  2. Announcements
  3. 💬 Water Meter Pulse Sensor
109 Posts 37 Posters 67.0k Views 35 Watching
  • rejoe2R rejoe2
    ...just let the node count some pulses (your code states: FALLING). So just pull the counter PIN (here: D3) to ground several times.
    B
    B
    bereska
    @rejoe2 i did like you said, still no show in HA
    here is the serial log:
     __  __       ____
    16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.0
    26 TSM:INIT
    28 TSF:WUR:MS=0
    34 !TSM:INIT:TSP FAIL
    36 TSM:FAIL:CNT=1
    38 TSM:FAIL:DIS
    40 TSF:TDI:TSL
     __  __       ____
    26 TSM:INIT
    28 TSF:WUR:MS=0
    34 TSM:INIT:TSP OK
    36 TSM:INIT:STATID=6
    38 TSF:SID:OK,ID=6
    40 TSM:FPAR
    77 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    532 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    538 TSF:MSG:FPAR OK,ID=0,D=1
    624 TSF:MSG:READ,31-31-6,s=255,c=3,t=8,pt=1,l=1,sg=0:1
    1267 TSF:MSG:READ,21-21-6,s=255,c=3,t=8,pt=1,l=1,sg=0:1
    1546 TSF:MSG:READ,41-41-6,s=255,c=3,t=8,pt=1,l=1,sg=0:1
    2088 TSM:FPAR:OK
    2088 TSM:ID
    2091 TSM:ID:OK
    2093 TSM:UPL
    2097 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2103 TSF:MSG:READ,0-0-6,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2109 TSF:MSG:PONG RECV,HP=1
    2113 TSM:UPL:OK
    2115 TSM:READY:ID=6,PAR=0,DIS=1
    2119 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2127 TSF:MSG:READ,0-0-6,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2138 TSF:MSG:SEND,6-6-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.0
    2148 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    2242 TSF:MSG:READ,0-0-6,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    2250 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=OK:Water Meter
    2260 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
    2273 TSF:MSG:SEND,6-6-0-0,s=1,c=0,t=21,pt=0,l=0,sg=0,ft=0,st=OK:
    2281 MCO:REG:REQ
    2289 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    2297 TSF:MSG:READ,0-0-6,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    2304 MCO:PIM:NODE REG=1
    2306 MCO:BGN:STP
    2310 TSF:MSG:SEND,6-6-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    2318 MCO:BGN:INIT OK,TSP=1
    32319 TSF:MSG:SEND,6-6-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    • rejoe2R
      rejoe2R
      rejoe2
      wrote on last edited by rejoe2
      #99
      @bereska said in 💬 Water Meter Pulse Sensor:
      Logparser states: there was nothing counted (empty payload). So make sure, there really was counted anything.
      (I didn't check your sketch, just assuming, it's the default one and everything is wired correctly; if that's the case, you should be able to see a different payload than nothing or "0", that your controller might treat as non existent).
        Great work @bart59 !
        Do you have any indication on how long battery life you will get with this setup?
        stevefury
        @mfalkvidd how looks the sensor now with the modifications? and how to wire this?
        • S stevefury
          #101
          @stevefury sorry, I don't understand. Which modifications are you referring to?
          • I
            I
            ibibiuooui
            I'm just getting this....
            16:57:15.660 -> 10091 TSM:FAIL:RE-INIT
            16:57:15.660 -> 10093 TSM:INIT
            16:57:15.660 -> 10101 !TSM:INIT:TSP FAIL
            16:57:15.660 -> 10103 TSM:FAIL:CNT=2
            16:57:15.660 -> 10107 TSM:FAIL:DIS
            16:57:15.713 -> 10111 TSF:TDI:TSL
            • rejoe2R
              rejoe2R
              rejoe2
              @ibibiuooui said in 💬 Water Meter Pulse Sensor:
              !TSM:INIT:TSP FAIL
              See https://www.mysensors.org/build/parser: There's a problem in the initialisation of your transceiver (whatever it may be). So first check wiring, see https://forum.mysensors.org/topic/666/read-this-first-it-could-save-you-a-lot-of-time for further details. If that doesn't help, imo you should open up a seperate thread.
              • CrankyCoderC
                CrankyCoderC
                CrankyCoder
                wrote on last edited by CrankyCoder
                #104
                I am finally getting around to trying this out. I was playing with just trying to see if i can get the pulses. First thing i did was take an old compass and put it beside the meter and had someone turn on the water. I could definitely see the compass needle pull a little as the water was flowing. So I assumed that pull was enough to be detectable with my hall effect sensor. I have tried a couple, and just can't seem to get it to pick up.
