  3. ESP8266Wifi Gateway won't connect
33 Posts 6 Posters 4.6k Views 6 Watching
    @dpcons have you enabled debug output? https://forum.mysensors.org/topic/666/read-this-first-it-could-save-you-a-lot-of-time describes how
    dpconsD
    dpconsD
    dpcons
    @mfalkvidd yes
    Yes, it's defined. I also ran the advanced webserver sample and it runs fine. It connects nicely and sends status to the serial port.
    • dpconsD dpcons
      @mfalkvidd yes
      @dpcons could you post photos of your setup? Having some more eyes on the wiring can help sometimes.
      When you test the webserver, do you use the exact same wiring?
      • dpconsD
        dpconsD
        dpcons
        IMG_20220819_114756303_HDR.jpg IMG_20220819_114858392_HDR.jpg IMG_20220819_114802950_HDR.jpg
        I tested the Advanced Web Server Sample with this setup. Works fine. I tried the GatewayESP8266 on this setup and another setup with a WEMOS Pro mini. Same results, nothing out the serial port. I also tried the gateway app on an esp8266 with no radio attached and got no serial at 115200 at all. Is this normal? Shouldn't I get some kind of error message.
        I'll try setting up an app to talk to the RF24 directly and see how that goes.
        Is the GatewayESP32 working for the RF24 radios? If so, maybe I'll try that. I'm quite puzzled.
        This assembly worked at one time a couple of years ago on another system.
        • dpconsD
          dpconsD
          dpcons
          Tried on windows 11 machine Arduino 1.8.19 with latest MySensors Library. Tried on Windows 10 machine with Arduino 1.8.13 and latest MySensors library. Just an FYI. Thanks for staying with me.
          H 1 Reply Last reply
          • dpconsD dpcons
            H
            H
            hard-shovel
            @dpcons As you are seeing no serial debug data. Have you checked that your serial data monitor is set for the same baud rate as set in the sketch (9600 on MySensors GatewayESP8266 sketch) as other sketches use default 115200
            • dpconsD
              dpconsD
              dpcons
              No comm at any baud rate except trash I/O at boot time. The gateway code specifies 9600 but I've tried them all. The problem is the system is not connecting with the network.
              In addition, built up a new system using an ESP32 module and an nRF24L01 module.
              Tried the "GatewayESP32" example app on the known good ESP32 module. After uploading, this module spits good data out the serial port at 115200 KHz (See below:)...but never tries to connect to the network. I'm using the "GatewayESP32" example with my network credentials added.
              The ESP32 appears to be getting data from my 2.4GHz sensors, but never gets to my network.
              16:57:05.271 -> 10009772 TSF:MSG:BC
              16:57:05.271 -> 10009774 TSF:MSG:FPAR REQ,ID=12
              16:57:05.271 -> 10009776 TSF:PNG:SEND,TO=0
              16:57:05.271 -> 10009779 TSF:CKU:OK
              16:57:05.271 -> 10009781 TSF:MSG:GWL OK
              16:57:05.505 -> 10010001 !TSF:MSG:SEND,0-0-12-12,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
              16:57:05.505 -> 10010008 TSF:MSG:READ,9-9-0,s=0,c=1,t=0,pt=7,l=5,sg=0:26.0
              16:57:21.018 -> 10025533 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
              16:57:21.018 -> 10025539 TSF:MSG:BC
              16:57:21.018 -> 10025540 TSF:MSG:FPAR REQ,ID=7
              16:57:21.018 -> 10025543 TSF:PNG:SEND,TO=0
              16:57:21.018 -> 10025545 TSF:CKU:OK
              16:57:21.018 -> 10025547 TSF:MSG:GWL OK
              16:57:21.674 -> 10026174 !TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
              16:57:29.313 -> 10033832 TSF:MSG:READ,3-3-0,s=0,c=1,t=37,pt=2,l=2,sg=0:1380
              16:57:31.843 -> 10036367 TSF:MSG:READ,5-5-0,s=0,c=1,t=0,pt=7,l=5,sg=0:-0.3
              16:57:31.937 -> 10036433 TSF:MSG:READ,5-5-0,s=1,c=1,t=0,pt=7,l=5,sg=0:-19.5
              16:57:43.934 -> 10048467 TSF:MSG:READ,7-7-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
              16:57:43.981 -> 10048472 TSF:MSG:PINGED,ID=7,HP=1
              16:57:43.981 -> 10048516 !TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
              16:57:56.119 -> 10060615 TSF:MSG:READ,2-2-0,s=0,c=1,t=1,pt=7,l=5,sg=0:43.3
              16:57:56.119 -> 10060635 TSF:MSG:READ,2-2-0,s=1,c=1,t=0,pt=7,l=5,sg=0:26.0
