  3. GWT:TPC:CONNECTING
GWT:TPC:CONNECTING
24 Posts 4 Posters 3.2k Views 2 Watching
  • D
    DenisJ
    Dear @mfalkvidd
    on the same ESP32 Gateway board I write a simply web server schetch from here.
    Then at the first reset the ESP32 take a new IP from DHCP server(router) without any problem.
    So I think that there is something wrong in my schetch... but what can be ???
    ...because this GTW was working for weeks until now.
    Just yesterday is stop working with always this error:
    323366 GWT:TPC:CONNECTING...
    324370 GWT:TPC:CONNECTING...
    325374 GWT:TPC:CONNECTING...
    326378 GWT:TPC:CONNECTING...
    327382 GWT:TPC:CONNECTING...
    328386 GWT:TPC:CONNECTING...
    329390 GWT:TPC:CONNECTING...
    330394 GWT:TPC:CONNECTING...
    The unique thinks that I have changed yesterday,
    it was the new PCB arrived for the sensor nodes:
    I have mount one of this and test it for about one hour in order to understand better antenna.
    It worked for some rounds and then boom... nothing arrived on my MQTT broker.
    So I connect the gateway at the USB in order to debug and I so that the GTW can not take the IP.
    I paste here my GTW schetch... maybe there is something that I can add in order to understand the problem.
     * Copyright (C) 2013-2019 Sensnology AB
     * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
     * Version 1.0 - tekka
     * The ESP32 gateway sends data received from sensors to the WiFi link.
     * Make sure to fill in your ssid and WiFi password below.
    denis:
    ESP32 pin out:
    https://circuits4you.com/2018/12/31/esp32-devkit-esp32-wroom-gpio-pinout/
    Radio wiring ESP32(GPIOxx): RFM69:
    | RFM69| ESP32 |
    | MOSI | 23    |
    | MISO | 19    |
    | SCK  | 18    |
    | NSS  | 5     |
    | DIO0 | 16    |
    #define MY_BAUD_RATE 115200
    // radio type (al meu ii RFM69HCW)
    #define MY_RFM69_NETWORKID (45)
    //#define MY_NODE_ID 39 // la gateway nu trebe node_id
    #define MY_RADIO_RFM69
    #define MY_IS_RFM69HW
    #define MY_RFM69_FREQUENCY RFM69_433MHZ
    #define MY_RFM69_NEW_DRIVER
    //astea is pt. puterea radioului
    #define MY_RFM69_ATC_TARGET_RSSI_DBM (-70) // target RSSI -70dBm
    #define MY_RFM69_MAX_POWER_LEVEL_DBM (20)   // max. TX power 10dBm = 10mW
    //#define MY_REPEATER_FEATURE // denis: what is this ?
    #define MY_GATEWAY_ESP32
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "MySensors-out"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "MySensors-in"
    // Set WIFI SSID and password
    #define MY_WIFI_SSID "DaVinci"
    #define MY_WIFI_PASSWORD "xxxxxxxxxxxxxx"
    // passed to the DHCP server if not static.
    #define MY_HOSTNAME "MySensorsGTW"
    // denis: If using static ip you can define Gateway and Subnet address as well
    //#define MY_IP_GATEWAY_ADDRESS 192,168,1,199
    // MQTT broker
    #define MY_MQTT_CLIENT_ID "MySensorsGTW"
    #define MY_MQTT_USER "usr"
    #define MY_MQTT_PASSWORD "pass"
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 168
    #define MY_PORT 1883
    #define   MY_SIGNAL_REPORT_ENABLED // denis: must undestand how is work
    // Flash leds on rx/tx/err (Led pin on ESP32)
    #define MY_DEFAULT_ERR_LED_PIN 2  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  2  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  2  // the PCB, on board LED
    // MySensors.h - must be after all #define
    Thanks a lot again
    Denis
    • D
      DenisJ
      wrote on last edited by DenisJ
      I just discover that if I comment the:
      //#define MY_GATEWAY_MQTT_CLIENT
      ...then the Gateway is connect to the WiFi router.
      29 MCO:BGN:INIT GW,CP=RPNGF---,FQ=240,REL=255,VER=2.3.2
      34 TSF:LRT:OK
      35 TSM:INIT
      36 TSF:WUR:MS=0
      38 TSM:INIT:TSP OK
      40 TSM:INIT:GW MODE
      42 TSM:READY:ID=0,PAR=0,DIS=0
      44 MCO:REG:NOT NEEDED
      1160 GWT:TIN:CONNECTING...
      2162 GWT:TIN:CONNECTING...
      3164 GWT:TIN:CONNECTING...
      3166 GWT:TIN:IP: 192.168.1.199
      3216 GWT:TIN:ETH OK
      And then I have a lot of:
      4139 GWT:TSA:ETH OK
      4234 GWT:TSA:ETH OK
      4307 GWT:TSA:ETH OK
      4400 GWT:TSA:ETH OK
      In my MQTT broker I can see the log:
      1619521529: New connection from 192.168.1.199 on port 1883.
