  3. Home Assistant
  4. Arduino+M5100 cannot connect to LAN
22 Posts 3 Posters 2.6k Views 2 Watching
  • mfalkviddM
    Welcome to the forum @PZDPRO !
    What does the debug output from the gateway say?
    If you haven't already, see https://forum.mysensors.org/topic/666/read-this-first-it-could-save-you-a-lot-of-time/ for the most common problems and how to troubleshoot them efficiently.
    • P
      P
      PZDPRO
      Hello Mfalkvidd!
      Thank you for your post. I checked your link and can't find any answer for my problem.
      Here is what i get:
      • mfalkviddM
        Did you read section #2:3 ?
        P 1 Reply Last reply
          P
          P
          PZDPRO
          @mfalkvidd
          Yes. I use this:
          It shouldn't be wired wrong.
          • P PZDPRO
            @mfalkvidd
            Yes. I use this:
            @PZDPRO I can’t see a nrf24 radio in that photo.
            • mfalkviddM
              @PZDPRO said in Arduino+M5100 cannot connect to LAN:
              #define MY_RADIO_RF24
              Comment out this if you don't want to use a nrf24.
                P
                P
                PZDPRO
                @mfalkvidd Hi,
                I tried this but still cannot connect to my LAN network. Router doesn't give me IP. I cannot see arduino in HA.
                I tried many configurations. Even i put a new sketches from my sensors examples in arduino IDE (GatewayW5100 and GatewayW5100Client).
                Maybe you someone have working sketch for tests?
                Thank you in advance.
                • P PZDPRO
                  @mfalkvidd Hi,
                  @PZDPRO all the examples in MySensors are known to work. We wouldn’t have them if they were broken.
                  What does the debug output say when you have removed the nrf24?
                    P
                    P
                    PZDPRO
                    wrote on last edited by PZDPRO
                    @mfalkvidd
                    This is what i have:
                    I cant see arduino in my router internal website, but i made a ping wrom Command line and i have this:
                    Unfortunatelly i cant connect it in HA:
                    • P PZDPRO
                      @mfalkvidd
                      @PZDPRO I have never used HA but port 1883 in your configuration hints that HA is expecting a MQTT gateway. Your gateway is configured as an ethernet gateway. Therefore, the gateway does not support MQTT.
                      Either configure HA to use an MySensors ethernet gateway, or reconfigure your gateway to use MQTT. See https://www.mysensors.org/build/mqtt_gateway for instructions.
                      I think you'll need a MQTT broker as well. Instructions are available at https://www.mysensors.org/build/mqtt_gateway#setup-and-test-gateway
                        P
                        P
                        PZDPRO
                        Thank you @mfalkvidd
                        Do i need this radio module even if i use wire system in my home?
                        • P PZDPRO
                          @PZDPRO you only need the nrf24 if you want to connect sensor nodes to your gateway. See https://www.mysensors.org/about/network for details on how MySensors works.
                            P
                            P
                            PZDPRO
                            @mfalkvidd OK.
                            I changed my sketch and finally i connect it to HA using integration but still dont have any device in HA.
                            code_text
                            //#define MY_RADIO_RF24
                            //#define MY_RADIO_NRF5_ESB
                            //#define MY_RADIO_RFM95
                            #define MY_GATEWAY_W5100
                            //#define MY_W5100_SPI_EN 4
                            // radio on the same spi bus.
