  3. Home Assistant
  4. Arduino+M5100 cannot connect to LAN
22 Posts 3 Posters 2.3k Views 2 Watching
  • P Offline
    P Offline
    PZDPRO
    Dears,
    I use Arduino Mega and M5100 ethernet Shield. I put prepared sketch but it won't connect to my local LAN. Could you please check my sketch?
    code_text/*
     * Copyright (C) 2013-2019 Sensnology AB
     * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
     * Version 1.0 - Henrik Ekblad
     * Contribution by a-lurker and Anticimex
     * LED purposes:
     * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
     * - ERR (red) - fast blink on error during transmission error or receive crc error
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
    #define MY_IP_ADDRESS 192,168,0,201
    #define MY_PORT 5003
    //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
    // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    #define MY_REPEATER_FEATURE
    #define RELAY_LA_01  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_LA_02  5
    #define RELAY_LA_03  6
    #define RELAY_LA_04  7
    #define RELAY_LA_05  8
    #define RELAY_LA_06  9
    #define RELAY_LA_07  10
    #define RELAY_LA_08  11
    #define RELAY_LA_09  12
    #define RELAY_LA_10  13
    #define NUMBER_OF_RELAYS 10 // Total number of attached relays
    #define LA_01 A1
    #define LA_02 A2
    #define LA_03 A3
    #define LA_04 A4
    #define LA_05 A5
    #define LA_06 A6
    #define LA_07 A7
    #define LA_08 A8
    #define LA_09 A9
    #define LA_10 A10
    void before() {
      for (int sensor=1, pin=RELAY_LA_01; sensor<=NUMBER_OF_RELAYS;sensor++, pin++) {
        pinMode(pin, OUTPUT);
    Bounce debouncer = Bounce();
    Bounce debouncer2 = Bounce();
    Bounce debouncer3 = Bounce();
    Bounce debouncer4 = Bounce();
    Bounce debouncer5 = Bounce();
    Bounce debouncer6 = Bounce();
    Bounce debouncer7 = Bounce();
    Bounce debouncer8 = Bounce();
    Bounce debouncer9 = Bounce();
    Bounce debouncer10 = Bounce();
      delay(10000);
       // Setup the button.
      pinMode(LA_01, INPUT_PULLUP);
      pinMode(LA_02, INPUT_PULLUP);
      pinMode(LA_03, INPUT_PULLUP);
      pinMode(LA_04, INPUT_PULLUP);
      pinMode(LA_05, INPUT_PULLUP);
      pinMode(LA_06, INPUT_PULLUP);
      pinMode(LA_07, INPUT_PULLUP);
      pinMode(LA_08, INPUT_PULLUP);
      pinMode(LA_09, INPUT_PULLUP);
      pinMode(LA_10, INPUT_PULLUP);
      // After setting up the button, setup debouncer.
      debouncer.attach(LA_01);
      debouncer.interval(5);
      debouncer2.attach(LA_02);
      debouncer2.interval(5);
      debouncer3.attach(LA_03);
      debouncer3.interval(5);
      debouncer4.attach(LA_04);
      debouncer4.interval(5);
      debouncer5.attach(LA_05);
      debouncer5.interval(5);
      debouncer6.attach(LA_06);
      debouncer6.interval(5);
      debouncer7.attach(LA_07);
      debouncer7.interval(5);
      debouncer8.attach(LA_08);
      debouncer8.interval(5);
      debouncer9.attach(LA_09);
      debouncer9.interval(5);
      debouncer10.attach(LA_10);
      debouncer10.interval(5);
      //presentation();
      sendSketchInfo("Relay", "1.0");
        present(sensor, S_LIGHT);
    MyMessage msg(1, V_LIGHT);
    MyMessage msg2(2, V_LIGHT);
    MyMessage msg3(3, V_LIGHT);
    MyMessage msg4(4, V_LIGHT);
    MyMessage msg5(5, V_LIGHT);
    MyMessage msg6(6, V_LIGHT);
    MyMessage msg7(7, V_LIGHT);
    MyMessage msg8(8, V_LIGHT);
    MyMessage msg9(9, V_LIGHT);
    MyMessage msg10(10, V_LIGHT);
      if (debouncer.update()) {
        // Get the update value.
        int value = debouncer.read();
        // Send in the new value.
