  3. Getting system time from the controller
13 Posts 4 Posters 2.3k Views 3 Watching
  • mfalkviddM
    The received message looks like this:
    Received Message
    Sender: 0
    Last Node: 0
    Destination: 6
    Sensor Id: 255
    Command: INTERNAL
    Message Type: I_TIME
    Payload Type: P_STRING
    Payload Length: 10
    Signing: 0
    Payload: 1740594416
    https://www.mysensors.org/build/parser?log=450375 TSF%3AMSG%3AREAD%2C0-0-6%2Cs%3D255%2Cc%3D3%2Ct%3D1%2Cpt%3D0%2Cl%3D10%2Csg%3D0%3A1740594416
    1740594416 is Thu, 27 Feb 2025 11:56:37 GMT which looks reasonable.
    So question is, why doesn’t the node print the received time?
    dpconsD 1 Reply Last reply
    • skywatchS
      skywatchS
      skywatch
        Received Message
        Sender: 0
        Last Node: 0
        Destination: 6
        Sensor Id: 255
        Command: INTERNAL
        Payload Length: 10
        Signing: 0
        Payload: 1740594416
        dpconsD
        dpconsD
        dpcons
        @mfalkvidd
        Thanks for your response. Yes, that's the question. Did I neglect something in my code? Do I have to register the "receiveTime" routine? Is there any workaround to use the response data? This node is an ESP32 D1 mini...if that makes a difference. Does the operation depend on an interrupt?
        Again, thanks
        dpconsD mfalkviddM 2 Replies Last reply
        • dpconsD dpcons
          @mfalkvidd
          Again, thanks
          dpconsD
          dpconsD
          dpcons
          @dpcons sorry...esp8266 wemos mini is the actual device.
          • dpconsD dpcons
            @mfalkvidd
            Again, thanks
            @dpcons it could be that the gateway code for receiving time is (unintentionally) broken. I noticed that the other thread you found also was about a gateway.
            I have never used receivetime myself but I am pretty sure I have seen it working for other people on regular nodes.
            • nagelcN
              nagelcN
              nagelc
              I have found that controllers can be very slow to respond to time requests. Same experience for Domoticz and for Homeassistant. Try a wait(1500) after the time request.
              • nagelcN nagelc
                dpconsD
                dpconsD
                dpcons
                @nagelc Thanks for responding. The response from the controller seems to be very quick. The problem is the 'receiveTime' routine never gets executed. mfalkvidd stated that the response in the serial output looked reasonable so I'm assuming the controller is responding OK. I tried adding the delay(1500) but same issue.
                Again, thanks for your response.
                  dpconsD
                  dpconsD
                  dpcons
                  @mfalkvidd Thanks for the response. I once built the 'Display and Time' sensor and I remember it working...but that was about 3-4 years ago and I no longer have the device. Maybe I build it back up again and give it a shot!
                  • dpconsD dpcons
                    dpconsD
                    dpconsD
                    dpcons
                    @dpcons I built the Time Display example and after a little futzing, I got it to talk to my NRF24L01 system but the receiveTimez() function looks broken. It appears to respond with data that's read, but function never executes.
                    Looks like I'll punt for now.
                    • mfalkviddM
                      I think the relevant code is here:
                      https://github.com/mysensors/MySensors/blob/e298769eb73ba2da781a34d66cae345c6840b7c0/core/MySensorsCore.cpp#L473
                      but I can’t see anything that looks broken.
                      • dpconsD dpcons
                        @dpcons try changing unsigned long in your sketch to uint32_t
                        Could be that the override needs to have an exact match.
                          dpconsD
                          dpconsD
                          dpcons
                          @mfalkvidd Thanks, I'll try that.