                If i use a magnet, simple code will detect the pulse and the green led on the sensor lights up.
                But no matter where I put that sensor near the meter it just doesn't seem to detect it. Not quite sure what's happening.
                The meter i have is this one.
                https://www.badgermeter.com/resources/add29b88-1ffb-49c9-80ab-bb8697bd6d1a/absolute digital encoder product data sheet ade-ds-00183-en.pdf/
                Not sure if anyone has any recommendation on which hall effect sensor would be the best for this but ill take suggestions lol
                My sensor I am testing with is
                3144E Hall Effect Sensor
                Doesn't have a sensitivity dial but the recommended one on this build page didn't either.
                Home Automation Tinkerer
                www.CrankyCoder.net
                Gateway: MQTTClientGateway
                MySensors: 2.3
                • bart59B bart59
                  I wanted to operate my water pulse meter on batteries and also get the water flow. The original design had the following issues with that:
                  • Incorrect flow calc: micros() was used to calculate the flow, however micros() wraps every 70 minutes which looks like a huge flow (which is then discarded in code)
                  • Volume calc: millis() wraps every 50 days which is not handled correctly either
                  • Too much current for battery use: The IR LED of the TCRT5000 is always on and the LM393 comparator is also taking a few mA's
                  • Could not report flow in sleep mode because millis() does not increment on sleep - need to do this based on calculation of total sleep time. We now simply calculate the number of pulses per minute and deduct the flow
                  • I also had issued with the data transport reliability, so I added error counters (which show up on the Gateway as distance sensors)
                  • I also wanted to provide a measurement counter to the gateway (that counts up each time a message is sent)
                  • The sensor will reboot itself when too many errors occur
                  So I modified the circuit of the IR sensor:
                  • Assumption that the wheel of the water meter turns slowly (takes at least a few seconds to turn around)
                  • We will wake up every 500 millisecond to turn on the IR LED connected to PIN 8. Pin 8 also powers the photo transistor that measures the reflection
                  • I removed the power from the opamp circuit that is linked to the photo transistor
                  • The voltage from the photo transistor is then read using an analog read on A1. Based on a threshold value we will deduct if the mirror on the water meter is in view
                  • Pin 7 is connected to a learning switch which will turn the device in a specific mode and the min/max values on A1 are used to calculate the value of the threshold (which is then stored in the EEPROM)
                  • After 30 seconds in learning mode, the new threshold is established and the LED on Pin 6 will show the actual on/off mirror signals, so you can see the pulses are correctly counted
                  • switch back the DIP switch on Pin 7 to bring back normal mode
                  • The circuit also contains the battery voltage sensor circuit (I am using a 1.5V battery and step up circuit). So the resistors used are 470k from + pole of battery to the A0 input and 1 M ohm from A0 to ground
                   * Version 1.0 - Henrik Ekblad
                   * Version 1.1 - GizMoCuz
                   * Version 1.2 - changed BM: using low power separate circuit for infra red on pin 8 + analog A1
                   * ISSUES WITH ORIGINAL CODE
                   * Incorrect flow calc: micros() was used to calculate the flow, however micros() is wraps every 70 minutes which looks like a huge flow (which is discarded)
                   * Volume calc: millis() wraps every 50 days which is not handled correctly
                   * Too much current for battery use: The IR LED of the TCRT5000 is always on and the LM393 comparator is also taking a few mA's
                   * Could not report flow in sleep mode because millis() does not increment on sleep - need to do this based on calculation of total sleep time
                   * MODIFIED CIRCUIT IR SENSOR
                   * Assumption that the wheel of the water meter turns slowly (takes at least a few seconds to turn around)
                   * We will wake up every second to turn on the IR LED (connected to PIN 8). Pin 8 also powers the photo transistor that measures the reflection
                   * The voltage from the photo transistor is then read using an analog read on A1. Based on a treshold value we will deduct if the mirror is in view
                   * Pin 7 is connected to a learning switch which will turn the device in continous mode and the min/max values on A1 are used to recalc the treshold
                   * during a 30 second period. After this period the new treshold is established and the LED on Pin 6 will show the actual on/off mirror signals
                   * http://www.mysensors.org/build/pulse_water
                  // BOARD: PRO MINI 3.3V/ 8Mhz ATMEGA328 8Mhz
                  #define MY_NODE_ID 10                 // hard code the node number
                  #define SENSOR_POWER 8                // pin that will provide power to IR LED + sense circuit
                  #define IR_SENSE_PIN  A1              // input for IR voltage
                  #define BATTERY_SENSE_PIN  A0         // select the input pin for the battery sense point
                  #define LEARN_SWITCH_PIN 7            // switch (SW1 on battery module) to turn on learning mode (low==on)
                  #define LEARN_LED_PIN 6               // LED feedback during learning mode (LED on battery module)
                  #define LEARN_TIME 30                 // number of seconds we will keep learn loop
                  #define PULSE_FACTOR 1000             // Nummber of blinks per m3 of your meter (One rotation/1 liter)
                  #define MAX_FLOW 80                   // Max flow (l/min) value to report. This filters outliers.
