  3. CAN bus transport implementation
54 Posts 5 Posters 8.4k Views 8 Watching
  • Adam SlowikA
    Adam SlowikA
    Adam Slowik
    • which CAN library did you start on,
    I have used https://github.com/coryjfowler/MCP_CAN_lib
    This library is embedded in code in my fork, so if You are going to test My fork You don't have to worry about underlying library. Consider it an implementation detail. If You are going to implement CAN bus transport at Your own, You can pick different library.
    • the management of Float values is also managed ?
    I did not tested transferring float numbers over CAN network, however in my opinion such concern is out of the scope of protocol implementation. During implementation My goal was to transfer array of bytes from one arduino to another via CAN. I don't care how those bytes are interpreted. Those bytes can be Strings, ints, floats, images etc. It should not matter.
    • and of course any CAN card is managed, like this one https://www.gotronic.fr/ori-module-bus-can-sbc-can01-28405.jpg
    Any CAN module supported by underlying library should be ok (so after all it's not an implemantation detail). Library readme says it will work with MCP2515 and MCP25625. Module picked by You (https://www.gotronic.fr/art-module-bus-can-sbc-can01-28405.htm) have MCP2515+MCP2562 so You should be god. Module used by Me had MCP2515+tja1050. Yours transciever is different then mine, however I hope it doesn't matter
    I prepare another test computer for the installation of your version :)
    I would really appreciate Your feedback
    • J
      J
      JeeLet
      "you can choose a different library"
      I like this freedom of choice, my questioning is not necessary :)
      "I would really appreciate your comments"
      yes yes in 4 to 5 days, theoretically
      Finally a high reliability Wired Bus for MySensors with the MyS protocol which is extraordinarily rich.
      (the RS485 bus is good, but the cables/wiring must be more rigorous and the management of collisions more delicate for X Nodes, and the CAN bus is a good field bus )
      • J
        J
        JeeLet
        wrote on last edited by JeeLet
        Hello
        to save time, you can tell me more about the configuration of MCP_CAN_lib
        not all settings are shown on the MyS sketch :)
        here in an example https://github.com/coryjfowler/MCP_CAN_lib/blob/master/examples/CAN_receive/CAN_receive.ino
        there are some parameters to adjust
        or the filters https://github.com/coryjfowler/MCP_CAN_lib/blob/master/examples/Extended_MaskFilter/Extended_MaskFilter.ino
        can you indicate me the files in question ???
        (I think I have found but to confirm)
        to make it clean
        thanks
        • Adam SlowikA
          Adam SlowikA
          Adam Slowik
          So I have pull up some config parameters. Those are defined and briefly described in:
          https://github.com/AdamSlowik/MySensors/blob/development/MyConfig.h
          lines 270-315
          You can set those parameters to different values, but for first run I suggest deploy examples without modifications. By examples I mean those 2 files:
          https://github.com/AdamSlowik/MySensors/blob/development/examples/CANSwitch/CANSwitch.ino
          https://github.com/AdamSlowik/MySensors/blob/development/examples/GatewaySerialCAN/GatewaySerialCAN.ino
          If it fails I would set:
          CAN_CLOCK to MCP_16MHZ
          because i think can module from Your vendor uses 16MHz (My used 8MHz)
          filters are set in:
          https://github.com/AdamSlowik/MySensors/blob/development/hal/transport/CAN/MyTransportCAN.cpp
          line 37 method _initFilters()
          without clear reason (eg. bug) I would recommend to not alter it.
          Filters are set to drop messages not intended for certain node. Thanks to this MCU do not have to handle 'spam'.
          If My answer answers Yours questions then great. If this is insufficient ask for a specific parameter or line in code I will try to answer any questions asap
          • J
            J
            JeeLet
            a start of error messages return (on both sketches)
            IDE version 1.8.19
            for CANSwitch.ino
            the message returns me to the line
            MyTransportCAN.cpp --->
            163 : ",TOTAL=%"PRIu8",CURR=%"PRIu8",TO=%"PRIu8",FROM=%"PRIu8"\n"), header, messageId, totalPartCount,
            228 : ",TOTAL=%"PRIu32",CURR=%"PRIu32",TO=%"PRIu32",FROM=%"PRIu32"\n"), rxId, messageId,
            the one copy (a part) of the IDE
            In file included from /home/mci/Arduino/libraries/MySensors-development/MySensors.h:395:0,
                             from /tmp/arduino_modified_sketch_39381/CANSwitch.ino:43:
            /home/Arduino/libraries/MySensors-development/hal/transport/CAN/MyTransportCAN.cpp:163:17: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
            /home/Arduino/libraries/MySensors-development/hal/transport/CAN/MyTransportCAN.cpp:163:32: war......
