  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 513.8k Views 73 Watching
  • 5546dug5 5546dug
    @tekka I am still a bit confused after rereading this thread.
    I have a humidity sensor plugged by usb and using config and debug see this sensor.
    Question is for the full gui do I need to unplug serial usb from gw and plug it into computer and start your program?
    If this is correct, then it will be temporarily disconnected from vera3 controller while I study and learn to understand what is being presented to me, when I again config and debug.
    After reviewing then reconfigure gw back to vera?
    tekkaT
    tekkaT
    tekka
    @5546dug MYSController connects directly to the gw to interact with the nodes.
    • FrancoisF Francois
      @tekka I update my bootloader to MYSbootloader and the fuses as per the doc but now when I try to program the Arduino mini pro I get this error can you help?
      upload-42f4e020-3b06-4acb-90b2-87beaeebdcac
      tekkaT
      tekkaT
      tekka
      That's correct: with the MYSBootloader you can upload the firmware OTA only - use MYSController to upload new fw
      • 5546dug5
        5546dug5
        5546dug
        thank you @tekka , will try it.
        • pit007P
          pit007P
          pit007
          @tekka A further small bug or misunerstanding by us - the unix time:
          API:
          I_TIME 1 Sensors can request the current time from the Controller using this message. The time will be reported as the seconds since 1970 = unix time ?
          The MYSController send the local time, but not the unix time (the unix time is the same all over te world)
          • 5546dug5
            5546dug5
            5546dug
            @tekka what does the dc =1 mean in this example?
            I understand the s c t pt and l but not dScreenshot (40).png c
            is the humidity sensor ok?
            pro mini
            serial gw nano to win 8.1 via usb interface
            ver 1.4
            lib 1.4
            humidity sketch mysensors
            readings seem accurate
            also have temp read 30 sec and hum read when changes only
            is all well or issues?
            thanks
            tekkaT 2 Replies Last reply
            • 5546dug5 5546dug
              pro mini
              ver 1.4
              lib 1.4
              thanks
              tekkaT
              tekkaT
              tekka
              wrote on last edited by tekka
              #94
              @5546dug dc=1 indicates that the message is truncated (i.e. you lack the first part of the telegram, see below). Please make sure, that you are running the most recent version of the library, i.e. 1.4.1.
              Your messages lack the bytes in bold:
              3/25/2015 23:24:29 RECV: **5;0;1;0;1;**send: 5-5-0-0...etc
              • J
                J
                JeJ
                You seem to have a sensor connected to your MYSController and not a gateway.
                Maybe wrong serialport?
                /J
                • 5546dug5 5546dug
                  pro mini
                  ver 1.4
                  lib 1.4
                  thanks
                  tekkaT
                  tekkaT
                  tekka
                  @JeJ indeed, you are right. thanks!
                    Mouridsen
                    Hi guys! I'm still a newbie but i'm very interested in this tool and I'm quite confused how to install it. I'm only interested in see the communication to start with.
                    Is there an installation instruction somewhere?
                    I have tried to install it but I can't see any serial ports in the config window. Here is what I have done:
                    1. Downloaded the package and run the program (I'm using Wine on a Mac)
                    2. Uploaded a the standard SerialGateway sketch from Mysensor to a Nano board and have it connected to the computer. I can see from the serial monitor in the Arduino IDE that it sees the communication fine from the various sensors.
                      I haven't done anything to the Gateway that's connected to the Vera. Is it that one I should use and connect to the computer???
                    Sorry for the newbie questions..
                    • M Mouridsen
                      Mouridsen
                      Well I found an old Windows laptop and it worked on that, so I guess it's the Mac computer :disappointed_relieved:
                      Yesterday I tried to make a Repeater with the standard sketch as instructed. Now I can see that it says: Undefined firmware/type. What is the reason for that???
