
                          21028 !MCO:PRO:RC=1
                          21030 !MCO:PRO:RC=1
                          21032 !MCO:PRO:RC=1
                          21035 !MCO:PRO:RC=1
                          21037 !MCO:PRO:RC=1
                          21039 !MCO:PRO:RC=1
                          21041 !MCO:PRO:RC=1
                          21043 !MCO:PRO:RC=1
                          21045 !MCO:PRO:RC=1
                          21047 !MCO:PRO:RC=1
                          21051 !MCO:PRO:RC=1
                          21053 !MCO:PRO:RC=1
                          21055 !MCO:PRO:RC=1
                          21057 !MCO:PRO:RC=1
                          21059 !MCO:PRO:RC=1
                          21061 !MCO:PRO:RC=1
                          21063 !MCO:PRO:RC=1
                          21065 !MCO:PRO:RC=1
                          21067 !MCO:PRO:RC=1
                          21069 !MCO:PRO:RC=1
                          21071 !MCO:PRO:RC=1
                          21075 !MCO:PRO:RC=1
                          21078 !MCO:PRO:RC=1
                          21080 !MCO:PRO:RC=1
                          21082 !MCO:PRO:RC=1
                          21084 !MCO:PRO:RC=1
                          21086 !MCO:PRO:RC=1
                          21088 !MCO:PRO:RC=1
                          21090 !MCO:PRO:RC=1
                          21092 !MCO:PRO:RC=1
                          21094 !MCO:PRO:RC=1
                          21096 !MCO:PRO:RC=1
                          21100 !MCO:PRO:RC=1
                          21102 !MCO:PRO:RC=1
                          21104 !MCO:PRO:RC=1
                          21106 !MCO:PRO:RC=1
                          21108 !MCO:PRO:RC=1
                          21110 !MCO:PRO:RC=1
                          21112 !MCO:PRO:RC=1
                          21114 !MCO:PRO:RC=1
                          21116 !MCO:PRO:RC=1
                          21118 !MCO:PRO:RC=1
                          21123 !MCO:PRO:RC=1
                          21125 !MCO:PRO:RC=1
                          21127 !MCO:PRO:RC=1
                          21129 !MCO:PRO:RC=1
                          21131 !MCO:PRO:RC=1
                          21133 !MCO:PRO:RC=1
                          21135 !MCO:PRO:RC=1
                          21137 !MCO:PRO:RC=1
                          21139 !MCO:PRO:RC=1
                          21141 !MCO:PRO:RC=1
                          21143 !MCO:PRO:RC=1
                          21147 !MCO:PRO:RC=1
                          21149 !MCO:PRO:RC=1
                          21151 !MCO:PRO:RC=1
                          21153 !SGN:BND:TMR
                          21161 TSF:MSG:READ,0-0-33,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                          21168 SGN:SKP:MSG CMD=3,TYPE=15
                          21170 SGN:PRE:SGN REQ,FROM=0
                          21174 SGN:SKP:MSG CMD=3,TYPE=16
                          22130 !TSF:MSG:SEND,33-33-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=NACK:
                          22136 !SGN:SGN:NCE REQ,TO=0 FAIL
                          22140 !TSF:MSG:SIGN FAIL
                          22142 SGN:SKP:MSG CMD=3,TYPE=16
                          23193 !TSF:MSG:SEND,33-33-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=2,st=NACK:
                          23199 !SGN:SGN:NCE REQ,TO=0 FAIL
                          23203 !TSF:MSG:SIGN FAIL
                          23205 !MCO:WAI:RC=1
                          23207 !MCO:PRO:RC=1
                          23212 !MCO:PRO:RC=1
                          23214 !MCO:PRO:RC=1
                          23216 !MCO:PRO:RC=1
                          23218 !MCO:PRO:RC=1
                          23220 !MCO:PRO:RC=1
                          23222 !MCO:PRO:RC=1
                          23224 !MCO:PRO:RC=1
                          23226 !MCO:PRO:RC=1
                          23228 !MCO:PRO:RC=1
                          23230 !MCO:PRO:RC=1
                          23234 !MCO:PRO:RC=1
                          23236 !MCO:PRO:RC=1
                          23238 !MCO:PRO:RC=1
                          23240 !MCO:PRO:RC=1
                          23242 !MCO:PRO:RC=1
                          23244 !MCO:PRO:RC=1
                          23246 !MCO:PRO:RC=1
                          23248 !MCO:PRO:RC=1
                          23250 !MCO:PRO:RC=1
                          23252 !MCO:PRO:RC=1
                          23255 !MCO:PRO:RC=1
                          23259 !MCO:PRO:RC=1
                          23261 !MCO:PRO:RC=1
                          23263 !MCO:PRO:RC=1
                          23265 !MCO:PRO:RC=1
                          23267 !MCO:PRO:RC=1
                          23269 !MCO:PRO:RC=1
                          23271 !MCO:PRO:RC=1
                          23273 !MCO:PRO:RC=1
                          23275 !MCO:PRO:RC=1
                          23277 !MCO:PRO:RC=1
                          23279 !MCO:PRO:RC=1
                          23283 !MCO:PRO:RC=1
                          23285 !MCO:PRO:RC=1
                          23287 !MCO:PRO:RC=1
                          23289 !MCO:PRO:RC=1
                          23291 !MCO:PRO:RC=1
                          23293 !MCO:PRO:RC=1
                          23296 !MCO:PRO:RC=1
                          23298 !MCO:PRO:RC=1
                          23300 !MCO:PRO:RC=1
                          23302 !MCO:PRO:RC=1
                          23306 !MCO:PRO:RC=1
                          23308 !MCO:PRO:RC=1
                          23310 !MCO:PRO:RC=1
                          23312 !MCO:PRO:RC=1
                          23314 !MCO:PRO:RC=1
                          23316 !MCO:PRO:RC=1
                          23318 !MCO:PRO:RC=1
                          23320 !MCO:PRO:RC=1
                          23322 !MCO:PRO:RC=1
                          23324 !MCO:PRO:RC=1
                          23326 !MCO:PRO:RC=1
                          23330 !MCO:PRO:RC=1
                          23332 !MCO:PRO:RC=1
                          23334 !MCO:PRO:RC=1
                          23336 !MCO:PRO:RC=1
                          23339 !MCO:PRO:RC=1
                          23341 !MCO:PRO:RC=1
                          23343 !MCO:PRO:RC=1
