  3. "req node id"
"req node id"
13 Posts 5 Posters 6.4k Views 3 Watching
  • TotcheT Totche
    I'm facing with a "req node id" problem
    For the gateway I use a mega2560, and for sensor node, a nano with a DS18B20 sensor.
    Both are usb powered, and radios have decoupling capacitors
    I read the temperature correctly
    The both arduinos seem to communicate, but I have always the message "req node id"
    From what I understood,, it's the gateway who sends the id ??
    For the temperature node
    And for the gateway
    So any tip ?
    And in general, what does this mean => 0;0;3;0;9;read: 255-255-0 s=255, c=3............ ?
    5546dug5
    5546dug5
    5546dug
    wrote on last edited by 5546dug
    @Totche said:
    So any tip ?
    I also am having trouble with understanding this type of code.
    • TotcheT
      TotcheT
      Totche
      Thanks for the answer.
      1. So how do you give an Id to a node, or is it unnecessary ?
      2. Is it possible to read/check the sent values on the gateway, and send them on the serial port (always with the gateway) ?
      ChaoticC 1 Reply Last reply
      • TotcheT Totche
        ChaoticC
        ChaoticC
        Chaotic
        @Totche
        1. The controller would do that. If you are using a serial gateway it should be passing all the messages and then the controller would send the correct message back. If you are just setting this up for testing then you can create the message manually.
          I believe that this should work and then just replace X with a number.
          255:255:3:0:4:X
        2. That is what the serial gateway does.
          wrote on last edited by hek
          To see exacly what the debug prints means, you can have a look in the code here:
          https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MySensor.cpp#L222
          and
          https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MySensor.cpp#L273
          All nodes must have an id. But you can set it statically in gw.begin if you don't have any controller. See api.
          1. Is it possible to read/check the sent values on the gateway, and send them on the serial port (always with the gateway) ?
          I don't understand. If you enable debug it will print the same information as the nodes when messages is received/sent. The only difference is that it prepends it with as a LOG-entry so the controller won't be confused.
          • TotcheT
            TotcheT
            Totche
            wrote on last edited by Totche
            I you read the first message, it is a screencopy of the serial monitor for both, and I don't see the temperature on the gateway. from the node
            Ps : ok the two are the same for the last question above ;)
            Ps : I don't have a controller
            • TotcheT Totche
              ChaoticC
              ChaoticC
              Chaotic
              Your going to want a controller in the long term. For testing you can either hard code the node ID in the sketch (you will want to flash the EEPROM clear sketch when you get a controller)
              The reason your not seeing the temp on the gateway is because it doesn't get sent if there is no node ID.
              Basically the node is asking the gateway/controller who am I and the controller isn't responding so it just keeps asking.
              • TotcheT
                TotcheT
                Totche
                Ok thanks, now it's clear.
                • ChaoticC
                  ChaoticC
                  Chaotic
                  wrote on last edited by Chaotic
                  I had the same questions when I started a few weeks ago.
                  Maybe one of the site admins could add the fact that the controller and not the gateway normally handles assigning IDs since it isn't clear.
                    I don't know how to make it more clear. If you got improvements, please help me.
                    http://www.mysensors.org/about/network
                    "Each node is assigned a unique sensorId or address that is used for sending and receiving point-to-point messages. You can assign a static sensorId or let the controller automatically assign one to the sensor. AUTO-mode configures the sensor to request a sensorId from the controller and is the default option for all the examples that we provide. The sensor stores the assigned sensorId in its non-volatile memory to ensure the correct sensorId persists across power transitions."
                    G 1 Reply Last reply
                      G
                      G
                      Ghydda
                      I may be able to give a pointer towards this.
                      I am, as I type this, a first time user digging into the MySensors universe in search for knowledge on how to get a reading (from my first ever mysensor) to pop up (on my first ever mysensor compatible controller).
                      And what I frequently found a little frustrating was your site navigation.
                      It somehow manages to hide some of the good bits -- or probably more correct; the item names in the top and side navigation bars does not always give me a sense of direction when I go information hunting on a given subject.
                      And thus I sometimes simply fold and head to the forum only to discover there is a page for the exact topic - which I just could not spot from the navigation bars.
                      I can not tell you if it is just me or if others feel the same.
                      In general your site seems very thorough put together and maintains a consistently high level across the board.
                      Alas I have no solution to offer per se, other than maybe there could be some more cross-linking directly between pages, or perhaps adding tags to each page as iot-playground.com does, which is really helpful when narrowing down which pages could be relevant to visit next in search of a solution.
                      hekH 1 Reply Last reply
                      • G Ghydda
                        @Ghydda
                        Thanks for the feedback. Agree, hard to create a good navigation. Open for suggestions.
