  3. Vera
  4. Scene too fast for gateway?
55 Posts 6 Posters 33.2k Views 3 Watching
  • ferpandoF
    ferpandoF
    ferpando
    After deleting the files and reuploading the 9600 version, nothing changed, so this is not the problem.
    From the lua file, I see there is a function that sends the data to the nodes.
    How does it work? Is it invoked by vera when you push some button?
    Would it be too complex to make the function store command on an array for instance and send a command to a node from that array queue and not sending another until acknowledge is recevied?
    hekH 1 Reply Last reply
    • ferpandoF ferpando
      @ferpando
      Perhaps you could do some research buffering the outgoing messages.
      I think they all requires ack back from nodes today so this new feature could also try to resend non-acked messages after some timeout.
      ferpandoF 1 Reply Last reply
        @ferpando
        ferpandoF
        ferpandoF
        ferpando
        @hek
        Nothing seems to work.
        I will upgrade the capacitor for the radio but I don't have many expectations.
        As for the plugin, I would need to know more about how vera works.
        Is there a main function in the plugin?
        Also, how do you debug the code in vera?
          The closest to "main" is this:
          https://github.com/mysensors/Vera/blob/master/L_Arduino.lua#L543
          Debugging isn't easy. I usually ssh:ed into the box and tailed the logfile. Was also able to mount the NAS from Vera so I didn't have to scp/file upload changes.
          ferpandoF 2 Replies Last reply
            ferpandoF
            ferpandoF
            ferpando
            @hek
            I'll take a look at this. Thank you.
            I already have my NAS mounted for datamine storage. How can I send the vera logs to the nas?
              You can do a soft link to from the mount to your logfile.
                ferpandoF
                ferpandoF
                ferpando
                @hek
                I'm no linux expert, but I tried this:
                ln -s /var/log/cmh/LuaUPnP.log /dataMine/log/vera.log
                ln: /dataMine/log/vera.log: Permission denied
                and it didn't work
                  Might be a cifs problem when linking.
                  http://ubuntuforums.org/showthread.php?t=1600541
                  Maybe I did it the other way around. Can't recall now.
                    ferpandoF
                    ferpandoF
                    ferpando
                    wrote on last edited by ferpando
                    #37
                    @hek
                    I think the problem might be that I'm trying to create the symLink as root and the cfis is using another user to connect to the nas
                      ferpandoF
                      ferpandoF
                      ferpando
                      #38
                      @hek
                      Here's a basic implementation of the sending queue I came up with.
                      First I modified this functions:
                      function sendCommandWithMessageType(altid, messageType, ack, variableId, value)
                      	local cmd = altid..";".. msgType[messageType] .. ";" .. ack .. ";" .. variableId .. ";" .. value
                      	-- only add to list if of SET type
                      	if (messageType =="SET") then
                      		addToMyQueue(cmd)
                       	end
                      	if (luup.io.write(cmd) == false)  then
                      		task("Cannot send command - communications error", TASK_ERROR)
                      		luup.set_failure(true)
                      		return false
                      	end
                      	return true
                      end
                      function processIncoming(s)
                      	local incomingData = s:split(";")
                      	if (#incomingData >=4) then
                      		-- check if msg is in the list to remove it
                      		checkMyQueue(s);
                      		local nodeId = incomingData[1]
                      end
                      And added this other functions:
                      -- adds cmd msg to the list before sending
                      function addToMyQueue(myCmd)
                      	local isFound = inTable(MyMsgs, myCmd);
                      	-- if not already in the list, add it
                      	if (isFound == false) then
                      		table.insert( MyMsgs, myCmd )
                      	end
                      end
                      function checkMyQueue(msg)
                      	log(MyPrefix .. ">T> queue        : " .. printTable(MyMsgs) )
                      	local isFound = inTable(MyMsgs, msg);
                      	-- if msg found, remove it because has been executed
                      	if (isFound ~= false) then
                      		log("msg found in pos: "..isFound..". Removing from list...")