      1619521529: Socket error on client <unknown>, disconnecting.
      What this mean please ? ...can be a problem with my MQTT broker ?
      It is work with all other topics around my home :-(
      Thanks again
      Denis
      • D
        DenisJ
        @DenisJ said in GWT:TPC:CONNECTING:
        I have try another time with commented out the define of MY_GATEWAY_MQTT_CLIENT.
        and I so that the GTW get the IP but after there is fail log on eth.
        Here is all log of connection with out MY_GATEWAY_MQTT_CLIENT
        34 TSF:LRT:OK
        35 TSM:INIT
        36 TSF:WUR:MS=0
        38 TSM:INIT:TSP OK
        40 TSM:INIT:GW MODE
        1164 GWT:TIN:CONNECTING...
        2166 GWT:TIN:CONNECTING...
        3168 GWT:TIN:CONNECTING...
        3170 GWT:TIN:IP: 192.168.1.199
        3279 !GWT:TIN:ETH FAIL
        3281 MCO:BGN:STP
        3283 MCO:BGN:INIT OK,TSP=1
        3289 !GWT:TSA:ETH FAIL
        3291 TSM:READY:NWD REQ
        3797 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
        3810 !GWT:TSA:ETH FAIL
        3815 !GWT:TSA:ETH FAIL
        !GWT:TIN:ETH FAIL is not parse, but I so in another page that is simply "ETH Connection failed"
        Anyone any idea on this please ?
        Thanks again
        Denis
        • D
          DenisJ
          I take out the MySensors official distro
          and I put on line the 2.4.0-alpha version.
          Now I have the eth connect but I have a lot (too much and too quick) "GWT:TSA:ETH OK" messages
          28 MCO:BGN:INIT GW,CP=RPNGF---,FQ=240,REL=0,VER=2.4.0-alpha
          34 TSF:LRT:OK
          35 TSM:INIT
          36 TSF:WUR:MS=0
          38 TSM:INIT:TSP OK
          40 TSM:INIT:GW MODE
          41 TSM:READY:ID=0,PAR=0,DIS=0
          1165 GWT:TIN:CONNECTING...
          2167 GWT:TIN:CONNECTING...
          3169 GWT:TIN:CONNECTING...
          3171 GWT:TIN:IP: 192.168.1.170
          3197 GWT:TIN:ETH OK
          3200 MCO:BGN:STP
          3202 MCO:BGN:INIT OK,TSP=1
          3205 TSM:READY:NWD REQ
          3217 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
          3238 GWT:TSA:ETH OK
          3254 GWT:TSA:ETH OK
          3282 GWT:TSA:ETH OK
          3303 GWT:TSA:ETH OK
          3319 GWT:TSA:ETH OK
          3341 GWT:TSA:ETH OK
          3368 GWT:TSA:ETH OK
          3388 GWT:TSA:ETH OK
          3410 GWT:TSA:ETH OK
          3461 GWT:TSA:ETH OK
          3495 GWT:TSA:ETH OK
          3524 GWT:TSA:ETH OK
          3541 GWT:TSA:ETH OK
          3556 GWT:TSA:ETH OK
          3576 GWT:TSA:ETH OK
          3592 GWT:TSA:ETH OK
          3613 GWT:TSA:ETH OK
          3632 GWT:TSA:ETH OK
          Any help with this messages ?
          Thanks again
          Denis
          • D
            DenisJ
            I understand that I forget the "#define MY_GATEWAY_MQTT_CLIENT" was commented out.
            So when I uncommented it, all return back with the:
            169206 GWT:TPC:CONNECTING...
            170210 GWT:TPC:CONNECTING...
            171214 GWT:TPC:CONNECTING...
            172218 GWT:TPC:CONNECTING...
            173222 GWT:TPC:CONNECTING...
            174226 GWT:TPC:CONNECTING...
            So if I take out all the MQTT story, the GTW is connect to WiFi and I can ping it.
