  3. Can I use MySensors library to have one Sensor Transmitter and one Receiver without any Gateway
node to node and no gateway
4 Posts 3 Posters 663 Views 3 Watching
  • RagoTubeR Offline
    RagoTubeR Offline
    RagoTube
    I am 74 years old retired Telecom Engineer and new to MySensors forum. I like the MySensors Battery node for Soil Monitoring and using it with ESP8266 WiFi gateway. I also want to have a Simple setup just One Transmitter and One Receiver without any Gateway to monitor Soil Moisture (and Node's Battery) of my Green House. Any pointer will be greatly appreciated.
    • RagoTubeR RagoTube
      Welcome to the forum @RagoTube
      Yes, it can be done by using node to node communication and setting MY_PARENT_NODE_IS_STATIC and MY_PARENT_NODE_ID.
      But it might be easier to use the plain radiohead library, since you would not need most features in MySensors.
      RagoTubeR 1 Reply Last reply
        RagoTubeR Offline
        RagoTubeR Offline
        RagoTube
        @mfalkvidd Thank you for your immediate solution. I will try it now.
        • OldSurferDudeO Offline
          OldSurferDude
          One little project and you're hooked! You know you're going to want another sensor in the yard, so consider a gateway running MQTT (called a broker). Once you have that, it's really easy to add more sensors.
          But if you're really strong willed an will only be using two devices ever, you might look at https://nrf24.github.io/RF24/index.html. You can get an Arduino Nano and an nRF24 radio for about $3.50 from Aliexpress (downside: delivery takes ~2 months, so get 10 each.)
          MySensors Library can do this, too, but I find it a little bloated.
          Personal note: I'm 70, retired engineer, and have only four projects going right now.