                  #define CHILD_ID 1                    // Id of the sensor child (contains 3 subs: V_FLOW, V_VOLUME, VAR1)
                  #define CHILD_PINGID 2                // ID of ping counter
                  #define CHILD_ERRID 3                 // ID of error counter
                  #define CHECK_FREQUENCY 500           // time in milliseconds between loop (where we check the sensor) - 500ms
                  #define MIN_SEND_FREQ 60              // Minimum time between send (in multiplies of CHECK_FREQUENCY). We don't want to spam the gateway (30 seconds)
                  #define MAX_SEND_FREQ 1200            // Maximum time between send (in multiplies of CHECK_FREQUENCY). We need to show we are alive (600 sec/10 min)
                  #define IR_ON_SETTLE 2                // number of milliseconds after we turned on the IR LED and we assume the receive signal is stable (in ms)
                  #define EE_TRESHOLD 10                // config addresses 0 + 1 used for treshold from learning (loadState() returns only uint8 value)
                  #define TRESHOLD_MARGIN 3             // additional margin before we actually see a one or zero
                  #define RESETMIN 5                    // number of cycle times (either 30 sec of 10 min) we consistently need to have transmission errors before we perform hard reset
                  MyMessage volumeMsg(CHILD_ID,V_VOLUME); // display volume and flow on the same CHILD_ID
                  MyMessage flowMsg(CHILD_ID,V_FLOW); // flow
                  MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
                  MyMessage pingMsg(CHILD_PINGID,V_DISTANCE); // use distance to keep track of changing value
                  MyMessage errMsg(CHILD_ERRID,V_DISTANCE); // use distance to keep track of changing value
                  double ppl = ((double)PULSE_FACTOR / 1000.0);    // Pulses per liter
                  unsigned int oldBatteryPcnt = 0;          // check if changed
                  unsigned int minsendcnt = MIN_SEND_FREQ;  // counter for keeping minimum intervals between sending
                  unsigned int maxsendcnt = MAX_SEND_FREQ;  // counter for keeping maximum intervals between sending
                  unsigned int treshold = 512;              // threshold value when to swap on/off for pulse
                  unsigned long pulseCount = 0;             // total volume of this pulse meter (value stored/received on gateway on pcReceived)
                  unsigned long oldPulseCount = 0;          // to see if we have received something
                  boolean pcReceived = false;               // received volume from prior reboot
                  boolean onoff = false;                    // sensor value above/below treshold
                  unsigned int intervalcnt = 0;             // number of cycles between last period (for flow calculation)
                  double flow = 0;                          // maintain flow
                  double oldflow = 0;                       // keep prior flow (only send on change)
                  unsigned int learntime=LEARN_TIME*2;      // timer for learning period
                  unsigned int learnlow = 1023;             // lowest value found during learning
                  unsigned int learnhigh = 0;               // highest value found during learning
                  boolean learnsaved = false;               // have saved learned value
                  unsigned long pingcnt = 0;
                  unsigned long errcnt = 0;                 // error count
                  unsigned int errcnt2 = 0;                 // error counter set to 0 when sending is ok
                  void(* resetFunc) (void) = 0;//declare reset function at address 0 (for rebooting the Arduino)
                    // make sure a few vars have the right init value after software reboot
                    pingcnt = 0;
                    pcReceived = false;
                    pulseCount = oldPulseCount = 0;
                    // setup hardware
                    pinMode(SENSOR_POWER, OUTPUT);
                    digitalWrite(SENSOR_POWER, LOW);
                    pinMode(LEARN_SWITCH_PIN, INPUT_PULLUP);
                    pinMode(LEARN_LED_PIN, INPUT);      // default is input because this pin also has SW2 of battery block
                    // Fetch last known pulse count value from gateway
                    request(CHILD_ID, V_VAR1);
                    // Fetch threshold value from EE prom
                    treshold = readEeprom(EE_TRESHOLD);
                    if (treshold<30 || treshold>1000) treshold = 512;   // wrong value in EEprom, take default
                    Serial.print("Treshold: ");
                    Serial.println(treshold);
                    // use the 1.1 V internal reference for the battery and IR sensor
                     analogReference(INTERNAL1V1);
                     analogReference(INTERNAL);
                    analogRead(IR_SENSE_PIN); // settle analogreference value
                    wait(CHECK_FREQUENCY); // wait a bit
