  2. Announcements
  3. 💬 Water Meter Pulse Sensor
109 Posts 37 Posters 67.0k Views 35 Watching
    Great work @bart59 !
    Do you have any indication on how long battery life you will get with this setup?
    stevefury
    @mfalkvidd how looks the sensor now with the modifications? and how to wire this?
    • S stevefury
      #101
      @stevefury sorry, I don't understand. Which modifications are you referring to?
      • I
        I
        ibibiuooui
        I'm just getting this....
        16:57:15.660 -> 10091 TSM:FAIL:RE-INIT
        16:57:15.660 -> 10093 TSM:INIT
        16:57:15.660 -> 10101 !TSM:INIT:TSP FAIL
        16:57:15.660 -> 10103 TSM:FAIL:CNT=2
        16:57:15.660 -> 10107 TSM:FAIL:DIS
        16:57:15.713 -> 10111 TSF:TDI:TSL
        • rejoe2R
          rejoe2R
          rejoe2
          @ibibiuooui said in 💬 Water Meter Pulse Sensor:
          !TSM:INIT:TSP FAIL
          See https://www.mysensors.org/build/parser: There's a problem in the initialisation of your transceiver (whatever it may be). So first check wiring, see https://forum.mysensors.org/topic/666/read-this-first-it-could-save-you-a-lot-of-time for further details. If that doesn't help, imo you should open up a seperate thread.
          • CrankyCoderC
            CrankyCoderC
            CrankyCoder
            wrote on last edited by CrankyCoder
            #104
            I am finally getting around to trying this out. I was playing with just trying to see if i can get the pulses. First thing i did was take an old compass and put it beside the meter and had someone turn on the water. I could definitely see the compass needle pull a little as the water was flowing. So I assumed that pull was enough to be detectable with my hall effect sensor. I have tried a couple, and just can't seem to get it to pick up.
            If i use a magnet, simple code will detect the pulse and the green led on the sensor lights up.
            But no matter where I put that sensor near the meter it just doesn't seem to detect it. Not quite sure what's happening.
            The meter i have is this one.
            https://www.badgermeter.com/resources/add29b88-1ffb-49c9-80ab-bb8697bd6d1a/absolute digital encoder product data sheet ade-ds-00183-en.pdf/
            Not sure if anyone has any recommendation on which hall effect sensor would be the best for this but ill take suggestions lol
            My sensor I am testing with is
            3144E Hall Effect Sensor
            Doesn't have a sensitivity dial but the recommended one on this build page didn't either.
            Home Automation Tinkerer
            www.CrankyCoder.net
            Gateway: MQTTClientGateway
            MySensors: 2.3
            • bart59B bart59
              I wanted to operate my water pulse meter on batteries and also get the water flow. The original design had the following issues with that:
              • Incorrect flow calc: micros() was used to calculate the flow, however micros() wraps every 70 minutes which looks like a huge flow (which is then discarded in code)
              • Volume calc: millis() wraps every 50 days which is not handled correctly either
              • Too much current for battery use: The IR LED of the TCRT5000 is always on and the LM393 comparator is also taking a few mA's
              • Could not report flow in sleep mode because millis() does not increment on sleep - need to do this based on calculation of total sleep time. We now simply calculate the number of pulses per minute and deduct the flow
              • I also had issued with the data transport reliability, so I added error counters (which show up on the Gateway as distance sensors)
              • I also wanted to provide a measurement counter to the gateway (that counts up each time a message is sent)
              • The sensor will reboot itself when too many errors occur
              So I modified the circuit of the IR sensor:
              • Assumption that the wheel of the water meter turns slowly (takes at least a few seconds to turn around)
              • We will wake up every 500 millisecond to turn on the IR LED connected to PIN 8. Pin 8 also powers the photo transistor that measures the reflection
              • I removed the power from the opamp circuit that is linked to the photo transistor
              • The voltage from the photo transistor is then read using an analog read on A1. Based on a threshold value we will deduct if the mirror on the water meter is in view
              • Pin 7 is connected to a learning switch which will turn the device in a specific mode and the min/max values on A1 are used to calculate the value of the threshold (which is then stored in the EEPROM)
              • After 30 seconds in learning mode, the new threshold is established and the LED on Pin 6 will show the actual on/off mirror signals, so you can see the pulses are correctly counted
              • switch back the DIP switch on Pin 7 to bring back normal mode
              • The circuit also contains the battery voltage sensor circuit (I am using a 1.5V battery and step up circuit). So the resistors used are 470k from + pole of battery to the A0 input and 1 M ohm from A0 to ground
               * Version 1.0 - Henrik Ekblad
               * Version 1.1 - GizMoCuz
               * Version 1.2 - changed BM: using low power separate circuit for infra red on pin 8 + analog A1
               * ISSUES WITH ORIGINAL CODE
