  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 257.0k Views 53 Watching
  • pepsonP pepson
    @magpern
    But get this board to Arduino IDE?
    magpernM
    magpernM
    magpern
    @pepson said in 💬 Sensebender Gateway:
    @magpern
    Boards / Boards manager...
    search for sensebender
    You might have to
    File / Preferences / Additional Board manager URLs
    add
    https://raw.githubusercontent.com/mysensors/ArduinoBoards/master/package_mysensors.org_index.json
    • pepsonP
      pepsonP
      pepson
      Hi
      I compiled and write to gateway this programmm. Then i connected it to my RPI with Hassio (Home Assistant). In logs on home assistant still show me info: Gateway /dev/serial/by-id/usb-MySensors.org_Sensebender_GW_6A153443514D355934202020FF10182D-if00 not ready after 15.0 secs so continuing with setup
      but after run Home Assistant gateway works ok. I send info mto developer Home Assistant ans she not see any bugs....
      How i can resolved this problem ?
      • pepsonP
        pepsonP
        pepson
        wrote on last edited by pepson
        #365
        And please help me how i can compile it as gateway Ethernet with module W5100.
        Only add to sketch:
        #define MY_GATEWAY_W5100
        // Enable to UDP
        //#define MY_USE_UDP
        //#define MY_IP_ADDRESS 192,168,3,160 // wpisz adres ip bramki
        #define MY_PORT 5003 //wpisz numer portu bramki
        // Note that most of the Ardunio examples use "DEAD BEEF FEED" for the MAC address.
        #define MY_MAC_ADDRESS 0xDC, 0xAE, 0xB2, 0x3F, 0xFF, 0xDC
        • pepsonP
          pepsonP
          pepson
          When try compilation with this W5100 i get error:
          Opcje projektu zmienione, przeładuj całość
          In file included from C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/MySensors.h:208:0,
                       from C:\Users\Piotrek\Desktop\SensebenderGatewayETHERNET\SensebenderGatewayETHERNET.ino:111:
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:74:1: error: 'EthernetServer' does not name a type
          EthernetServer _ethernetServer(_ethernetGatewayPort);
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:89:8: error: 'EthernetClient' does not name a type
          static EthernetClient client = EthernetClient();
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp: In function 'bool gatewayTransportInit()':
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:149:7: error: 'Ethernet' was not declared in this scope
          if (!Ethernet.begin(_ethernetGatewayMAC)) {
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:149:7: note: suggested alternative: '_ethernetMsg'
             _ethernetMsg
          In file included from C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/MySensors.h:49:0,
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:156:16: error: 'Ethernet' was not declared in this scope
                      Ethernet.localIP()[0],
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/MyConfig.h:1815:48: note: in definition of macro 'DEBUG_OUTPUT'
          #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##VA_ARGS) //!< debug
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:155:2: note: in expansion of macro 'GATEWAY_DEBUG'
          GATEWAY_DEBUG(PSTR("GWT:TIN:IP=%" PRIu8 ".%" PRIu8 ".%" PRIu8 ".%" PRIu8 "\n"),
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:156:16: note: suggested alternative: '_ethernetMsg'
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:189:2: error: '_ethernetServer' was not declared in this scope
          _ethernetServer.begin();
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:189:2: note: suggested alternative: '_ethernetMsg'
          _ethernetMsg
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp: In function 'bool gatewayTransportSend(MyMessage&)':
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:246:11: error: '_ethernetServer' was not declared in this scope
          nbytes = _ethernetServer.write(_ethernetMsg);
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:246:11: note: suggested alternative: '_ethernetMsg'
                 _ethernetMsg
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp: In function 'bool _readFromClient()':
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:289:9: error: 'client' was not declared in this scope
          while (client.connected() && client.available()) {
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:289:9: note: suggested alternative: 'Print'
               Print
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp: In function 'bool gatewayTransportAvailable()':
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:409:2: error: 'EthernetClient' was not declared in this scope
          EthernetClient newclient = _ethernetServer.available();
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:411:6: error: 'newclient' was not declared in this scope
          if (newclient) {
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:412:7: error: 'client' was not declared in this scope
          if (client != newclient) {
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:412:7: note: suggested alternative: 'Print'
             Print
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:422:6: error: 'client' was not declared in this scope
          if (client) {
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:422:6: note: suggested alternative: 'Print'
          if (client) {
            Print
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp: In function 'void gatewayTransportRenewIP()':
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:463:6: error: 'Ethernet' was not declared in this scope
          if (Ethernet.maintain() & ~(0x06)) {
          C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:463:6: note: suggested alternative: '_ethernetMsg'
            _ethernetMsg
          exit status 1
          Błąd kompilacji dla płytki Sensebender Gateway.
          What is a problem ?
          • pepsonP
            pepsonP
            pepson
            please help me....
            • pepsonP
              pepsonP
              pepson
              Hi
              Can anybody help me how compile sketch to this gateway to work as Ethernet Gateway...