            When I put back the MQTT rows the GTW is not connected and I always have the GWT:TPC:CONNECTING
            I try with another ESP32, I try with another MQTT broker... I don't know anymore what to try :-(
            A little help will be so appreciated
            Thanks again
            Denis
              smilvert
              @DenisJ I have the same problem. Works with
              but with
              it dosen't. But when I changed the delay to 3000
              bool gatewayTransportConnect(void)
              #if defined(MY_GATEWAY_ESP8266) || defined(MY_GATEWAY_ESP32)
              	if (WiFi.status() != WL_CONNECTED) {
              		GATEWAY_DEBUG(PSTR("GWT:TPC:CONNECTING...\n"));
              		delay(3000); // Was 1000
              		return false;
              	GATEWAY_DEBUG(PSTR("GWT:TPC:IP=%s\n"), WiFi.localIP().toString().c_str());
              in MyGatewayTransportMQTTClient.cpp then it started to work! :)
              • D
                DenisJ
                @smilvert said in GWT:TPC:CONNECTING:
                Thanks a lot @smilvert ...for me it's a big step forward, cause is 2 days that I'm so angry with this connections
                I don't understand why I test a lot of Arduino schetch that use ETH+MQTT and was work all,
                but MySensors use something that is not work always...
                Now my GTW is connect (eth and mqtt) but then it goes in error:
                E (46) psram: PSRAM ID read error: 0xffffffff
                32 MCO:BGN:INIT GW,CP=RPNGF---,FQ=240,REL=0,VER=2.4.0-alpha
                38 TSF:LRT:OK
                39 TSM:INIT
                40 TSF:WUR:MS=0
                42 TSM:INIT:TSP OK
                44 TSM:INIT:GW MODE
                46 TSM:READY:ID=0,PAR=0,DIS=0
                49 MCO:REG:NOT NEEDED
                171 GWT:TPC:CONNECTING...
                3173 MCO:BGN:STP
                3175 MCO:BGN:INIT OK,TSP=1
                3177 GWT:TPC:IP=192.168.1.170
                3180 GWT:RMQ:CONNECTING...
                3234 GWT:RMQ:OK
                3235 GWT:TPS:TOPIC=MySensors-out/0/255/0/0/18,MSG SENT
                Stack smashing protect failure!
                abort() was called at PC 0x401353af on core 1
                ELF file SHA256: 0000000000000000
                Backtrace: 0x4008c6a8:0x3ffb1eb0 0x4008c921:0x3ffb1ed0 0x401353af:0x3ffb1ef0 0x400d2a56:0x3ffb1f10 0x400d2a91:0x3ffb1f50 0x400d2cb3:0x3ffb1f70 0x400d32f6:0x3ffb1f90 0x400d3429:0x3ffb1fb0 0x4008d926:0x3ffb1fd0
                Rebooting...
                ets Jun  8 2016 00:22:57
                rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
                configsip: 0, SPIWP:0xee
                clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
                mode:DIO, clock div:1
                load:0x3fff0018,len:4
                load:0x3fff001c,len:1216
                ho 0 tail 12 room 4
                load:0x40078000,len:10944
                load:0x40080400,len:6388
                entry 0x400806b4
                37 TSF:LRT:OK
                39 TSM:INIT
                40 TSF:WUR:MS=0
                42 TSM:INIT:TSP OK
                44 TSM:INIT:GW MODE
                48 MCO:REG:NOT NEEDED
                168 GWT:TPC:CONNECTING...
                3170 MCO:BGN:STP
                3172 MCO:BGN:INIT OK,TSP=1
                3174 GWT:TPC:IP=192.168.1.170
                3177 GWT:RMQ:CONNECTING...
                11960 GWT:RMQ:OK
                11962 GWT:TPS:TOPIC=MySensors-out/0/255/0/0/18,MSG SENT
                Do you think is a hardware problem ?
                Thank you so much for the help
                Denis
                  smilvert
                  No I have no idea. For me it seems to work.
                  Currently I don't have any sensors conncted so its hard to see if it works.
                  • electrikE
                    electrikE
                    electrik
                    Do you have the latest ESP32 framework installed?
                    • D
                      DenisJ
                      @electrik said in GWT:TPC:CONNECTING:
                      I use Ardiono IDE and I have Espressif Systems version 1.0.6 installed on boards manager.
                      It tell me that is the last.
                      Do I must install other please ?
                      Thanks a lot
                      Denis
                      • electrikE
                        electrikE
                        electrik
                        That should be okay. Maybe use the mysensors stable release 2.3.2?
                        • D
                          DenisJ
                          Thanks a lot @electrik ... but I was on stable release when the problem has began.
                          For this reason I download the DEV version, but I have the same problem.
                          There is surely something stupid think that is wrong, but I don't know what is it.
                          This gateway was working for more than a month.
                          Thanks again
                          Denis
                          • electrikE
                            electrikE
                            electrik
                            And if you change the lines like below now?