                      		table.remove (MyMsgs , isFound)
                      			log("msg not found in list")
                      		end
                      	log(MyPrefix .. ">T> queue updated: " .. printTable(MyMsgs) )
                      end
                      function inTable(tbl, item)
                          for key, value in pairs(tbl) do
                              if value == item then return key end
                          end
                          return false
                      end
                      It basically works but the problem with this is that processIncoming() is only processed when a new message arrives, so there is no way we could re-send lost messages when iddle.
                      We need a function that could be executed at regular intervals to check if there are any messages left in the queue to be re-send.
                        @hek
                        		addToMyQueue(cmd)
                         	end
                        		return false
                        	end
                        	return true
                        end
                        		checkMyQueue(s);
                        end
                        	end
                        end
                        		end
                        end
                            end
                            return false
                        end
                        http://wiki.micasaverde.com/index.php/Luup_Lua_extensions#function:_call_timer
                          ferpandoF
                          ferpandoF
                          ferpando
                          @hek
                          I almost got it but for some reason the call_timer is not being excuted. Not even the first time.
                          Looking at the logs, i can see that the 6 commands are sent really quickly within milliseconds, and as you can see at the end, only 3 of the messages get through, leaving 3 lost
                          08	03/20/15 14:26:46.549	Scene::RunScene running 81 test6on <0x2f250680>
                          08	03/20/15 14:26:46.550	JobHandler_LuaUPnP::HandleActionRequest device: 219 service: urn:upnp-org:serviceId:SwitchPower1 action: SetTarget <0x2f250680>
                          08	03/20/15 14:26:46.550	JobHandler_LuaUPnP::HandleActionRequest argument newTargetValue=1 <0x2f250680>
                          50	03/20/15 14:26:46.553	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> switchPower <0x2b2c1000>
                          50	03/20/15 14:26:46.554	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> sendCommand <0x2b2c1000>
                          50	03/20/15 14:26:46.554	luup_log:130: ****<-*->**** Arduino: *** **** **** **** *** *** Sending: 6;0;1;1;2;1 <0x2b2c1000>
                          04	03/20/15 14:26:46.556	<Job ID="42" Name="" Device="219" Created="2015-03-20 14:26:46" Started="2015-03-20 14:26:46" Completed="2015-03-20 14:26:46" Duration="0.4574000" Runtime="0.2382000" Status="Successful" LastNote=""/> <0x2b2c1000>
                          08	03/20/15 14:26:46.562	JobHandler_LuaUPnP::HandleActionRequest device: 221 service: urn:upnp-org:serviceId:SwitchPower1 action: SetTarget <0x2f250680>
                          08	03/20/15 14:26:46.562	JobHandler_LuaUPnP::HandleActionRequest argument newTargetValue=1 <0x2f250680>
                          08	03/20/15 14:26:46.595	JobHandler_LuaUPnP::HandleActionRequest device: 216 service: urn:upnp-org:serviceId:SwitchPower1 action: SetTarget <0x2f250680>
                          08	03/20/15 14:26:46.596	JobHandler_LuaUPnP::HandleActionRequest argument newTargetValue=1 <0x2f250680>
                          08	03/20/15 14:26:46.597	JobHandler_LuaUPnP::HandleActionRequest device: 215 service: urn:upnp-org:serviceId:SwitchPower1 action: SetTarget <0x2f250680>
                          08	03/20/15 14:26:46.598	JobHandler_LuaUPnP::HandleActionRequest argument newTargetValue=1 <0x2f250680>
                          08	03/20/15 14:26:46.599	JobHandler_LuaUPnP::HandleActionRequest device: 218 service: urn:upnp-org:serviceId:SwitchPower1 action: SetTarget <0x2f250680>
                          08	03/20/15 14:26:46.600	JobHandler_LuaUPnP::HandleActionRequest argument newTargetValue=1 <0x2f250680>
                          50	03/20/15 14:26:46.601	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> switchPower <0x2b2c1000>
                          50	03/20/15 14:26:46.602	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> sendCommand <0x2b2c1000>
