  3. Newbie question : how to toggle a led with MQTT
2 Posts 2 Posters 1.7k Views 1 Watching
    Hello.
    I am newbie with Mysensors and iot world. So I am reading a lot actually. I am trying to do basics tests for learning. So my confiuration is
    • MySensors lib 1.4, all arduino nano, nrf24
    • Gateway : I use the MQTT broker gateway
    • for debugging MQTT, I use MQTTLens (maybe there is a better tool)
    My first test was using just one node with a DHT11. I am able to read the infos in MQTTLens.
    Now I am trying to toggle a led with MQTT.
    So, I removed the DHT11, and connected a led. I verified that hardware is ok by using a simple blink led sketch.
    I am using the MySensors relay example.
    1. I added this line in Setup(). Is it ok?
      gw.request(sensor, V_LIGHT,0);
    2. Here is my problem, maybe a silly question, but I am learning so
      in MQTTLens, what command must I send ?? Is it in the subscribe or publish field? I thought that subscribe was just for receiving and publish for sending info. Maybe not?
    In subscribe field, if I do MyMQTT/20/1/V_LIGHT my Led toggle on. But How to toggle off?
    I think I do not understand how MQTT works yet but I will get it!
    Thanks for your help I hope my english is not too bad...
    Have a good day.
    • XanderX
      XanderX
      Xander
      at 1) The RelaisActor sketch works out of the box. There is nothing to add. (I think :-) )
      at 2) You are right. I don't know "MQTTLens" (I use MQTTfx) but it should be another Input Field for the payload. "1" means Relais on, "0" means off.