              16:58:04.393 -> 10068900 TSF:MSG:READ,3-3-0,s=0,c=1,t=37,pt=2,l=2,sg=0:1380
              16:58:05.190 -> 10069700 TSF:MSG:READ,9-9-0,s=0,c=1,t=0,pt=7,l=5,sg=0:26.0
              16:58:06.736 -> 10071270 TSF:MSG:READ,5-5-0,s=0,c=1,t=0,pt=7,l=5,sg=0:-0.1
              16:58:06.830 -> 10071334 TSF:MSG:READ,5-5-0,s=1,c=1,t=0,pt=7,l=5,sg=0:-19.4
              16:58:35.125 -> 10099641 TSF:MSG:READ,9-9-0,s=0,c=1,t=0,pt=7,l=5,sg=0:26.0
              16:58:39.437 -> 10103962 TSF:MSG:READ,3-3-0,s=0,c=1,t=37,pt=2,l=2,sg=0:1380
              16:58:41.640 -> 10106168 TSF:MSG:READ,5-5-0,s=0,c=1,t=0,pt=7,l=5,sg=0:0.0
              16:58:59.372 -> 10123897 TSF:MSG:READ,2-2-0,s=0,c=1,t=1,pt=7,l=5,sg=0:43.3
              16:58:59.419 -> 10123914 TSF:MSG:READ,2-2-0,s=1,c=1,t=0,pt=7,l=5,sg=0:26.0
              16:59:05.091 -> 10129603 TSF:MSG:READ,9-9-0,s=0,c=1,t=0,pt=7,l=5,sg=0:26.0
              16:59:14.527 -> 10139033 TSF:MSG:READ,3-3-0,s=0,c=1,t=37,pt=2,l=2,sg=0:1380
              16:59:16.571 -> 10141065 TSF:MSG:READ,5-5-0,s=0,c=1,t=0,pt=7,l=5,sg=0:0.1
              Again, as with the ESP8266 gateway the "Advanced Web Server" for the ESP32 chip uploads nicely, connects to my network and runs as expected. I'm stopped anyway I try to go.
              • dpconsD dpcons
                H
                H
                hard-shovel
                @dpcons I assembled a board copied from yours for testing.
                I could replicate the problem. It is with the ESP core version and the MySensor Version
                MySensors version 2.3.2 and ESP8266 core 3.0.2 does not work,
                MySensors version 2.3.2 and ESP8266 core 2.7.4 works
                Mysensors development version 2.4.0-Alpha and newest ESP8266 core 3.0.2 also works
                So you can either update the esp core to older version 2.7.4, or install the development version of MySensors 2.4.0-Alpha
                paqorP C dpconsD 3 Replies Last reply
                • H hard-shovel
                  paqorP
                  paqorP
                  paqor
                  wrote on last edited by paqor
                  @hard-shovel said in ESP8266Wifi Gateway won't connect:
                  • H hard-shovel
                    C
                    C
                    chrishiscox
                    @hard-shovel I had same issue and using older version worked for me too
                    • H hard-shovel
                      dpconsD
                      dpconsD
                      dpcons
                      @hard-shovel Thanks so much for your effort and your timely resolution. I tried going back with previous versions of the library and they didn't work or didn't compile. I greatly appreciate your help with this. I assume something similar is happening to the ESP32 version also. Again, thanks.
                      OldSurferDudeO 1 Reply Last reply
                      • dpconsD dpcons
                        OldSurferDudeO
                        OldSurferDudeO
                        OldSurferDude
                        wrote on last edited by OldSurferDude
                        @dpcons @hard-shovel @paqor @chrishiscox @mfalkvidd Hi all,
                        I saw this and got excited that I could use my NodeMCUv1.0 as a MySensors Gateway. I made sure I had the latest MySensors library (2.3.2) and ESP8266 board (3.0.2). I successfully ran a couple examples, first file-->examples-->ESP8266-->Blink then file-->examples-->ESP8266-->interactive (with my ssid & pass), the latter with serial monitor at 115200 baud.
                        I ensured that my nRF24l01 was functional by connecting it to an Arduino Nano and running the scanner program.
                        I connected my nRF24l01 to my NodeMCU, both having pins, using new 10cm 7 conductor ribbon cable. (I have successfully used this type of connection to an RPi)
                        The program ... I copied the program from this page and applied my ssid and password. Nothing ... I suspected that this code is a node template, not a the gateway program.
                        On that same page was the instruction "Open the WiFi gateway in the Arduino IDE (File -> Sketchbook -> Libraries -> MySensors -> Esp8266Gateway)" I didn't find "Libraries" under "Sketchbook" I a file of the same name at (File -> Sketchbook -> Libraries -> MySensors -> examples --> Esp8266Gateway) which is the same file.
