💬 Easy-Peasy Amplified MySensors Serial Gateway
I had a chance to test the module more thoroughly, and it appears to work just fine at 2mbps also. So, as of this moment, everything seems good, and I'm not aware of any problems. :)
The newer E01-2G4M27D has more powerful transmit and more sensitive receive capability:
https://www.aliexpress.com/item/4000536940861.html?spm=a2g0s.9042311.0.0.58a24c4dtdfoIK
I know this thread is old but it seems the most relevant. I just tried to compile the standard GatewaySerial.ino sketch using Wemos D1 mini as board type and I get error:
MyMainESP8266.cpp:95:9: error: 'cont_can_yield' was not declared in this scope;I'm using MySensors Library v2.3.2
I'm assuming this used to work. Is it broken or I am doing something wrong?
Hi @mfalkvidd
I rolled back the esp8266 library to 2.6.2 and it compiles.
Is there an upcoming release to fix this?
Hi @mfalkvidd
Yes, Lol, you have 2 PRs but both have issues. I looked, but I didn't manage to find them on Github/MySensors. I did read that espressif updated their esp8266 core to use standard Arduino yield functions. I guess it's related to that.
That issue is caused by the newer ESP8266 core changing yield functions. Downgrading the ESP8266 core to v2.6.2 (or v2.7.4 depending on your board setup) remains the most reliable workaround until those MySensors core PRs get merged into a main release. Keep an eye on those GitHub PRs for updates on full compatibility with current core releases!
For anyone building this in CI or PlatformIO, pin the ESP8266 platform version that bundles core 2.6.2 instead of relying on a globally installed core. That keeps builds reproducible while the MySensors PRs are pending. In Arduino IDE the selected core is global, so switching between projects can pick the newer version again. Might be worth adding a note to the build instructions.