                  void presentation()  {
                    sendSketchInfo("Water Meter", "1.2");
                    // Register this device as Waterflow sensor
                    present(CHILD_ID, S_WATER);
                    present(CHILD_PINGID, S_DISTANCE);
                    present(CHILD_ERRID, S_DISTANCE);
                    if (digitalRead(LEARN_SWITCH_PIN)==LOW) {
                      pinMode(LEARN_LED_PIN, OUTPUT);
                      digitalWrite(SENSOR_POWER, HIGH);
                      intervalcnt = 0;
                      learn_loop();
                      learnlow = 1023;
                      learnhigh = 0;
                      normal_loop();
                  void learn_loop() {
                    // will run into this loop as long as we are learning
                    wait(500);
                    unsigned int sensorValue = analogRead(IR_SENSE_PIN);
                    Serial.print("IR: ");
                    Serial.print(sensorValue);
                    if (learntime>0) {
                      // still learning
                      learntime--;
                      learnsaved = false;
                      digitalWrite(LEARN_LED_PIN, !digitalRead(LEARN_LED_PIN));  // blink led
                      if (sensorValue < learnlow) {
                        learnlow = sensorValue;
                        Serial.println(" Lowest");
                      } else if (sensorValue > learnhigh) {
                        learnhigh = sensorValue;
                        Serial.println(" Highest");
                      } else Serial.println();
                      if (!learnsaved) {
                        treshold = (learnhigh + learnlow)/2;
                        storeEeprom(EE_TRESHOLD, treshold);
                      learnsaved = true;
                      // just display using LED
                      digitalWrite(LEARN_LED_PIN, sensorValue>treshold);
                      Serial.println((sensorValue>treshold ? " on" : " off"));
                  void normal_loop() {
                    unsigned long start_loop = millis();    // to allow adjusting wait time
                    intervalcnt++;
                    // we start doing a measurement
                    wait(IR_ON_SETTLE);
                    #ifdef MY_DEBUG_DETAIL
                    Serial.println(sensorValue);
                    boolean nowvalue = onoff;
                    if (onoff && (sensorValue<treshold-TRESHOLD_MARGIN)) nowvalue = false;
                    if (!onoff && (sensorValue>treshold+TRESHOLD_MARGIN)) nowvalue = true;
                    if (nowvalue != onoff) {
                      // we have a pulse, only count on upwards pulse
                      onoff = nowvalue;
                      if (onoff) {
                        pulseCount++;
                        #ifdef MY_DEBUG
                        Serial.print("p: ");
                        Serial.println(pulseCount);
                    if (minsendcnt>0) minsendcnt--;
                    if (maxsendcnt>0) maxsendcnt--;
                    // send minimum interval when we have pulse changes or if we had some flow the prior time or send on timeout
                    if ((minsendcnt==0 && (pulseCount != oldPulseCount)) || (minsendcnt==0 && oldflow != 0) || maxsendcnt==0) {
                      if (!pcReceived) {   //Last Pulsecount not yet received from controller, request it again
                        Serial.print("Re-request var1 ..");
                  // Prevent flooding the gateway with re-requests,,, wait at least 1000 ms for gateway (cannot be sleep or smartSleep
                        wait(2*CHECK_FREQUENCY);
                        return;
                      pingcnt++;
                      sensorValue = analogRead(BATTERY_SENSE_PIN);
                      // ((1e6+470e3)/1e6)*1.1 = Vmax = 1.67 Volts
                      // 1.67/1023 = Volts per bit = 0.00158065
                      Serial.print("Battery %: ");
                      Serial.println(batteryPcnt);
                        oldBatteryPcnt = batteryPcnt;
                      double volume = ((double)pulseCount/((double)PULSE_FACTOR));
                      flow = ((double) (pulseCount-oldPulseCount)) * (60000.0 / ((double) intervalcnt*(double) CHECK_FREQUENCY)) / ppl;  // flow in liter/min
                      #ifdef MY_DEBUG
                      Serial.print("pulsecount:");
                      Serial.print("volume:");
                      Serial.println(volume, 3);
                      Serial.print("l/min:");
                      Serial.println(flow);
                      bool b = send(lastCounterMsg.set(pulseCount));  // Send  pulsecount value to gw in VAR1
                      if (b) errcnt2=0; else { errcnt++; errcnt2++; }
                      b = send(volumeMsg.set(volume, 3));               // Send volume (set function 2nd argument is resolution)
                      b = send(flowMsg.set(flow, 2));                   // Send flow value to gw
