  3. Smart Water Level Detector
6 Posts 5 Posters 2.8k Views 5 Watching
  • J
    J
    jemish
    Any one make smart water level Detector in our home water tank?
    Boots33B 1 Reply Last reply
    • J jemish
      Boots33B
      Boots33B
      Boots33
      @jemish Have a look at these
      Coal or water level sensor
      Water tank instant volume
      Round water tank level sensor
      • V
        V
        vomaxa
        I want manage my water tank. Do you have any idea how can I do that ??? If you have any idea about sensor I can use, would be great.
        • V
          V
          vomaxa
          Sensors output is 0-190 ohms (2 wire output). Output needs to activate 4 (empty -- -- full) red LEDs sequentially as the tank fills. What component will activate as a SW by 0, 63, 126, 190 ohms? And how to wire the four SWs from a two wire input. Source 12v. Thanks for looking
          • C
            C
            Cassy0110
            Banned
            @jemish said in Smart Water Level Detector:
            One popular option is a float switch sensor, which can be easily installed on the side of the tank and will trigger an alert when the water level reaches a certain point.
            • kriti shahK
              kriti shahK
              kriti shah
              Hello@jemish
              Yes, it is possible to create a smart water level detector for your home water tank using an ultrasonic sensor or a float switch connected to a microcontroller with wireless connectivity.