                          50	03/20/15 14:26:46.602	luup_log:130: ****<-*->**** Arduino: *** **** **** **** *** *** Sending: 6;1;1;1;2;1 <0x2b2c1000>
                          04	03/20/15 14:26:46.604	<Job ID="43" Name="" Device="221" Created="2015-03-20 14:26:46" Started="2015-03-20 14:26:46" Completed="2015-03-20 14:26:46" Duration="0.40816000" Runtime="0.2283000" Status="Successful" LastNote=""/> <0x2b2c1000>
                          50	03/20/15 14:26:46.605	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> switchPower <0x2b2c1000>
                          50	03/20/15 14:26:46.606	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> sendCommand <0x2b2c1000>
                          50	03/20/15 14:26:46.606	luup_log:130: ****<-*->**** Arduino: *** **** **** **** *** *** Sending: 6;2;1;1;2;1 <0x2b2c1000>
                          04	03/20/15 14:26:46.608	<Job ID="44" Name="" Device="216" Created="2015-03-20 14:26:46" Started="2015-03-20 14:26:46" Completed="2015-03-20 14:26:46" Duration="0.11100000" Runtime="0.2205000" Status="Successful" LastNote=""/> <0x2b2c1000>
                          50	03/20/15 14:26:46.610	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> switchPower <0x2b2c1000>
                          50	03/20/15 14:26:46.610	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> sendCommand <0x2b2c1000>
                          50	03/20/15 14:26:46.610	luup_log:130: ****<-*->**** Arduino: *** **** **** **** *** *** Sending: 6;3;1;1;2;1 <0x2b2c1000>
                          08	03/20/15 14:26:46.614	JobHandler_LuaUPnP::HandleActionRequest device: 220 service: urn:upnp-org:serviceId:SwitchPower1 action: SetTarget <0x2f250680>
                          08	03/20/15 14:26:46.614	JobHandler_LuaUPnP::HandleActionRequest argument newTargetValue=1 <0x2f250680>
                          04	03/20/15 14:26:46.620	<Job ID="45" Name="" Device="215" Created="2015-03-20 14:26:46" Started="2015-03-20 14:26:46" Completed="2015-03-20 14:26:46" Duration="0.20340000" Runtime="0.9573000" Status="Successful" LastNote=""/> <0x2b2c1000>
                          50	03/20/15 14:26:46.624	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> switchPower <0x2b2c1000>
                          50	03/20/15 14:26:46.624	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> sendCommand <0x2b2c1000>
                          50	03/20/15 14:26:46.625	luup_log:130: ****<-*->**** Arduino: *** **** **** **** *** *** Sending: 6;4;1;1;2;1 <0x2b2c1000>
                          04	03/20/15 14:26:46.627	<Job ID="46" Name="" Device="218" Created="2015-03-20 14:26:46" Started="2015-03-20 14:26:46" Completed="2015-03-20 14:26:46" Duration="0.25886000" Runtime="0.5533000" Status="Successful" LastNote=""/> <0x2b2c1000>
                          50	03/20/15 14:26:46.628	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> switchPower <0x2b2c1000>
                          50	03/20/15 14:26:46.629	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> sendCommand <0x2b2c1000>
                          50	03/20/15 14:26:46.629	luup_log:130: ****<-*->**** Arduino: *** **** **** **** *** *** Sending: 6;5;1;1;2;1 <0x2b2c1000>
                          04	03/20/15 14:26:46.631	<Job ID="47" Name="" Device="220" Created="2015-03-20 14:26:46" Started="2015-03-20 14:26:46" Completed="2015-03-20 14:26:46" Duration="0.15803000" Runtime="0.2479000" Status="Successful" LastNote=""/> <0x2b2c1000>
                          50	03/20/15 14:26:46.672	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> processIncoming msg: 6;0;1;1;2;1 <0x2e850680>
                          50	03/20/15 14:26:46.673	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue        : {6;0;1;1;2;1, 6;1;1;1;2;1, 6;2;1;1;2;1, 6;3;1;1;2;1, 6;4;1;1;2;1, 6;5;1;1;2;1, } <0x2e850680>
                          50	03/20/15 14:26:46.674	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue retrais: {0, 0, 0, 0, 0, 0, } <0x2e850680>
                          50	03/20/15 14:26:46.674	luup_log:130: ****<-*->**** Arduino: msg found in pos: 1. Removing from list... <0x2e850680>
                          50	03/20/15 14:26:46.677	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue updated: {6;1;1;1;2;1, 6;2;1;1;2;1, 6;3;1;1;2;1, 6;4;1;1;2;1, 6;5;1;1;2;1, } <0x2e850680>
                          50	03/20/15 14:26:46.677	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue retrais: {0, 0, 0, 0, 0, } <0x2e850680>
                          50	03/20/15 14:26:46.678	luup_log:130: ****<-*->**** Arduino: ****<-->**** Set variable: 6;0;1;1;2;1 <0x2e850680>
