  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 257.0k Views 53 Watching
  • A
    Andreas Kräuchi
    Ok solved it by adding:
    #undef PRId8
    #undef PRIi8
    #undef PRIo8
    #undef PRIu8
    #undef PRIx8
    #undef PRIX8
    #undef PRIdLEAST8
    #undef PRIiLEAST8
    #undef PRIoLEAST8
    #undef PRIuLEAST8
    #undef PRIxLEAST8
    #undef PRIXLEAST8
    #undef PRIdFAST8
    #undef PRIiFAST8
    #undef PRIoFAST8
    #undef PRIuFAST8
    #undef PRIxFAST8
    #undef PRIXFAST8
    #define PRId8    "d"
    #define PRIi8   "i"
    #define PRIo8   "o"
    #define PRIu8   "u"
    #define PRIx8   "x"
    #define PRIX8   "X"
    #define PRIdLEAST8  "d"
    #define PRIiLEAST8  "i"
    #define PRIoLEAST8  "o"
    #define PRIuLEAST8  "u"
    #define PRIxLEAST8  "x"
    #define PRIXLEAST8  "X"
    #define PRIdFAST8 "d"
    #define PRIiFAST8 "i"
    #define PRIoFAST8 "o"
    #define PRIuFAST8 "u"
    #define PRIxFAST8 "x"
    #define PRIXFAST8 "X"
    • A
      andy5211d
      I have a similar issue with Sensebender Ethernet MQTT Gateway and MYSController. Can only connect to the gateway by serial from MYSController. The set-up is working correctly as best I can tell, and has several different MySensors in use. Has been working for a number of years. Only just discovered the MYSController software.
      So the Controller only shows data in the MYSController Debug tab. Nothing in any of the others. NOTE in the screen grab below the Controller at 192.168.1.96 is not connected, there is no difference when it is other than the Gateway error (!GWT:RMQ:FAIL) is not shown. Anyone with any ides for me to pursue? Thanks.
      • bjornhallbergB
        bjornhallbergB
        bjornhallberg
        As previously noted, Sensebender Gateway sketch from 2.3.2 with MySensors SAMD Boards 1.0.6 does not compile with Arduino SAMD Boards 1.8.9. Rolling back to Arduino SAMD Boards 1.8.8 or earlier version works.
        • YoshuY
          YoshuY
          Yoshu
          Does anyone have an idea about the sensebender gateway board not being recognised in windows 11? A new driver maybe or any other clues ?
          • tbowmoT
            tbowmoT
            tbowmo
            #376
            Unfortunately I do not have any hardware compatible with win11, so can't test myself.. But if I remember right it should turn up as a generic cdc device..
            Is there any info in the windows device manager?
            YoshuY 1 Reply Last reply
            • tbowmoT tbowmo
              YoshuY
              YoshuY
              Yoshu
              @tbowmo
              Nothing new appears in device manager or the usual ding.
              tbowmoT 1 Reply Last reply
              • YoshuY Yoshu
                @tbowmo
                tbowmoT
                tbowmoT
                tbowmo
                @Yoshu Does the same device work on another machine, running win10 / linux?
                • YoshuY
                  YoshuY
                  Yoshu
                  I have not had the opportunity to try another machine yet. unfortunately I had only just given into the windows 11 upgrade messages days before deciding to set up my gateway.
                  • YoshuY Yoshu
                    tbowmoT
                    tbowmoT
                    tbowmo
                    @Yoshu you could boot linux off a usb, and check there..
                    • YoshuY
                      YoshuY
                      Yoshu
                      Sensebender ethernet gateway success with help.
                      Was unable to connect sensebender to Windows 11.
                      Using a suggesetions and assistance by tbowmo
                      (you could boot linux off a usb, and check there..)
                      I used an old rasberry pi with Arduino ide to connect and load the sketch, loaded
                      Mysensors SAMD and Arduino SAMD board profiles, inital compile errors (clinent.h) but recified this with the help of comments by
                      bjornhallberg (Sensebender Gateway sketch from 2.3.2 with MySensors SAMD Boards 1.0.6 does not compile with Arduino SAMD Boards 1.8.9. Rolling back to Arduino SAMD Boards 1.8.8).
                      Used the standard ethernet gateway sketch that I am using with my unsecured nano ethernet gateway. Only changed the ip address and #define MY_RF24_CHANNEL to another channel for this second gateway.
                      I have not setup signing yet, but that is my intention for my sensebender gateway now the basics are working.
                        maafkari4
                        Banned
                        I'll update the PDF once I get to my own computer (which should be Sunday evening)
