  3. MySensors GW on rpi3
gateway
20 Posts 2 Posters 3.8k Views 2 Watching
  • K
    K
    Kurtsejr
    Yes I made a reboot, just made a new reboot - same result :-(
    • K Kurtsejr
      @Kurtsejr yes the gateway will start automatically at each boot, unless automatic start is disabled.
      • mfalkviddM
        To check if the gateway has started automatically, run sudo systemctl enable mysgw.service
        K 1 Reply Last reply
        • mfalkviddM
          @Kurtsejr I tested the gateway on a spare raspberry pi and it does indeed print lots of ERROR accept: Bad file descriptor when more than one instance of the gateway is started. The solution is easy: don't start two instances at the same time.
          The reason is actually printed in the log: ERROR bind: Address already in use but is easy to miss due to the many ERROR accept: Bad file descriptor
          INFO  Starting gateway...
          INFO  Protocol version - 2.4.0-alpha
          DEBUG MCO:BGN:INIT GW,CP=R-NGL---,FQ=NA,REL=0,VER=2.4.0-alpha
          ERROR Failed to bind!
          DEBUG MCO:BGN:STP
          DEBUG MCO:REG:NOT NEEDED
          DEBUG MCO:BGN:INIT OK,TSP=NA
            K
            K
            Kurtsejr
            @mfalkvidd said in MySensors GW on rpi3:
            Thanks for your reply
            I have run the command, result:
            pi@MySensor-GW:~ $ sudo systemctl enable mysgw.service
            pi@MySensor-GW:~ $
            How do I remove if more that one instance is started? - I will try to google it. Perhaps it's easier to start from beginning again
              DEBUG MCO:BGN:STP
              K
              K
              Kurtsejr
              @mfalkvidd I decided to reinstall, start from scratch by installing a new pi image om my SDHC disk, but trying to install the GW software I get this message:
              pi@MySensor-GW:~ $ pwd
              /home/pi
              pi@MySensor-GW:~ $ sudo git clone https://github.com/mysensors/MySensors.git --branch development
              Cloning into 'MySensors'...
              fatal: unable to access 'https://github.com/mysensors/MySensors.git/': Couldn't connect to server
              pi@MySensor-GW:~ $ sudo git clone https://github.com/mysensors/MySensors.git --branch master
              pi@MySensor-GW:~ $
              Has something changed? or is it github that does not response?
              • K Kurtsejr
                /home/pi
                pi@MySensor-GW:~ $
                @Kurtsejr said in MySensors GW on rpi3:
                The Raspberry Pi probably doesn't have the right settings for connecting to Internet. What happens if you run ping google.com for example? You should get something like this:
                ping google.com
                PING google.com (142.250.179.142) 56(84) bytes of data.
                64 bytes from ams17s10-in-f14.1e100.net (142.250.179.142): icmp_seq=1 ttl=58 time=33.3 ms
                64 bytes from ams17s10-in-f14.1e100.net (142.250.179.142): icmp_seq=2 ttl=58 time=33.4 ms
                If you don't get any replies, the raspberry pi doesn't have a working internet connection.
                • K Kurtsejr
                  pi@MySensor-GW:~ $
                  sudo systemctl stop mysgw.service will stop the gateway service if it is currently running. It will start automatically again after reboot (unless disabled).
                  sudo systemctl disable mysgw.service will disable autostart, but will keep the service running if it has already been started.
                  https://www.linuxtrainingacademy.com/systemd-cheat-sheet/ can be a good place to start
                    ping google.com
                    K
                    K
                    Kurtsejr
                    @mfalkvidd You are right, no network connection - strange I will investigate, thanks!
                    • K Kurtsejr
                      K
                      K
                      Kurtsejr
                      @Kurtsejr Now I have network connection, made an update and upgrade, and now I can install from github. Changed to rf24 radio, and could see that ethernet was default.
                      pi@MySensor-GW:~/MySensors $ sudo ./configure --my-transport=rf24
                      [OK] SPI driver detected:BCM.
                      [SECTION] Gateway configuration.
                      [OK] Type: ethernet.
                      [OK] Transport: rf24.
                      [OK] Signing: Disabled.
                      [OK] Encryption: Disabled.
                      [OK] CPPFLAGS: -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloa t-abi=hard -DMY_RADIO_RF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX _ARCH_RASPBERRYPI
                      [OK] CXXFLAGS: -std=c++11
                      [OK] Init system detected: systemd.
                      [OK] Saved.
                      [OK] Finished.
                      Next was to do a make, result:
                      pi@MySensor-GW:~/MySensors $ sudo make
                      g++ -MT build/hal/architecture/Linux/drivers/core/interrupt.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_RF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -std=c++11 -I. -I./core -I./hal/architecture/Linux/drivers/core -I./hal/architecture/Linux/drivers/BCM -c hal/architecture/Linux/drivers/core/interrupt.cpp -o build/hal/architecture/Linux/drivers/core/interrupt.o
                      hal/architecture/Linux/drivers/core/interrupt.cpp:33:10: fatal error: stropts.h: No such file or directory
                      33 | #include <stropts.h>
                      compilation terminated.
                      make: *** [Makefile:99: build/hal/architecture/Linux/drivers/core/interrupt.o] Error 1
                      So it seems that something is missing, something linux basic ....
                      mfalkviddM K 2 Replies Last reply
                      • K Kurtsejr
                        [OK] Saved.
                        [OK] Finished.
                        Nice work on the internet connectivity @Kurtsejr
                        It is an issue on some (newer?) linux versions. It has been fixed in the development version of MySensors. You can switch to the development version, or add the fix yourself.
                        See https://github.com/mysensors/MySensors/issues/1431 and https://github.com/mysensors/MySensors/pull/1446/files
                        Sorry for the inconvenience.
                        • K Kurtsejr
                          [OK] Saved.
                          [OK] Finished.
                          K
                          K
                          Kurtsejr
                          @Kurtsejr Thanks a lot!
                          I removed the entry in the interrupt.cpp fil, and was then able to do a make , "make" - with some warnings, but make ended up writing this to me:
                          /home/pi/MySensors/./hal/architecture/Linux/drivers/core/config.h:39: multiple d efinition of `conf'; build/hal/architecture/Linux/drivers/core/config.o:/home/pi /MySensors/hal/architecture/Linux/drivers/core/config.h:39: first defined here
                          collect2: error: ld returned 1 exit status
                          make: *** [Makefile:80: bin/mysgw] Error 1
                          pi@MySensor-GW:~/MySensors $ sudo ./bin/mysgw -c
                          sudo: ./bin/mysgw: command not found
                          This means that I do not have a mysgw file in "bin" - bin dir is empty
                          • K Kurtsejr
                            K
                            K
                            Kurtsejr
                            @Kurtsejr Thanks
                            Everything seems to be working, used the "dev version" - thanks for helping, I started with a new image.
                            • K Kurtsejr
                              @Kurtsejr Thanks
                              Nice work @Kurtsejr, thanks for reporting back
