  3. 💬 My Slim 2AA Battery Node
arduinomysensorslow powerbatteryenclosurenrf24l01
27 Posts 17 Posters 13.3k Views 14 Watching
  • Aki1988A
    Aki1988A
    Aki1988
    wrote on last edited by Aki1988
    Hello, i made a few. is someone interested in these nodes in Germany? We switched to an other Home Automation (wife: you can't build something DIY in our house that is so important than a light switch ...) system and so those nodes were never used. All nodes come untested and most of them unflashed. It would be a shame if they would just lay around here. Shipping is on you, the nodes and other s no longer needed (mysensors) stuff is free. Nodes are in Germany, and i will send them via DHL. if you are interested write me a mail to aki1988 (at) me (dot) com - first come first serve.
    Edit: gone
    • J
      J
      Johove
      wrote on last edited by Johove
      I built a couple of these nodes last year, I used 8 MHz internal, fuses off, and a DTH22.
      This a node on a dometizc network, it measures temperatur and internal voltage every 6 minutes, then it deep sleep.
      I can confirm that these nodes last more that a year on 2 aa batteries.
      • G
        G
        GHoggan
        Hello, I placed an order through the openhardware.io website with Itead last night.
        They came back this morning with a ticket saying :
        Your gerber file: 571bf156249971713bb044ea.zip (Normalized Name:A100151928AN_A2AGLF002A.zip) in the order #100151928 is rejected.
        The reason is:
        The Gerber file doesn't have outline layer , please add it and re-upload the new file , thank you.
        Can you please assist as I don't really want to cancel my order.
        Thanks in advance
        Glenn
        • joaoabsJ
          joaoabsJ
          joaoabs
          This board has an ICSP header. Does it mean that I can use it to burn the bootloader in a new ATMega328 chip?
          I've been trying to do burn the minicore in a board with all the required capacitors and resistor but without the NRF, but without success...
          Any idea?
          • joaoabsJ joaoabs
            Any idea?
            sundberg84S
            sundberg84S
            #22
            @joaoabs - yes!
            Just as you, I burned it with as few components (like radio) as possible but that worked out for me.
            • joaoabsJ
              joaoabsJ
              joaoabs
              wrote on last edited by joaoabs
              #23
              I'm sorry to insist on this one, but I'm a bit lost....
              I could understand that the recommended bootloader is MiniCore. I installed it in my Arduino IDE and after several tries-and-errors I believe I was able to burn the MiniCore bootloader by using an USBasp2 connected to the ICSP on the slim board:
              /home/jabss/Desktop/arduino-1.8.2/hardware/tools/avr/bin/avrdude -C/root/.arduino15/packages/MiniCore/hardware/avr/2.0.1/avrdude.conf -v -patmega328p -cusbasp -Pusb -e -Ulock:w:0x3f:m -Uefuse:w:0xff:m -Uhfuse:w:0xd7:m -Ulfuse:w:0xe2:m
              avrdude: Version 6.3, compiled on Jan 17 2017 at 11:00:16
                       System wide configuration file is "/root/.arduino15/packages/MiniCore/hardware/avr/2.0.1/avrdude.conf"
                       User configuration file is "/home/jabss/.avrduderc"
                       Using Programmer              : usbasp
                       Programmer Type : usbasp
                       Description     : USBasp, http://www.fischl.de/usbasp/
              avrdude: auto set sck period (because given equals null)
              avrdude: erasing chip
              avrdude: reading input file "0x3f"
              /home/jabss/Desktop/arduino-1.8.2/hardware/tools/avr/bin/avrdude -C/root/.arduino15/packages/MiniCore/hardware/avr/2.0.1/avrdude.conf -v -patmega328p -cusbasp -Pusb -Uflash:w:/root/.arduino15/packages/MiniCore/hardware/avr/2.0.1/bootloaders/empty/empty.hex:i -Ulock:w:0x0f:m
              avrdude: verifying lock memory against 0x3f:
              avrdude: load data lock data from input file 0x3f:
              avrdude: input file 0x3f contains 1 bytes
              avrdude: verifying ...
              avrdude: reading input file "0xff"
              avrdude: verifying efuse memory against 0xff:
              avrdude: load data efuse data from input file 0xff:
              avrdude: input file 0xff contains 1 bytes
              avrdude: reading input file "0xd7"
              avrdude: verifying hfuse memory against 0xd7:
              avrdude: load data hfuse data from input file 0xd7:
              avrdude: input file 0xd7 contains 1 bytes
              avrdude: reading input file "0xe2"
              avrdude: verifying lfuse memory against 0xe2:
              avrdude: load data lfuse data from input file 0xe2:
              avrdude: input file 0xe2 contains 1 bytes
              avrdude done.  Thank you.
