  3. 💬 Easy-Peasy Amplified MySensors Serial Gateway
18 Posts 10 Posters 11.8k Views 8 Watching
  • YveauxY Yveaux
    @mfalkvidd said in 💬 Amplified MySensors Serial Gateway:
    Wemos D1 mini uses a ME6211 ldo which is rated for 500mA
    I hope all the clones will use the same LDO, or equivalent then ;-)
    korttomaK
    korttomaK
    korttoma
    @Yveaux said in 💬 Amplified MySensors Serial Gateway:
    Lets hope people stick to the originals since they are not that expensive
    https://wemoscc.aliexpress.com/store/1331105
    • Tomas
      very simple :)
      I agree with yveaux though, always good to have some optional footprints for decoupling in case. No idea if there are some. Also, putting electronics above antenna (of esp8266) is not very recommended, but this should work.
      • skywatchS
        skywatchS
        skywatch
        This does not use the genuine NRF24L01+ by the looks of it.
        The wording is clever, but the imported parts list does not include Norway and the device is only 'based on' and imported chip from Norway. Nowhere does it say it incorporates this chip and if you look at the RF spec, it can operate higher than the NRF spec sheet for the real chip.....
          I don't know anything more than you do. However, you could substitute a different amplified nRF24L01+ module if you prefer. I can say that it seems to work alright at 250kbps and 1mbps. 2mbps is possibly problematic, though in my limited testing the cause of that may be unrelated.
            I had a chance to test the module more thoroughly, and it appears to work just fine at 2mbps also. So, as of this moment, everything seems good, and I'm not aware of any problems. :)
              seaspac
              is there a connection diagram?
                The newer E01-2G4M27D has more powerful transmit and more sensitive receive capability:
                https://www.aliexpress.com/item/4000536940861.html?spm=a2g0s.9042311.0.0.58a24c4dtdfoIK
                • K
                  K
                  KevinT
                  I know this thread is old but it seems the most relevant. I just tried to compile the standard GatewaySerial.ino sketch using Wemos D1 mini as board type and I get error:
                  MyMainESP8266.cpp:95:9: error: 'cont_can_yield' was not declared in this scope;
                  I'm using MySensors Library v2.3.2
                  I'm assuming this used to work. Is it broken or I am doing something wrong?
                  • K KevinT
                    Great to see you again @KevinT
                    It is broken, and you are doing something wrong :-)
                    Use the latest supported version of the board definitions. See https://forum.mysensors.org/post/114086
                    • K
                      K
                      KevinT
                      Hi @mfalkvidd
                      I rolled back the esp8266 library to 2.6.2 and it compiles.
                      Is there an upcoming release to fix this?
                      • K KevinT
                        Hi @mfalkvidd
                        @KevinT did you read the thread I linked?
                        • K
                          K
                          KevinT
                          Yes, Lol, you have 2 PRs but both have issues. I looked, but I didn't manage to find them on Github/MySensors. I did read that espressif updated their esp8266 core to use standard Arduino yield functions. I guess it's related to that.
                          • K KevinT
                            @KevinT should be one of these https://github.com/mysensors/MySensors/pulls?q=is%3Apr+esp8266+sort%3Aupdated-desc+
                            • Lucas FischerL
                              Lucas FischerL
                              Lucas Fischer
                              That issue is caused by the newer ESP8266 core changing yield functions. Downgrading the ESP8266 core to v2.6.2 (or v2.7.4 depending on your board setup) remains the most reliable workaround until those MySensors core PRs get merged into a main release. Keep an eye on those GitHub PRs for updates on full compatibility with current core releases!