                          50	03/20/15 14:26:46.678	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> setVariable <0x2e850680>
                          50	03/20/15 14:26:46.679	luup_log:130: ****<-*->**** Arduino: Setting variable 'Status' to value '1' <0x2e850680>
                          50	03/20/15 14:26:46.679	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> setVariableIfChanged <0x2e850680>
                          50	03/20/15 14:26:46.679	luup_log:130: ****<-*->**** Arduino: ****<-*->**** urn:upnp-org:serviceId:SwitchPower1,Status, 1, 219 <0x2e850680>
                          06	03/20/15 14:26:46.680	Device_Variable::m_szValue_set device: 219 service: urn:upnp-org:serviceId:SwitchPower1 variable: Status was: 0 now: 1 #hooks: 4 upnp: 0 v:0x9b41e8/NONE duplicate:0 <0x2e850680>
                          50	03/20/15 14:26:46.680	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> setVariableIfChanged <0x2e850680>
                          50	03/20/15 14:26:46.684	luup_log:130: ****<-*->**** Arduino: ****<-*->**** urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1426858006, 219 <0x2e850680>
                          06	03/20/15 14:26:46.685	Device_Variable::m_szValue_set device: 219 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1426688846 now: 1426858006 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2e850680>
                          50	03/20/15 14:26:46.685	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> setVariableIfChanged <0x2e850680>
                          50	03/20/15 14:26:46.686	luup_log:130: ****<-*->**** Arduino: ****<-*->**** urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1426858006, 217 <0x2e850680>
                          06	03/20/15 14:26:46.686	Device_Variable::m_szValue_set device: 217 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1426857982 now: 1426858006 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2e850680>
                          50	03/20/15 14:26:46.687	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> setVariableIfChanged <0x2e850680>
                          50	03/20/15 14:26:46.688	luup_log:130: ****<-*->**** Arduino: ****<-*->**** urn:micasaverde-com:serviceId:HaDevice1,LastUpdateHR, 14:26, 217 <0x2e850680>
                          50	03/20/15 14:26:46.752	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> processIncoming msg: 6;1;1;1;2;1 <0x2e850680>
                          50	03/20/15 14:26:46.753	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue        : {6;1;1;1;2;1, 6;2;1;1;2;1, 6;3;1;1;2;1, 6;4;1;1;2;1, 6;5;1;1;2;1, } <0x2e850680>
                          50	03/20/15 14:26:46.753	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue retrais: {0, 0, 0, 0, 0, } <0x2e850680>
                          50	03/20/15 14:26:46.754	luup_log:130: ****<-*->**** Arduino: msg found in pos: 1. Removing from list... <0x2e850680>
                          50	03/20/15 14:26:46.754	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue updated: {6;2;1;1;2;1, 6;3;1;1;2;1, 6;4;1;1;2;1, 6;5;1;1;2;1, } <0x2e850680>
                          50	03/20/15 14:26:46.755	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue retrais: {0, 0, 0, 0, } <0x2e850680>
                          50	03/20/15 14:26:46.755	luup_log:130: ****<-*->**** Arduino: ****<-->**** Set variable: 6;1;1;1;2;1 <0x2e850680>
                          50	03/20/15 14:26:46.756	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> setVariable <0x2e850680>
                          50	03/20/15 14:26:46.756	luup_log:130: ****<-*->**** Arduino: Setting variable 'Status' to value '1' <0x2e850680>
                          50	03/20/15 14:26:46.756	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> setVariableIfChanged <0x2e850680>
                          50	03/20/15 14:26:46.757	luup_log:130: ****<-*->**** Arduino: ****<-*->**** urn:upnp-org:serviceId:SwitchPower1,Status, 1, 221 <0x2e850680>
                          06	03/20/15 14:26:46.757	Device_Variable::m_szValue_set device: 221 service: urn:upnp-org:serviceId:SwitchPower1 variable: Status was: 0 now: 1 #hooks: 4 upnp: 0 v:0x9b41e8/NONE duplicate:0 <0x2e850680>
                          50	03/20/15 14:26:46.759	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> setVariableIfChanged <0x2e850680>
                          50	03/20/15 14:26:46.759	luup_log:130: ****<-*->**** Arduino: ****<-*->**** urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1426858006, 221 <0x2e850680>