                      30-03-2015 15:03:38 NODE: New node discovered, node id=34
                      30-03-2015 15:03:38 CHILD: New child discovered, node id=34, child id=internal
                      30-03-2015 15:03:38 DEBUG: Update child id=255, type=ARDUINO_RELAY
                      30-03-2015 15:03:38 RECV: 0;0;3;0;9;read: 34-34-0 s=255,c=3,t=6,pt=1,l=1:0
                      30-03-2015 15:03:38 RECV: 34;255;3;0;6;0
                      30-03-2015 15:03:38 SEND: 34;255;3;0;6;M
                      30-03-2015 15:03:38 RECV: 0;0;3;0;9;send: 0-0-34-34 s=255,c=3,t=6,pt=0,l=1,st=ok:M
                      30-03-2015 15:03:40 RECV: 0;0;3;0;9;read: 34-34-0 s=255,c=3,t=11,pt=0,l=13:Repeater Node
                      30-03-2015 15:03:40 RECV: 34;255;3;0;11;Repeater Node
                      30-03-2015 15:03:40 DEBUG: Undefined firmware/type for node=34
                      30-03-2015 15:03:40 RECV: 0;0;3;0;9;read: 34-34-0 s=255,c=3,t=12,pt=0,l=3:1.0
                      30-03-2015 15:03:40 RECV: 34;255;3;0;12;1.0
                      I think it works because when I disconnect it stops sending messages to MYSController so all communication to this is done via the repeater.
                      Is it something to worry about???
                      tekkaT 1 Reply Last reply
                      • M Mouridsen
                        tekkaT
                        tekkaT
                        tekka
                        @Mouridsen MYSController should work using Wine on Mac - for the serial communication, just type e.g. /dev/ttyUSB0 or whatever your GW is assigned to in the serial edit field. The "undefined firmware/type" message appears, if you use the standard arduino bootloader (e.g. optiboot). For OTA functionality, you can use MYSBootloader which will also transmit the firmware type/version to MYSController.
                        • tekkaT tekka
                          Mouridsen
                          @tekka Thanks, it works perfect. That was a quite easy fix :)
                          • tekkaT
                            tekkaT
                            tekka
                            #101
                            MYSController Version 0.1.2.278 released
                            New features:
                            • Support MYSBootloader 2.0 / SHA (signing bootloader) ==> will be released in the nearest future
                            • Support 1.5 framework (dev branch)
                            • Parse MySensors log/debug messages
                            • Div. options
                            Changelog:
                            • Moved send message dialog to main window
                            • Handler adjustments
                            • Bugfix FW upload in GW debug mode
                            • Bugfix message logging
                            Update via update button in MYSController or download here.
                            • D
                              derry
                              Brilliant work! Ran perfectly under Wine on Fedora linux by using /dev/ttyUSB0 for serial port [after first checking my gateway was connected to that port]. Solved a problem I was having with a sensor getting assigned a weird node ID. Saved me loads of time tracking down the problem, many thanks for sharing this tool, much appreciated!
                              • R
                                R
                                rickmontana83
                                This is awesome!
                                Any plans to provide source or a back-end API that could be used to connect this up to an HA controller? That way you could control everything downstream in the MySensors cloud from this app, and everything upstream (the HA controller and the cloud) could interface with a much richer (and presumably more robust) infrastructure rather than yet again figuring out how to parse the bits coming off of the serial port...
                                ch3b7C tekkaT 2 Replies Last reply
                                • R rickmontana83
                                  This is awesome!
                                  ch3b7C
                                  ch3b7C
                                  ch3b7
                                  @rickmontana83 parse the data from the serial port is easy, im put in other post in this forum with a part of my code in vb.net
                                  • R rickmontana83
                                    This is awesome!
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @rickmontana83 Serial API is described here.
                                    • FrancoisF
                                      FrancoisF
                                      Francois
                                      wrote on last edited by Francois
                                      #106
                                      @tekka once you flash the Arduino with the MYSBootloader is the only why that now you can programme the Arduino is though the MYSController software?
                                        tekkaT
                                        tekkaT
                                        tekka
                                        #107
                                        @Francois AFAIK, MYSController and NodeJsController (see framework, link here) are the only controllers that provide OTA updates via bootloader. Both controllers use the OTA protocol described here. However, MYSBootloader 2.0 will support updates OTA and via IDE.
                                        • FrancoisF
                                          FrancoisF
                                          Francois
                                          @tekka the reason I asked I has a problem where I had 2 node with the same node ID and a could not do a OTA via MYSController. As i keep the same ID. I clear the EEPROM and still l it did not work. So the only why I could get the node working was to reflash the boot loader.