                        I tried putting into setup the line
                        Serial.println("com check");
                        but nothing came out on the console.
                        I think I'm at the same place as @dpcons
                        update: rechecked my radio with the RF24 "getting started" program and found the radio good. Updated my Arduino IDE. Still not working.
                          H
                          H
                          hard-shovel
                          wrote on last edited by hard-shovel
                          @OldSurferDude @dpcons Hi all,
                          The sample sketch could also be found using (File -> Examples -> MySensors -> Esp8266Gateway
                          As MySensors version 2.3.2 and ESP8266 core 3.0.2 combination does not work you need to change one or the other versions.
                          The simplest is to roll back the ESP8266 Core version to 2.7.4 and keep the MySensors 2.3.2 version
                          (Tools -> Board -> Board Manager)
                          Enter ESP8266 in search bar, then click within the ESP8266 data info box, click the select version pulldown.
                          Select 2.7.4 and then click Install.
                          Other option is to update the MySensors library to the development version 2.4.0-Alpha but that has to be done manually.
                          OldSurferDudeO 2 Replies Last reply
                          • H hard-shovel
                            OldSurferDudeO
                            OldSurferDudeO
                            OldSurferDude
                            @hard-shovel Thanks! Now I'm getting output to the monitor. I think I need to set up the IP address and the port 1883 for the MQTT broker. How is that done? I am also getting data from my Arduino node sensors :) I see "controller" but when I change that to my broker's address I get streaming ETH FAIL
                              OldSurferDudeO
                              OldSurferDudeO
                              OldSurferDude
                              The port was set to 5003 and setting it to 1883 (the default MQTT broker port) it now seems to work
                                H
                                H
                                hard-shovel
                                @OldSurferDude If connecting to a MQTT Broker i would have expected you to use the GatewayESP8266MQTTClient sketch.
                                as this is already setup with correct Port 1883 for MQTT and the publishing and subscription topics.
                                I did a quick test of a GatewayESP8266MQTTClient sketch with mosquitto and it works fine for me.
                                OldSurferDudeO 3 Replies Last reply
                                • H hard-shovel
                                  OldSurferDudeO
                                  OldSurferDudeO
                                  OldSurferDude
                                  @hard-shovel While it all seemed to be working, it appears that the ESP8266 MySensors Gateway was not passing the data onto the MQTT broker. Working, meaning that data from the Arduino sensors were getting to the Gateway, but that data was not getting to the broker. Here are some lines of the debug output:
                                  6217818 TSF:MSG:READ,133-133-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                  6217883 TSF:MSG:BC
                                  6217903 TSF:MSG:FPAR REQ,ID=133
                                  6217936 TSF:CKU:OK,FCTRL
                                  6217962 TSF:MSG:GWL OK
                                  6218281 !TSF:MSG:SEND,0-0-133-133,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                  Also, as an indication that data was not being passed from the Gateway to the broker, I had reset my MQTT Broker and subsequently monitored it with MQTT explorer. The topic "mysensors-out" was not created.
                                  I shut down the ESP8266 MySensors Gateway and restarted the my original one that is running on an RPi. Everything started running as expected.
                                  Thus, my conclusion.
                                  OK, so why isn't the ESP8266 MySensors Gateway passing on the data?
                                  • H hard-shovel
                                    OldSurferDudeO
                                    OldSurferDudeO
                                    OldSurferDude
                                    @hard-shovel I try the client
                                    • H hard-shovel
                                      OldSurferDudeO
                                      OldSurferDudeO
                                      OldSurferDude
                                      @hard-shovel client worked for me, too. That is, it sent the message "2.3.2" to topic "mygateway1-outx/0/255/0/0/18"
                                      • H hard-shovel
                                        OldSurferDudeO
                                        OldSurferDudeO
                                        OldSurferDude
                                        @hard-shovel I tried the client and it did indeed send the MySensors version message. But it does not pass along the messages from the Arduino nodes.
                                          H
                                          H
                                          hard-shovel
                                          #22
                                          @OldSurferDude have you set the MQTT user and MQTT passwords in the sketch and uncommented them as well?
                                          #define MY_MQTT_USER "MQTTusername2022"
                                          #define MY_MQTT_PASSWORD "MQTTpassword2022"
                                          what does your debug log look like?
                                          This sample is not connected correctly to the MQTT Broker
                                          10:33:26.151 -> dhcp client start...
                                          10:33:26.151 -> 341 TSM:INIT:GW MODE
                                          10:33:26.199 -> 364 TSM:READY:ID=0,PAR=0,DIS=0
                                          10:33:26.199 -> 396 MCO:REG:NOT NEEDED
                                          10:33:26.339 -> 505 GWT:TPC:CONNECTING...