                          06	03/20/15 14:26:46.760	Device_Variable::m_szValue_set device: 221 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1426688847 now: 1426858006 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2e850680>
                          50	03/20/15 14:26:46.760	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> setVariableIfChanged <0x2e850680>
                          50	03/20/15 14:26:46.761	luup_log:130: ****<-*->**** Arduino: ****<-*->**** urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1426858006, 217 <0x2e850680>
                          06	03/20/15 14:26:46.761	Device_Variable::m_szValue_set device: 217 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1426858006 now: 1426858006 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2e850680>
                          50	03/20/15 14:26:46.762	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> setVariableIfChanged <0x2e850680>
                          50	03/20/15 14:26:46.762	luup_log:130: ****<-*->**** Arduino: ****<-*->**** urn:micasaverde-com:serviceId:HaDevice1,LastUpdateHR, 14:26, 217 <0x2e850680>
                          50	03/20/15 14:26:46.862	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> processIncoming msg: 6;2;1;1;2;1 <0x2e850680>
                          50	03/20/15 14:26:46.863	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue        : {6;2;1;1;2;1, 6;3;1;1;2;1, 6;4;1;1;2;1, 6;5;1;1;2;1, } <0x2e850680>
                          50	03/20/15 14:26:46.863	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue retrais: {0, 0, 0, 0, } <0x2e850680>
                          50	03/20/15 14:26:46.864	luup_log:130: ****<-*->**** Arduino: msg found in pos: 1. Removing from list... <0x2e850680>
                          50	03/20/15 14:26:46.864	luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue updated: {6;3;1;1;2;1, 6;4;1;1;2;1, 6;5;1;1;2;1, } <0x2e850680>
                            @hek
                            I think you have to re-initialize timer after each call. But it is weird that the first call never executes.
                              ferpandoF
                              ferpandoF
                              ferpando
                              @hek
                              yes, I call the timer again at the end of the function, but the first is inside the start function
                                @hek
                                @ferpando
                                Found this thread: http://forum.micasaverde.com/index.php/topic,15304.msg116321.html#msg116321
                                We're using job in the MySensors plugin. You might wanna try call_delay instead.
                                ferpandoF 3 Replies Last reply
                                  @ferpando
                                  ferpandoF
                                  ferpandoF
                                  ferpando
                                  @hek
                                  yes I saw it too, but in this case, the call should be recursive, so it should be better to use the timer version.
                                  I'll try with delay and see if at least works.
                                  • ferpandoF
                                    ferpandoF
                                    ferpando
                                    Well, If I call the function directly at the begining it gets executed, but neither timer nor delay work.
                                      @ferpando
                                      ferpandoF
                                      ferpandoF
                                      ferpando
                                      @hek
                                      I got the timer working with this help:
                                      http://forum.micasaverde.com/index.php?topic=10258.0
                                      I'll implement it and see what happens
                                        @ferpando
                                        ferpandoF
                                        ferpandoF
                                        ferpando
                                        @hek
                                        Well, I think it sort of works for now.. still too slow and a lot of polishing might be needed, but the concept I think is valid.
                                        Here I turn on 2 devices on an unplugged node, so the commands are put into the queue and the timer is started. Because the node i sunplugged no response is received.
