  3. GWT:TPC:CONNECTING
GWT:TPC:CONNECTING
24 Posts 4 Posters 3.3k Views 2 Watching
  • D
    DenisJ
    wrote on last edited by DenisJ
    I just discover that if I comment the:
    //#define MY_GATEWAY_MQTT_CLIENT
    ...then the Gateway is connect to the WiFi router.
    29 MCO:BGN:INIT GW,CP=RPNGF---,FQ=240,REL=255,VER=2.3.2
    34 TSF:LRT:OK
    35 TSM:INIT
    36 TSF:WUR:MS=0
    38 TSM:INIT:TSP OK
    40 TSM:INIT:GW MODE
    42 TSM:READY:ID=0,PAR=0,DIS=0
    44 MCO:REG:NOT NEEDED
    1160 GWT:TIN:CONNECTING...
    2162 GWT:TIN:CONNECTING...
    3164 GWT:TIN:CONNECTING...
    3166 GWT:TIN:IP: 192.168.1.199
    3216 GWT:TIN:ETH OK
    And then I have a lot of:
    4139 GWT:TSA:ETH OK
    4234 GWT:TSA:ETH OK
    4307 GWT:TSA:ETH OK
    4400 GWT:TSA:ETH OK
    In my MQTT broker I can see the log:
    1619521529: New connection from 192.168.1.199 on port 1883.
    1619521529: Socket error on client <unknown>, disconnecting.
    What this mean please ? ...can be a problem with my MQTT broker ?
    It is work with all other topics around my home :-(
    Thanks again
    Denis
    • D
      DenisJ
      @DenisJ said in GWT:TPC:CONNECTING:
      I have try another time with commented out the define of MY_GATEWAY_MQTT_CLIENT.
      and I so that the GTW get the IP but after there is fail log on eth.
      Here is all log of connection with out MY_GATEWAY_MQTT_CLIENT
      34 TSF:LRT:OK
      35 TSM:INIT
      36 TSF:WUR:MS=0
      38 TSM:INIT:TSP OK
      40 TSM:INIT:GW MODE
      1164 GWT:TIN:CONNECTING...
      2166 GWT:TIN:CONNECTING...
      3168 GWT:TIN:CONNECTING...
      3170 GWT:TIN:IP: 192.168.1.199
      3279 !GWT:TIN:ETH FAIL
      3281 MCO:BGN:STP
      3283 MCO:BGN:INIT OK,TSP=1
      3289 !GWT:TSA:ETH FAIL
      3291 TSM:READY:NWD REQ
      3797 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
      3810 !GWT:TSA:ETH FAIL
      3815 !GWT:TSA:ETH FAIL
      !GWT:TIN:ETH FAIL is not parse, but I so in another page that is simply "ETH Connection failed"
      Anyone any idea on this please ?
      Thanks again
      Denis
      • D
        DenisJ
        I take out the MySensors official distro
        and I put on line the 2.4.0-alpha version.
        Now I have the eth connect but I have a lot (too much and too quick) "GWT:TSA:ETH OK" messages