        if(value == LOW){
             saveState(1, !loadState(1));
             digitalWrite(RELAY_LA_01, loadState(1)?RELAY_ON:RELAY_OFF);
             send(msg.set(loadState(1)));
      if (debouncer2.update()) {
        if(value2 == LOW){
             saveState(2, !loadState(2));
             digitalWrite(RELAY_LA_02, loadState(2)?RELAY_ON:RELAY_OFF);
             send(msg2.set(loadState(2)));
      if (debouncer3.update()) {
        int value3 = debouncer3.read();
        if(value3 == LOW){
             saveState(3, !loadState(3));
             digitalWrite(RELAY_LA_03, loadState(3)?RELAY_ON:RELAY_OFF);
             send(msg3.set(loadState(3)));
      if (debouncer4.update()) {
        int value4 = debouncer4.read();
        if(value4 == LOW){
             saveState(4, !loadState(4));
             digitalWrite(RELAY_LA_04, loadState(4)?RELAY_ON:RELAY_OFF);
             send(msg4.set(loadState(4)));
      if (debouncer5.update()) {
        int value5 = debouncer5.read();
        if(value5 == LOW){
             saveState(5, !loadState(5));
             digitalWrite(RELAY_LA_05, loadState(5)?RELAY_ON:RELAY_OFF);
             send(msg5.set(loadState(5)));
      if (debouncer6.update()) {
        int value6 = debouncer6.read();
        if(value6 == LOW){
             saveState(6, !loadState(6));
             digitalWrite(RELAY_LA_06, loadState(6)?RELAY_ON:RELAY_OFF);
             send(msg6.set(loadState(6)));
      if (debouncer7.update()) {
        int value7 = debouncer7.read();
        if(value7 == LOW){
             saveState(7, !loadState(7));
             digitalWrite(RELAY_LA_07, loadState(7)?RELAY_ON:RELAY_OFF);
             send(msg7.set(loadState(7)));
      if (debouncer8.update()) {
        int value8 = debouncer8.read();
        if(value8 == LOW){
             saveState(8, !loadState(8));
             digitalWrite(RELAY_LA_08, loadState(8)?RELAY_ON:RELAY_OFF);
             send(msg8.set(loadState(8)));
      if (debouncer9.update()) {
        int value9 = debouncer9.read();
        if(value9 == LOW){
             saveState(9, !loadState(9));
             digitalWrite(RELAY_LA_09, loadState(9)?RELAY_ON:RELAY_OFF);
             send(msg9.set(loadState(9)));
      if (debouncer10.update()) {
        int value10 = debouncer10.read();
        if(value10 == LOW){
             saveState(10, !loadState(10));
             digitalWrite(RELAY_LA_10, loadState(10)?RELAY_ON:RELAY_OFF);
             send(msg10.set(loadState(10)));
      if (message.type==V_LIGHT) {
         // Change relay state
         digitalWrite(message.sensor-1+RELAY_LA_01, message.getBool()?RELAY_ON:RELAY_OFF);
         // Store state in eeprom
    • mfalkviddM Offline
      Welcome to the forum @PZDPRO !
      What does the debug output from the gateway say?
      If you haven't already, see https://forum.mysensors.org/topic/666/read-this-first-it-could-save-you-a-lot-of-time/ for the most common problems and how to troubleshoot them efficiently.
      • P Offline
        P Offline
        PZDPRO
        Hello Mfalkvidd!
        Thank you for your post. I checked your link and can't find any answer for my problem.
        Here is what i get:
          Did you read section #2:3 ?
          P 1 Reply Last reply
            P Offline
            P Offline
            PZDPRO
            @mfalkvidd
            Yes. I use this:
            It shouldn't be wired wrong.
            • P PZDPRO
              @mfalkvidd
              Yes. I use this:
              @PZDPRO I can’t see a nrf24 radio in that photo.
                @PZDPRO said in Arduino+M5100 cannot connect to LAN:
                Comment out this if you don't want to use a nrf24.
                  P Offline
                  P Offline
                  PZDPRO
                  @mfalkvidd Hi,
                  I tried this but still cannot connect to my LAN network. Router doesn't give me IP. I cannot see arduino in HA.
                  I tried many configurations. Even i put a new sketches from my sensors examples in arduino IDE (GatewayW5100 and GatewayW5100Client).
                  Maybe you someone have working sketch for tests?
                  Thank you in advance.
                  • P PZDPRO
                    @mfalkvidd Hi,
                    @PZDPRO all the examples in MySensors are known to work. We wouldn’t have them if they were broken.
                    What does the debug output say when you have removed the nrf24?
                      P Offline
                      P Offline
                      PZDPRO
                      wrote on last edited by PZDPRO
                      @mfalkvidd
                      This is what i have:
                      I cant see arduino in my router internal website, but i made a ping wrom Command line and i have this:
                      Unfortunatelly i cant connect it in HA:
                      • P PZDPRO
                        @mfalkvidd
                        @PZDPRO I have never used HA but port 1883 in your configuration hints that HA is expecting a MQTT gateway. Your gateway is configured as an ethernet gateway. Therefore, the gateway does not support MQTT.
                        Either configure HA to use an MySensors ethernet gateway, or reconfigure your gateway to use MQTT. See https://www.mysensors.org/build/mqtt_gateway for instructions.