            /home/Arduino/libraries/MySensors-development/hal/transport/CAN/MyTransportCAN.cpp:228:18: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
            /home/Arduino/libraries/MySensors-development/hal/transport/CAN/MyTransportCAN.cpp:228:34: warni.....
            • J
              J
              JeeLet
              https://sourcecodeartisan.com/2021/03/06/invalid-suffix-on-literal.html
              for the Error code it is
              a requirement in C++ 11 (or later).
              lines 163 and 228 modify and error resolved
              .../hal.transport/CAN/MyTransportCAN.cpp
              CAN_DEBUG(PSTR("CAN:SND:CANH=%" PRIu32 ",ID=%" PRIu8 ",TOTAL=%" PRIu8 ",CURR=%" PRIu8 ",TO=%" PRIu8 ",FROM=%" PRIu8 "\n"), header, messageId, totalPartCount,
              CAN_DEBUG(PSTR("CAN:RCV:CANH=%" PRIu32 ",ID=%" PRIu32 ",TOTAL=%" PRIu32 ",CURR=%" PRIu32 ",TO=%" PRIu32 ",FROM=%" PRIu32 "\n"), rxId, messageId,
              :+1:
              • J
                J
                JeeLet
                a topo of the day
                on the hardware side, I got screwed with an arduino pin that became too soft, too dilated, look for an hour before understanding why no dialog.
                Otherwise, on the Gateway side, no problem, MyController recognized well.
                and CAN_Switch.ino is good too, my Widget on MyC switches well on the switch change.
                listing of the dialog pour le Node 51 (set up in a fixed place )
                coter log from MyC:
                2022-06-11T18:49:35.167+0200	recd	0;255;3;0;9;1482640 TSF:MSG:READ,51-51-0,s=4,c=1,t=16,pt=1,l=1,sg=0:1
                2022-06-11T18:49:35.170+0200	recd	51;4;1;0;16;1
                2022-06-11T18:49:35.179+0200	recd	0;255;3;0;9;1482653 TSF:MSG:READ,51-51-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
                2022-06-11T18:49:35.182+0200	recd	51;255;3;0;21;0
                coter IDE from MyS:
                67889 TSF:MSG:BC
                68197 TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
                68203 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                68208 TSF:MSG:BC
                68836 TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
                68843 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
                68848 TSF:TDI:TSL
                68849 MCO:SLP:WUP=-1 ........ it is incomplete
                well now we have to calm down the CAN bus dialog, the Rx/Tx Led of the gateway looks like a Christmas tree :)
                tomorrow I'll test a CAN_Switch version2 sketch
                • J
                  J
                  JeeLet
                  test with the digital output inputs of 2 Arduino on CAN Bus.
                  • status of a button and control of a led with MyC
                  a proof in video that it is functional :)
                  video
                  all is not functional, on the end of the video, the reset or reboot does not work, (but functional with the RS485 bus)
                  .... to follow ;)
                  (now the Analog values, decimal to test )
                  I would like to test the Node to Node with the filtering.
                  a question : is it difficult to put the filters on the MySensors sketch ???
                  there are still MySensors on the forum ???
                  if yes, a help for Adam Slowik would be a great thing.
                  implement it in MyS Yes Yes
                  • Adam SlowikA
                    Adam SlowikA
                    Adam Slowik
                    @JeeLet as I can see You had bussy weekend. I was AFK so I was unable to respond. Within working days I should be able to respond quicker.
                    @JeeLet said in CAN bus transport implementation:
                    Can you push Your fix to My repo?
                    Great job! I never was at this stage.
                    .... to follow
                    Can You provide (gateway/node) logs from reset scenario. It would be great to have those logs either for RS485 and CAN so I can compare them.
                    Could You describe what kind of test You would like to perform? Right now there is no way to set filters from the sketch. I think it should stay this way.
                    Perhaps We have different things in mind when We think about filters. I'll try to describe how I see this.
                    When it comes to CAN frame there is header and body. Header contains metadata and body contains data. mcp2515 can filter frames based on header content. Header contains id of destination node. Based on this id filters are set to drop any messages not intended for current node. This way if gateway want to send message to node with id=51 only node with this id receives this message.
                    There is exception for this rule. Messages with destination id set to BROADCAST_ADDRESS reaches all nodes.
                    With this in mind I see no reason to set filters differently. Of course I can be wrong.
                    Composition of header is described in MyTransportCAN.cpp in method _buildHeader()
                    As of now my all can modules and arduinos are burried in some box at My attic so I am unable to test anything
                    • J
                      J
                      JeeLet
                      "Can you provide logs (gateway/node) from the reset scenario. It would be great to have these logs for RS485 and CAN so I can compare them."
                      listing
                      Released today 2 gateways connect to MyController
                      • UNO_usb - Gateway and RS485 bus
                      • UNO_usb - Gateway and CAN Bus
                      with connect, a UNO with the basic sketch "RelayWithButtonActuator_base.ino" (slightly modified)
                      with ... a Led and a Switch, for each bus.