                                          10:33:27.365 -> 1533 MCO:BGN:STP
                                          10:33:27.365 -> 1551 MCO:BGN:INIT OK,TSP=1
                                          10:33:27.412 -> 1579 TSM:READY:NWD REQ
                                          10:33:27.412 -> 1606 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                                          10:33:28.671 -> scandone
                                          10:33:35.993 -> pm open,type:2 0
                                          10:33:44.664 -> 18861 TSF:MSG:READ,254-254-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                          10:33:44.758 -> 18924 TSF:MSG:BC
                                          10:33:44.758 -> 18942 TSF:MSG:FPAR REQ,ID=254
                                          10:33:44.804 -> 18973 TSF:PNG:SEND,TO=0
                                          10:33:44.804 -> 18998 TSF:CKU:OK
                                          10:33:44.851 -> 19016 TSF:MSG:GWL OK
                                          10:33:45.459 -> 19646 TSF:MSG:SEND,0-0-254-254,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                          10:33:46.671 -> 20876 TSF:MSG:READ,254-254-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                          10:33:46.766 -> 20939 TSF:MSG:PINGED,ID=254,HP=1
                                          10:33:46.813 -> 20980 TSF:MSG:SEND,0-0-254-254,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                          10:33:46.860 -> 21057 TSF:MSG:READ,254-254-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                          This is working correctly
                                          10:36:34.908 -> dhcp client start...
                                          10:36:37.655 -> ip:192.168.1.202,mask:255.255.255.0,gw:192.168.1.254
                                          10:36:37.702 -> 7014 GWT:TPC:IP=192.168.1.202
                                          10:36:37.702 -> 7100 GWT:RMQ:CONNECTING...
                                          10:36:37.749 -> 7144 GWT:RMQ:OK
                                          10:36:37.795 -> 7161 GWT:TPS:TOPIC=mygateway4-out/0/255/0/0/18,MSG SENT
                                          10:36:44.792 -> pm open,type:2 0
                                          10:38:56.629 -> 146027 TSF:MSG:READ,254-254-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                          10:38:56.723 -> 146091 TSF:MSG:BC
                                          10:38:56.723 -> 146109 TSF:MSG:FPAR REQ,ID=254
                                          10:38:56.770 -> 146142 TSF:PNG:SEND,TO=0
                                          10:38:56.770 -> 146168 TSF:CKU:OK
                                          10:38:56.816 -> 146187 TSF:MSG:GWL OK
                                          10:38:57.655 -> 147013 TSF:MSG:SEND,0-0-254-254,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                          10:38:58.683 -> 148042 TSF:MSG:READ,254-254-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                          10:38:58.730 -> 148105 TSF:MSG:PINGED,ID=254,HP=1
                                          10:38:58.776 -> 148148 TSF:MSG:SEND,0-0-254-254,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                          10:38:58.869 -> 148226 TSF:MSG:READ,254-254-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                          10:38:58.916 -> 148294 TSF:MSG:SEND,0-0-254-254,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                          10:38:59.010 -> 148375 TSF:MSG:READ,254-254-0,s=255,c=0,t=17,pt=0,l=11,sg=0:2.4.0-alpha
                                          10:38:59.058 -> 148450 GWT:TPS:TOPIC=mygateway4-out/254/255/0/0/17,MSG SENT
                                          10:38:59.151 -> 148515 TSF:MSG:READ,254-254-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                          10:38:59.197 -> 148578 GWT:TPS:TOPIC=mygateway4-out/254/255/3/0/6,MSG SENT
                                          10:39:00.923 -> 150319 TSF:MSG:READ,254-254-0,s=255,c=3,t=11,pt=0,l=14,sg=0:MockMySensors
                                          10:39:01.017 -> 150398 GWT:TPS:TOPIC=mygateway4-out/254/255/3/0/11,MSG SENT
                                          10:39:01.064 -> 150462 TSF:MSG:READ,254-254-0,s=255,c=3,t=12,pt=0,l=4,sg=0:v0.5
                                          10:39:01.157 -> 150529 GWT:TPS:TOPIC=mygateway4-out/254/255/3/0/12,MSG SENT
                                          10:39:01.949 -> 151337 TSF:MSG:READ,254-254-0,s=1,c=0,t=0,pt=0,l=12,sg=0:Outside Door
                                          10:39:02.044 -> 151410 GWT:TPS:TOPIC=mygateway4-out/254/1/0/0/0,MSG SENT
                                          10:39:02.091 -> 151471 TSF:MSG:READ,254-254-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                          10:39:02.184 -> 151542 TSF:MSG:SEND,0-0-254-254,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                                          10:39:02.699 -> 152055 TSF:MSG:READ,254-254-0,s=255,c=3,t=0,pt=1,l=1,sg=0:83
