  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 513.7k Views 73 Watching
  • D
    Dab0G
    How can I increase the number of blocks greater than 2048?
    [2017-12-05 16:04:36.925 Info] REPO FW "STM32_RS485_Node_Relay" loaded. t=100, v=7, blocks=2048, crc=0xCC88
    [2017-12-05 16:04:36.926 Info] REPO FW repository loaded. Items=2
    [2017-12-05 16:04:52.544 Info] INFO FW "STM32_RS485_Node_Relay" assigned to node 100
    [2017-12-05 16:04:52.545 Info] INFO Send FW info to node 100: type=64, version=7, blocks=0x0800, CRC=0xCC88
    For STM32F407ZGT6, it may take up to 65k blocks. And in the controller, I understand it is a hard limit on 2048?
    • R
      R
      robosensor
      Is it OK?
      https://www.virustotal.com/#/file/6082b86e6a56783e692afaa7c6d79e5af0d6ca58476ef7e180a39594ce441cd7/detection
      No such warnings/detections for .282 version.
      • HomerH
        HomerH
        Homer
        Hi all
        I have an issue which I've documented in the Troubleshooting section. When I've searched for a resolution, this program has been mentioned. What I'm trying to do is get my controller to see the part of the gateway sketch that references a sensor that I added. Can this program help? What does this program actually do?
          @Homer
          Try it ;)
          It's a handy controller software for debugging MySensors.
          • K
            K
            kalj
            This is quite a nice piece of software! You have suggested you are going to release the sources at some point. Maybe that time is now? It would be great to see if it can be ported to Linux!
              mickecarlsson
              Bug in MYScontroller.
              When I edit the file firmware_config.csv and set a version number with a decimal the output in the debug is wrong.
              This is my file:
              10,Blink,1,Blink.ino.hex,blinking example
              20,Tvattstugan-2,3,Tvattstugan-2.ino.hex,Testar Flash
              30,Tvattstugan,2,Tvattstugan.ino.hex,Tvattstugan
              40,Sovrummet,2.1,Sovrummet.ino.hex,Sovrummet
              Note that I have 2.1 as the version in 40, Sovrummet.
              But when I load the repo in MYSController v is 65535:
              2021-02-13 17:06:37	REPO	FW "Blink" loaded. t=10, v=1, blocks=80, crc=0x46D4
              2021-02-13 17:06:37	REPO	FW "Tvattstugan-2" loaded. t=20, v=3, blocks=1488, crc=0x6D13
              2021-02-13 17:06:37	REPO	FW "Tvattstugan" loaded. t=30, v=2, blocks=960, crc=0xBB4F
              2021-02-13 17:06:37	REPO	FW "Sovrummet" loaded. t=40, v=65535, blocks=936, crc=0x6AB3
              2021-02-13 17:06:37	REPO	FW repository loaded. Items=4
              And in the GUI the version is also 65535.
              Actually there are two bugs.
              If I add (sloppy I know) more empty lines at the end in the firmware_config.csv file I get this in the debug:
              2021-02-13 17:13:35	REPO	FW "Blink" loaded. t=10, v=1, blocks=80, crc=0x46D4
              2021-02-13 17:13:35	REPO	FW "Tvattstugan-2" loaded. t=20, v=3, blocks=1488, crc=0x6D13
              2021-02-13 17:13:35	REPO	FW "Tvattstugan" loaded. t=30, v=2, blocks=960, crc=0xBB4F
              2021-02-13 17:13:35	REPO	FW "Sovrummet" loaded. t=40, v=65535, blocks=936, crc=0x6AB3
              2021-02-13 17:13:35	ERROR	2107-15-31 is not a valid date specification
              Other than that, great piece of software. Thanks.
              • R
                R
                ru64
                Download seems unavailable. Could you please update the link?
                  mickecarlsson
                  wrote on last edited by mickecarlsson
                  #481
                  Here is a version that I downloaded a long time ago.
                  EDIT: It seems that I can't upload files. Bummer. PM me if you want the file.
                  • tekkaT tekka
                    Hi all,
                    I've been working on this project since some time, basically it's a GUI for controlling/updating/debugging a network of MySensors nodes. OTA functionality is supported via MYSBootloader - read posts for further instructions/troubleshooting or PM.
                    link updated: MYSController Version 1.0.0.3316 released
                    New features:
                    • support OTA FW update Sensebender board
                    • metric/imperial system I_CONFIG
                    • save nodes
                    Update via update button in MYSController or download here.
                    Mac65
                    @tekka can you provide sources of this project?
                    Mac65
                    • E
                      E
                      emre299
                      link broken, please share new link
                      OldSurferDudeO 1 Reply Last reply
                      • E emre299
                        OldSurferDudeO
                        OldSurferDudeO
                        OldSurferDude
                        @emre299 alas, this cool project seems to be abandoned.
                          sindrome73
                            sindrome73
                            https://drive.google.com/file/d/14h8-8UccetEXxKET6ylry5_OcifdcJPz/view?usp=sharing
