  3. Advisory: put IOT devices on a separate LAN/vLAN for better security
40 Posts 11 Posters 6.9k Views 10 Watching
  • Thomas WeeksT
    Thomas WeeksT
    Thomas Weeks
    FBI recommendation or not.. Never trust closed source, non-human (IoT/embedded) systems on your human network. Take most any Chinese IP webcam or similar device and set it up on a sniffer (wireshark or tcpdump) and you'll see many of these devices "calling home" to China (C&C?) and even exfiltrating your WiFi passwords. Not cool.
    I've been running a near-edge IoT DMZ for years now. All Bluray players, VoIP terminals, and even network printers (if you set up a reverse established related rule) should be pushed outside your human network.
    T.Weeks
      A little more than one year ago the FBI recommended that everyone put their IOT devices onto a separate LAN because.... that cheap LED lightbulb with built-in wi-fi can be a penetration point for hackers to gain access to your home network.
      https://www.zdnet.com/article/fbi-recommends-that-you-keep-your-iot-devices-on-a-separate-network/
      I wasn't aware of the FBI advisory until now, so I'm a little behind in setting up a solution. A brute force solution would be to setup a completely separate LAN for IOT, but a lot of savvy people seem to utilize vlans for network isolation instead.
      My current plan: run pfsense on a VM to act as a firewall/router and replace my current dumb ethernet switches with a couple of inexpensive netgear GS108Ev3 managed ethernet switches to configure the vlan. Apparently I can also run a security program (perhaps Security Onion 2. Any better suggestions?) that will scan incoming packets and do protection and/or detection of suspicious packets , but I'm not sure what kind of latency that might introduce or even whether there's enough added protected to be worth the effort. I've read some people use the Ubiquiti Dream Machine as an all-in-one to do these things, but I checked the Dream Machine specs and found that it's running on just a not very powerful ARM CPU. So, I'm guessing the same kind of security packet inspection software inside a vm powered by a decent Intel/AMD CPU should be no worse in terms of performance. That way I'd be free to choose whatever the best security software might be rather than be locked into whatever software the Dream Machine developers happened to pick.
      Well, that's my plan. What hardware/software are you all using to isolate your IOT devices and provide good overall security?
      OldSurferDudeO
      OldSurferDudeO
      OldSurferDude
      @NeverDie You going to need an NTP Server. You can make one with an arduino nano, gps module and LAN module for under $20.
      • petterP
        petterP
        petter
        as noted before you should always move IoT stuff on a own VLAN, for security purposes you should always segregate traffic as much as possible and create different security zones.
        This will allow to control traffic flow with firewall rules and other systems such as IDS/IPS.
        The Firewall rules controls what traffic you allow between the zones, and an IDS will control and verify that traffic. They can scan the content of a data packet and look at the content of the message or recognize applications (such as SSH over port 80 as an example)
        back to your question, yes PfSense is a great "enterprise grade" firewall which gives you the toolset you need such as:
        • Firewall rules between zones/subnets
        • 2 different IDPS systems (Snort & Suricata)
        • DNS filtering & interception
        • RADIUS server for mac filtering, 802.1x EAP-TLS etc.
        • IGMP proxy and mDNS services for stuff like Sonos speakers etc.
        so the firewall gives you the ability to control and verify the traffic, however it offers no correlation, intelligence and management. for that you use something called a SIEM (Security Information Event Management) A SIEM will capture all the logs from your firewall, switches, endpoints, mirrored traffic etc. and do correlation and analysis.
        let say you have an outgoing HTTPS connection which you allowed in your firewall, (your IDS wont be able to analyze the content unless you decrypt the traffic which may break stuff). the only thing your IDS see is $&$#$&%^%*%$%^ a.k.a garbage. with a SIEM you can get open source threat intelligence etc. which will generate an alert IF a connection is made to a compromised IP/domain. A great example on a open source SIEM is Alienvault OSSIM. its an all-in-one and easy to install. Im running it as VM's in my system, together with PfSense (also VM) and some other firewalls.
        If you do choose to use VM's you should use ESXi as a hypervisor. this is free, very reliable and it is what most businesses are using in their server room or datacenters. on my PfSense VM I get about 800-900 Mb/s throughput with 1 IDS enabled, so if you set it up correctly you will get the performance you need.
        • E
          E
          evb
          @petter, When I read your reply, I notice that you are at home in this security matter.
          I think many readers, even on this technical forum, are already dropping out when reading so many jargon terms ;-)
          As I said, how far do you want to go for your home security?
          Already, with my 'simple' setup (see above), I am the only person at home who can fix it if there are 'internet' problems for the other family members.
          Once everything is set up, there is the regular maintenance in the form of updates. If updates have breaking changes, then there is extra work involved to reconfigure everything, etc.
          In these covid times I had to face the facts, what if I drop out, what will my family members do?
          I have several colleagues who also have security measures set up at home and are also SPOF or Single Point Of Failure....
          I have also thought about it for my MySensors network.
          Actually, that is quite a complicated setup for an outsider: sensors connect to a gateway, then, in my case, an MQTT server and then a home controller (Home Assistant), all running in VMs on the NAS.
          This is also where I am the SPOF....
          And the family members are already starting to rely on Home Assistant. The kids have named it Lexa ;-)
          So my advice, provide basic security, but don't overcomplicate it....
