  3. Getting childId from IncomingMessage
6 Posts 4 Posters 3.7k Views 2 Watching
  • B Offline
    B Offline
    bluman
    Hi there guys,
    I'm not a coder and struggling to expand the LED dimmer example to work as a three channel RGB driver.
    Could someone please show me how to extract the childId in the message received from the gateway?
    Any help is greatly appreciated. Here is what I'm trying to do:
    if (message.type == V_DIMMER && message.childId = 0) {
    H 1 Reply Last reply
    • B bluman
      Hi there guys,
      H Offline
      H Offline
      @bluman said:
      message.childId = 0
      You're doing an assignment here. Should probably be ==
      • B Offline
        B Offline
        bluman
        Hek,
        OK, thanks for that however it still wont compile.
        if (message.type == V_DIMMER && message.childId == 0) {
        Here is the error.
        _150309_RBG_LED_Driver.ino: In function ‘void incomingMessage(const MyMessage&)’:
        _150309_RBG_LED_Driver.ino:82:43: error: ‘const class MyMessage’ has no member named ‘childId’
        V 1 Reply Last reply
        • H Offline
          H Offline
          https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MyMessage.h#L189
          • B bluman
            Hek,
            Here is the error.
            V Offline
            V Offline
            vikasjee
            wrote on last edited by vikasjee
            @bluman said:
            Hek,
            Here is the error.
            Use message.sensor == 0
            B 1 Reply Last reply
            • V vikasjee
              @bluman said:
              Hek,
              Here is the error.
              B Offline
              B Offline
              BulldogLowell
              @vikasjee
              you should post your entire sketch... put between three backticks (the character left of your "1" key on you keyboard
              <three backticks>
              your code
              <three backticks>
              12.0k