              When i try compile i get the error:
              https://pastebin.com/BSQGsCgi
              and my sketch looks like:
              https://pastebin.com/R3vG076i
              tekkaT 1 Reply Last reply
              • pepsonP pepson
                Hi
                tekkaT
                tekkaT
                tekka
                @pepson Did you add
                #include <Ethernet.h>
                pepsonP 1 Reply Last reply
                • tekkaT tekka
                  @pepson Did you add
                  pepsonP
                  pepsonP
                  pepson
                  @tekka
                  No.... thanks i fixed it....:)
                  • A
                    Andreas Kräuchi
                    I just got my Sensebender Gateway and loaded the Sensebender Gateway Serial sketch. When I use the MYSController I get those wired infos...
                    Currently there is no other Snesor runing just the Sensebender Gateway with an RF24. Why does it see a new child and what are all thos "hu;hu;hu" errors?
                    • A
                      Andreas Kräuchi
                      Ok solved it by adding:
                      #undef PRId8
                      #undef PRIi8
                      #undef PRIo8
                      #undef PRIu8
                      #undef PRIx8
                      #undef PRIX8
                      #undef PRIdLEAST8
                      #undef PRIiLEAST8
                      #undef PRIoLEAST8
                      #undef PRIuLEAST8
                      #undef PRIxLEAST8
                      #undef PRIXLEAST8
                      #undef PRIdFAST8
                      #undef PRIiFAST8
                      #undef PRIoFAST8
                      #undef PRIuFAST8
                      #undef PRIxFAST8
                      #undef PRIXFAST8
                      #define PRId8    "d"
                      #define PRIi8   "i"
                      #define PRIo8   "o"
                      #define PRIu8   "u"
                      #define PRIx8   "x"
                      #define PRIX8   "X"
                      #define PRIdLEAST8  "d"
                      #define PRIiLEAST8  "i"
                      #define PRIoLEAST8  "o"
                      #define PRIuLEAST8  "u"
                      #define PRIxLEAST8  "x"
                      #define PRIXLEAST8  "X"
                      #define PRIdFAST8 "d"
                      #define PRIiFAST8 "i"
                      #define PRIoFAST8 "o"
                      #define PRIuFAST8 "u"
                      #define PRIxFAST8 "x"
                      #define PRIXFAST8 "X"
                      • A
                        andy5211d
                        I have a similar issue with Sensebender Ethernet MQTT Gateway and MYSController. Can only connect to the gateway by serial from MYSController. The set-up is working correctly as best I can tell, and has several different MySensors in use. Has been working for a number of years. Only just discovered the MYSController software.
                        So the Controller only shows data in the MYSController Debug tab. Nothing in any of the others. NOTE in the screen grab below the Controller at 192.168.1.96 is not connected, there is no difference when it is other than the Gateway error (!GWT:RMQ:FAIL) is not shown. Anyone with any ides for me to pursue? Thanks.
                        • bjornhallbergB
                          bjornhallbergB
                          bjornhallberg
                          As previously noted, Sensebender Gateway sketch from 2.3.2 with MySensors SAMD Boards 1.0.6 does not compile with Arduino SAMD Boards 1.8.9. Rolling back to Arduino SAMD Boards 1.8.8 or earlier version works.
                          • YoshuY
                            YoshuY
                            Yoshu
                            Does anyone have an idea about the sensebender gateway board not being recognised in windows 11? A new driver maybe or any other clues ?
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              #376
                              Unfortunately I do not have any hardware compatible with win11, so can't test myself.. But if I remember right it should turn up as a generic cdc device..
                              Is there any info in the windows device manager?
                              YoshuY 1 Reply Last reply
                              • tbowmoT tbowmo
                                YoshuY
                                YoshuY
                                Yoshu
                                @tbowmo
                                Nothing new appears in device manager or the usual ding.
                                tbowmoT 1 Reply Last reply
                                • YoshuY Yoshu
                                  @tbowmo
                                  tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @Yoshu Does the same device work on another machine, running win10 / linux?
                                  • YoshuY
                                    YoshuY
                                    Yoshu
                                    I have not had the opportunity to try another machine yet. unfortunately I had only just given into the windows 11 upgrade messages days before deciding to set up my gateway.
                                    • YoshuY Yoshu
                                      tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @Yoshu you could boot linux off a usb, and check there..
                                      • YoshuY
                                        YoshuY
                                        Yoshu
                                        Sensebender ethernet gateway success with help.
                                        Was unable to connect sensebender to Windows 11.
                                        Using a suggesetions and assistance by tbowmo
                                        (you could boot linux off a usb, and check there..)
                                        I used an old rasberry pi with Arduino ide to connect and load the sketch, loaded
                                        Mysensors SAMD and Arduino SAMD board profiles, inital compile errors (clinent.h) but recified this with the help of comments by
                                        bjornhallberg (Sensebender Gateway sketch from 2.3.2 with MySensors SAMD Boards 1.0.6 does not compile with Arduino SAMD Boards 1.8.9. Rolling back to Arduino SAMD Boards 1.8.8).
                                        Used the standard ethernet gateway sketch that I am using with my unsecured nano ethernet gateway. Only changed the ip address and #define MY_RF24_CHANNEL to another channel for this second gateway.
                                        I have not setup signing yet, but that is my intention for my sensebender gateway now the basics are working.
                                          maafkari4
                                          Banned
                                          I'll update the PDF once I get to my own computer (which should be Sunday evening)