          • E evb
            @evb said in Advisory: put IOT devices on a separate LAN/vLAN for better security:
            I get what you mean, but it's nonetheless helpful to at least have a target to aim for. Ideally there would be something entirely turn-key that one could either just buy like an appliance (as Dream Machine tried to be) or else download and run, but AFAIK neither is available yet. The problem is that quality matters, and the consumer marketplace tends to attract junk, so I'm not sure it will ever get sorted out like it should be.
              @OldSurferDude said in Advisory: put IOT devices on a separate LAN/vLAN for better security:
              Is an NTP truly essential?
              monteM 1 Reply Last reply
              • petterP petter
                @petter said in Advisory: put IOT devices on a separate LAN/vLAN for better security:
                Is ESXi essential? Basedon @monte 's recommendation above, I just recently made the leap from ESXi to Proxmox, and so far so good, including the ability to migrate VM's from one physical host to another. A bit of a learning curve, but so far it seems rock solid. The only downside I've noticed compared to ESXi is that booting from a USB isn't recommended, but that's minor.
                Thomas WeeksT 1 Reply Last reply
                • Ikes 72000I
                  Ikes 72000I
                  Ikes 72000
                  I have 2 hp servers at home running esxi from an SD card, and it has been working fine for 2 years now.
                  I also tried proxmox for a few months, but encountered some stability issues and bugs.
                  Both solutions have pros and cons, but now I clearly prefer esxi.
                  Datastores and network are easier to manage and it is very easy to passtrought hardware to virtual machine. All the hard disks of my servers are managed by VM (Open Media Vault, Raid 5 software), without any problem.
                  I also use a Pfsense VM to manage all my networks, with different VLANs. It is very easy to manage VLAN under esxi with vSwitch.
                  In the next few weeks, I will be switching to OPNsense.
                  I chose this solution to mutualize the material resources, knowing that this solution can pose problems in certain cases.
                  • Ikes 72000I Ikes 72000
                    @Ikes-72000 said in Advisory: put IOT devices on a separate LAN/vLAN for better security:
                    Datastores ... are easier to manage
                    Yes, I can believe that: https://forum.mysensors.org/topic/11607/best-pc-platform-for-running-esxi-docker-at-home/55?_=1617658580974
                      monteM
                      monteM
                      monte
                      @NeverDie said in Advisory: put IOT devices on a separate LAN/vLAN for better security:
                      I use my pfsense box as NTP relay and pass it's port in firewall rules for unsecure subnet. I don't think it can be as much a problem in home networks.
                        Originally I thought: why not just read the BIOS clock on the motherboard? Well, I suppose that would work if there were only one physical PC. For coordinating backups and file date stamps among multiple PC's, I can see how an NTP server might be helpful. I'm still doubtful absolute accuracy on a home network matters for that, as long as all the PCs sync to the same time. Then again extreme accuracy would cover all possible edge cases, including ones I can't even imagine. I could just turn the GPS clock on and forget it...forever, with no NTP port on the gateway firewall. So, after thinking it through while writing this, I can finally see how for $20 it might be worthwhile after all. For a home network you'd only need one, and it would last a lifetime.
                          monteM
                          monteM
                          monte
                          wrote on last edited by monte
                          #21
                          @NeverDie I might be missing something. What is the problem exactly to get time from the internet? Sure you may not need precise sync, but why bother yourself with GPS clock, or setting clock by hand, if every OS can pull time from public NTP severs?
                          • monteM monte
                            #22
                            @monte Good question! I'm completely new to security hardening, and so I just assumed that the guy who posted the GPS NPT suggestion was aware of some threat. But if you aren't aware of one, then maybe there's no reason for it. :blush:
                              Thomas WeeksT
                              Thomas WeeksT
                              Thomas Weeks
                              @NeverDie I wouldn't.. check out this dedicated/embedded hardware.. used in many pieces of high end network appliances:
                              https://pcengines.ch/apu4d4.htm
                              T.Weeks
                              • Thomas WeeksT Thomas Weeks
                                T.Weeks
                                #24
                                @Thomas-Weeks said in Advisory: put IOT devices on a separate LAN/vLAN for better security:
                                T.Weeks
                                You wouldn't... what? The pcengine you linked appears to be a 4 port router. What should I be learning/realizing from or doing with that piece of information? Is it meant for creating vlans or is it meant for getting the time from an atomic clock somewhere on the internet? Or something else?
                                  T.Weeks
                                  monteM
                                  monteM
                                  monte
                                  @NeverDie that's not just a router it's a an x86 motherboard that you can install pfsense on. I think he meant, he wouldn't install pfsense in vm :)
                                  It is also fairly priced, I have one of their products before, but didn't check them recently, that's a great choice for self-built firewall.
                                  • mfalkviddM
                                    I have an apu4d4. Started with Esxi and Opnsense in a vm, but esxi crashed when I was running a lot of traffic in opnsens. Instead I installed Debian on it and run just a basic nftables firewall. I run Proxmox on it as well. Here are performance benchmarks:
                                      monteM
                                      monteM
                                      monte
                                      @mfalkvidd you installed proxmox on apu4d4? I wonder why opnsense is so much slower, can it be some misconfiguration? Did you try pfsense, I'd like to know if it is any faster.
                                      • monteM monte
                                        #28
                                        @monte yes I did.
                                        opnsense is so much slower because of BSD. pfsense has the same problem. I don't know the details, but it boils down to some important part of the BSD networking stack being single-threaded. It seems to be a well-known problem in the router world. I applied multiple tweaks to the BSD kernel, but they did not make any significant difference.
                                          @monte yes I did.
                                          monteM
                                          monteM
                                          monte
                                          @mfalkvidd one more question. Did you measure throughput WAN-LAN or LAN-LAN?
