  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 514.5k Views 73 Watching
  • D dzairo
    Hi.
    One idea .. FIFO buffer for outgoing message..
    low power relay node .. if use bi stable relay then is possible to power only from battery .. but radio must go to sleep.. then wake up every 5 or 10 second .. and ask gateway for new command ..
    node just if wake up then waiting for example 0,5 sec for incoming message .. if not received then go sleep ..
    gateway wait for node .. and if got command in FIFO for this node then send message ..
    just idea..
    tekkaT
    tekkaT
    tekka
    @dzairo excellent idea, this will be implemented in the .276 release. Thanks
    • D
      dzairo
      Hi.
      ...ehm , in Windows is possible use database and install web server .. you have idea use this?
      database is good way , pls try thinking about my idea using cheap windows tablet as controller , by serial port (usb) or lan (wifi ..etc) . .. problem is that tablet memory is not good for many write cycle .. but this is possible solve ..
      best regards
      • B
        B
        blackdog65
        Hi Tekka,
        Great tool and SO useful for debugging.
        I have MYSController running under Wine on Linux Mint with no problems.
        I do have one small issue though. I have a serial gateway that reports to Domoticz on my Mint PC. This works fine and MSController connects fine. When I tried to move my gateway to a remote installation of Domoticz on a Raspberry Pi (same network) MSController cannot see it if I try to connect by TCP. I hope it's just something silly like port no. or something, but any ideas?
        Many thanks
        tekkaT 1 Reply Last reply
        • B blackdog65
          Hi Tekka,
          Many thanks
          tekkaT
          tekkaT
          tekka
          @blackdog65 You will have to pipe the serial gateway via tcp:port with e.g. ser2net.
          • B
            B
            blackdog65
            @tekka WOW! I thought that was going to be SO difficult... but it took 10mins total! Thank you very much... I'm good to go ;)
            • B blackdog65
              tekkaT
              tekkaT
              tekka
              wrote on last edited by tekka
              #76
              For completeness, here are the MYSBootloader instructions for OTA updates via MYSController:
              1. Load gw sketch and connect arduino either via serial or ethernet port. No special bootloader needed for that part (i.e. standard optiboot bootloader will do the job).
              2. Add these lines to the boards.txt file in your Arduino IDE installation folder (located somewhere like C:/Program Files/Arduino/hardware/arduino/avr)
                proMYSBL16.name=ATmega328 external 16Mhz with MYSBootloader
                proMYSBL16.upload.tool=avrdude
                proMYSBL16.upload.protocol=arduino
                proMYSBL16.upload.maximum_size=30720
                proMYSBL16.upload.maximum_data_size=2048
                proMYSBL16.upload.speed=115200
                proMYSBL16.bootloader.tool=avrdude
                proMYSBL16.bootloader.low_fuses=0xF7
                proMYSBL16.bootloader.high_fuses=0xDA
                proMYSBL16.bootloader.extended_fuses=0x06
                proMYSBL16.bootloader.unlock_bits=0x3F
                proMYSBL16.bootloader.lock_bits=0x3F
                proMYSBL16.bootloader.file=MySensors/MYSBootloader.hex
                proMYSBL16.build.mcu=atmega328p
                proMYSBL16.build.f_cpu=16000000L
                proMYSBL16.build.board=AVR_UNO
                proMYSBL16.build.core=arduino
                proMYSBL16.build.variant=standard
                ######## settings for 8Mhz internal clock
                proMYSBL8.upload.tool=avrdude
                proMYSBL8.upload.speed=57600
                proMYSBL8.build.board=AVR_UNO
                proMYSBL8.build.core=arduino
              3. Copy MYSBootloader.hex (from MYSController/Bootloader folder) to the Arduino IDE installation folder C:/Program Files/Arduino/hardware/arduino/avr/bootloaders/MySensors/
              4. Restart Arduino IDE, choose under Tools | Board | ATmega328 external 16Mhz with MYSBootloader or Tools | Board | ATmega328 internal 8Mhz with MYSBootloader depending on your HW settings
              5. Connect USBasp to sensor node and select Tools | Burn Bootloader
              6. If everything worked well until here, you now have the MYSBootloader with the fuse settings from above burnt to your sensor node (16Mhz extXTAL or 8Mhz intRC, BOOTSZ 1024W, BOD 1V8).
              7. Please use the AVR fuse calculator to retrieve the individual fuse settings. If you need to change frequency, BOD or other settings, change the fuse settings based on the fuse calculator.
                Important: The MYSBootloader.hex file was compiled for 16Mhz oscillators but it should also work at 8Mhz. If you intend to go below 8Mhz, I highly recommend to compile the bootloader with adjusted frequency settings.
              8. Start MYSController, hit config and adjust settings (COM-Port & baud or IP address:port)
              9. Hit connect: Connection to gateway should be established (gateway answers with gateway ready message), the node should appear and request an ID & FW.
              10. Right-mouse click on that node, select assign FW, choose for example **TimeReporter ** (demo firmware included in the MYSController/Firmware folder). Then click reboot and wait until FW is uploaded and node boots.
              11. TimeReporter firmware reports every few seconds some values such as time, millis, and voltage.
              12. Custom firmware: compile your sketch and retrieve the generated .hex file (activate verbose mode in the Arduino IDE to get compiler messages and output path).
              13. Copy .hex file to MYSController/Firmware folder and edit firmware_config.csv file according to the existing lines.
              14. Hit Refresh Repo in MYSController and the newly copied firmware should appear in the Assign FW dropdown list, ready to be uploaded.