                        I think you'll need a MQTT broker as well. Instructions are available at https://www.mysensors.org/build/mqtt_gateway#setup-and-test-gateway
                          P Offline
                          P Offline
                          PZDPRO
                          Thank you @mfalkvidd
                          Do i need this radio module even if i use wire system in my home?
                          • P PZDPRO
                            @PZDPRO you only need the nrf24 if you want to connect sensor nodes to your gateway. See https://www.mysensors.org/about/network for details on how MySensors works.
                              P Offline
                              P Offline
                              PZDPRO
                              @mfalkvidd OK.
                              I changed my sketch and finally i connect it to HA using integration but still dont have any device in HA.
                              code_text
                              //#define MY_RADIO_RF24
                              #define MY_SOFTSPI
                              #define MY_IP_ADDRESS 192,168,0,207
                              #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 140
                              #define MY_NODE_ID 1
                              #define RELAY_PIN  5
                              #define BUTTON_PIN  3
                              #define CHILD_ID 1
                              #define RELAY_ON 1
                              #define RELAY_OFF 0
                              bool state = false;
                              bool initialValueSent = false;
                                pinMode(BUTTON_PIN, INPUT_PULLUP);
                                debouncer.attach(BUTTON_PIN);
                                debouncer.interval(10);
                                pinMode(RELAY_PIN, OUTPUT);
                              void presentation()  {
                                sendSketchInfo("Relay+button", "1.0");
                                present(CHILD_ID, S_BINARY);
                                if (!initialValueSent) {
                                  Serial.println("Sending initial value");
                                  send(msg.set(state?RELAY_ON:RELAY_OFF));
                                  Serial.println("Requesting initial value from controller");
                                  request(CHILD_ID, V_STATUS);
                                  wait(2000, C_SET, V_STATUS);
                                  if (debouncer.read()==LOW) {
                                    state = !state;
                                    // Send new state and request ack back
                                    send(msg.set(state?RELAY_ON:RELAY_OFF), true);
                                if (message.isAck()) {
                                    Serial.println("Receiving initial value from controller");
                                    initialValueSent = true;
                                  state = (bool)message.getInt();
                              mfalkviddM V 2 Replies Last reply
                              • P PZDPRO
                                @mfalkvidd OK.
                                code_text
                                #define MY_SOFTSPI
                                #define RELAY_PIN  5
                                #define CHILD_ID 1
                                #define RELAY_ON 1
                                #define RELAY_OFF 0
                                bool state = false;
                                      state = !state;
                                @PZDPRO since I have never used HA, I don't know what devices in HA are, or how they work.
                                • P PZDPRO
                                  @mfalkvidd OK.
                                  code_text
                                  #define MY_SOFTSPI
                                  #define RELAY_PIN  5
                                  #define CHILD_ID 1
                                  #define RELAY_ON 1
                                  #define RELAY_OFF 0
                                  bool state = false;
                                        state = !state;
                                  V Offline
                                  V Offline
                                  virtualmkr
                                  @PZDPRO
                                  Hi, have you checked in HA the file /config/mysensors/mysensors.json?
                                  Can you provide the content here?
                                  I have been using HA with MySensors for some time and it works for me, but sometimes HA behaves strangely for me too.
                                  Maybe we can fix your problem here and maybe someone with more HA experience can join the discussion.
                                  So far your second Arduino sketch should work with HA.
                                  BR Immo
                                  • V virtualmkr
                                    @PZDPRO
                                    BR Immo
                                    P Offline
                                    P Offline
                                    PZDPRO
                                    @virtualmkr Hello!
                                    I checked and i think i dont have any file from mysensors.
                                    I'm not good at programming and i only change ready skatches. Maybe you can be my guide how to start with this?
                                    Main thing for me is to have arduino as a light controller. To analogs i have connected monostable switches and on digitals outputs a i had connected relays. In domoticz it works very well via USB.
                                    V 1 Reply Last reply
                                    • P PZDPRO
                                      @virtualmkr Hello!
                                      V Offline
                                      V Offline
                                      virtualmkr
                                      @PZDPRO
                                      I use the File editor from Add-on Store:
                                      Then I can see the MySensors nodes configuration:
                                      • V virtualmkr
                                        @PZDPRO
                                        P Offline
                                        P Offline
                                        PZDPRO
                                        @virtualmkr
                                        I cant connect to arduino again. I ping ip from my laptop and its ok.
                                        Error in HA is "cannot make connection"
                                        I installed file editor and i dont have such a folder and file.
                                        V 3 Replies Last reply
                                        • P PZDPRO
                                          @virtualmkr
                                          V Offline
                                          V Offline
                                          virtualmkr
                                          @PZDPRO It may be you use the automatic config file name. For me I have a second MySensors integration with the configuration file located directly in the config folder:
                                          When your MyS gateway is reachable via ping then HA should be able to connect.
                                          How is your HA hosted? Do you use the HA Raspi image?
