1.1k Posts 105 Posters 793.5k Views 98 Watching
  • BearWithBeardB
    BearWithBeardB
    BearWithBeard
    wrote on last edited by BearWithBeard
    #1016
    Winter time is tinker time!
    This is a compact environmental sensor node with an E-Paper display. My goal was to have a decent screen-to-body ratio with a simple and minimalistic display, easy to read from a distance. It is the first design in which I did not use an ATmega MCU. It is also the first time that I used KiCAD instead of EAGLE, soldered no-lead SMD components and worked with an EPD.
    • It features a SHTC3 sensor to measure temperature and relative humidity and a VEML6030 to measure the ambient light, so that I can toggle lights or other appliances in the room based on temperature, humidity or light conditions.
    • I have also added a MEMS sensor (LIS3DH) to auto-detect the device orientation and rotate the EPD image accordingly and / or detect tap events to toggle between different display modes / data sets.
    • It can be powered directly from a 3V source or use the optional 3.3V boost circuit which accepts 1.5V or 3V sources.
    I finished soldering and testing all the components today and just started programming the rough "framework". Looks promising so far! But still lots to do, including finalizing the 3D printed enclosure. This is how it is supposed to look in the end:
    berkseoB skywatchS 2 Replies Last reply
    • berkseoB
      berkseoB
      berkseo
      #1017
      Hi guys. I recently made a plant watering control sensor with an electronic paper display. Today I did my first tests, ..everything went well :)
      https://youtu.be/0dnzQiRZj7M
      • BearWithBeardB BearWithBeard
        berkseoB
        berkseoB
        berkseo
        @BearWithBeard said in What did you build today (Pictures) ?:
        VEML6030
        Take a closer look at the max44009 light sensor and the lis2dw12 accelerometer. You can save a few microamps.
        • N
          N
          ncollins
          First attempt at a modular NRF52805 based board. The smaller board has a Si7021 temp + humidity sensor and a BH1750 light level sensor, both I2C. Ideally, I should be-able to make other sensor boards with the same footprint as long as the sensors are I2C.
          Also included:
          • CR2032 Battery (~1.5 years between battery changes)
          • 10P 0.5 FPC connector for programming and serial debugging
          • 2 LEDs with solderable jumpers
          • On/Off switch (I find this really useful, especially when fighting with coin batteries)
          • RST button
          • Secondary button that I use to force immediate readings
          • Footprint for centered button for alternative use as a remote button (my most common MySensors node)
          I'll post pictures of the enclosure when it's ready.
          I'm also waiting on delivery of a slightly larger version of this board that holds a 2477 battery and a SMD PIR motion sensor.
          berkseoB NeverDieN 2 Replies Last reply
          • N ncollins
            Also included:
            • RST button
            berkseoB
            berkseoB
            berkseo
            @ncollins
            Very, very beautiful project! I also already have several such radio modules from different manufacturers. Here are just these ebyte specifically, they are without dc-dc. ...I plan to transfer support from nordic sdk to sandeep mistry (just like I did with 52810 and 52811), but how do you flash them under mysensors? Maybe there is already some shorter way?
            N 1 Reply Last reply
            • berkseoB berkseo
              @ncollins
              N
              N
              ncollins
              @berkseo Thank you!
              First, I made the compatibility changes to SandeepMistry. This was surprisingly easy. The SDK in SandeepMistry/nRF5-arduino does most of the heavy lifting. I had to modify a few of the precompiler conditions to exclude PWM, change some serial definitions, and update to new handler naming conventions: https://github.com/sandeepmistry/arduino-nRF5/pull/442
              Then, I defined a new Generic NRF52805 variant in mysensors/ArduinoHwNRF5 and handled one assumption of LPCOMP: https://github.com/mysensors/ArduinoHwNRF5/pull/12
              Last, I had to handle a few small assumptions in the MySensors library: https://github.com/mysensors/MySensors/pull/1461
              • N
                N
                ncollins
                Playing around with enclosure designs for my new node
                  skywatchS
                  skywatchS
                  skywatch
                  @BearWithBeard Very nice indeed!
                  • N
                    N
                    ncollins
                    Sensor node on the left, button node on the right.
                    • N ncollins
                      Also included:
                      • RST button
                      @ncollins said in What did you build today (Pictures) ?:
                      How many of the 10 pins do you actually use?
                        N
                        N
                        ncollins
                        @NeverDie Currently using 6, [GND, VCC, SWDIO, SWCLK, - , TX, RX, -, -, -]
                        • N
                          N
                          ncollins
                          The latest addition to my coin cell nodes, a PIR motion sensor based on the Ebyte NRF52805 module.
                          The PIR sensor is a Senba S16-L221D-2. I'm measuring around 24uA, which is higher than advertised, but with the 6-7uA from the NRF52805, should still get me 3-4 years on a single 2477.
                          Amit BTA 1 Reply Last reply
                          • kalinaK
                            kalinaK
                            kalina
                            #1028
                            Today i have assembled the latest revision of my Lighting X3 for DIN rail mounting.
                            • kalinaK
                              kalinaK
                              kalina
                              #1029
                              Oh yes, I forgot to share photos of my new project - Multinetwork Mysensors Gateway. The main idea of this gateway is that it can at the same time serve up to four different networks (Lora - RFM9X, 2.4 GHz - NRF24 and ISM band RFM69). These networks can be assembled in separate modules and each user can build own set of modules. The incoming stream will be connected via Ethernet on various ports, for example, the gate will have the IP address 192.168.1.128, and each subnet will be served on ports 5003 - the first subnet, 5004 - the second, and so on ...
                              monteM 1 Reply Last reply
                              • kalinaK kalina
                                monteM
                                monteM
                                monte
                                @kalina looking great! Is it opensource?
                                kalinaK 1 Reply Last reply
                                • monteM monte
                                  kalinaK
                                  kalinaK
                                  kalina
                                  #1031
                                  @monte Not certainly in that way. In this project, everything is open source with the exception of the board with an ethernet (based on STM32). The ethernet board was developed by my partners and they are not ready to share it yet. But I hope I can persuade them to do it :-)1.jpg
                                  NeverDieN monteM 2 Replies Last reply
                                  • kalinaK kalina
                                    @kalina I like how it both consolidates and reduces wall-wart clutter all in one stroke. :-)
                                    I don't see any antennas though. Where do they go? And does having multiple radios packed close together like that create any noteworthy EMI? I knew a guy who had set up an RFM69 hat on his Raspberry Pi but later found that the raspberry Pi produced a lot of RF noise/EMI that reduced the effective range of his gateway. I don't know whether or not that might happen in your case, but I thought I'd mention it to help with your troubleshooting in the event you notice any unexpected range reduction.
                                    • kalinaK kalina
                                      monteM
                                      monteM
                                      monte
                                      @kalina I see. I have the same STM32 chip and was going to use it in one of my next projects, so I asked to get some inspiration :)
                                        kalinaK
                                        kalinaK
                                        kalina
                                        #1034
                                        @NeverDie EMI is a big topic. I think there will be no problems. I am going to do some tests of communication
                                        quality for various modules and antennas. As for the antennas, I am going to fixed them to the body through the holes, but I have not yet decided on the location. As for connection antenna to the module you can see the on photo ...
                                        • berkseoB
                                          berkseoB
                                          berkseo
                                          #1035
                                          Hello everyone. I want to show you my new device, battery powered air quality sensor. The device also has light, temperature, humidity, and atmospheric pressure sensors. I am currently testing the software.
                                          NeverDieN berkseoB 2 Replies Last reply