                                        08 03/20/15 22:13:19.706 JobHandler_LuaUPnP::HandleActionRequest device: 219 service: urn:upnp-org:serviceId:SwitchPower1 action: SetTarget <0x2f7fc680>
                                        08 03/20/15 22:13:19.707 JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=219 <0x2f7fc680>
                                        08 03/20/15 22:13:19.707 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:upnp-org:serviceId:SwitchPower1 <0x2f7fc680>
                                        08 03/20/15 22:13:19.707 JobHandler_LuaUPnP::HandleActionRequest argument action=SetTarget <0x2f7fc680>
                                        08 03/20/15 22:13:19.707 JobHandler_LuaUPnP::HandleActionRequest argument newTargetValue=1 <0x2f7fc680>
                                        08 03/20/15 22:13:19.708 JobHandler_LuaUPnP::HandleActionRequest argument rand=0.980960675558267 <0x2f7fc680>
                                        50 03/20/15 22:13:19.710 luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> switchPower <0x2ac6e000>
                                        50 03/20/15 22:13:19.710 luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> sendCommand <0x2ac6e000>
                                        50 03/20/15 22:13:19.711 luup_log:130: ****<-*->**** Arduino: *** **** **** **** *** *** Sending: 6;0;1;1;2;1 <0x2ac6e000>
                                        04 03/20/15 22:13:19.714 <Job ID="5" Name="" Device="219" Created="2015-03-20 22:13:19" Started="2015-03-20 22:13:19" Completed="2015-03-20 22:13:19
                                        08 03/20/15 22:13:22.567 JobHandler_LuaUPnP::HandleActionRequest device: 221 service: urn:upnp-org:serviceId:SwitchPower1 action: SetTarget <0x2f5fc680>
                                        08 03/20/15 22:13:22.567 JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=221 <0x2f5fc680>
                                        08 03/20/15 22:13:22.568 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:upnp-org:serviceId:SwitchPower1 <0x2f5fc680>
                                        08 03/20/15 22:13:22.568 JobHandler_LuaUPnP::HandleActionRequest argument action=SetTarget <0x2f5fc680>
                                        08 03/20/15 22:13:22.568 JobHandler_LuaUPnP::HandleActionRequest argument newTargetValue=1 <0x2f5fc680>
                                        08 03/20/15 22:13:22.568 JobHandler_LuaUPnP::HandleActionRequest argument rand=0.3527142092837271 <0x2f5fc680>
                                        50 03/20/15 22:13:22.570 luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> switchPower <0x2ac6e000>
                                        50 03/20/15 22:13:22.570 luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> sendCommand <0x2ac6e000>
                                        50 03/20/15 22:13:22.571 luup_log:130: ****<-*->**** Arduino: *** **** **** **** *** *** Sending: 6;1;1;1;2;1 <0x2ac6e000>
                                        04 03/20/15 22:13:22.573 <Job ID="6" Name="" Device="221" Created="2015-03-20 22:13:22" Started="2015-03-20 22:13:22" Completed="2015-03-20 22:13:22"
                                        then it starts to try to resend the messages. i did set a limit of retries and then the message is deleted for good.
                                        50 03/20/15 22:13:24.101 luup_log:130: ****<-*->**** Arduino: -=OOOO-chk-OOOO=- queue length: 2 <0x2cba1680>
                                        50 03/20/15 22:13:24.102 luup_log:130: ****<-*->**** Arduino: -=OOOO-chk-OOOO=- queue : {6;0;1;1;2;1, 6;1;1;1;2;1, } <0x2cba1680>
                                        50 03/20/15 22:13:24.102 luup_log:130: ****<-*->**** Arduino: queue last elem: 6;1;1;1;2;1 retried: 0 <0x2cba1680>
                                        50 03/20/15 22:13:24.102 luup_log:130: ****<-*->**** Arduino: ****<-*->**** -=OOOO-snd-OOOO=- resending: 6;1;1;1;2;1 <0x2cba1680>
                                        50 03/20/15 22:13:24.104 luup_log:130: ****<-*->**** Arduino: -=OOOO-ooo-OOOO=- starting timer <0x2cba1680>
                                        50 03/20/15 22:13:49.102 luup_log:130: ****<-*->**** Arduino: -=OOOO-chk-OOOO=- queue length: 2 <0x2cba1680>