                            #define MY_SOFTSPI
                            #ifndef MY_RF24_CE_PIN
                            #define MY_RF24_CE_PIN 5
                            #ifndef MY_RF24_CS_PIN
                            #define MY_RF24_CS_PIN 6
                            // Enable UDP communication
                            //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
                            #define MY_IP_ADDRESS 192,168,0,207
                            #define MY_PORT 5003
                            #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 140
                            //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
                            // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
                            // Enable inclusion mode
                            // Set blinking period
                            // Flash leds on rx/tx/err
                            #if defined(MY_USE_UDP)
                            #include <EthernetUdp.h>
                            #include <Ethernet.h>
                            #define MY_REPEATER_FEATURE
                            #define MY_NODE_ID 1
                            #define RELAY_PIN  5
                            #define BUTTON_PIN  3
                            #define CHILD_ID 1
                            #define RELAY_ON 1
                            #define RELAY_OFF 0
                            Bounce debouncer = Bounce();
                            bool state = false;
                            bool initialValueSent = false;
                              pinMode(BUTTON_PIN, INPUT_PULLUP);
                              debouncer.attach(BUTTON_PIN);
                              debouncer.interval(10);
                              pinMode(RELAY_PIN, OUTPUT);
                            void presentation()  {
                              sendSketchInfo("Relay+button", "1.0");
                              present(CHILD_ID, S_BINARY);
                              if (!initialValueSent) {
                                Serial.println("Sending initial value");
                                send(msg.set(state?RELAY_ON:RELAY_OFF));
                                Serial.println("Requesting initial value from controller");
                                request(CHILD_ID, V_STATUS);
                                wait(2000, C_SET, V_STATUS);
                              if (debouncer.update()) {
                                if (debouncer.read()==LOW) {
                                  state = !state;
                                  // Send new state and request ack back
                                  send(msg.set(state?RELAY_ON:RELAY_OFF), true);
                              if (message.isAck()) {
                                  Serial.println("Receiving initial value from controller");
                                  initialValueSent = true;
                                // Change relay state
                                state = (bool)message.getInt();
                            mfalkviddM V 2 Replies Last reply
                            • P PZDPRO
                              @mfalkvidd OK.
                              code_text
                              #define MY_SOFTSPI
                              #define RELAY_PIN  5
                              #define CHILD_ID 1
                              #define RELAY_ON 1
                              #define RELAY_OFF 0
                              bool state = false;
                                    state = !state;
                              @PZDPRO since I have never used HA, I don't know what devices in HA are, or how they work.
                              • P PZDPRO
                                @mfalkvidd OK.
                                code_text
                                #define MY_SOFTSPI
                                #define RELAY_PIN  5
                                #define CHILD_ID 1
                                #define RELAY_ON 1
                                #define RELAY_OFF 0
                                bool state = false;
                                      state = !state;
                                V
                                V
                                virtualmkr
                                @PZDPRO
                                Hi, have you checked in HA the file /config/mysensors/mysensors.json?
                                Can you provide the content here?
                                I have been using HA with MySensors for some time and it works for me, but sometimes HA behaves strangely for me too.
                                Maybe we can fix your problem here and maybe someone with more HA experience can join the discussion.
                                So far your second Arduino sketch should work with HA.
                                BR Immo
                                • V virtualmkr
                                  @PZDPRO
                                  BR Immo
                                  P
                                  P
                                  PZDPRO
                                  @virtualmkr Hello!
                                  I checked and i think i dont have any file from mysensors.
                                  I'm not good at programming and i only change ready skatches. Maybe you can be my guide how to start with this?
                                  Main thing for me is to have arduino as a light controller. To analogs i have connected monostable switches and on digitals outputs a i had connected relays. In domoticz it works very well via USB.
                                  V 1 Reply Last reply
                                  • P PZDPRO
                                    @virtualmkr Hello!
                                    V
                                    V
                                    virtualmkr
                                    @PZDPRO
                                    I use the File editor from Add-on Store:
                                    Then I can see the MySensors nodes configuration:
                                    • V virtualmkr
                                      @PZDPRO
                                      P
                                      P
                                      PZDPRO
                                      @virtualmkr
                                      I cant connect to arduino again. I ping ip from my laptop and its ok.
                                      Error in HA is "cannot make connection"
                                      I installed file editor and i dont have such a folder and file.
                                      V 3 Replies Last reply
                                      • P PZDPRO
                                        @virtualmkr
                                        V
                                        V
                                        virtualmkr
                                        @PZDPRO It may be you use the automatic config file name. For me I have a second MySensors integration with the configuration file located directly in the config folder:
                                        When your MyS gateway is reachable via ping then HA should be able to connect.
                                        How is your HA hosted? Do you use the HA Raspi image?
                                        • P PZDPRO
                                          @virtualmkr
                                          V
                                          V
                                          virtualmkr
                                          @PZDPRO
                                          Additional I use the MYSController tool, very helpful for debug:
                                          MYSBootloader 1.3 pre-release & MYSController 1.0.0beta
                                          With this you can check if the problem is on HA side or with your gateway.
