  3. MY_GATEWAY_MQTT_CLIENT
4 Posts 2 Posters 782 Views 2 Watching
  • K
    K
    keithJ
    I am trying to setup a MQTT (client) ethernet gateway using an UNO R3, W5100 ethernet shield, and Adafruit RFM69HCW.
    The nodes are communicating well with gateway using #define MY_GATEWAY_W5100; but I am having no luck when i change it to #define MY_GATEWAY_MQTT_CLIENT, and am getting the following error :
    34779 GWT:TPC:IP=192.168.1.177
    35781 GWT:RMQ:CONNECTING...
    37785 !GWT:RMQ:FAIL
    //#define MY_GATEWAY_W5100
    // Set MQTT client id
    #define SD_SS_PIN (4)  // chip-select for SD card (normally unused, pull high!, see code!)
    // Enable these if your MQTT broker requires username/password
    // Enable MY_IP_ADDRESS here if you want a static p address (no DHCP)
    #define MY_IP_ADDRESS 192,168,1,177   // If this is disabled, DHCP is used to retrieve address
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 225
    //#define MY_PORT 1883
    I can connect to the MQTT broker (which is my openhab instance on 192.168.1.225)
    without username and password)
    I have read lots but become even more confused :/
    In addition to #define MY_GATEWAY_MQTT_CLIENT, what else should be set? How can i see if there is even an attempt to contact the broker?
    many thanks
    • K
      K
      keithJ
      OMG!!! i feel such a fool!
      Spent a good hour searching - and immediately after posting the above - realised the ethernet cable was unplugged!!!!
      facepalm!
      :blush:
      • K
        K
        keithJ
        actually it was longer than that :/
        • electrikE
          electrikE
          electrik
          This is a good tip to add to the build instructions. Check if you plugged the cable 😂
