Gateway on my PI when i run HA
Is it possible to put a gateway (Radio RF24) on my PI when i run my Home assistant on same machine ?
@mfalkvidd said in Gateway on my PI when i run HA:
Home Assistant Operating System
With Home Assistant as Operating System it might not work, if the radio is connected to the GPIO of the Pi. The HASS-Os has some restrictions to run software like the Pi gateway beside Homeassistant.
I have currently a setup with a RFM69 connected to the GPIO for the RPI ethernet gateway. Homeassistant runs in a container and the mysensors plugin connects in Homeassistant to localhost or 127.0.0.1. But I have problems with the stability (I think so) with this combination, as seen in this forum.
In my opinion is a Serial (USB-Serial-Converter) Gateway with Homeassistant the best choice. So I want to build another gateway and resinstall my Pi with HASS-Os. -
Thank for your reply. Yes, i run since many years with a serial Gateway connected with my PI.
I thought it was possible to use the same machine to remove this extra element.
If you had a stability issue, I would just stick with my current formula and not change everything for now.Regards,
