  3. Minimal design thoughts
299 Posts 34 Posters 279.2k Views 17 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @hek
    I have a BOM at mouser, but need to double check it.. (Also, might have some of the capacitors/resistors in my "private" stock, so you don't need to order them)
    • blaceyB
      blaceyB
      blacey
      @tbowmo you can sign me up too however I can handle the component side of it if you share the mouser BOM.
      tbowmoT 1 Reply Last reply
      • blaceyB blacey
        tbowmoT
        tbowmoT
        tbowmo
        #241
        The BOM should be available at
        http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=a509f9ca59
        It should match the current PCB layout for the major number of parts. I haven't looked at the crystal yet, to see if that fits, as I have changed the footprint to the one provided by the manufacturer in china when going with rev. 2.
        At the moment I'm considering if the crystal should be dropped from the BOM, kind of missing a real purpose for it at the moment, as I don't think that "precise timing" is necessary for a node that repports in at a regular interval.. I (for one) don't care if it reports temperature / humidity "exactly" every 60 seconds, or if it's every 55 or 65 seconds.. But others might have another priority?
        Schematics / PCB layout is available on github : https://github.com/tbowmo/MySensorMicro (please double check BOM from mouser, and the eagle files. I might have missed something :))
        blaceyB 1 Reply Last reply
        • tbowmoT tbowmo
          blaceyB
          blaceyB
          blacey
          @tbowmo Awesome! I'm on it :+1:
          • tbowmoT
            tbowmoT
            tbowmo
            #243
            So, a small update on the rev.2 board status.
            I am verifying the rest of the board now, before we kick of an initial testrun of 5 boards at the manufacturer. Everything seems to be working, electrically..
            Unfortunately something has happened in the SPI library in arduino, so the external flash, is now crashing the arduino sketch, while initializing. Someone else has already reported it to lowpowerlabs github repo https://github.com/LowPowerLab/SPIFlash/issues/8
            Having had the above issues, I have already build, and disassembled two nodes, trying to debug things :s
            Oh the fun of debugging embedded things...
            update
            I found a solution, someone else had made the necessary changes to lowpowerlabs spiflash library (check the issue comments in the link above)
            I also read in the release notes for arduino 1.6.0, that they have changed the SPI library to support transactions. Will this have any effect on MySensors? (@hek, any comments?)
              sharath krishna
              @tbowmo : if the connections are fine when can we expect he board for production ?? looks everything is fine
              • tbowmoT
                tbowmoT
                tbowmo
                @sharath-krishna
                We are getting closer to a launch. A production partner has been found. All on-board hardware have been verified as OK! And I'm verifying the last bits (Want to have a complete node running, before giving a GO..) Also finishing the software that should be preloaded on the atmega.
                Depending on how things are going, we should be able to make the first trial batch within the next couple of weeks (I hope!) which we then need to verify before starting the big machine.
                Going to be an exiting spring this year :)
                • D
                  doblanch
                  To where will you be able to ship the nodes ? I live in France. I don't know where you are located...
                  hekH 1 Reply Last reply
                  • D doblanch
                    @doblanch
                    It will be shipped directly from the producer to any location.
                    D 1 Reply Last reply
                      @doblanch
                      doblanch
                      @hek Thank you for your reply. I'm going to deploy may be like 5/6 nodes. Another question, By any chance, did you think about a case which accept module+battery ?
                        A case already was on my short-list and we could very well provide it.
                        Depending on demand it could be 3d-printed or for larger quantities done with mold injection by our partner.
                        But I would really need some help from a (talented) 3d modeller for this. Do we have anyone here that can help out?
                        The box must have a battery compartment for 2XAA. A big question is if it also should have space for an extra sensor?
                        Would be great if we could provide a couple of cover-options for things like motion (HC-SR501) and another for light/uv/ir sensor. Hope we can get creative together here.
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          A small update from the workbench here :)
                          The first rev.2 node is transmitting like it has never done anything else right now.
                          Next up is programming the bootloader, I am having some troubles in that area.. It seems that it is programmed, but I can't get it to accept any downloads from the arduino IDE.
                          Anyone got any hints for me to follow?
                          AnticimexA 1 Reply Last reply
                          • tbowmoT tbowmo
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @tbowmo have you checked that the fuse configuration matches the HW with respect to frequencies and such?
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @Anticimex
                              I have checked, and double checked fuses :) I'm using avrdude to program the bootloader directly, and it seems that it is starting up (the LED is lighting up as it is supposed to). Also when I program a sketch via ISP (using jtagice3) serial is working fine, so it seems that fuse settings is right for oscillator (at least)
                              But I might have missed something with the fuse settings.
                              I get these fuses
                              AVRDUDE -U lfuse:w:0xE2:m -U hfuse:w:0xDA:m -U efuse:w:0xFE:m -U lock:w:0xFF:m
                              from http://eleccelerator.com/fusecalc/fusecalc.php?chip=atmega328p&LOW=E2&HIGH=DA&EXTENDED=FE&LOCKBIT=FF
                              AnticimexA tekkaT 2 Replies Last reply
                              • tbowmoT tbowmo
                                @Anticimex
                                I get these fuses
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @tbowmo I am just taking wild guesses and the one thing that came to my mind if you seem to have bootloader running but cannot download is that the serial line is out of sync for some reason. But I have not dissected the arduino bootloader or the protocol so I am in deep murky waters making assumptions now :)
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @Anticimex
                                  Yeah, but it's hard to debug things in the bootloader.
                                  • tbowmoT tbowmo
                                    @Anticimex
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @tbowmo Tell me about it. It's what I do for a living :)
                                    You don't have means to pick up the serial line after the FTDI adapter by any chance? It perhaps reveals garbage or signs of non-matching BAUD rates.
                                    • tbowmoT tbowmo
                                      @Anticimex
                                      I get these fuses
                                      tekkaT
                                      tekkaT
                                      tekka
                                      wrote on last edited by tekka
                                      #256
                                      @tbowmo
                                      The fuse settings say 8Mhz internal, 2kb bootloader. Which bootloader are you using and did you adjust the baud settings in the boards.txt for the IDE (i.e. upload.speed=57600)? Also, do you get serial output at the set baud rate when uploading a simple serial output sketch via isp? Alternatively, I recommend recompiling the bootloader at 8Mhz for correct baud settings.
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @tekka
                                        It's DualOptiboot that I'm using, compiled for 8Mhz (internal RC oscillator).
                                          doblanch
                                          @hek Hello, I have a friend who is working with 3D modeling. i can study it. I do not guaranty for the moment, as it doesn't rely on me directly. however I can do the best, and try to move forward.
                                          If I understand correctly, we need the place for the sensor+antenna+AA battery...
                                          On the PCB, is there some hole to place some screws ?
                                          How should we close the case ? by putting some screw or just putting a cover ? make sense ?
                                          12.5k
