  3. The Big Picture. Will this work?
9 Posts 4 Posters 3.4k Views 1 Watching
  • dakkyD Offline
    dakkyD Offline
    dakky
    Greetings everybody.
    I'm beginning to dig myself into the topic of DIY homeautomation :D But there are also some questions i can't answer myself properly :(
    I'm planning the following setup:
    • raspi as OpenHAB Base with raspbian
    • MQTT Gateway (installed on the pi? possible?)
    • sensors:
      • energy source: battery for all. I don't want to cut cables into my walls (besides: my wife would kill me :D ) runtimes should be at least 6 months ^^
      • transmission sensors -> gateway: WiFi with (WPA2 enabled) would be awesome, maybe bluetooth4 (with bluetooth low energy ??)
      • sensor types: temp, humidy and door/window sensors
    Any chance to archieve this?
    Thx
    Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
    Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
    Software: MySensors 2.0development
    • M Offline
      M Offline
      Magiske
      OpenHab on a pi is a good choice.
      I would use an Arduino Uno with an ethernet shield for the MQTT gateway, so much easier to setup.
      A good 18650 3.7v battery should give you more than 6 months if you power trim you sensors.
      And the transmission would be by using NRF24L01+'s.
      So all about making it easy for yourself:)
      So to answer you question.. Yes, should be easy to achieve fairly fast.
      • T Offline
        T Offline
        tbowmo
        @dakky
        have seen http://www.mysensors.org/hardware/micro ? (temperature/humidity sensor, battery powered)
        • dakkyD Offline
          dakkyD Offline
          dakky
          @tbowmo
          jep thats the target on the sensor side. I'd select an ardiuno pro micro (3,3V), strip the LED from it an connect the sensors and the NRF24L01+ to it. Of course i could buy your sensor board (and maybe, depending on price an availability i will), but where is the fun and the learning progress? :D
          @Magiske
          but why an extra device for the gateway? Is it really "too hard" to connect the receiving NRF24L01+ via the gpio and run it under raspbian? An extra device means extra costs and extra wiring (power, LAN).
          • M Offline
            M Offline
            Magiske
            @dakky Well you can do the gateway for around $13ish and thats easy. Adding the gateway module to the running OpenHab could be easy if they can coexist. I have not done that, so again, it could be easy. But since you are just starting out, keep it easy.
            And afterwards, you can reuse the uno for other projects..
            • dakkyD Offline
              dakkyD Offline
              dakky
              hmm do you have a hint for me? I'm trying to understand the way the gateway works. The ethernet part is ok. But what about the NRF24L01+ and WiFi? Do u have some docs/tutorials/codesnipplets for me?
              • dakkyD Offline
                dakkyD Offline
                dakky
                u i got trapped .... the nrf24l01+ does't do WiFi. It just uses the same band :( i would prefer real WPA2 protected WiFi. Is anything like that possible (with battery power)?
                if NOT, how "secure" is it, to use open radio transmission for communication?
                • M Offline
                  M Offline
                  maha
                  wrote on last edited by maha
                  Under Development is a great thread about security:
                  • T Offline
                    T Offline
                    tbowmo
                    @dakky
                    look here http://forum.mysensors.org/topic/1021/security-introducing-signing-support-to-mysensors
                    12.0k