                            return false;
                            • D
                              DenisJ
                              I changed it:
                              		delay(3000); // denis: era 1000 dar l am schimbat pt. ca nu se lega la MQTT
                              		return false;
                              #elif defined(MY_GATEWAY_LINUX)
                              #if defined(MY_IP_ADDRESS)
                              	_MQTT_ethClient.bind(_MQTT_clientIp);
                              #endif /* End of MY_IP_ADDRESS */
                              #elif defined(MY_GATEWAY_TINYGSM)
                              	GATEWAY_DEBUG(PSTR("GWT:TPC:IP=%s\n"), modem.getLocalIP().c_str());
                              	Ethernet.begin(_MQTT_clientMAC, _MQTT_clientIp);
                              #else /* Else part of MY_IP_ADDRESS */
                              	// Get IP address from DHCP
                              	if (!Ethernet.begin(_MQTT_clientMAC)) {
                              		GATEWAY_DEBUG(PSTR("!GWT:TPC:DHCP FAIL\n"));
                              		_MQTT_connecting = false;
                              		return false;
                              	GATEWAY_DEBUG(PSTR("GWT:TPC:IP=%" PRIu8 ".%" PRIu8 ".%" PRIu8 ".%" PRIu8 "\n"),
                              	              Ethernet.localIP()[0],
                              	              Ethernet.localIP()[1], Ethernet.localIP()[2], Ethernet.localIP()[3]);
                              	// give the Ethernet interface a second to initialize
                              	delay(1000);
                              	return true;
                              But in this case I get this error:
                              29 MCO:BGN:INIT GW,CP=RPNGF---,FQ=240,REL=0,VER=2.4.0-alpha
                              34 TSF:LRT:OK
                              35 TSM:INIT
                              37 TSF:WUR:MS=0
                              39 TSM:INIT:TSP OK
                              40 TSM:INIT:GW MODE
                              45 MCO:REG:NOT NEEDED
                              159 GWT:TPC:CONNECTING...
                              3162 MCO:BGN:STP
                              3164 MCO:BGN:INIT OK,TSP=1
                              3166 GWT:TPC:IP=192.168.1.170
                              3169 GWT:RMQ:CONNECTING...
                              3371 GWT:RMQ:OK
                              3372 GWT:TPS:TOPIC=MySensors-out/0/255/0/0/18,MSG SENT
                              abort() was called at PC 0x40134cef on core 1
                              Backtrace: 0x40088620:0x3ffb1eb0 0x4008889d:0x3ffb1ed0 0x40134cef:0x3ffb1ef0 0x400d27e6:0x3ffb1f10 0x400d281e:0x3ffb1f50 0x400d2a23:0x3ffb1f70 0x400d2ff4:0x3ffb1f90 0x400d3105:0x3ffb1fb0 0x400898ae:0x3ffb1fd0
                              Rebooting...
                              ho 0 tail 12 room 4
                              entry 0x400806b4
                              34 TSF:LRT:OK
                              36 TSM:INIT
                              37 TSF:WUR:MS=0
                              39 TSM:INIT:TSP OK
                              40 TSM:INIT:GW MODE
                              164 GWT:TPC:CONNECTING...
                              3166 MCO:BGN:STP
                              3168 MCO:BGN:INIT OK,TSP=1
                              3170 GWT:TPC:IP=192.168.1.170
                              3173 GWT:RMQ:CONNECTING...
                              6058 GWT:RMQ:OK
                              6059 GWT:TPS:TOPIC=MySensors-out/0/255/0/0/18,MSG SENT
                              ...from here it goes in LOOP
                              I'm near to become creasy :-(
                              Thanks again
                              Denis
                              • electrikE
                                electrikE
                                electrik
                                Yes, but now use the 2.3.2 release with this modification
                                • D
                                  DenisJ
                                  Yes... good idea :-)
                                  I'll try now.
                                  Thanks a lot
                                  Denis
                                  • D
                                    DenisJ
                                    2.3.2 release
                                    I can't believe... IT'S WOOOOOOORK !!!
                                    Thanks a lot @electrik !!!
                                    I don't know why, and I don't understand... but with 2.3.2 release it's work if I make that modify in the MyGatewayTransportMQTTClient.cpp file.
                                    Also I don't like that I must modify that time... but for now it's ok.
                                    Also I don't understand why 2 days ago it's change same hardware and same soft,
                                    from work to no work (I don't know haw to tell this in english) :-)
                                    Thanks so much again :-)
                                    Denis
                                    • electrikE
                                      electrikE
                                      electrik
                                      Good to hear! Perhaps a GitHub issue should be raised for these points...
                                      • D
                                        DenisJ
                                        Well... if the DEV version is not work even if I make that change... I don't know.
                                        I thinks this part is too sensibile. I'm not a programmer, but I think that this important part of communication must be renovate.
                                        Tomorrow I can return to my node sensors test.
                                        Thanks a lot all for the help.
                                        Denis
                                          smilvert
                                          @electrik A ticket is raised quite long time ago, https://github.com/mysensors/MySensors/issues/1376