                          23345 !MCO:PRO:RC=1
                          23347 !MCO:PRO:RC=1
                          23349 !MCO:PRO:RC=1
                          23353 !MCO:PRO:RC=1
                          23355 !MCO:PRO:RC=1
                          23357 !MCO:PRO:RC=1
                          23359 !MCO:PRO:RC=1
                          23361 !MCO:PRO:RC=1
                          23363 !MCO:PRO:RC=1
                          23365 !MCO:PRO:RC=1
                          23367 !MCO:PRO:RC=1
                          23369 !MCO:PRO:RC=1
                          23371 !MCO:PRO:RC=1
                          23373 !MCO:PRO:RC=1
                          23377 !MCO:PRO:RC=1
                          23379 !MCO:PRO:RC=1
                          23382 !MCO:PRO:RC=1
                          23384 !MCO:PRO:RC=1
                          23386 !MCO:PRO:RC=1
                          23388 !MCO:PRO:RC=1
                          23390 !MCO:PRO:RC=1
                          23392 !MCO:PRO:RC=1
                          23394 !MCO:PRO:RC=1
                          23396 !MCO:PRO:RC=1
                          23398 !MCO:PRO:RC=1
                          23402 !MCO:PRO:RC=1
                          23404 !MCO:PRO:RC=1
                          23406 !MCO:PRO:RC=1
                          23408 !MCO:PRO:RC=1
                          23410 !MCO:PRO:RC=1
                          23412 !MCO:PRO:RC=1
                          23414 !MCO:PRO:RC=1
                          23416 !MCO:PRO:RC=1
                          23418 !MCO:PRO:RC=1
                          23420 !MCO:PRO:RC=1
                          23425 !MCO:PRO:RC=1
                          23427 !MCO:PRO:RC=1
                          23429 !MCO:PRO:RC=1
                          23431 !MCO:PRO:RC=1
                          23433 !MCO:PRO:RC=1
                          23435 !MCO:PRO:RC=1
                          23437 !MCO:PRO:RC=1
                          23439 !MCO:PRO:RC=1
                          23441 !MCO:PRO:RC=1
                          23443 !MCO:PRO:RC=1
                          23445 !MCO:PRO:RC=1
                          23449 !MCO:PRO:RC=1
                          23451 !MCO:PRO:RC=1
                          23453 !MCO:PRO:RC=1
                          23455 !MCO:PRO:RC=1
                          23457 !MCO:PRO:RC=1
                          23459 !MCO:PRO:RC=1
                          23461 !MCO:PRO:RC=1
                          23463 !MCO:PRO:RC=1
                          23465 !MCO:PRO:RC=1
                          23468 !MCO:PRO:RC=1
                          23470 !MCO:PRO:RC=1
                          23474 !MCO:PRO:RC=1
                          23476 !MCO:PRO:RC=1
                          23478 !MCO:PRO:RC=1
                          23480 !MCO:PRO:RC=1
                          23482 !MCO:PRO:RC=1
                          23484 !MCO:PRO:RC=1
                          23486 !MCO:PRO:RC=1
                          23488 !MCO:PRO:RC=1
                          23490 !MCO:PRO:RC=1
                          23492 !MCO:PRO:RC=1
                          23496 !MCO:PRO:RC=1
                          23498 !MCO:PRO:RC=1
                          23500 !MCO:PRO:RC=1
                          23502 !MCO:PRO:RC=1
                          23504 !MCO:PRO:RC=1
                          23506 !MCO:PRO:RC=1
                          23508 !MCO:PRO:RC=1
                          23511 !MCO:PRO:RC=1
                          23513 !MCO:PRO:RC=1
                          23517 !MCO:PRO:RC=1
                          23519 !MCO:PRO:RC=1
                          23521 !MCO:PRO:RC=1
                          23523 !MCO:PRO:RC=1
                          23525 !MCO:PRO:RC=1
                          23527 !MCO:PRO:RC=1
                          23529 !MCO:PRO:RC=1
                          23531 !MCO:PRO:RC=1
                          23533 !MCO:PRO:RC=1
                          23535 !MCO:PRO:RC=1
                          23537 !MCO:PRO:RC=1
                          23541 !MCO:PRO:RC=1
                          23543 !MCO:PRO:RC=1
                          23545 !MCO:PRO:RC=1
                          23547 !MCO:PRO:RC=1
                          23549 !MCO:PRO:RC=1
                          23552 !MCO:PRO:RC=1
                          23554 !MCO:PRO:RC=1
                          23556 !MCO:PRO:RC=1
                          23558 !MCO:PRO:RC=1
                          23560 !MCO:PRO:RC=1
                          23564 !MCO:PRO:RC=1
                          23566 !MCO:PRO:RC=1
                          23568 !MCO:PRO:RC=1
                          23570 !MCO:PRO:RC=1
                          23572 !MCO:PRO:RC=1
                          23574 !MCO:PRO:RC=1
                          23576 !MCO:PRO:RC=1
                          23578 !MCO:PRO:RC=1
                          23580 !MCO:PRO:RC=1
                          23582 !MCO:PRO:RC=1
                          23584 !MCO:PRO:RC=1
                          23588 !MCO:PRO:RC=1
                          23590 !MCO:PRO:RC=1
                          23592 !MCO:PRO:RC=1
                          23595 !MCO:PRO:RC=1
                          23597 !MCO:PRO:RC=1
                          23599 !MCO:PRO:RC=1
                          23601 !MCO:PRO:RC=1
                          23603 !MCO:PRO:RC=1
                          23605 !MCO:PRO:RC=1
                          23607 !MCO:PRO:RC=1
                          23611 !MCO:PRO:RC=1
                          23613 !MCO:PRO:RC=1
                          23615 !MCO:PRO:RC=1
                          23617 !MCO:PRO:RC=1
                          23619 !MCO:PRO:RC=1
                          23621 !MCO:PRO:RC=1
                          23623 !MCO:PRO:RC=1
                          23625 !MCO:PRO:RC=1
                          23627 !MCO:PRO:RC=1
                          23629 !MCO:PRO:RC=1
                          23631 !MCO:PRO:RC=1
                          23635 !MCO:PRO:RC=1
                          23638 !MCO:PRO:RC=1
                          23640 !MCO:PRO:RC=1
                          23642 !MCO:PRO:RC=1
                          23644 !MCO:PRO:RC=1
                          23646 !MCO:PRO:RC=1