               * Incorrect flow calc: micros() was used to calculate the flow, however micros() is wraps every 70 minutes which looks like a huge flow (which is discarded)
               * Volume calc: millis() wraps every 50 days which is not handled correctly
               * Too much current for battery use: The IR LED of the TCRT5000 is always on and the LM393 comparator is also taking a few mA's
               * Could not report flow in sleep mode because millis() does not increment on sleep - need to do this based on calculation of total sleep time
               * MODIFIED CIRCUIT IR SENSOR
               * Assumption that the wheel of the water meter turns slowly (takes at least a few seconds to turn around)
               * We will wake up every second to turn on the IR LED (connected to PIN 8). Pin 8 also powers the photo transistor that measures the reflection
               * The voltage from the photo transistor is then read using an analog read on A1. Based on a treshold value we will deduct if the mirror is in view
               * Pin 7 is connected to a learning switch which will turn the device in continous mode and the min/max values on A1 are used to recalc the treshold
               * during a 30 second period. After this period the new treshold is established and the LED on Pin 6 will show the actual on/off mirror signals
               * http://www.mysensors.org/build/pulse_water
              // BOARD: PRO MINI 3.3V/ 8Mhz ATMEGA328 8Mhz
              #define MY_NODE_ID 10                 // hard code the node number
              #define SENSOR_POWER 8                // pin that will provide power to IR LED + sense circuit
              #define IR_SENSE_PIN  A1              // input for IR voltage
              #define BATTERY_SENSE_PIN  A0         // select the input pin for the battery sense point
              #define LEARN_SWITCH_PIN 7            // switch (SW1 on battery module) to turn on learning mode (low==on)
              #define LEARN_LED_PIN 6               // LED feedback during learning mode (LED on battery module)
              #define LEARN_TIME 30                 // number of seconds we will keep learn loop
              #define PULSE_FACTOR 1000             // Nummber of blinks per m3 of your meter (One rotation/1 liter)
              #define MAX_FLOW 80                   // Max flow (l/min) value to report. This filters outliers.
              #define CHILD_ID 1                    // Id of the sensor child (contains 3 subs: V_FLOW, V_VOLUME, VAR1)
              #define CHILD_PINGID 2                // ID of ping counter
              #define CHILD_ERRID 3                 // ID of error counter
              #define CHECK_FREQUENCY 500           // time in milliseconds between loop (where we check the sensor) - 500ms
              #define MIN_SEND_FREQ 60              // Minimum time between send (in multiplies of CHECK_FREQUENCY). We don't want to spam the gateway (30 seconds)
              #define MAX_SEND_FREQ 1200            // Maximum time between send (in multiplies of CHECK_FREQUENCY). We need to show we are alive (600 sec/10 min)
              #define IR_ON_SETTLE 2                // number of milliseconds after we turned on the IR LED and we assume the receive signal is stable (in ms)
              #define EE_TRESHOLD 10                // config addresses 0 + 1 used for treshold from learning (loadState() returns only uint8 value)
              #define TRESHOLD_MARGIN 3             // additional margin before we actually see a one or zero
              #define RESETMIN 5                    // number of cycle times (either 30 sec of 10 min) we consistently need to have transmission errors before we perform hard reset
              MyMessage volumeMsg(CHILD_ID,V_VOLUME); // display volume and flow on the same CHILD_ID
              MyMessage flowMsg(CHILD_ID,V_FLOW); // flow
              MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
              MyMessage pingMsg(CHILD_PINGID,V_DISTANCE); // use distance to keep track of changing value
              MyMessage errMsg(CHILD_ERRID,V_DISTANCE); // use distance to keep track of changing value
              double ppl = ((double)PULSE_FACTOR / 1000.0);    // Pulses per liter
              unsigned int oldBatteryPcnt = 0;          // check if changed
              unsigned int minsendcnt = MIN_SEND_FREQ;  // counter for keeping minimum intervals between sending
              unsigned int maxsendcnt = MAX_SEND_FREQ;  // counter for keeping maximum intervals between sending
              unsigned int treshold = 512;              // threshold value when to swap on/off for pulse
              unsigned long pulseCount = 0;             // total volume of this pulse meter (value stored/received on gateway on pcReceived)
              unsigned long oldPulseCount = 0;          // to see if we have received something
              boolean pcReceived = false;               // received volume from prior reboot
              boolean onoff = false;                    // sensor value above/below treshold
              unsigned int intervalcnt = 0;             // number of cycles between last period (for flow calculation)
              double flow = 0;                          // maintain flow
              double oldflow = 0;                       // keep prior flow (only send on change)
              unsigned int learntime=LEARN_TIME*2;      // timer for learning period
              unsigned int learnlow = 1023;             // lowest value found during learning
              unsigned int learnhigh = 0;               // highest value found during learning
