  3. Can not compile MySensors on esp8266
6 Posts 2 Posters 2.0k Views 2 Watching
  • T Offline
    T Offline
    TheoL
    wrote on last edited by TheoL
    I wanted to dust off an old MySensors project that is running on an esp8266, but when I try uploading the Clear EEPROM sketch I get the following error:
    In file included from Arduino/libraries/MySensors/MySensors.h:441,
                     from /private/var/folders/pm/z613mrwd6rx83wg51dx6jkfr0000gn/T/.arduinoIDE-unsaved2024724-45646-98sze5.cjzrw/ClearEepromConfig/ClearEepromConfig.ino:29:
    Arduino/libraries/MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp: In function 'bool can_yield()':
    Arduino/libraries/MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp:95:9: error: 'cont_can_yield' was not declared in this scope; did you mean 'can_yield'?
       95 |  return cont_can_yield(g_pcont);
          |         can_yield
    Arduino/libraries/MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp: In function 'void esp_yield_within_cont()':
    Arduino/libraries/MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp:101:2: error: 'cont_yield' was not declared in this scope; did you mean 'can_yield'?
      101 |  cont_yield(g_pcont);
          |  can_yield
    Arduino/libraries/MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp: In function 'void loop_task(ETSEvent*)':
    Arduino/libraries/MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp:199:26: error: invalid operands of types 'void' and 'int' to binary 'operator!='
      199 |  if (cont_check(g_pcont) != 0) {
          |                void         int
    exit status 1
    Compilation error: exit status 1
    As far as I can tell I'm running the latest MySensors version and the latest ESP board version. I'm running on Arduino 1.8.12 though, but that shouldn't matter?
    Help much appreciated.
    • T TheoL
            |         can_yield
            |  can_yield
            |                void         int
      exit status 1
      T Offline
      T Offline
      TheoL
      @TheoL said in Can not compile MySensors on esp8266:
      Since the search function is broken it was hard to find it on mysensors forum. But google search helped https://forum.mysensors.org/topic/12066/no-lan-connection-esp8266-gateway/16?_=1724514129827
      • T TheoL
        T Offline
        T Offline
        TheoL
        @TheoL Although I'm curious what the latest supported version for an EsP8266 is. As some of the other libraries I use complain about the 2.6.2 version
        • T TheoL
          @TheoL the latest supported version is ESP8266 2.6.2
          Reference: https://github.com/mysensors/MySensors/releases/tag/2.3.2
            T Offline
            T Offline
            TheoL
            @mfalkvidd I know xd. But it would be nice - if possible - if a newer version is supported. I'll post a project soon why I would like it.
            • T TheoL
              @TheoL there are two pull requests adding support for newer versions.
              One is guaranteed to break again.
              One should not break in the future, but will instead break all existing sketches.
              I’m sure a third option would be welcome if you write the code and submit.