                          23648 !MCO:PRO:RC=1
                          23650 !MCO:PRO:RC=1
                          23652 !MCO:PRO:RC=1
                          23654 !MCO:PRO:RC=1
                          23656 !MCO:PRO:RC=1
                          23660 !MCO:PRO:RC=1
                          23662 !MCO:PRO:RC=1
                          23664 !MCO:PRO:RC=1
                          23666 !MCO:PRO:RC=1
                          23668 !MCO:PRO:RC=1
                          23670 !MCO:PRO:RC=1
                          23672 !MCO:PRO:RC=1
                          23674 !MCO:PRO:RC=1
                          23676 !MCO:PRO:RC=1
                          23678 !MCO:PRO:RC=1
                          23683 !MCO:PRO:RC=1
                          23685 !MCO:PRO:RC=1
                          23687 !MCO:PRO:RC=1
                          23689 !MCO:PRO:RC=1
                          23691 !MCO:PRO:RC=1
                          23693 !MCO:PRO:RC=1
                          23695 !MCO:PRO:RC=1
                          23697 !MCO:PRO:RC=1
                          23699 !MCO:PRO:RC=1
                          23701 !MCO:PRO:RC=1
                          23703 !MCO:PRO:RC=1
                          23707 !MCO:PRO:RC=1
                          23709 !MCO:PRO:RC=1
                          23711 !MCO:PRO:RC=1
                          23713 !MCO:PRO:RC=1
                          23715 !MCO:PRO:RC=1
                          23717 !MCO:PRO:RC=1
                          23719 !MCO:PRO:RC=1
                          23721 !MCO:PRO:RC=1
                          23724 !MCO:PRO:RC=1
                          23726 !MCO:PRO:RC=1
                          23730 !MCO:PRO:RC=1
                          23732 !MCO:PRO:RC=1
                          23734 !MCO:PRO:RC=1
                          23736 !MCO:PRO:RC=1
                          23738 !MCO:PRO:RC=1
                          23740 !MCO:PRO:RC=1
                          23742 !MCO:PRO:RC=1
                          23744 !MCO:PRO:RC=1
                          23746 !MCO:PRO:RC=1
                          23748 !MCO:PRO:RC=1
                          23750 !MCO:PRO:RC=1
                          23754 !MCO:PRO:RC=1
                          • joaoabsJ joaoabs
                             __  __       ____
                                    |___/                      2.3.2
                            40 SGN:PER:OK
                            69 SGN:INI:BND OK
                            71 TSM:INIT
                            71 TSF:WUR:MS=0
                            75 TSM:INIT:TSP OK
                            79 TSF:SID:OK,ID=33
                            81 TSM:FPAR
                            83 SGN:SGN:NREQ=255
                            2099 TSM:FPAR:OK
                            2099 TSM:ID
                            2101 TSM:ID:OK
                            2103 TSM:UPL
                            3823 TSM:UPL:OK
                            6152 SGN:NCE:FROM=0
                            6283 SGN:SGN:SGN
                            8069 SGN:NCE:FROM=0
                            8523 SGN:NCE:FROM=0
                            13725 MCO:REG:REQ
                            14477 TSM:FPAR
                            15321 !TSF:SND:TNR
                            16476 !TSF:SND:TNR
                            16498 TSM:FPAR
                            18479 !TSF:SND:TNR
                            18518 TSM:FPAR:OK
                            18520 TSM:ID
                            18520 TSM:ID:OK
                            18522 TSM:UPL
                            20301 TSM:UPL:OK
                            20430 !MCO:WAI:RC=1
                            20432 !MCO:PRO:RC=1
                            20434 !MCO:PRO:RC=1
                            20436 !MCO:PRO:RC=1
                            20439 !MCO:PRO:RC=1
                            20441 !MCO:PRO:RC=1
                            20443 !MCO:PRO:RC=1
                            20445 !MCO:PRO:RC=1
                            20447 !MCO:PRO:RC=1
                            20449 !MCO:PRO:RC=1
                            20451 !MCO:PRO:RC=1
                            20455 !MCO:PRO:RC=1
                            20457 !MCO:PRO:RC=1
                            20459 !MCO:PRO:RC=1
                            20461 !MCO:PRO:RC=1
                            20463 !MCO:PRO:RC=1
                            20465 !MCO:PRO:RC=1
                            20467 !MCO:PRO:RC=1
                            20469 !MCO:PRO:RC=1
                            20471 !MCO:PRO:RC=1
                            20473 !MCO:PRO:RC=1
                            20477 !MCO:PRO:RC=1
                            20480 !MCO:PRO:RC=1
                            20482 !MCO:PRO:RC=1
                            20484 !MCO:PRO:RC=1
                            20486 !MCO:PRO:RC=1
                            20488 !MCO:PRO:RC=1
                            20490 !MCO:PRO:RC=1
                            20492 !MCO:PRO:RC=1
                            20494 !MCO:PRO:RC=1
                            20496 !MCO:PRO:RC=1
                            20498 !MCO:PRO:RC=1
                            20502 !MCO:PRO:RC=1
                            20504 !MCO:PRO:RC=1
                            20506 !MCO:PRO:RC=1
                            20508 !MCO:PRO:RC=1
                            20510 !MCO:PRO:RC=1
                            20512 !MCO:PRO:RC=1
                            20514 !MCO:PRO:RC=1
                            20516 !MCO:PRO:RC=1
                            20518 !MCO:PRO:RC=1
                            20520 !MCO:PRO:RC=1
                            20523 !MCO:PRO:RC=1
                            20527 !MCO:PRO:RC=1
                            20529 !MCO:PRO:RC=1
                            20531 !MCO:PRO:RC=1
                            20533 !MCO:PRO:RC=1
                            20535 !MCO:PRO:RC=1
                            20537 !MCO:PRO:RC=1
                            20539 !MCO:PRO:RC=1
                            20541 !MCO:PRO:RC=1
                            20543 !MCO:PRO:RC=1
                            20545 !MCO:PRO:RC=1
                            20549 !MCO:PRO:RC=1
                            20551 !MCO:PRO:RC=1
