  3. MQTT-Help me understand about the MQTT Gateway.
11 Posts 3 Posters 2.3k Views 3 Watching
  • dpconsD
    dpconsD
    dpcons
    Th purpose of the mqtt gateway with an NRF24L01 is, I assume , to collect data from RF based sensors and pass the data through to controller. In my situation, I create a temperature node using an esp8266 and a nRF24L01. The MQTT gateway handles the data just like any other gateway. Goes anyone have an example of a sensor node that posts a mqtt message to the gateway? The GatewayESP8266MQTTClient.ino example doesn't show me much. Sorry to be a pain. just saying...
    • dpconsD dpcons
      @dpcons sensor nodes can not post a mqtt message. Sensor nodes can’t even be aware that they talk to a mqtt gateway: the nodes don’t know if the gateway is wifi, mqtt, serial or any other type.
      With that said, sensor nodes can send any message to a gateway, and the gateway will forward the message on mqtt (if it is a mqtt gateway). Simplest example is probably something like https://github.com/mysensors/MySensors/blob/development/examples/BatteryPoweredSensor/BatteryPoweredSensor.ino or https://github.com/mysensors/MySensors/blob/development/examples/BinarySwitchSleepSensor/BinarySwitchSleepSensor.ino
      dpconsD 1 Reply Last reply
      • OldSurferDudeO
        OldSurferDudeO
        OldSurferDude
        @dpcons All the esp8266 devices with which I have experience have WiFi and can be Tasmotized. Fundamental to Tasmota is to WiFi; you specify the SSID and passphrase. Also fundamental to Tasmota is connecting to an MQTT broker; you supply IP address and, if necessary, name and password. In addition, there exists DHTxx configurations. Load this software and your data is going to the broker.
        (Home Assistant has an integration for Tasmota whch requires the MQTT integration.)
        I have done this many times and for me it takes less time that it did to write this response to get a DHT12 putting data to the broker. Tasmota is incredibly well supported, so it shouldn't take you much longer.
        I make the assumption that you already have a way to program the esp8266. The process to which I refer ggoes something like this:
        • Put your esp8266 in the programmer
        • connect your programmer to a usb port of the your computer
        • open the tasmota web installer
        • In following the istructions, be sure to do the load SSID/passphrase, if you don't you'll have to connect to your esp8266 over WiFi (http://192.168.4.1) and enter them on that web page. If the connection goes well, an IP address on your network will be presented... briefly.
        • Once your esp8266 device is connected to your WiFi, you connect to the ip address of your esp8266 device.
        • from there, after searching "Tasmota DHT12" you can configure you esp8266 device to read your temperature sensor.
        All that said, I still like an Arduino Nano with the nRF radio (or an RF Nano) and MySensors. I have yet to brick or lose the program of a Nano but have done both on several esp8266's.
        OK, back to what I came here to do ... make a serial gateway. ;)
          dpconsD
          dpconsD
          dpcons
          @mfalkvidd Sorry, I guess I'm dense. I didn't think you necessarily needed a radio connected to the MQTT gateway. I thought the MQTT gateway was to be used in addition to the other gateways in the system, and used to send data to the broker. If that's not the case, is there a point to having one, if I already have an esp8266 WIFI gateway with a nRF24L01. If a radio is required on the MQTT, does that mean another nRF24L01 can be connected to the system? Is that possible? I guess what you're saying is that you only need one 2.4G network, be it wifi, mqtt or serial. True?
          Again thanks.
            dpconsD
            dpconsD
            dpcons
            @OldSurferDude Thanks for the reply. So you're going straight to the MQTT broker itself and basically bypassing a gateway? I'm using My Sensors and Domoticz and I like them. I see Domiticz is compatible with Tasmota. I'll have to do some research.
            Thanks much
            OldSurferDudeO 1 Reply Last reply
            • dpconsD dpcons
              Again thanks.
              @dpcons there can only be one MySensors gateway in a MySensors network.
              You can have as many MySensors networks as you like.
              A MySensors network can exist of only a gateway (no other MySensors nodes required)
              There can be points. I don’t know your needs.
              No radio is required on the mqtt gateway.
              A mqtt gateway can have a nrf2l01.
              Could you elaborate on what you mean by ”one 2.4G network”? Do you mean one MySensors nrf24l01 network? Or one 2.4GHz wifi network? Or something else?
                dpconsD
                dpconsD
                dpcons
                @mfalkvidd Hi. My system here is using a RPI4B running Domoticz, one 433MHz RFXCom gateway and one 2.4 gHz ESP8266 WIFI gateway. I know I can add a 915MHz gateway, but could I add another 2.4G gateway? (I mean a nRF24l01 based system, or are there other radios MySensors uses for that frequency?). If this is possible, why would someone want it?...and how would the two gateways differentiate the traffic? Obviously, I'm not a radio guy.
                • dpconsD dpcons
                  @dpcons you can have as many nrf24l01 MySensors networks as you like.
                  They are differentiated by channel and base radio id.
                  The reason for multiple networks may be more control, isolation, lab/test/production network, approaching the limit (255) of the number of nodes in a single network, separate network for high-traffic devices, different versions of MySensors, interference, range problems, and more.
                  • dpconsD dpcons
                    Thanks much
                    OldSurferDudeO
                    OldSurferDudeO
                    OldSurferDude
                    @dpcons that is correct. The ESP communicates directly with the MQTT broker.
                    It's very easy if you're ESP has been Tasmotized. I am of the understanding that one can compile their own Tasmota binary to suit particular needs. I have not done this.
                    If you're using the Arduino IDE to program your ESP, it is possible to communicate directly to the MQTT broker. You will have to come up with your own protocol though, This I have done and it takes some perseverence.
                    Both Tasmota and Arduino IDE accomodate Over-The-Air (OTA) updates. This is nice, especially when your device is behind a panel or up the hill. Interestingly enough, if something is Tasmotized, an Arduino IDE binary can replace it OTA; and vice versa. This I have done many times. (Yes, some failures to communicate and a hike up the hill ;)
                      dpconsD
                      dpconsD
                      dpcons
                      @OldSurferDude Thanks for the tips. I've download Tasmota and have it running on an Wemos Mini. Have it turning on and off a virtual switch. Maybe Mqtt soon...
                      • dpconsD dpcons
                        OldSurferDudeO
                        OldSurferDudeO
                        OldSurferDude
                        @dpcons MQTT sounds intimidating and looks imitimidating when you see all of the options available.
                        Here's the scenario:
                        • You want to send a message. That's the -m option followed by a space and the message between " "
                        • the location, topic, is a tree, -t option, separated by forward slash / eg. MyRootTopic/MyTopicsSub/MyTopicSubSub
                        It's as easy as that if your broker, the MQTT service (program) is on the same computer as the sending program. Usually it's not.
                        • Specifiy the location, the host, of the broker with the -h option followed by the host name or IP address
                        The retain option, -r is important but explaining it is beyone the scope of this message
                        Receiving, subscribing, to a topic is just the same, but you wouldn't have the -m message
                        If you subscribe from the command line, the subscribe function waits indefinitely for messages published to the subscribed topic (unless you use the -C option) ^C to terminate the command.
                        A tamotized device with the MQTT configured will create a number of topics on the broker. Home Assistant will see this automatically, if you have the Tasmota and MQTT Integrations installed.
                        The MySensors MQTT gateway takes care of MQTT communication for a MySensors device. Again the MySensors and MQTT integrations.
                        I use both.
                        -OSD
