  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 513.7k Views 73 Watching
  • R
    R
    robosensor
    Is it OK?
    https://www.virustotal.com/#/file/6082b86e6a56783e692afaa7c6d79e5af0d6ca58476ef7e180a39594ce441cd7/detection
    No such warnings/detections for .282 version.
    • HomerH
      HomerH
      Homer
      Hi all
      I have an issue which I've documented in the Troubleshooting section. When I've searched for a resolution, this program has been mentioned. What I'm trying to do is get my controller to see the part of the gateway sketch that references a sensor that I added. Can this program help? What does this program actually do?
        @Homer
        Try it ;)
        It's a handy controller software for debugging MySensors.
        • K
          K
          kalj
          This is quite a nice piece of software! You have suggested you are going to release the sources at some point. Maybe that time is now? It would be great to see if it can be ported to Linux!
            mickecarlsson
            Bug in MYScontroller.
            When I edit the file firmware_config.csv and set a version number with a decimal the output in the debug is wrong.
            This is my file:
            10,Blink,1,Blink.ino.hex,blinking example
            20,Tvattstugan-2,3,Tvattstugan-2.ino.hex,Testar Flash
            30,Tvattstugan,2,Tvattstugan.ino.hex,Tvattstugan
            40,Sovrummet,2.1,Sovrummet.ino.hex,Sovrummet
            Note that I have 2.1 as the version in 40, Sovrummet.
            But when I load the repo in MYSController v is 65535:
            2021-02-13 17:06:37	REPO	FW "Blink" loaded. t=10, v=1, blocks=80, crc=0x46D4
            2021-02-13 17:06:37	REPO	FW "Tvattstugan-2" loaded. t=20, v=3, blocks=1488, crc=0x6D13
            2021-02-13 17:06:37	REPO	FW "Tvattstugan" loaded. t=30, v=2, blocks=960, crc=0xBB4F
            2021-02-13 17:06:37	REPO	FW "Sovrummet" loaded. t=40, v=65535, blocks=936, crc=0x6AB3
            2021-02-13 17:06:37	REPO	FW repository loaded. Items=4
            And in the GUI the version is also 65535.
            Actually there are two bugs.
            If I add (sloppy I know) more empty lines at the end in the firmware_config.csv file I get this in the debug:
            2021-02-13 17:13:35	REPO	FW "Blink" loaded. t=10, v=1, blocks=80, crc=0x46D4
            2021-02-13 17:13:35	REPO	FW "Tvattstugan-2" loaded. t=20, v=3, blocks=1488, crc=0x6D13
            2021-02-13 17:13:35	REPO	FW "Tvattstugan" loaded. t=30, v=2, blocks=960, crc=0xBB4F
            2021-02-13 17:13:35	REPO	FW "Sovrummet" loaded. t=40, v=65535, blocks=936, crc=0x6AB3
            2021-02-13 17:13:35	ERROR	2107-15-31 is not a valid date specification
            Other than that, great piece of software. Thanks.
            • R
              R
              ru64
              Download seems unavailable. Could you please update the link?
                mickecarlsson
                wrote on last edited by mickecarlsson
                #481
                Here is a version that I downloaded a long time ago.
                EDIT: It seems that I can't upload files. Bummer. PM me if you want the file.
                • tekkaT tekka
                  Hi all,
                  I've been working on this project since some time, basically it's a GUI for controlling/updating/debugging a network of MySensors nodes. OTA functionality is supported via MYSBootloader - read posts for further instructions/troubleshooting or PM.
                  link updated: MYSController Version 1.0.0.3316 released
                  New features:
                  • support OTA FW update Sensebender board
                  • metric/imperial system I_CONFIG
                  • save nodes
                  Update via update button in MYSController or download here.
                  Mac65
                  @tekka can you provide sources of this project?
                  Mac65
                  • E
                    E
                    emre299
                    link broken, please share new link
                    OldSurferDudeO 1 Reply Last reply
                    • E emre299
                      OldSurferDudeO
                      OldSurferDudeO
                      OldSurferDude
                      @emre299 alas, this cool project seems to be abandoned.
                        sindrome73
                          sindrome73
                          https://drive.google.com/file/d/14h8-8UccetEXxKET6ylry5_OcifdcJPz/view?usp=sharing