                            20553 !MCO:PRO:RC=1
                            20555 !MCO:PRO:RC=1
                            20557 !MCO:PRO:RC=1
                            20559 !MCO:PRO:RC=1
                            20561 !MCO:PRO:RC=1
                            20563 !MCO:PRO:RC=1
                            20566 !MCO:PRO:RC=1
                            20568 !MCO:PRO:RC=1
                            20570 !MCO:PRO:RC=1
                            20574 !MCO:PRO:RC=1
                            20576 !MCO:PRO:RC=1
                            20578 !MCO:PRO:RC=1
                            20580 !MCO:PRO:RC=1
                            20582 !MCO:PRO:RC=1
                            20584 !MCO:PRO:RC=1
                            20586 !MCO:PRO:RC=1
                            20588 !MCO:PRO:RC=1
                            20590 !MCO:PRO:RC=1
                            20592 !MCO:PRO:RC=1
                            20594 !MCO:PRO:RC=1
                            20598 !MCO:PRO:RC=1
                            20600 !MCO:PRO:RC=1
                            20602 !MCO:PRO:RC=1
                            20604 !MCO:PRO:RC=1
                            20606 !MCO:PRO:RC=1
                            20609 !MCO:PRO:RC=1
                            20611 !MCO:PRO:RC=1
                            20613 !MCO:PRO:RC=1
                            20615 !MCO:PRO:RC=1
                            20617 !MCO:PRO:RC=1
                            20621 !MCO:PRO:RC=1
                            20623 !MCO:PRO:RC=1
                            20625 !MCO:PRO:RC=1
                            20627 !MCO:PRO:RC=1
                            20629 !MCO:PRO:RC=1
                            20631 !MCO:PRO:RC=1
                            20633 !MCO:PRO:RC=1
                            20635 !MCO:PRO:RC=1
                            20637 !MCO:PRO:RC=1
                            20639 !MCO:PRO:RC=1
                            20641 !MCO:PRO:RC=1
                            20645 !MCO:PRO:RC=1
                            20647 !MCO:PRO:RC=1
                            20649 !MCO:PRO:RC=1
                            20652 !MCO:PRO:RC=1
                            20654 !MCO:PRO:RC=1
                            20656 !MCO:PRO:RC=1
                            20658 !MCO:PRO:RC=1
                            20660 !MCO:PRO:RC=1
                            20662 !MCO:PRO:RC=1
                            20664 !MCO:PRO:RC=1
                            20666 !MCO:PRO:RC=1
                            20670 !MCO:PRO:RC=1
                            20672 !MCO:PRO:RC=1
                            20674 !MCO:PRO:RC=1
                            20676 !MCO:PRO:RC=1
                            20678 !MCO:PRO:RC=1
                            20680 !MCO:PRO:RC=1
                            20682 !MCO:PRO:RC=1
                            20684 !MCO:PRO:RC=1
                            20686 !MCO:PRO:RC=1
                            20688 !MCO:PRO:RC=1
                            20692 !MCO:PRO:RC=1
                            20695 !MCO:PRO:RC=1
                            20697 !MCO:PRO:RC=1
                            20699 !MCO:PRO:RC=1
                            20701 !MCO:PRO:RC=1
                            20703 !MCO:PRO:RC=1
                            20705 !MCO:PRO:RC=1
                            20707 !MCO:PRO:RC=1
                            20709 !MCO:PRO:RC=1
                            20711 !MCO:PRO:RC=1
                            20713 !MCO:PRO:RC=1
                            20717 !MCO:PRO:RC=1
                            20719 !MCO:PRO:RC=1
                            20721 !MCO:PRO:RC=1
                            20723 !MCO:PRO:RC=1
                            20725 !MCO:PRO:RC=1
                            20727 !MCO:PRO:RC=1
                            20729 !MCO:PRO:RC=1
                            20731 !MCO:PRO:RC=1
                            20733 !MCO:PRO:RC=1
                            20736 !MCO:PRO:RC=1
                            20738 !MCO:PRO:RC=1
                            20742 !MCO:PRO:RC=1
                            20744 !MCO:PRO:RC=1
                            20746 !MCO:PRO:RC=1
                            20748 !MCO:PRO:RC=1
                            20750 !MCO:PRO:RC=1
                            20752 !MCO:PRO:RC=1
                            20754 !MCO:PRO:RC=1
                            20756 !MCO:PRO:RC=1
                            20758 !MCO:PRO:RC=1
                            20760 !MCO:PRO:RC=1
                            20764 !MCO:PRO:RC=1
                            20766 !MCO:PRO:RC=1
                            20768 !MCO:PRO:RC=1
                            20770 !MCO:PRO:RC=1
                            20772 !MCO:PRO:RC=1
                            20774 !MCO:PRO:RC=1
                            20776 !MCO:PRO:RC=1
                            20779 !MCO:PRO:RC=1
                            20781 !MCO:PRO:RC=1
                            20783 !MCO:PRO:RC=1
                            20785 !MCO:PRO:RC=1
                            20789 !MCO:PRO:RC=1
                            20791 !MCO:PRO:RC=1
                            20793 !MCO:PRO:RC=1
                            20795 !MCO:PRO:RC=1
                            20797 !MCO:PRO:RC=1
                            20799 !MCO:PRO:RC=1
                            20801 !MCO:PRO:RC=1
                            20803 !MCO:PRO:RC=1
                            20805 !MCO:PRO:RC=1
                            20807 !MCO:PRO:RC=1
                            20809 !MCO:PRO:RC=1
                            20813 !MCO:PRO:RC=1
                            20815 !MCO:PRO:RC=1
                            20817 !MCO:PRO:RC=1
                            20819 !MCO:PRO:RC=1
                            20822 !MCO:PRO:RC=1
                            20824 !MCO:PRO:RC=1
                            20826 !MCO:PRO:RC=1
                            20828 !MCO:PRO:RC=1
                            20830 !MCO:PRO:RC=1
                            20832 !MCO:PRO:RC=1
                            20836 !MCO:PRO:RC=1
                            20838 !MCO:PRO:RC=1
                            20840 !MCO:PRO:RC=1
                            20842 !MCO:PRO:RC=1
