  3. Domoticz
  4. mysensors on rpi with NRF2401 with Domoticz
raspberry pi
18 Posts 3 Posters 3.2k Views 3 Watching
  • G Offline
    G Offline
    goblin
    hello all,
    the best thing on my Domoticz was MySensors.
    But is was because Domoticz crashed during the latest update.
    I had ti re-buid it but i can get MySensors back to work.
    The NRF pcb is directly connected to the MOSI and MISO of the RPI connector.
    But i have only three posible choices in hardware on Domoticz.
    MySensors Gateway with MQTT, with LAN interface or USB.
    What do i have to do to get it working again.
    i have 10 MySensors units and 15 esp via MQTT units and since MySensors are the most reliable so don't want to change it to ESP-MQTT
    • G goblin
      hello all,
      Hello @goblin, welcome to the forum.
      You probably had installed the raspberry pi gateway, which supports serial (usb), ethernet (LAN) and mqtt.
      Instructions: https://www.mysensors.org/build/raspberry
      Easiest is probably ethernet.
      • G Offline
        G Offline
        goblin
        that's correct. but i seems to have a problem with the correct Domoticz settings.
        I need to select one out of three and i get a message "Error: rf: Failed to start, return code: 14/Connection refused (Check IP/Port" when select mqtt
        and when select LAN the message "Error: rf: Can not connect to: 127.0.0.1:5003".
        so it's obvious that i have did something wrong.
        • G Offline
          G Offline
          goblin
          good evening,
          I have tried ./configure --my-gateway=ethernet --my-controller-ip-address=127.0.0.1
          But still the same error
          • G Offline
            G Offline
            goblin
            good night :)
            i have tried "Step-by-step procedure to connect the NRF24L01+ to the GPIO pins and use the Raspberry as a Serial Gateway (MySensors 1.x) " and get an error that is not mentioned (MySensor.cpp:644:5: error: ‘gettimeofday’ was not declared in this scope).
            and this after sudo: /usr/local/sbin/PiGatewaySerial: command not found
            i will have a good sleep and continue tomorrow
            • G goblin
              good night :)
              Nice work @goblin
              Could you share all commands you ran and the entire output, including the configure, build and test steps?
              Also, I don’t think Domoticz can use the gateway as a client. You should probably omit the --my-controller-ip-address=127.0.0.1 argument.
              • G Offline
                G Offline
                goblin
                thanks for your response.
                I tried all possible combinations but one ( the one that works)
                I started with "https://www.mysensors.org/build/raspberry"
                git clone https://github.com/mysensors/MySensors.git --branch master. Expected response "fatal: destination path 'MySensors' already exists and is not an empty directory"
                cd MySensors
                /MySensors $ ./configure --my-transport=rf24
                [OK] SPI driver detected:BCM.
                [SECTION] Gateway configuration.
                [OK] Type: ethernet.
                [OK] Transport: rf24.
                [OK] Signing: Disabled.
                [OK] Encryption: Disabled.
                [OK] CPPFLAGS: -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_RF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI
                [OK] CXXFLAGS: -std=c++11
                [OK] Init system detected: systemd.
                [OK] Saved.
                [OK] Finished.
                /MySensors $ make .
                return : gcc -MT build/hal/architecture/Linux/drivers/core/config.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_RF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -I. -I./core -I./hal/architecture/Linux/drivers/core -I./hal/architecture/Linux/drivers/BCM -c hal/architecture/Linux/drivers/core/config.c -o build/hal/architecture/Linux/drivers/core/config.o
                gcc -MT build/hal/architecture/Linux/drivers/core/log.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_RF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -I. -I./core -I./hal/architecture/Linux/drivers/core -I./hal/architecture/Linux/drivers/BCM -c hal/architecture/Linux/drivers/core/log.c -o build/hal/architecture/Linux/drivers/core/log.o
                g++ -MT build/hal/architecture/Linux/drivers/core/compatibility.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_RF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -std=c++11 -I. -I./core -I./hal/architecture/Linux/drivers/core -I./hal/architecture/Linux/drivers/BCM -c hal/architecture/Linux/drivers/core/compatibility.cpp -o build/hal/architecture/Linux/drivers/core/compatibility.o
                g++ -MT build/hal/architecture/Linux/drivers/core/EthernetClient.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_RF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -std=c++11 -I. -I./core -I./hal/architecture/Linux/drivers/core -I./hal/architecture/Linux/drivers/BCM -c hal/architecture/Linux/drivers/core/EthernetClient.cpp -o build/hal/architecture/Linux/drivers/core/EthernetClient.o
                g++ -MT build/hal/architecture/Linux/drivers/core/EthernetServer.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_RF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -std=c++11 -I. -I./core -I./hal/architecture/Linux/drivers/core -I./hal/architecture/Linux/drivers/BCM -c hal/architecture/Linux/drivers/core/EthernetServer.cpp -o build/hal/architecture/Linux/drivers/core/EthernetServer.o
                g++ -MT build/hal/architecture/Linux/drivers/core/GPIO.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_RF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -std=c++11 -I. -I./core -I./hal/architecture/Linux/drivers/core -I./hal/architecture/Linux/drivers/BCM -c hal/architecture/Linux/drivers/core/GPIO.cpp -o build/hal/architecture/Linux/drivers/core/GPIO.o
                hal/architecture/Linux/drivers/core/GPIO.cpp: In constructor ‘GPIOClass::GPIOClass()’:
                hal/architecture/Linux/drivers/core/GPIO.cpp:53:71: warning: ‘%s’ directive output may be truncated writing up to 255 bytes into a region of size 48 [-Wformat-truncation=]
                53 | snprintf(file, sizeof(file), "/sys/class/gpio/%s/base", de->d_name);
                hal/architecture/Linux/drivers/core/GPIO.cpp:53:33: note: ‘snprintf’ output between 22 and 277 bytes into a destination of size 64
                hal/architecture/Linux/drivers/core/GPIO.cpp:62:71: warning: ‘%s’ directive output may be truncated writing up to 255 bytes into a region of size 48 [-Wformat-truncation=]
                62 | snprintf(file, sizeof(file), "/sys/class/gpio/%s/ngpio", de->d_name);
                hal/architecture/Linux/drivers/core/GPIO.cpp:62:33: note: ‘snprintf’ output between 23 and 278 bytes into a destination of size 64
                g++ -MT build/hal/architecture/Linux/drivers/core/interrupt.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_RF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -std=c++11 -I. -I./core -I./hal/architecture/Linux/drivers/core -I./hal/architecture/Linux/drivers/BCM -c hal/architecture/Linux/drivers/core/interrupt.cpp -o build/hal/architecture/Linux/drivers/core/interrupt.o
                hal/architecture/Linux/drivers/core/interrupt.cpp:33:10: fatal error: stropts.h: No such file or directory
                33 | #include <stropts.h>
                compilation terminated.