              boolean learnsaved = false;               // have saved learned value
              unsigned long pingcnt = 0;
              unsigned long errcnt = 0;                 // error count
              unsigned int errcnt2 = 0;                 // error counter set to 0 when sending is ok
              void(* resetFunc) (void) = 0;//declare reset function at address 0 (for rebooting the Arduino)
                // make sure a few vars have the right init value after software reboot
                pingcnt = 0;
                pcReceived = false;
                pulseCount = oldPulseCount = 0;
                // setup hardware
                pinMode(SENSOR_POWER, OUTPUT);
                digitalWrite(SENSOR_POWER, LOW);
                pinMode(LEARN_SWITCH_PIN, INPUT_PULLUP);
                pinMode(LEARN_LED_PIN, INPUT);      // default is input because this pin also has SW2 of battery block
                // Fetch last known pulse count value from gateway
                request(CHILD_ID, V_VAR1);
                // Fetch threshold value from EE prom
                treshold = readEeprom(EE_TRESHOLD);
                if (treshold<30 || treshold>1000) treshold = 512;   // wrong value in EEprom, take default
                Serial.print("Treshold: ");
                Serial.println(treshold);
                // use the 1.1 V internal reference for the battery and IR sensor
                 analogReference(INTERNAL1V1);
                 analogReference(INTERNAL);
                analogRead(IR_SENSE_PIN); // settle analogreference value
                wait(CHECK_FREQUENCY); // wait a bit
              void presentation()  {
                sendSketchInfo("Water Meter", "1.2");
                // Register this device as Waterflow sensor
                present(CHILD_ID, S_WATER);
                present(CHILD_PINGID, S_DISTANCE);
                present(CHILD_ERRID, S_DISTANCE);
                if (digitalRead(LEARN_SWITCH_PIN)==LOW) {
                  pinMode(LEARN_LED_PIN, OUTPUT);
                  digitalWrite(SENSOR_POWER, HIGH);
                  intervalcnt = 0;
                  learn_loop();
                  learnlow = 1023;
                  learnhigh = 0;
                  normal_loop();
              void learn_loop() {
                // will run into this loop as long as we are learning
                wait(500);
                unsigned int sensorValue = analogRead(IR_SENSE_PIN);
                Serial.print("IR: ");
                Serial.print(sensorValue);
                if (learntime>0) {
                  // still learning
                  learntime--;
                  learnsaved = false;
                  digitalWrite(LEARN_LED_PIN, !digitalRead(LEARN_LED_PIN));  // blink led
                  if (sensorValue < learnlow) {
                    learnlow = sensorValue;
                    Serial.println(" Lowest");
                  } else if (sensorValue > learnhigh) {
                    learnhigh = sensorValue;
                    Serial.println(" Highest");
                  } else Serial.println();
                  if (!learnsaved) {
                    treshold = (learnhigh + learnlow)/2;
                    storeEeprom(EE_TRESHOLD, treshold);
                  learnsaved = true;
                  // just display using LED
                  digitalWrite(LEARN_LED_PIN, sensorValue>treshold);
                  Serial.println((sensorValue>treshold ? " on" : " off"));
              void normal_loop() {
                unsigned long start_loop = millis();    // to allow adjusting wait time
                intervalcnt++;
                // we start doing a measurement
                wait(IR_ON_SETTLE);
                #ifdef MY_DEBUG_DETAIL
                Serial.println(sensorValue);
                boolean nowvalue = onoff;
                if (onoff && (sensorValue<treshold-TRESHOLD_MARGIN)) nowvalue = false;
                if (!onoff && (sensorValue>treshold+TRESHOLD_MARGIN)) nowvalue = true;
                if (nowvalue != onoff) {
                  // we have a pulse, only count on upwards pulse
                  onoff = nowvalue;
                  if (onoff) {
                    pulseCount++;
                    #ifdef MY_DEBUG
                    Serial.print("p: ");
                    Serial.println(pulseCount);
                if (minsendcnt>0) minsendcnt--;
                if (maxsendcnt>0) maxsendcnt--;
                // send minimum interval when we have pulse changes or if we had some flow the prior time or send on timeout
                if ((minsendcnt==0 && (pulseCount != oldPulseCount)) || (minsendcnt==0 && oldflow != 0) || maxsendcnt==0) {
                  if (!pcReceived) {   //Last Pulsecount not yet received from controller, request it again
                    Serial.print("Re-request var1 ..");
              // Prevent flooding the gateway with re-requests,,, wait at least 1000 ms for gateway (cannot be sleep or smartSleep
                    wait(2*CHECK_FREQUENCY);
                    return;
                  pingcnt++;
                  sensorValue = analogRead(BATTERY_SENSE_PIN);
                  // ((1e6+470e3)/1e6)*1.1 = Vmax = 1.67 Volts
                  // 1.67/1023 = Volts per bit = 0.00158065
                  Serial.print("Battery %: ");
                  Serial.println(batteryPcnt);
                    oldBatteryPcnt = batteryPcnt;
                  double volume = ((double)pulseCount/((double)PULSE_FACTOR));