        28 MCO:BGN:INIT GW,CP=RPNGF---,FQ=240,REL=0,VER=2.4.0-alpha
        34 TSF:LRT:OK
        35 TSM:INIT
        36 TSF:WUR:MS=0
        38 TSM:INIT:TSP OK
        40 TSM:INIT:GW MODE
        41 TSM:READY:ID=0,PAR=0,DIS=0
        1165 GWT:TIN:CONNECTING...
        2167 GWT:TIN:CONNECTING...
        3169 GWT:TIN:CONNECTING...
        3171 GWT:TIN:IP: 192.168.1.170
        3197 GWT:TIN:ETH OK
        3200 MCO:BGN:STP
        3202 MCO:BGN:INIT OK,TSP=1
        3205 TSM:READY:NWD REQ
        3217 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
        3238 GWT:TSA:ETH OK
        3254 GWT:TSA:ETH OK
        3282 GWT:TSA:ETH OK
        3303 GWT:TSA:ETH OK
        3319 GWT:TSA:ETH OK
        3341 GWT:TSA:ETH OK
        3368 GWT:TSA:ETH OK
        3388 GWT:TSA:ETH OK
        3410 GWT:TSA:ETH OK
        3461 GWT:TSA:ETH OK
        3495 GWT:TSA:ETH OK
        3524 GWT:TSA:ETH OK
        3541 GWT:TSA:ETH OK
        3556 GWT:TSA:ETH OK
        3576 GWT:TSA:ETH OK
        3592 GWT:TSA:ETH OK
        3613 GWT:TSA:ETH OK
        3632 GWT:TSA:ETH OK
        Any help with this messages ?
        Thanks again
        Denis
        • D
          DenisJ
          I understand that I forget the "#define MY_GATEWAY_MQTT_CLIENT" was commented out.
          So when I uncommented it, all return back with the:
          169206 GWT:TPC:CONNECTING...
          170210 GWT:TPC:CONNECTING...
          171214 GWT:TPC:CONNECTING...
          172218 GWT:TPC:CONNECTING...
          173222 GWT:TPC:CONNECTING...
          174226 GWT:TPC:CONNECTING...
          So if I take out all the MQTT story, the GTW is connect to WiFi and I can ping it.
          When I put back the MQTT rows the GTW is not connected and I always have the GWT:TPC:CONNECTING
          I try with another ESP32, I try with another MQTT broker... I don't know anymore what to try :-(
          A little help will be so appreciated
          Thanks again
          Denis
            smilvert
            @DenisJ I have the same problem. Works with
            #define MY_GATEWAY_ESP32
            but with
            it dosen't. But when I changed the delay to 3000
            bool gatewayTransportConnect(void)
            #if defined(MY_GATEWAY_ESP8266) || defined(MY_GATEWAY_ESP32)
            	if (WiFi.status() != WL_CONNECTED) {
            		GATEWAY_DEBUG(PSTR("GWT:TPC:CONNECTING...\n"));
            		delay(3000); // Was 1000
            		return false;
            	GATEWAY_DEBUG(PSTR("GWT:TPC:IP=%s\n"), WiFi.localIP().toString().c_str());
            in MyGatewayTransportMQTTClient.cpp then it started to work! :)
            • D
              DenisJ
              @smilvert said in GWT:TPC:CONNECTING:
              Thanks a lot @smilvert ...for me it's a big step forward, cause is 2 days that I'm so angry with this connections
              I don't understand why I test a lot of Arduino schetch that use ETH+MQTT and was work all,
              but MySensors use something that is not work always...
              Now my GTW is connect (eth and mqtt) but then it goes in error:
              E (46) psram: PSRAM ID read error: 0xffffffff
              32 MCO:BGN:INIT GW,CP=RPNGF---,FQ=240,REL=0,VER=2.4.0-alpha
              38 TSF:LRT:OK
              39 TSM:INIT
              40 TSF:WUR:MS=0
              42 TSM:INIT:TSP OK
              44 TSM:INIT:GW MODE
              46 TSM:READY:ID=0,PAR=0,DIS=0
              49 MCO:REG:NOT NEEDED
              171 GWT:TPC:CONNECTING...
              3173 MCO:BGN:STP
              3175 MCO:BGN:INIT OK,TSP=1
              3177 GWT:TPC:IP=192.168.1.170
              3180 GWT:RMQ:CONNECTING...
              3234 GWT:RMQ:OK
              3235 GWT:TPS:TOPIC=MySensors-out/0/255/0/0/18,MSG SENT
              Stack smashing protect failure!