                            20844 !MCO:PRO:RC=1
                            20846 !MCO:PRO:RC=1
                            20848 !MCO:PRO:RC=1
                            20850 !MCO:PRO:RC=1
                            20852 !MCO:PRO:RC=1
                            20854 !MCO:PRO:RC=1
                            20856 !MCO:PRO:RC=1
                            20860 !MCO:PRO:RC=1
                            20862 !MCO:PRO:RC=1
                            20865 !MCO:PRO:RC=1
                            20867 !MCO:PRO:RC=1
                            20869 !MCO:PRO:RC=1
                            20871 !MCO:PRO:RC=1
                            20873 !MCO:PRO:RC=1
                            20875 !MCO:PRO:RC=1
                            20877 !MCO:PRO:RC=1
                            20879 !MCO:PRO:RC=1
                            20881 !MCO:PRO:RC=1
                            20885 !MCO:PRO:RC=1
                            20887 !MCO:PRO:RC=1
                            20889 !MCO:PRO:RC=1
                            20891 !MCO:PRO:RC=1
                            20893 !MCO:PRO:RC=1
                            20895 !MCO:PRO:RC=1
                            20897 !MCO:PRO:RC=1
                            20899 !MCO:PRO:RC=1
                            20901 !MCO:PRO:RC=1
                            20903 !MCO:PRO:RC=1
                            20908 !MCO:PRO:RC=1
                            20910 !MCO:PRO:RC=1
                            20912 !MCO:PRO:RC=1
                            20914 !MCO:PRO:RC=1
                            20916 !MCO:PRO:RC=1
                            20918 !MCO:PRO:RC=1
                            20920 !MCO:PRO:RC=1
                            20922 !MCO:PRO:RC=1
                            20924 !MCO:PRO:RC=1
                            20926 !MCO:PRO:RC=1
                            20928 !MCO:PRO:RC=1
                            20932 !MCO:PRO:RC=1
                            20934 !MCO:PRO:RC=1
                            20936 !MCO:PRO:RC=1
                            20938 !MCO:PRO:RC=1
                            20940 !MCO:PRO:RC=1
                            20942 !MCO:PRO:RC=1
                            20944 !MCO:PRO:RC=1
                            20946 !MCO:PRO:RC=1
                            20948 !MCO:PRO:RC=1
                            20951 !MCO:PRO:RC=1
                            20953 !MCO:PRO:RC=1
                            20957 !MCO:PRO:RC=1
                            20959 !MCO:PRO:RC=1
                            20961 !MCO:PRO:RC=1
                            20963 !MCO:PRO:RC=1
                            20965 !MCO:PRO:RC=1
                            20967 !MCO:PRO:RC=1
                            20969 !MCO:PRO:RC=1
                            20971 !MCO:PRO:RC=1
                            20973 !MCO:PRO:RC=1
                            20975 !MCO:PRO:RC=1
                            20979 !MCO:PRO:RC=1
                            20981 !MCO:PRO:RC=1
                            20983 !MCO:PRO:RC=1
                            20985 !MCO:PRO:RC=1
                            20987 !MCO:PRO:RC=1
                            20989 !MCO:PRO:RC=1
                            20992 !MCO:PRO:RC=1
                            20994 !MCO:PRO:RC=1
                            20996 !MCO:PRO:RC=1
                            20998 !MCO:PRO:RC=1
                            21000 !MCO:PRO:RC=1
                            21004 !MCO:PRO:RC=1
                            21006 !MCO:PRO:RC=1
                            21008 !MCO:PRO:RC=1
                            21010 !MCO:PRO:RC=1
                            21012 !MCO:PRO:RC=1
                            21014 !MCO:PRO:RC=1
                            21016 !MCO:PRO:RC=1
                            21018 !MCO:PRO:RC=1
                            21020 !MCO:PRO:RC=1
                            21022 !MCO:PRO:RC=1
                            21024 !MCO:PRO:RC=1
                            21028 !MCO:PRO:RC=1
                            21030 !MCO:PRO:RC=1
                            21032 !MCO:PRO:RC=1
                            21035 !MCO:PRO:RC=1
                            21037 !MCO:PRO:RC=1
                            21039 !MCO:PRO:RC=1
                            21041 !MCO:PRO:RC=1
                            21043 !MCO:PRO:RC=1
                            21045 !MCO:PRO:RC=1
                            21047 !MCO:PRO:RC=1
                            21051 !MCO:PRO:RC=1
                            21053 !MCO:PRO:RC=1
                            21055 !MCO:PRO:RC=1
                            21057 !MCO:PRO:RC=1
                            21059 !MCO:PRO:RC=1
                            21061 !MCO:PRO:RC=1
                            21063 !MCO:PRO:RC=1
                            21065 !MCO:PRO:RC=1
                            21067 !MCO:PRO:RC=1
                            21069 !MCO:PRO:RC=1
                            21071 !MCO:PRO:RC=1
                            21075 !MCO:PRO:RC=1
                            21078 !MCO:PRO:RC=1
                            21080 !MCO:PRO:RC=1
                            21082 !MCO:PRO:RC=1
                            21084 !MCO:PRO:RC=1
                            21086 !MCO:PRO:RC=1
                            21088 !MCO:PRO:RC=1
                            21090 !MCO:PRO:RC=1
                            21092 !MCO:PRO:RC=1
                            21094 !MCO:PRO:RC=1
                            21096 !MCO:PRO:RC=1
                            21100 !MCO:PRO:RC=1
                            21102 !MCO:PRO:RC=1
                            21104 !MCO:PRO:RC=1
                            21106 !MCO:PRO:RC=1
                            21108 !MCO:PRO:RC=1
                            21110 !MCO:PRO:RC=1
                            21112 !MCO:PRO:RC=1
                            21114 !MCO:PRO:RC=1
                            21116 !MCO:PRO:RC=1
                            21118 !MCO:PRO:RC=1
                            21123 !MCO:PRO:RC=1
                            21125 !MCO:PRO:RC=1
                            21127 !MCO:PRO:RC=1
                            21129 !MCO:PRO:RC=1
                            21131 !MCO:PRO:RC=1
                            21133 !MCO:PRO:RC=1
