  3. Raspberry Pi 3 (RPI 3) gateway initialization loop
6 Posts 3 Posters 771 Views 3 Watching
  • OumuamuaO Offline
    OumuamuaO Offline
    Oumuamua
    Hi all,
    I have a working ESP8266 gateway with 2 nodes, but I want to move the gateway to my Raspberry.
    I followed all the instructions on the website and had a successful installation.
    However, I notice that the gateway enters a loop on its initialization and keeps sending the version of MySensors to the MQTT server.
    The gateway configuration is:
    ./configure --my-transport=rfm69 --my-rfm69-frequency=433 --my-is-rfm69hw --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-user=user --my-mqtt-password=password --my-mqtt-publish-topic-prefix=mygateway1-out --my-mqtt-subscribe-topic-prefix=mygateway1-in --my-mqtt-client-id=gw_01
    My Raspberry runs:
    Raspbian GNU/Linux 11 (bullseye)
    Where I run Openhab 3.3.0
    When I run mysgw or start the service, it keeps sending the same message over an over again (many times per second) as below:
    Aug 27 23:16:00 INFO  Starting gateway...
    Aug 27 23:16:00 INFO  Protocol version - 2.3.2
    Aug 27 23:16:00 DEBUG MCO:BGN:INIT GW,CP=RPNGL---,FQ=NA,REL=255,VER=2.3.2
    Aug 27 23:16:00 DEBUG TSF:LRT:OK
    Aug 27 23:16:00 DEBUG TSM:INIT
    Aug 27 23:16:00 DEBUG TSF:WUR:MS=0
    Aug 27 23:16:00 DEBUG TSM:INIT:TSP OK
    Aug 27 23:16:00 DEBUG TSM:INIT:GW MODE
    Aug 27 23:16:00 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
    Aug 27 23:16:00 DEBUG MCO:REG:NOT NEEDED
    Aug 27 23:16:00 DEBUG MCO:BGN:STP
    Aug 27 23:16:00 DEBUG MCO:BGN:INIT OK,TSP=1
    Aug 27 23:16:00 DEBUG GWT:RMQ:CONNECTING...
    Aug 27 23:16:00 DEBUG connected to 127.0.0.1
    Aug 27 23:16:00 DEBUG GWT:RMQ:OK
    Aug 27 23:16:00 DEBUG GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
    Aug 27 23:16:00 DEBUG TSM:READY:NWD REQ
    Aug 27 23:16:00 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    Aug 27 23:16:01 DEBUG GWT:RMQ:CONNECTING...
    Aug 27 23:16:01 DEBUG connected to 127.0.0.1
    Aug 27 23:16:01 DEBUG GWT:RMQ:OK
    Aug 27 23:16:01 DEBUG GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
    Many thanks for any help.
    OldSurferDudeO 1 Reply Last reply
    • OumuamuaO Oumuamua
      Hi all,
      My Raspberry runs:
      OldSurferDudeO Offline
      OldSurferDude
      @Oumuamua When you set
      you are saying your MQTT broker is on the same machine as your gateway. If, on your RPi you installed your broker with (what I do)
      sudo apt install mosquitto
      you will have to add the lines to /etc/mosquitto/mosquitto.conf
      allow_anonymous true
      listener 1883 0.0.0.0
      After that, reboot.
      Alas, this may not fix your problem. I see you're looping on connecting/connected/sent. I make the assumption that the debug message aren't quite accurate because ... well ... sometimes they aren't.
      Let us know if this works :)
      OSD
      • mfalkviddM Online
        mfalkviddM Online
        Add --extra-cxxflags="-DMY_DEBUG_VERBOSE_GATEWAY to the configure command and run make again. This will give more details in the debug log.
        Edit: the log file of your mqtt broker might give some iseful info as well.
        • OumuamuaO Offline
          OumuamuaO Offline
          Oumuamua
          @mfalkvidd and @OldSurferDude
          My thanks for the quick hints.
          Yes, Mosquitto is running on the same machine.
          I added --extra-cxxflags="-DMY_DEBUG_VERBOSE_GATEWAY to the configure file and also updated the Mosquitto conf as per @mfalkvidd suggestion.
          Unfortunately the log did change (see below).
          One important comment: the connection is actually successful with the MQTT server as I can see all the publications in it using MQTT Explorer. It seems to me that the problem is with the gateway in some way that keeps sending it non-stop.
          The problem happens if I just run mysgw or when I start the service.
          Aug 28 07:39:11 INFO  Starting gateway...
          Aug 28 07:39:11 INFO  Protocol version - 2.3.2
          Aug 28 07:39:11 DEBUG MCO:BGN:INIT GW,CP=RPNGL---,FQ=NA,REL=255,VER=2.3.2
          Aug 28 07:39:11 DEBUG TSF:LRT:OK
          Aug 28 07:39:11 DEBUG TSM:INIT
          Aug 28 07:39:11 DEBUG TSF:WUR:MS=0
          Aug 28 07:39:11 DEBUG TSM:INIT:TSP OK
          Aug 28 07:39:11 DEBUG TSM:INIT:GW MODE
          Aug 28 07:39:11 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
          Aug 28 07:39:11 DEBUG MCO:REG:NOT NEEDED
          Aug 28 07:39:11 DEBUG MCO:BGN:STP
          Aug 28 07:39:11 DEBUG MCO:BGN:INIT OK,TSP=1
          Aug 28 07:39:11 DEBUG GWT:RMQ:CONNECTING...
          Aug 28 07:39:11 DEBUG connected to 127.0.0.1
          Aug 28 07:39:11 DEBUG GWT:RMQ:OK
          Aug 28 07:39:11 DEBUG GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
          Aug 28 07:39:11 DEBUG TSM:READY:NWD REQ
          Aug 28 07:39:12 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
          Aug 28 07:39:12 DEBUG GWT:RMQ:CONNECTING...
          Aug 28 07:39:12 DEBUG connected to 127.0.0.1
          Aug 28 07:39:12 DEBUG GWT:RMQ:OK
          Aug 28 07:39:12 DEBUG GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
          Aug 28 07:39:13 DEBUG GWT:RMQ:CONNECTING...
          Aug 28 07:39:13 DEBUG connected to 127.0.0.1
          Aug 28 07:39:13 DEBUG GWT:RMQ:OK
          Aug 28 07:39:13 DEBUG GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
            OldSurferDude
            @Oumuamua said in Raspberry Pi 3 (RPI 3) gateway initialization loop:
            This is a clue (or a red herring) because there is a ? in the message.
            Hopefully @mfalkvidd can tell us what it means
            • OumuamuaO Offline
              OumuamuaO Offline
              Oumuamua
              Problem solved: I was using as --my-mqtt-client-id the same name as my previous broker.
              Thanks for your help all!