              abort() was called at PC 0x401353af on core 1
              ELF file SHA256: 0000000000000000
              Backtrace: 0x4008c6a8:0x3ffb1eb0 0x4008c921:0x3ffb1ed0 0x401353af:0x3ffb1ef0 0x400d2a56:0x3ffb1f10 0x400d2a91:0x3ffb1f50 0x400d2cb3:0x3ffb1f70 0x400d32f6:0x3ffb1f90 0x400d3429:0x3ffb1fb0 0x4008d926:0x3ffb1fd0
              Rebooting...
              ets Jun  8 2016 00:22:57
              rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
              configsip: 0, SPIWP:0xee
              clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
              mode:DIO, clock div:1
              load:0x3fff0018,len:4
              load:0x3fff001c,len:1216
              ho 0 tail 12 room 4
              load:0x40078000,len:10944
              load:0x40080400,len:6388
              entry 0x400806b4
              37 TSF:LRT:OK
              39 TSM:INIT
              40 TSF:WUR:MS=0
              42 TSM:INIT:TSP OK
              44 TSM:INIT:GW MODE
              48 MCO:REG:NOT NEEDED
              168 GWT:TPC:CONNECTING...
              3170 MCO:BGN:STP
              3172 MCO:BGN:INIT OK,TSP=1
              3174 GWT:TPC:IP=192.168.1.170
              3177 GWT:RMQ:CONNECTING...
              11960 GWT:RMQ:OK
              11962 GWT:TPS:TOPIC=MySensors-out/0/255/0/0/18,MSG SENT
              Do you think is a hardware problem ?
              Thank you so much for the help
              Denis
                smilvert
                No I have no idea. For me it seems to work.
                Currently I don't have any sensors conncted so its hard to see if it works.
                • electrikE
                  electrikE
                  electrik
                  Do you have the latest ESP32 framework installed?
                  • D
                    DenisJ
                    @electrik said in GWT:TPC:CONNECTING:
                    I use Ardiono IDE and I have Espressif Systems version 1.0.6 installed on boards manager.
                    It tell me that is the last.
                    Do I must install other please ?
                    Thanks a lot
                    Denis
                    • electrikE
                      electrikE
                      electrik
                      That should be okay. Maybe use the mysensors stable release 2.3.2?
                      • D
                        DenisJ
                        Thanks a lot @electrik ... but I was on stable release when the problem has began.
                        For this reason I download the DEV version, but I have the same problem.
                        There is surely something stupid think that is wrong, but I don't know what is it.
                        This gateway was working for more than a month.
                        Thanks again
                        Denis
                        • electrikE
                          electrikE
                          electrik
                          And if you change the lines like below now?
                          return false;
                          • D
                            DenisJ
                            I changed it:
                            		delay(3000); // denis: era 1000 dar l am schimbat pt. ca nu se lega la MQTT
                            		return false;
                            #elif defined(MY_GATEWAY_LINUX)
                            #if defined(MY_IP_ADDRESS)
                            	_MQTT_ethClient.bind(_MQTT_clientIp);
                            #endif /* End of MY_IP_ADDRESS */
                            #elif defined(MY_GATEWAY_TINYGSM)
                            	GATEWAY_DEBUG(PSTR("GWT:TPC:IP=%s\n"), modem.getLocalIP().c_str());
                            	Ethernet.begin(_MQTT_clientMAC, _MQTT_clientIp);
                            #else /* Else part of MY_IP_ADDRESS */
                            	// Get IP address from DHCP
                            	if (!Ethernet.begin(_MQTT_clientMAC)) {
                            		GATEWAY_DEBUG(PSTR("!GWT:TPC:DHCP FAIL\n"));
                            		_MQTT_connecting = false;
                            		return false;
                            	GATEWAY_DEBUG(PSTR("GWT:TPC:IP=%" PRIu8 ".%" PRIu8 ".%" PRIu8 ".%" PRIu8 "\n"),
                            	              Ethernet.localIP()[0],
                            	              Ethernet.localIP()[1], Ethernet.localIP()[2], Ethernet.localIP()[3]);
                            	// give the Ethernet interface a second to initialize
                            	delay(1000);
                            	return true;
                            But in this case I get this error:
                            29 MCO:BGN:INIT GW,CP=RPNGF---,FQ=240,REL=0,VER=2.4.0-alpha
                            34 TSF:LRT:OK
                            35 TSM:INIT
                            37 TSF:WUR:MS=0
                            39 TSM:INIT:TSP OK
                            40 TSM:INIT:GW MODE
                            45 MCO:REG:NOT NEEDED
                            159 GWT:TPC:CONNECTING...
                            3162 MCO:BGN:STP
                            3164 MCO:BGN:INIT OK,TSP=1
                            3166 GWT:TPC:IP=192.168.1.170
                            3169 GWT:RMQ:CONNECTING...
                            3371 GWT:RMQ:OK
                            3372 GWT:TPS:TOPIC=MySensors-out/0/255/0/0/18,MSG SENT
                            abort() was called at PC 0x40134cef on core 1
                            Backtrace: 0x40088620:0x3ffb1eb0 0x4008889d:0x3ffb1ed0 0x40134cef:0x3ffb1ef0 0x400d27e6:0x3ffb1f10 0x400d281e:0x3ffb1f50 0x400d2a23:0x3ffb1f70 0x400d2ff4:0x3ffb1f90 0x400d3105:0x3ffb1fb0 0x400898ae:0x3ffb1fd0
                            Rebooting...
                            ho 0 tail 12 room 4
                            entry 0x400806b4
                            34 TSF:LRT:OK
                            36 TSM:INIT
                            37 TSF:WUR:MS=0
                            39 TSM:INIT:TSP OK
                            40 TSM:INIT:GW MODE
                            164 GWT:TPC:CONNECTING...
                            3166 MCO:BGN:STP
                            3168 MCO:BGN:INIT OK,TSP=1
                            3170 GWT:TPC:IP=192.168.1.170
                            3173 GWT:RMQ:CONNECTING...
                            6058 GWT:RMQ:OK
                            6059 GWT:TPS:TOPIC=MySensors-out/0/255/0/0/18,MSG SENT
                            ...from here it goes in LOOP
                            I'm near to become creasy :-(
                            Thanks again
                            Denis
                            • electrikE
                              electrikE
                              electrik
                              Yes, but now use the 2.3.2 release with this modification
                              • D
                                DenisJ
                                Yes... good idea :-)
                                I'll try now.
                                Thanks a lot
                                Denis
                                • D
                                  DenisJ
                                  2.3.2 release
                                  I can't believe... IT'S WOOOOOOORK !!!
                                  Thanks a lot @electrik !!!
                                  I don't know why, and I don't understand... but with 2.3.2 release it's work if I make that modify in the MyGatewayTransportMQTTClient.cpp file.
                                  Also I don't like that I must modify that time... but for now it's ok.
                                  Also I don't understand why 2 days ago it's change same hardware and same soft,
                                  from work to no work (I don't know haw to tell this in english) :-)
                                  Thanks so much again :-)
                                  Denis
                                  • electrikE
                                    electrikE
                                    electrik
                                    Good to hear! Perhaps a GitHub issue should be raised for these points...
                                    • D
                                      DenisJ
                                      Well... if the DEV version is not work even if I make that change... I don't know.
                                      I thinks this part is too sensibile. I'm not a programmer, but I think that this important part of communication must be renovate.
                                      Tomorrow I can return to my node sensors test.
                                      Thanks a lot all for the help.
                                      Denis
                                        smilvert
                                        @electrik A ticket is raised quite long time ago, https://github.com/mysensors/MySensors/issues/1376
                                        • D
                                          DenisJ
                                          Thanks a lot... I put my case there also, maybe can help.
                                          That gui use same ESP32 DevKit V1 like me.
                                          Strange that I didn't fount that page in this 2 days of research.
                                          Thanks a lot
                                          Denis