                            21135 !MCO:PRO:RC=1
                            21137 !MCO:PRO:RC=1
                            21139 !MCO:PRO:RC=1
                            21141 !MCO:PRO:RC=1
                            21143 !MCO:PRO:RC=1
                            21147 !MCO:PRO:RC=1
                            21149 !MCO:PRO:RC=1
                            21151 !MCO:PRO:RC=1
                            21153 !SGN:BND:TMR
                            23205 !MCO:WAI:RC=1
                            23207 !MCO:PRO:RC=1
                            23212 !MCO:PRO:RC=1
                            23214 !MCO:PRO:RC=1
                            23216 !MCO:PRO:RC=1
                            23218 !MCO:PRO:RC=1
                            23220 !MCO:PRO:RC=1
                            23222 !MCO:PRO:RC=1
                            23224 !MCO:PRO:RC=1
                            23226 !MCO:PRO:RC=1
                            23228 !MCO:PRO:RC=1
                            23230 !MCO:PRO:RC=1
                            23234 !MCO:PRO:RC=1
                            23236 !MCO:PRO:RC=1
                            23238 !MCO:PRO:RC=1
                            23240 !MCO:PRO:RC=1
                            23242 !MCO:PRO:RC=1
                            23244 !MCO:PRO:RC=1
                            23246 !MCO:PRO:RC=1
                            23248 !MCO:PRO:RC=1
                            23250 !MCO:PRO:RC=1
                            23252 !MCO:PRO:RC=1
                            23255 !MCO:PRO:RC=1
                            23259 !MCO:PRO:RC=1
                            23261 !MCO:PRO:RC=1
                            23263 !MCO:PRO:RC=1
                            23265 !MCO:PRO:RC=1
                            23267 !MCO:PRO:RC=1
                            23269 !MCO:PRO:RC=1
                            23271 !MCO:PRO:RC=1
                            23273 !MCO:PRO:RC=1
                            23275 !MCO:PRO:RC=1
                            23277 !MCO:PRO:RC=1
                            23279 !MCO:PRO:RC=1
                            23283 !MCO:PRO:RC=1
                            23285 !MCO:PRO:RC=1
                            23287 !MCO:PRO:RC=1
                            23289 !MCO:PRO:RC=1
                            23291 !MCO:PRO:RC=1
                            23293 !MCO:PRO:RC=1
                            23296 !MCO:PRO:RC=1
                            23298 !MCO:PRO:RC=1
                            23300 !MCO:PRO:RC=1
                            23302 !MCO:PRO:RC=1
                            23306 !MCO:PRO:RC=1
                            23308 !MCO:PRO:RC=1
                            23310 !MCO:PRO:RC=1
                            23312 !MCO:PRO:RC=1
                            23314 !MCO:PRO:RC=1
                            23316 !MCO:PRO:RC=1
                            23318 !MCO:PRO:RC=1
                            23320 !MCO:PRO:RC=1
                            23322 !MCO:PRO:RC=1
                            23324 !MCO:PRO:RC=1
                            23326 !MCO:PRO:RC=1
                            23330 !MCO:PRO:RC=1
                            23332 !MCO:PRO:RC=1
                            23334 !MCO:PRO:RC=1
                            23336 !MCO:PRO:RC=1
                            23339 !MCO:PRO:RC=1
                            23341 !MCO:PRO:RC=1
                            23343 !MCO:PRO:RC=1
                            23345 !MCO:PRO:RC=1
                            23347 !MCO:PRO:RC=1
                            23349 !MCO:PRO:RC=1
                            23353 !MCO:PRO:RC=1
                            23355 !MCO:PRO:RC=1
                            23357 !MCO:PRO:RC=1
                            23359 !MCO:PRO:RC=1
                            23361 !MCO:PRO:RC=1
                            23363 !MCO:PRO:RC=1
                            23365 !MCO:PRO:RC=1
                            23367 !MCO:PRO:RC=1
                            23369 !MCO:PRO:RC=1
                            23371 !MCO:PRO:RC=1
                            23373 !MCO:PRO:RC=1
                            23377 !MCO:PRO:RC=1
                            23379 !MCO:PRO:RC=1
                            23382 !MCO:PRO:RC=1
                            23384 !MCO:PRO:RC=1
                            23386 !MCO:PRO:RC=1
                            23388 !MCO:PRO:RC=1
                            23390 !MCO:PRO:RC=1
                            23392 !MCO:PRO:RC=1
                            23394 !MCO:PRO:RC=1
                            23396 !MCO:PRO:RC=1
                            23398 !MCO:PRO:RC=1
                            23402 !MCO:PRO:RC=1
                            23404 !MCO:PRO:RC=1
                            23406 !MCO:PRO:RC=1
                            23408 !MCO:PRO:RC=1
                            23410 !MCO:PRO:RC=1
                            23412 !MCO:PRO:RC=1
                            23414 !MCO:PRO:RC=1
                            23416 !MCO:PRO:RC=1
                            23418 !MCO:PRO:RC=1
                            23420 !MCO:PRO:RC=1
                            23425 !MCO:PRO:RC=1
                            23427 !MCO:PRO:RC=1
                            23429 !MCO:PRO:RC=1
                            23431 !MCO:PRO:RC=1
                            23433 !MCO:PRO:RC=1
                            23435 !MCO:PRO:RC=1
                            23437 !MCO:PRO:RC=1
                            23439 !MCO:PRO:RC=1
                            23441 !MCO:PRO:RC=1
                            23443 !MCO:PRO:RC=1
                            23445 !MCO:PRO:RC=1
                            23449 !MCO:PRO:RC=1
                            23451 !MCO:PRO:RC=1
                            23453 !MCO:PRO:RC=1
                            23455 !MCO:PRO:RC=1
                            23457 !MCO:PRO:RC=1
                            23459 !MCO:PRO:RC=1
                            23461 !MCO:PRO:RC=1
                            23463 !MCO:PRO:RC=1
                            23465 !MCO:PRO:RC=1
                            23468 !MCO:PRO:RC=1
                            23470 !MCO:PRO:RC=1
                            23474 !MCO:PRO:RC=1
                            23476 !MCO:PRO:RC=1