                                        50 03/20/15 22:13:49.102 luup_log:130: ****<-*->**** Arduino: -=OOOO-chk-OOOO=- queue : {6;0;1;1;2;1, 6;1;1;1;2;1, } <0x2cba1680>
                                        50 03/20/15 22:13:49.102 luup_log:130: ****<-*->**** Arduino: queue last elem: 6;1;1;1;2;1 retried: 5 <0x2cba1680>
                                        50 03/20/15 22:13:49.103 luup_log:130: ****<-*->**** Arduino: ****<-*->**** -=OOOO-snd-OOOO=- resending: 6;1;1;1;2;1 <0x2cba1680>
                                        50 03/20/15 22:13:49.105 luup_log:130: ****<-*->**** Arduino: -=OOOO-ooo-OOOO=- starting timer <0x2cba1680>
                                        then when I connect the node back online, the messages are delivered
                                        50 03/20/15 22:13:54.179 luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> processIncoming msg: 6;1;1;1;2;1 <0x2e3fc680>
                                        50 03/20/15 22:13:54.180 luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue : {6;0;1;1;2;1, 6;1;1;1;2;1, } <0x2e3fc680>
                                        50 03/20/15 22:13:54.180 luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue retries: {0, 7, } <0x2e3fc680>
                                        50 03/20/15 22:13:54.181 luup_log:130: ****<-*->**** Arduino: msg found in pos: 2. Removing from list... <0x2e3fc680>
                                        50 03/20/15 22:13:54.182 luup_log:130: ****<-*->**** Arduino: ****<-->**** Set variable: 6;1;1;1;2;1 <0x2e3fc680>
                                        50 03/20/15 22:13:54.182 luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> setVariable <0x2e3fc680>
                                        50 03/20/15 22:13:54.182 luup_log:130: ****<-*->**** Arduino: Setting variable 'Status' to value '1' <0x2e3fc680>
                                        50 03/20/15 22:13:59.101 luup_log:130: ****<-*->**** Arduino: -=OOOO-chk-OOOO=- queue length: 1 <0x2cba1680>
                                        50 03/20/15 22:13:59.101 luup_log:130: ****<-*->**** Arduino: -=OOOO-chk-OOOO=- queue : {6;0;1;1;2;1, } <0x2cba1680>
                                        50 03/20/15 22:13:59.102 luup_log:130: ****<-*->**** Arduino: queue last elem: 6;0;1;1;2;1 retried: 0 <0x2cba1680>
                                        50 03/20/15 22:13:59.102 luup_log:130: ****<-*->**** Arduino: ****<-*->**** -=OOOO-snd-OOOO=- resending: 6;0;1;1;2;1 <0x2cba1680>
                                        50 03/20/15 22:13:59.104 luup_log:130: ****<-*->**** Arduino: -=OOOO-snd-OOOO=- set cheking off queue just emptied <0x2cba1680>
                                        50 03/20/15 22:13:59.209 luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> processIncoming msg: 6;0;1;1;2;1 <0x2e3fc680>
                                        50 03/20/15 22:13:59.210 luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue : {6;0;1;1;2;1, } <0x2e3fc680>
                                        50 03/20/15 22:13:59.210 luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue retries: {1, } <0x2e3fc680>
                                        50 03/20/15 22:13:59.211 luup_log:130: ****<-*->**** Arduino: msg found in pos: 1. Removing from list... <0x2e3fc680>
                                        50 03/20/15 22:13:59.211 luup_log:130: ****<-*->**** Arduino: ****<-*->**** >T> queue updated: {} <0x2e3fc680>
                                        50 03/20/15 22:13:59.212 luup_log:130: ****<-*->**** Arduino: ****<-->**** Set variable: 6;0;1;1;2;1 <0x2e3fc680>
                                        50 03/20/15 22:13:59.212 luup_log:130: ****<-*->**** Arduino: ****<-*->**** >F> setVariable <0x2e3fc680>
                                        50 03/20/15 22:13:59.212 luup_log:130: ****<-*->**** Arduino: Setting variable 'Status' to value '1' <0x2e3fc680>
                                        I don't really know if this would be a useful way to solve the problem, or maybe I should look somewhere else
                                          Looks good, Might be more people finding this useful. Could you prepare a pull request?
                                          Q: Should the queuing/#retries be options in the plugin settings?