                  flow = ((double) (pulseCount-oldPulseCount)) * (60000.0 / ((double) intervalcnt*(double) CHECK_FREQUENCY)) / ppl;  // flow in liter/min
                  #ifdef MY_DEBUG
                  Serial.print("pulsecount:");
                  Serial.print("volume:");
                  Serial.println(volume, 3);
                  Serial.print("l/min:");
                  Serial.println(flow);
                  bool b = send(lastCounterMsg.set(pulseCount));  // Send  pulsecount value to gw in VAR1
                  if (b) errcnt2=0; else { errcnt++; errcnt2++; }
                  b = send(volumeMsg.set(volume, 3));               // Send volume (set function 2nd argument is resolution)
                  b = send(flowMsg.set(flow, 2));                   // Send flow value to gw
                  b = send(pingMsg.set(pingcnt));                   // ensure at least this var has a different value
                  b = send(errMsg.set(errcnt2+((float) errcnt2/100),2));    // ensure we always send error count
                  oldPulseCount = pulseCount;
                  intervalcnt = 0;
                  oldflow = flow;
                  if (errcnt2>= (5*RESETMIN)) {
                    Serial.println("Reset");
                    wait(300);
                    resetFunc(); //call reset to reboot the Arduino
              // calculate how long it took to process all of this. then go to sleep for the remaining period
                unsigned long end_loop = millis();
                if (end_loop - start_loop < CHECK_FREQUENCY)
                  sleep(CHECK_FREQUENCY - (end_loop > start_loop ? end_loop - start_loop : 0));
                if (message.type==V_VAR1) {
                  unsigned long gwPulseCount=message.getULong();
                  pulseCount += gwPulseCount;
                  oldPulseCount += gwPulseCount;
                  flow=oldflow=0;
                  Serial.print("Received last pulse count from gw:");
                  pcReceived = true;
              void storeEeprom(int pos, int value) {
                  // function for saving the values to the internal EEPROM
                  // value = the value to be stored (as int)
                  // pos = the first byte position to store the value in
                  // only two bytes can be stored with this function (max 32.767)
                  saveState(pos, ((unsigned int)value >> 8 ));
                  pos++;
                  saveState(pos, (value & 0xff));
              int readEeprom(int pos) {
                  // function for reading the values from the internal EEPROM
                  // pos = the first byte position to read the value from
                  int hiByte;
                  int loByte;
                  hiByte = loadState(pos) << 8;
                  pos++;
                  loByte = loadState(pos);
                  return (hiByte | loByte);
              Emmanuel AbrahamE
              Emmanuel AbrahamE
              Emmanuel Abraham
              @bart59 Can you post full circuit diagram for the modified code you made?
              • Paolo RendanoP
                Paolo RendanoP
                Paolo Rendano
                I made some improvements on this sketch. Please review them here: https://github.com/mysensors/MySensors/pull/1540
                with these changes you will have:
                1 - factory reset
                2 - automatic home assistant entities creation
                3 - counter correction from home assistant using service notify.mysensors
                4 - fixed counter automatically incremented by 1 at each device restart (due to arduino library interrupt bug)
                5- other tiny improvements
                • J
                  J
                  JeeLet
                  wrote on last edited by JeeLet
                  #107
                  Thanks for the feedback
                  For those who think MySensors is finished, the proof is in the pudding, thousands of systems are functional :earth_asia:
                    StephanXL
                    I really like the update you did for Home Assistant integration.
                    But: I do not really understand, how to correctly send the VALUE_TO_ADD.
                    This is what I tried to add 967.067 m³:
                    service: notify.mysensors
                    data:
                      message: VALUE_TO_ADD
                      target: text.water_meter_100_2
                      data: 967067
                    But I just get this error message:
                    Fehler beim Aufrufen des Diensts notify.mysensors. expected dict for dictionary value @ data['data']. Got None
                    These are my newly found entities:
                    What is wrong here?
                    S 1 Reply Last reply
                    • S StephanXL
                      data:
                        data: 967067
                      What is wrong here?
                      StephanXL
                      I finally got this to work. Unlike what the description here says, this is how to update the value:
                      In Home Assistant, go to Developer->Service->YAML mode:
                      service: text.set_value
                      data:
                        value: "967067"
                      target:
                        entity_id: text.water_meter_100_2
                      (change 967067 with the value you want to add to the current counter)
                      The service "notify.mysensors" seems to be deprecated by Home Assistant.