                            23478 !MCO:PRO:RC=1
                            23480 !MCO:PRO:RC=1
                            23482 !MCO:PRO:RC=1
                            23484 !MCO:PRO:RC=1
                            23486 !MCO:PRO:RC=1
                            23488 !MCO:PRO:RC=1
                            23490 !MCO:PRO:RC=1
                            23492 !MCO:PRO:RC=1
                            23496 !MCO:PRO:RC=1
                            23498 !MCO:PRO:RC=1
                            23500 !MCO:PRO:RC=1
                            23502 !MCO:PRO:RC=1
                            23504 !MCO:PRO:RC=1
                            23506 !MCO:PRO:RC=1
                            23508 !MCO:PRO:RC=1
                            23511 !MCO:PRO:RC=1
                            23513 !MCO:PRO:RC=1
                            23517 !MCO:PRO:RC=1
                            23519 !MCO:PRO:RC=1
                            23521 !MCO:PRO:RC=1
                            23523 !MCO:PRO:RC=1
                            23525 !MCO:PRO:RC=1
                            23527 !MCO:PRO:RC=1
                            23529 !MCO:PRO:RC=1
                            23531 !MCO:PRO:RC=1
                            23533 !MCO:PRO:RC=1
                            23535 !MCO:PRO:RC=1
                            23537 !MCO:PRO:RC=1
                            23541 !MCO:PRO:RC=1
                            23543 !MCO:PRO:RC=1
                            23545 !MCO:PRO:RC=1
                            23547 !MCO:PRO:RC=1
                            23549 !MCO:PRO:RC=1
                            23552 !MCO:PRO:RC=1
                            23554 !MCO:PRO:RC=1
                            23556 !MCO:PRO:RC=1
                            23558 !MCO:PRO:RC=1
                            23560 !MCO:PRO:RC=1
                            23564 !MCO:PRO:RC=1
                            23566 !MCO:PRO:RC=1
                            23568 !MCO:PRO:RC=1
                            23570 !MCO:PRO:RC=1
                            23572 !MCO:PRO:RC=1
                            23574 !MCO:PRO:RC=1
                            23576 !MCO:PRO:RC=1
                            23578 !MCO:PRO:RC=1
                            23580 !MCO:PRO:RC=1
                            23582 !MCO:PRO:RC=1
                            23584 !MCO:PRO:RC=1
                            23588 !MCO:PRO:RC=1
                            23590 !MCO:PRO:RC=1
                            23592 !MCO:PRO:RC=1
                            23595 !MCO:PRO:RC=1
                            23597 !MCO:PRO:RC=1
                            23599 !MCO:PRO:RC=1
                            23601 !MCO:PRO:RC=1
                            23603 !MCO:PRO:RC=1
                            23605 !MCO:PRO:RC=1
                            23607 !MCO:PRO:RC=1
                            23611 !MCO:PRO:RC=1
                            23613 !MCO:PRO:RC=1
                            23615 !MCO:PRO:RC=1
                            23617 !MCO:PRO:RC=1
                            23619 !MCO:PRO:RC=1
                            23621 !MCO:PRO:RC=1
                            23623 !MCO:PRO:RC=1
                            23625 !MCO:PRO:RC=1
                            23627 !MCO:PRO:RC=1
                            23629 !MCO:PRO:RC=1
                            23631 !MCO:PRO:RC=1
                            23635 !MCO:PRO:RC=1
                            23638 !MCO:PRO:RC=1
                            23640 !MCO:PRO:RC=1
                            23642 !MCO:PRO:RC=1
                            23644 !MCO:PRO:RC=1
                            23646 !MCO:PRO:RC=1
                            23648 !MCO:PRO:RC=1
                            23650 !MCO:PRO:RC=1
                            23652 !MCO:PRO:RC=1
                            23654 !MCO:PRO:RC=1
                            23656 !MCO:PRO:RC=1
                            23660 !MCO:PRO:RC=1
                            23662 !MCO:PRO:RC=1
                            23664 !MCO:PRO:RC=1
                            23666 !MCO:PRO:RC=1
                            23668 !MCO:PRO:RC=1
                            23670 !MCO:PRO:RC=1
                            23672 !MCO:PRO:RC=1
                            23674 !MCO:PRO:RC=1
                            23676 !MCO:PRO:RC=1
                            23678 !MCO:PRO:RC=1
                            23683 !MCO:PRO:RC=1
                            23685 !MCO:PRO:RC=1
                            23687 !MCO:PRO:RC=1
                            23689 !MCO:PRO:RC=1
                            23691 !MCO:PRO:RC=1
                            23693 !MCO:PRO:RC=1
                            23695 !MCO:PRO:RC=1
                            23697 !MCO:PRO:RC=1
                            23699 !MCO:PRO:RC=1
                            23701 !MCO:PRO:RC=1
                            23703 !MCO:PRO:RC=1
                            23707 !MCO:PRO:RC=1
                            23709 !MCO:PRO:RC=1
                            23711 !MCO:PRO:RC=1
                            23713 !MCO:PRO:RC=1
                            23715 !MCO:PRO:RC=1
                            23717 !MCO:PRO:RC=1
                            23719 !MCO:PRO:RC=1
                            23721 !MCO:PRO:RC=1
                            23724 !MCO:PRO:RC=1
                            23726 !MCO:PRO:RC=1
                            23730 !MCO:PRO:RC=1
                            23732 !MCO:PRO:RC=1
                            23734 !MCO:PRO:RC=1
                            23736 !MCO:PRO:RC=1
                            23738 !MCO:PRO:RC=1
                            23740 !MCO:PRO:RC=1
                            23742 !MCO:PRO:RC=1
                            23744 !MCO:PRO:RC=1
                            23746 !MCO:PRO:RC=1
                            23748 !MCO:PRO:RC=1
                            23750 !MCO:PRO:RC=1
                            23754 !MCO:PRO:RC=1
                            I found the root cause: https://github.com/mysensors/MySensors/issues/1458#issuecomment-739139339
                            It is part of the signing code, so expected to occur on all nodes/gateways that request nonces for signing.
