  3. The Big Picture. Will this work?
9 Posts 4 Posters 3.7k Views 1 Watching
  • dakkyD
    dakkyD
    dakky
    Greetings everybody.
    I'm beginning to dig myself into the topic of DIY homeautomation :D But there are also some questions i can't answer myself properly :(
    I'm planning the following setup:
    • raspi as OpenHAB Base with raspbian
    • MQTT Gateway (installed on the pi? possible?)
    • sensors:
      • energy source: battery for all. I don't want to cut cables into my walls (besides: my wife would kill me :D ) runtimes should be at least 6 months ^^
      • transmission sensors -> gateway: WiFi with (WPA2 enabled) would be awesome, maybe bluetooth4 (with bluetooth low energy ??)
      • sensor types: temp, humidy and door/window sensors
    Any chance to archieve this?
    Thx
    Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
    Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
    Software: MySensors 2.0development
    • MagiskeM
      MagiskeM
      Magiske
      OpenHab on a pi is a good choice.
      I would use an Arduino Uno with an ethernet shield for the MQTT gateway, so much easier to setup.
      A good 18650 3.7v battery should give you more than 6 months if you power trim you sensors.
      And the transmission would be by using NRF24L01+'s.
      So all about making it easy for yourself:)
      So to answer you question.. Yes, should be easy to achieve fairly fast.
      • tbowmoT
        tbowmoT
        tbowmo
        @dakky
        have seen http://www.mysensors.org/hardware/micro ? (temperature/humidity sensor, battery powered)
        • dakkyD
          dakkyD
          dakky
          @tbowmo
          jep thats the target on the sensor side. I'd select an ardiuno pro micro (3,3V), strip the LED from it an connect the sensors and the NRF24L01+ to it. Of course i could buy your sensor board (and maybe, depending on price an availability i will), but where is the fun and the learning progress? :D
          @Magiske
          but why an extra device for the gateway? Is it really "too hard" to connect the receiving NRF24L01+ via the gpio and run it under raspbian? An extra device means extra costs and extra wiring (power, LAN).
          • MagiskeM
            MagiskeM
            Magiske
            @dakky Well you can do the gateway for around $13ish and thats easy. Adding the gateway module to the running OpenHab could be easy if they can coexist. I have not done that, so again, it could be easy. But since you are just starting out, keep it easy.
            And afterwards, you can reuse the uno for other projects..
            • dakkyD
              dakkyD
              dakky
              hmm do you have a hint for me? I'm trying to understand the way the gateway works. The ethernet part is ok. But what about the NRF24L01+ and WiFi? Do u have some docs/tutorials/codesnipplets for me?
              • dakkyD
                dakkyD
                dakky
                u i got trapped .... the nrf24l01+ does't do WiFi. It just uses the same band :( i would prefer real WPA2 protected WiFi. Is anything like that possible (with battery power)?
                if NOT, how "secure" is it, to use open radio transmission for communication?
                  maha
                  wrote on last edited by maha
                  Under Development is a great thread about security:
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @dakky
                    look here http://forum.mysensors.org/topic/1021/security-introducing-signing-support-to-mysensors