              Have fun :)
              • D
                dzairo
                ..nice..
                .. and you try add new function what we talking above..? .. if make node with bi-stable relay battery powered only ..
                regards..
                • AnticimexA
                  AnticimexA
                  Anticimex
                  #78
                  I have tried to use the GUI controller but I cannot get any output although it claims to be connected to my ethernet GW.
                  I should mention that I run on the development branch. Perhaps there are changes that prevents your tool from acknowlegding my "development" gateway?
                  EDIT: When connected through serial, it seem to work though. Perhaps the gw does not permit multiple connections on Ethernet. Nice! It barfs on my messages though but I guess it is because I run on dev and you have already stated that development branch support is "coming" so I don't worry about that.
                  This is the output though in case you are interested:
                  2015-03-10 20:31:02 ERROR: Truncated message, Msg=101;1;1;1;36;0
                  101;1;1;1;36;0
                  2015-03-10 20:31:14 RECV: 101;1;1;1;36;1
                  101;1;1;1;36;1
                  2015-03-10 20:31:14 ERROR: Truncated message, Msg=101;1;1;1;36;1
                  101;1;1;1;36;1
                  2015-03-10 20:31:20 RECV: 101;1;1;1;36;0
                  101;1;1;1;36;0
                  2015-03-10 20:31:20 ERROR: Truncated message, Msg=101;1;1;1;36;0
                  101;1;1;1;36;0
                  • AnticimexA Anticimex
                    101;1;1;1;36;0
                    101;1;1;1;36;1
                    101;1;1;1;36;1
                    101;1;1;1;36;0
                    101;1;1;1;36;0
                    tekkaT
                    tekkaT
                    tekka
                    #79
                    MYSController 0.1.2.276 and MYSBootloader 1.1 released:
                    • send message upon RX (for battery-powered nodes)
                    • bootloader commands (for MYSBootloader 1.1)
                    • bugfixes
                    Enjoy!
                    • tekkaT tekka
                      • bugfixes
                      Enjoy!
                      mz-fuzzy
                      @tekka
                      Where can this be downloaded? Is that under an open source license, are sources available in github or something? If so, maybe someone would be willing to help with making it platform independent :-)
                      mz-fuzzy
                      http://mz-fuzzy.github.io
                      • pit007P
                        pit007P
                        pit007
                        @tekka very good job :+1: Thx !
                        The ID change worked (but tried it only one time :-) A stesstest will follow ! )
                        Next thing: Know how often a node send a package (or how long it like to sleep) and take this info to create a quality level and a warning if - i.e. after 3 times - there is no feedback from the node ?
                        • Pit
                        • pit007P
                          pit007P
                          pit007
                          The included TimeReporter (I don't know where to find the sketch) has a small problem.
                          In the minutes and the seconds the leading zero is missing - i.e. 11h 9 min 5 sevc is shown as: 11:9:5 instead of 11:09:05.
                          -Pit
                          • D
                            diamantmatch
                            i tried using the OTA FW update by following your guide a few posts up and i must say i like it a lot!
                            i just cant figure out how to upload FW from the software. every time it starts uploading FW by responding on FW requests my gateway seems to freeze, i use a usb ttl converter and arduino pro mini with radio as gw. i also uploaded the log. by the time the server responds to the FW req i have assigned FW to the node. then the GW just stops recieving and transmitting for no apearent reason so there is no communication back and forth, then when i reset the GW ( by pushing the reset button on the GW the comm is back up.. when the GW is frosen the led (pin 13, clock) is also completely off.. and yes, i also tried a radio with capacitor.
                            MySensors_20150318-202006.log
                            • D diamantmatch
                              tekkaT
                              tekkaT
                              tekka
                              #84
                              @diamantmatch The link to the log file is broken (currently, the forum experiences some issues with uploading files / pictures. Can you share it on e.g. dropbox and post the link?).
                              I've come across similar issues with debug mode activated on the GW sketch - try reflashing the GW with debug mode disabled and give it another shot.
                                wrote on last edited by hek
                                #85
                                @diamantmatch
                                I have cherry-picked a couple of patches that should fix file-uploads now. Please try to re-upload your log file. Downloading your logfile works again.
                                • D
                                  diamantmatch
                                  @tekka
                                  Awesome! everything now works like a charm! many thanks for your help!
                                  • 5546dug5
                                    5546dug5
                                    5546dug
                                    @tekka I am still a bit confused after rereading this thread.
                                    I have a humidity sensor plugged by usb and using config and debug see this sensor.
                                    Question is for the full gui do I need to unplug serial usb from gw and plug it into computer and start your program?
                                    If this is correct, then it will be temporarily disconnected from vera3 controller while I study and learn to understand what is being presented to me, when I again config and debug.
                                    After reviewing then reconfigure gw back to vera?
                                    • FrancoisF
                                      FrancoisF
                                      Francois
                                      wrote on last edited by Francois
                                      #88
                                      @tekka I update my bootloader to MYSbootloader and the fuses as per the doc but now when I try to program the Arduino mini pro I get this error can you help?
                                      upload-42f4e020-3b06-4acb-90b2-87beaeebdcac
                                      • 5546dug5 5546dug
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @5546dug MYSController connects directly to the gw to interact with the nodes.
                                        • FrancoisF Francois
                                          tekkaT
                                          tekkaT
                                          tekka
                                          That's correct: with the MYSBootloader you can upload the firmware OTA only - use MYSController to upload new fw