                make: *** [Makefile:99: build/hal/architecture/Linux/drivers/core/interrupt.o] Error 1
                Then i need to make a hardware choice in domoticz : between USB,LAN or MQTT.
                and that is something i don't understand because non are used. The NRF24L01 is connected to MOSI MISO of the RPI.
                sorry for the long Reply
                • G Offline
                  G Offline
                  goblin
                  I am missing mysgw
                  I have searched the whole sdcard with WINSCP but can't find the config file, should be in /etc/mysensors.conf.
                  • G goblin
                    cd MySensors
                    [OK] Saved.
                    [OK] Finished.
                    /MySensors $ make .
                    The key is here:
                    See https://forum.mysensors.org/topic/11138/mysensors-build-problem-on-ubuntu-20-04-rpi-or-tinker-board/2 for a possible workaround. Then restart from the make step.
                    Mysgw will only be created after successful make.
                    • G Offline
                      G Offline
                      goblin
                      thanks for pointing this out .
                      i have added a empty file stropts.h with sudo touch stropts.h. in the dir : usr/include
                      then Build make
                      a lot of response with a lot of warnings but 1 error at the end
                      (last lines )
                      /usr/bin/ld: build/examples_linux/mysgw.o: in function .LANCHOR1': /home/pi/MySensors/./hal/architecture/Linux/drivers/core/config.h:39: multiple definition of conf'; build/hal/architecture/Linux/drivers/core/config.o:/home/pi/MySensors/hal/architecture/Linux/drivers/core/config.h:39: first defined here
                      collect2: error: ld returned 1 exit status
                      make: *** [Makefile:80: bin/mysgw] Error 1
                      and still no "If there were no errors during compilation the file bin/mysgw will be created"
                      any idea were to look for this error ?
                      thanks
                      • G goblin
                        then Build make
                        (last lines )
                        thanks
                        The bew error you got is discussed in https://forum.mysensors.org/topic/11448/config-h-39-first-defined-here/4
                        Easiest way is probably to switch to the development branch of mysensors.
                        Run git checkout development and then start over from the configure step. Or follow the step ”To use the development version with the latest updates” on the raspberry pi gateway build page.
                        • G Offline
                          G Offline
                          goblin
                          Sounds like a plan but i am just a monkey that's able to push some buttons so very little knowledge of linux.
                          Tried to start with the development version but it seems that the previous version has to removed.
                          "fatal: destination path 'MySensors' already exists and is not an empty directory".
                          • G Offline
                            G Offline
                            goblin
                            it's a pitty of all the used MySensors units but i am better with hardware then software so will see if i can replace them with tasmota.
                            thanks for the help
                            • dirkjuD Offline
                              dirkjuD Offline
                              dirkju
                              @goblin said in mysensors on rpi with NRF2401 with Domoticz:
                              Seems like you're trying to clone the MySensors git repo but there's already an existing MySensors folder. This is a typical git error message.
                              If you haven't given up yet, you could rename the Mysensors folder to something else and git-clone the development branch as advised by @mfalkvidd.
                              (As a general advise, if you are unsure, it might be an option to just ask ChatGPT about the error messages, describing your scenario. It knows git and Mysensors ;-))
                              • G Offline
                                G Offline
                                goblin
                                thanks dirkju. have tried the ChatGPT method and used --branch development.
                                i haven't give up hope (yet)
                                MySGW is running but are stuck at the choice between MySensors Gateway with MQTT, with LAN interface or USB. although it is connected via MOSI/MISO of the RPI
                                So basically the configure -- ?? settings and the Domoticz hardware settings.
                                thank
                                • dirkjuD Offline
                                  dirkjuD Offline
                                  dirkju
                                  Hi goblin, so you got MySGW compiled successfully now using the development branch in git? That's great to hear! I do not have experiences with RPi gateways, neither Domoticz. But I believe choosing the Ethernet option is the easiest to configure (see Domoticz). Does that work for you?
                                  • G Offline
                                    G Offline
                                    goblin
                                    i was not able to get MySensors running in domoticz but i will thing CHATgpt will help getting it to work
                                    dirkjuD 1 Reply Last reply
                                    • G goblin
                                      dirkjuD Offline
                                      dirkjuD Offline
                                      dirkju
                                      @goblin feel free to share concrete error messages or questions. We might be able to help on well-described problems. Otherwise - hope ChatGPT can help you ;-)
                                      12.2k