                      The Listing split in several parts
                      "Log of the IDE and MyC for the two types of bus (node34 and node 54), CAN and RS485.
                      - Listing Action RESET with MyController
                      	2 parts for CAN
                      	and
                      	2 parts for RS485
                      and
                      - Listing Action On/Off on the node switch or with MyController
                      	4 parts for CAN
                      	and
                      	4 parts for RS485
                      No error on the Reset, it works fine, an error from me.
                      Oh yes, I even found an error :)
                      the sendSketchInfo("test xxxxx", "1.0"); is not up
                      see the end of the video
                      video
                      ....I will answer the other question tomorrow.
                      • J
                        J
                        JeeLet
                        @Adam-Slowik "Can you push your patch to my repository? " .... I don't know how
                        On the CAN principle
                        @Adam-Slowik "Based on this id, the filters are configured to remove all messages not intended for the current node. This way, if the gateway wants to send a message to the node with id = 51, only the node with that id receives that message." ... yes, that's how I see it.
                        another way to say/explain it.
                        "The philosophy of CAN is to constitute a messaging system.
                        The messages (the letter) send on the CAN Bus (the post office), distributed by the CAN Bus (the letter carrier).
                        Each (letter) have each an identifier (stamp of the post ☺ ) that ... identifies it.
                        And put in the right mailbox (the MCP2515) according to the choice of filter/mask ( color, scent? ☺ ) of the letter."
                        So there are two "stratum" of dialogue / work.
                        • one on the Can Bus, and another on the Nodes.
                        The idea is to relieve the Nodes of unnecessary work/effort with the risks that this brings. Less letter to open :)
                        @Adam-Slowik "... my modules and arduinos are buried in a box in my attic..." ? Arduino 8bit and MySensors is over for you?
                        ( if it's a personal / family reason don't say anything )
                        • J
                          J
                          JeeLet
                          #21
                          I tested my sketch with clock and OLED to see :)
                          bah No the time is not up :(
                          I give this information for an overview, it can help for the continuation (but not to give you work :) )
                          The listing of the messages of mySensors
                          test with "void receiveTime" function (without RTC clock)
                          https://forum.mysensors.org/topic/4809/real-time-clock-module-lcd-display-and-controller-time/8?_=1655208396048
                          ..........Log MyC - terminal ssh  .........
                          2022-06-14T14:01:45.115+0200	recd	0;255;3;0;9;65310350 TSF:MSG:READ,55-55-0,s=255,c=3,t=1,pt=0,l=0,sg=0:
                          2022-06-14T14:01:45.119+0200	recd	0;255;3;0;9;65310356 TSF:MSG:ECHO REQ
                          2022-06-14T14:01:45.127+0200	recd	0;255;3;0;9;65310360 TSF:MSG:SEND,0-0-55-55,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                          2022-06-14T14:01:45.127+0200	recd	55;255;3;0;1;
                          2022-06-14T14:01:45.146+0200	sent	55;255;3;0;1;1655215305
                          2022-06-14T14:01:45.160+0200	recd	0;255;3;0;9;65310394 TSF:MSG:SEND,0-0-55-55,s=255,c=3,t=1,pt=0,l=10,sg=0,ft=0,st=OK:1655215305
                          ..........Log MyS - terminal IDE .........
                               time current:0   -------------------------------------------
                          58007 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                          58017 TSF:MSG:READ,0-0-55,s=255,c=3,t=1,pt=0,l=0,sg=0:
                          58022 TSF:MSG:ECHO
                          avec Bus RS485
                          2022-06-14T14:22:41.265+0200	recd	0;255;3;0;9;72000090 TSF:SAN:OK
                          2022-06-14T14:22:41.274+0200	recd	0;255;3;0;9;72000096 TSM:READY:NWD REQ
                          2022-06-14T14:22:41.298+0200	recd	0;255;3;0;9;72000115 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                          2022-06-14T14:22:41.917+0200	recd	0;255;3;0;9;72000736 TSF:MSG:READ,22-22-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
                          2022-06-14T14:22:41.920+0200	recd	22;255;3;0;21;0
                             time current:1422   -------------------------------------------
                          423956 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=1,l=1,sg=0:0
                          423962 TSF:MSG:BC
                          424008 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
                             requestOn-----------------------------------------
                          • Adam SlowikA
                            Adam SlowikA
                            Adam Slowik
                            No it is not over. Right now I don't have enough time. Now I am able to work for let's say 1 hour per week. Probably I will become more active at the end of 2023 :D
                            Here You posted RS485 version:
                            Could You post here CAN version?