              avrdude: reading input file "/root/.arduino15/packages/MiniCore/hardware/avr/2.0.1/bootloaders/empty/empty.hex"
              avrdude: writing flash (2 bytes):
              Writing | ################################################## | 100% 0.07s
              avrdude: 2 bytes of flash written
              avrdude: verifying flash memory against /root/.arduino15/packages/MiniCore/hardware/avr/2.0.1/bootloaders/empty/empty.hex:
              avrdude: load data flash data from input file /root/.arduino15/packages/MiniCore/hardware/avr/2.0.1/bootloaders/empty/empty.hex:
              avrdude: input file /root/.arduino15/packages/MiniCore/hardware/avr/2.0.1/bootloaders/empty/empty.hex contains 2 bytes
              Reading | ################################################## | 100% 0.04s
              avrdude: 2 bytes of flash verified
              avrdude: reading input file "0x0f"
              avrdude: verifying lock memory against 0x0f:
              avrdude: load data lock data from input file 0x0f:
              avrdude: input file 0x0f contains 1 bytes
              Just for reference, the parameters were:
              Board: Atmega328
              Bootloader: No (only worked this way, but still not sure what this means: If is already a bootloader on the chip, or if we want to write a bootloader)
              Variant: 328P
              BOD: Disabled
              Clock: 8Mhz internal (here I think its what we want to configure on the target chip - I wasn't sure what was about because it could also have been the clock frequency of the programmer)
              Compiler LTO: Disabled
              Programer: USBASP
              Anyway, after this supposed success message, I believe I have a MiniCore bootloader in the chip and now it should be able to be programed with the AVRISPMKII (with the usb/serial programing adapter I use to program my mini-pros).
              However, I'm not able to get it working. Maybe I'm choosing the wrong definitions in the arduino IDE.
              As board definition, I'm using the same as when burning the bootloader:
              Board: Atmega328 (from the minicore subset)
              Bootloader: Yes
              Variant: 328P
              BOD: Disabled
              Programer: AVRISPMKII
              For instance, to load the ascii table example (for testing purposes), I get this error:
              Insert Code Build options changed, rebuilding all
              Sketch uses 2330 bytes (7%) of program storage space. Maximum is 32256 bytes.
              Global variables use 308 bytes (15%) of dynamic memory, leaving 1740 bytes for local variables. Maximum is 2048 bytes.
              /home/jabss/Desktop/arduino-1.8.2/hardware/tools/avr/bin/avrdude -C/root/.arduino15/packages/MiniCore/hardware/avr/2.0.1/avrdude.conf -v -patmega328p -carduino -P/dev/ttyUSB0 -b38400 -D -Uflash:w:/tmp/arduino_build_636369/ASCIITable.ino.hex:i
                       Using Port                    : /dev/ttyUSB0
                       Overriding Baud Rate          : 38400
              avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
              avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
              avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
              avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
              avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
              avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
              avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
              avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
              avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
              avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
              Any hint on what I may be doing wrong?
              • I
                I
                iteafreely
                I just made a new case for a LiFePO4 magnetic sensor implementation of this. Thanks for the excellent work on this handy node design!
                https://www.thingiverse.com/thing:3034907!
                a picture
                • J
                  J
                  John Oliva
                  Here is a new enclosure for the My Slim 2AA Battery Node. Not as slim but the overall form factor is still small.
                  https://www.thingiverse.com/thing:3269357
                  • joaoabsJ
                    joaoabsJ
                    joaoabs
                    Hi @m26872
                    Congrats for the great and simple design.
                    I've been troubleshooting this slimnode with RFM69 radios and realized that a shunt between RFM69's DIO0 and Mega328's INT0 is required, otherwise the node will not "hear" the gateway. Even if the nrf2rmf69 board is used this shunt is required.
                    It seems this is a re-current issue. Although this may be solved in the PCB2.0 could it be mentioned somewhere in the page above?
                    Thanks and cheers!
                    m26872M 1 Reply Last reply
                    • joaoabsJ joaoabs
                      Hi @m26872
                      Thanks and cheers!
                      m26872M
                      m26872M
                      m26872
                      @joaoabs said in 💬 My Slim 2AA Battery Node:
                      Thx! Done!