                      b = send(pingMsg.set(pingcnt));                   // ensure at least this var has a different value
                      b = send(errMsg.set(errcnt2+((float) errcnt2/100),2));    // ensure we always send error count
                      oldPulseCount = pulseCount;
                      intervalcnt = 0;
                      oldflow = flow;
                      if (errcnt2>= (5*RESETMIN)) {
                        Serial.println("Reset");
                        wait(300);
                        resetFunc(); //call reset to reboot the Arduino
                  // calculate how long it took to process all of this. then go to sleep for the remaining period
                    unsigned long end_loop = millis();
                    if (end_loop - start_loop < CHECK_FREQUENCY)
                      sleep(CHECK_FREQUENCY - (end_loop > start_loop ? end_loop - start_loop : 0));
                    if (message.type==V_VAR1) {
                      unsigned long gwPulseCount=message.getULong();
                      pulseCount += gwPulseCount;
                      oldPulseCount += gwPulseCount;
                      flow=oldflow=0;
                      Serial.print("Received last pulse count from gw:");
                      pcReceived = true;
                  void storeEeprom(int pos, int value) {
                      // function for saving the values to the internal EEPROM
                      // value = the value to be stored (as int)
                      // pos = the first byte position to store the value in
                      // only two bytes can be stored with this function (max 32.767)
                      saveState(pos, ((unsigned int)value >> 8 ));
                      pos++;
                      saveState(pos, (value & 0xff));
                  int readEeprom(int pos) {
                      // function for reading the values from the internal EEPROM
                      // pos = the first byte position to read the value from
                      int hiByte;
                      int loByte;
                      hiByte = loadState(pos) << 8;
                      pos++;
                      loByte = loadState(pos);
                      return (hiByte | loByte);
                  Emmanuel AbrahamE
                  Emmanuel AbrahamE
                  Emmanuel Abraham
                  @bart59 Can you post full circuit diagram for the modified code you made?
                  • Paolo RendanoP
                    Paolo RendanoP
                    Paolo Rendano
                    I made some improvements on this sketch. Please review them here: https://github.com/mysensors/MySensors/pull/1540
                    with these changes you will have:
                    1 - factory reset
                    2 - automatic home assistant entities creation
                    3 - counter correction from home assistant using service notify.mysensors
                    4 - fixed counter automatically incremented by 1 at each device restart (due to arduino library interrupt bug)
                    5- other tiny improvements
                    • J
                      J
                      JeeLet
                      wrote on last edited by JeeLet
                      #107
                      Thanks for the feedback
                      For those who think MySensors is finished, the proof is in the pudding, thousands of systems are functional :earth_asia:
                        StephanXL
                        I really like the update you did for Home Assistant integration.
                        But: I do not really understand, how to correctly send the VALUE_TO_ADD.
                        This is what I tried to add 967.067 m³:
                        service: notify.mysensors
                        data:
                          message: VALUE_TO_ADD
                          target: text.water_meter_100_2
                          data: 967067
                        But I just get this error message:
                        Fehler beim Aufrufen des Diensts notify.mysensors. expected dict for dictionary value @ data['data']. Got None
                        These are my newly found entities:
                        What is wrong here?
                        S 1 Reply Last reply
                        • S StephanXL
                          data:
                            data: 967067
                          What is wrong here?
                          StephanXL
                          I finally got this to work. Unlike what the description here says, this is how to update the value:
                          In Home Assistant, go to Developer->Service->YAML mode:
                          service: text.set_value
                          data:
                            value: "967067"
                          target:
                            entity_id: text.water_meter_100_2
                          (change 967067 with the value you want to add to the current counter)
                          The service "notify.mysensors" seems to be deprecated by Home Assistant.