                            • J
                              J
                              JeeLet
                              #23
                              @Adam-Slowik "Could you post the CAN version here?"
                              it's the same, except that the bus is not rs485 but CAN :)
                              #define MY_NODE_ID 55          /*Node en ID static*/
                                #define MY_CAN
                                #include "SSD1306Ascii.h"
                              but I'll go back to PaulStoffregen's Lib <TimeLib.h> to see if I can simplify the basic sketch of MySensors
                              • Adam SlowikA
                                Adam SlowikA
                                Adam Slowik
                                In previous example (with diodes) did You set CAN_CLOCK to MCP_16MHZ?
                                • J
                                  J
                                  JeeLet
                                  #25
                                  no it stayed on 8Mhz ?
                                  I didn't modify anything (the other sketches work)
                                  But I just looked at the quartz and it's 16M!! (SW-65-16M)
                                  I am lost :(
                                  but on the doc there is :
                                  The 8000000 stands that the MCP2515 operates with a clock of 8 MHz. This
                                  depends on the quartz used and may need to be adjusted.
                                  error
                                  on the official doc it's a 16Mhz like mine.
                                  • https://www.joy-it.net/en/products/SBC-CAN01
                                    OSCILLATOR 16 MHz Crystal Oscillator
                                  so 8Mhz or 16Mhz?
                                  and why does it work with the previous sketches?
                                  • J
                                    J
                                    JeeLet
                                    #26
                                    I think the dialogue is good
                                    but the problem is the length of the storyline
                                    a part of the dialog on the IDE terminal for both types
                                    CAN and RS485
                                       - IDE terminal sur RS485 :
                                    4066 TSF:MSG:ECHO
                                    4132 TSF:MSG:READ,0-0-22,s=255,c=3,t=1,pt=0,l=10,sg=0:1655285320
                                    8018 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                                    8054 TSF:MSG:READ,0-0-22,s=255,c=3,t=1,pt=0,l=0,sg=0:
                                    8058 TSF:MSG:ECHO
                                    8111 TSF:MSG:READ,0-0-22,s=255,c=3,t=1,pt=0,l=10,sg=0:1655285324
                                      newTime:1655285324   -------------------------------------------
                                      - IDE terminal sur CAN :
                                    22224 MCO:REG:REQ
                                    22226 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                    22233 !MCO:PRO:RC=1
                                    22235 TSF:MSG:READ,0-0-55,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                    22240 MCO:PIM:NODE REG=1
                                    28004 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                                    28014 TSF:MSG:READ,0-0-55,s=255,c=3,t=1,pt=0,l=0,sg=0:
                                    28019 TSF:MSG:ECHO
                                      newTime:0   -------------------------------------------
                                    sketch
                                    void receiveTime(unsigned long controllerTime)   {
                                        if (receiveTime) stateCom = true ; else stateCom = false;
                                          newTime = controllerTime;
                                    Serial.print("  newTime:"); Serial.print(newTime);
                                    • J
                                      J
                                      JeeLet
                                      #27
                                      frequency change
                                      with 16Mhz I have a NACK
                                      // #define CAN_CLOCK MCP_16MHZ
                                      105 TSM:FPAR
                                      18107 ?TSF:MSG:SEND,55-55-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=4,st=NACK:
                                      20115 !TSM:FPAR:NO REPLY
                                      20117 TSM:FPAR
                                      20119 ?TSF:MSG:SEND,55-55-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=5,st=NACK:
                                      // #define CAN_CLOCK MCP_8MHZ
                                      28019 TSF:MSG:ECHO
                                      38005 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                                      38016 TSF:MSG:READ,0-0-55,s=255,c=3,t=1,pt=0,l=0,sg=0:
                                      https://forum.arduino.cc/t/how-to-set-the-mhz-in-mcp2515-library-file-based-on-crystal-oscillator/628822
                                      • J
                                        J
                                        JeeLet
                                        in the sketch I added lines to visualize the buffer data
                                        a part of I recopied
                                        log IDE :
                                           Extended ID: 0x0410FF00  DLC: 8  Data: 0x00 0x00 0xFF 0x0A 0x23 0x14 0xFF 0x00
                                        88010 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                                        Extended ID: 0x05103700  DLC: 7  Data: 0x00 0x00 0x37 0x02 0x13 0x01 0xFF
                                        Extended ID: 0x06303700  DLC: 8  Data: 0x00 0x00 0x37 0x52 0x03 0x01 0xFF 0x31
                                        I stop for me, I pause for 1 day or 2 :)
                                        • Adam SlowikA
                                          Adam SlowikA
                                          Adam Slowik
                                          I found a bug in my code. Please re-download new version.
                                          If something won't work please enable CAN debug by adding:
                                          #define MY_DEBUG_VERBOSE_CAN
                                          add this to gateway and to node sketch