                            Currently discussing if it is a real issue or not.
                            T joaoabsJ 2 Replies Last reply
                            • YveauxY Yveaux
                              TimO
                              @Yveaux thank you for digging in!
                              • fritsF
                                fritsF
                                frits
                                @joaoabs said in MQTT GW with RFM69 on RPi:
                                are you setting #define MY_TRANSPORT_WAIT_READY_MS ([timeout])? This causes MCO:PRO in my test cases as well.
                                joaoabsJ 1 Reply Last reply
                                • fritsF frits
                                  joaoabsJ
                                  joaoabsJ
                                  joaoabs
                                  wrote on last edited by joaoabs
                                  #23
                                  @frits
                                  Don't think so, unless it is set by default.
                                  The code corresponding to the log:
                                   * Copyright (C) 2013-2019 Sensnology AB
                                   * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
                                   * @ingroup MySigninggrp
                                   * @file SecureActuator.ino
                                   * @brief Example sketch showing how to securely control locks.
                                   * This example will remember lock state even after power failure.
                                   *  - See git log (git log libraries/MySensors/examples/SecureActuator/SecureActuator.ino)
                                   * @example SecureActuator.ino
                                   * This example implements a secure actuator in the form of a IO controlled electrical lock.<br>
                                   * Multiple locks are supported as long as they are on subsequent IO pin indices. The first lock pin
                                   * is defined by @ref LOCK_1. The number of locks is controlled by @ref NOF_LOCKS .<br>
                                   * The sketch will require incoming messages to be signed and the use of signing backend is selected
                                   * by @ref MY_SIGNING_ATSHA204 or @ref MY_SIGNING_SOFT. Hard or soft ATSHA204 signing is supported.<br>
                                   * Whitelisting can be enabled through @ref MY_SIGNING_NODE_WHITELISTING in which case a single entry
                                   * is provided in this example which typically should map to the gateway of the network.
                                  #define MY_DEBUG //!< Enable debug prints to serial monitor
                                  //#define MY_NODE_LOCK_FEATURE //!< Enable lockdown of node if suspicious activity is detected
                                  // RADIO STUFF
                                  #define MY_RADIO_RFM69 //!< RFM69 radio driver
                                  #define MY_RFM69_NEW_DRIVER
                                  #define MY_RFM69_FREQUENCY RFM69_433MHZ
                                  //#define MY_IS_RFM69HW
                                  #define MY_RFM69_ENABLE_ENCRYPTION
                                  // SIGNING STUFF
                                  // Select soft/hardware signing method
                                  //#define MY_SIGNING_SOFT //!< Software signing
                                  #define MY_SIGNING_ATSHA204 //!< Hardware signing using ATSHA204A
                                  // Enable node whitelisting
                                  #define MY_SIGNING_REQUEST_SIGNATURES //!< destination node signs all messages sent to this node
                                  //#define MY_SIGNING_SOFT_RANDOMSEED_PIN 7 //!< Unconnected analog pin for random seed
                                  // SETTINGS FOR MY_SIGNING_ATSHA204
                                  #define MY_SIGNING_ATSHA204_PIN 17 //!< A3 - pin where ATSHA204 is attached
                                  #define MY_DEBUG_VERBOSE_SIGNING //!< Enable signing related debug prints to serial monitor
                                  #define MY_NODE_ID 33
                                  #define LOCK_1  3     //!< Arduino Digital I/O pin number for first lock (second on pin+1 etc)
                                  #define NOF_LOCKS 2   //!< Total number of attached locks
                                  #define LOCK_LOCK 1   //!< GPIO value to write to lock attached lock
                                  #define LOCK_UNLOCK 0 //!< GPIO value to write to unlock attached lock
                                  	for (int lock=1, pin=LOCK_1; lock<=NOF_LOCKS; lock++, pin++) {
                                  		// Set lock pins in output mode
                                  		pinMode(pin, OUTPUT);
                                  		// Set lock to last known state (using eeprom storage)
                                  		digitalWrite(pin, loadState(lock)?LOCK_LOCK:LOCK_UNLOCK);
                                  	sendSketchInfo("Secure Lock", "1.0");
                                  	// Fetch lock status
                                  		// Register all locks to gw (they will be created as child devices)
                                  		present(lock, S_LOCK, "SecureActuator", false);
                                  /** @brief Sketch execution code */
                                   * @brief Incoming message handler
                                   * @param message The message to handle.
                                  	// And echoed messages are not accepted as control messages
                                  	if (message.getType()==V_LOCK_STATUS && message.getSensor()<=NOF_LOCKS && !message.isEcho()) {
                                  		// Change relay state
                                  		digitalWrite(message.getSensor()-1+LOCK_1, message.getBool()?LOCK_LOCK:LOCK_UNLOCK);
                                  		// Store state in eeprom
                                  		saveState(message.getSensor(), message.getBool());
                                  		Serial.print("Incoming change for lock:");
                                  		Serial.print(message.getSensor());
                                  • YveauxY Yveaux
                                    joaoabsJ
                                    joaoabsJ
                                    joaoabs
                                    @Yveaux Hello, Any update if this is an issue or just a cosmetic log thing? Cheers
                                    • joaoabsJ joaoabs
                                      @joaoabs no, sorry. I didn't investigate any deeper.
