  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 514.5k Views 73 Watching
  • pit007P
    pit007P
    pit007
    The included TimeReporter (I don't know where to find the sketch) has a small problem.
    In the minutes and the seconds the leading zero is missing - i.e. 11h 9 min 5 sevc is shown as: 11:9:5 instead of 11:09:05.
    -Pit
    • D
      diamantmatch
      i tried using the OTA FW update by following your guide a few posts up and i must say i like it a lot!
      i just cant figure out how to upload FW from the software. every time it starts uploading FW by responding on FW requests my gateway seems to freeze, i use a usb ttl converter and arduino pro mini with radio as gw. i also uploaded the log. by the time the server responds to the FW req i have assigned FW to the node. then the GW just stops recieving and transmitting for no apearent reason so there is no communication back and forth, then when i reset the GW ( by pushing the reset button on the GW the comm is back up.. when the GW is frosen the led (pin 13, clock) is also completely off.. and yes, i also tried a radio with capacitor.
      MySensors_20150318-202006.log
      tekkaT 1 Reply Last reply
      • D diamantmatch
        tekkaT
        tekkaT
        tekka
        wrote on last edited by tekka
        #84
        @diamantmatch The link to the log file is broken (currently, the forum experiences some issues with uploading files / pictures. Can you share it on e.g. dropbox and post the link?).
        I've come across similar issues with debug mode activated on the GW sketch - try reflashing the GW with debug mode disabled and give it another shot.
          wrote on last edited by hek
          #85
          @diamantmatch
          I have cherry-picked a couple of patches that should fix file-uploads now. Please try to re-upload your log file. Downloading your logfile works again.
          • D
            diamantmatch
            @tekka
            Awesome! everything now works like a charm! many thanks for your help!
            • 5546dug5
              5546dug5
              5546dug
              @tekka I am still a bit confused after rereading this thread.
              I have a humidity sensor plugged by usb and using config and debug see this sensor.
              Question is for the full gui do I need to unplug serial usb from gw and plug it into computer and start your program?
              If this is correct, then it will be temporarily disconnected from vera3 controller while I study and learn to understand what is being presented to me, when I again config and debug.
              After reviewing then reconfigure gw back to vera?
              • FrancoisF
                FrancoisF
                Francois
                wrote on last edited by Francois
                #88
                @tekka I update my bootloader to MYSbootloader and the fuses as per the doc but now when I try to program the Arduino mini pro I get this error can you help?
                upload-42f4e020-3b06-4acb-90b2-87beaeebdcac
                • 5546dug5 5546dug
                  tekkaT
                  tekkaT
                  tekka
                  @5546dug MYSController connects directly to the gw to interact with the nodes.
                  • FrancoisF Francois
                    tekkaT
                    tekkaT
                    tekka
                    That's correct: with the MYSBootloader you can upload the firmware OTA only - use MYSController to upload new fw
                    • 5546dug5
                      5546dug5
                      5546dug
                      thank you @tekka , will try it.
                      • pit007P
                        pit007P
                        pit007
                        @tekka A further small bug or misunerstanding by us - the unix time:
                        API:
                        I_TIME 1 Sensors can request the current time from the Controller using this message. The time will be reported as the seconds since 1970 = unix time ?
                        The MYSController send the local time, but not the unix time (the unix time is the same all over te world)
                        • 5546dug5
                          5546dug5
                          5546dug
                          @tekka what does the dc =1 mean in this example?
                          I understand the s c t pt and l but not dScreenshot (40).png c
                          is the humidity sensor ok?
                          pro mini
                          serial gw nano to win 8.1 via usb interface
                          ver 1.4
                          lib 1.4
                          humidity sketch mysensors
                          readings seem accurate
                          also have temp read 30 sec and hum read when changes only
                          is all well or issues?
                          thanks
                          tekkaT 2 Replies Last reply
                          • 5546dug5 5546dug
                            pro mini
                            ver 1.4
                            lib 1.4
                            thanks
                            tekkaT
                            tekkaT
                            tekka
                            #94
                            @5546dug dc=1 indicates that the message is truncated (i.e. you lack the first part of the telegram, see below). Please make sure, that you are running the most recent version of the library, i.e. 1.4.1.
                            Your messages lack the bytes in bold:
                            3/25/2015 23:24:29 RECV: **5;0;1;0;1;**send: 5-5-0-0...etc
                            • J
                              J
                              JeJ
                              You seem to have a sensor connected to your MYSController and not a gateway.
                              Maybe wrong serialport?
                              /J
                              • 5546dug5 5546dug
                                pro mini
                                ver 1.4
                                lib 1.4
                                thanks
                                tekkaT
                                tekkaT
                                tekka
                                @JeJ indeed, you are right. thanks!
                                  Mouridsen
                                  Hi guys! I'm still a newbie but i'm very interested in this tool and I'm quite confused how to install it. I'm only interested in see the communication to start with.
                                  Is there an installation instruction somewhere?
                                  I have tried to install it but I can't see any serial ports in the config window. Here is what I have done:
                                  1. Downloaded the package and run the program (I'm using Wine on a Mac)
                                  2. Uploaded a the standard SerialGateway sketch from Mysensor to a Nano board and have it connected to the computer. I can see from the serial monitor in the Arduino IDE that it sees the communication fine from the various sensors.
                                    I haven't done anything to the Gateway that's connected to the Vera. Is it that one I should use and connect to the computer???
                                  Sorry for the newbie questions..
                                  • M Mouridsen
                                    Mouridsen
                                    Well I found an old Windows laptop and it worked on that, so I guess it's the Mac computer :disappointed_relieved:
                                    Yesterday I tried to make a Repeater with the standard sketch as instructed. Now I can see that it says: Undefined firmware/type. What is the reason for that???
                                    30-03-2015 15:03:38 NODE: New node discovered, node id=34
                                    30-03-2015 15:03:38 CHILD: New child discovered, node id=34, child id=internal
                                    30-03-2015 15:03:38 DEBUG: Update child id=255, type=ARDUINO_RELAY
                                    30-03-2015 15:03:38 RECV: 0;0;3;0;9;read: 34-34-0 s=255,c=3,t=6,pt=1,l=1:0
                                    30-03-2015 15:03:38 RECV: 34;255;3;0;6;0
                                    30-03-2015 15:03:38 SEND: 34;255;3;0;6;M
                                    30-03-2015 15:03:38 RECV: 0;0;3;0;9;send: 0-0-34-34 s=255,c=3,t=6,pt=0,l=1,st=ok:M
                                    30-03-2015 15:03:40 RECV: 0;0;3;0;9;read: 34-34-0 s=255,c=3,t=11,pt=0,l=13:Repeater Node
                                    30-03-2015 15:03:40 RECV: 34;255;3;0;11;Repeater Node
                                    30-03-2015 15:03:40 DEBUG: Undefined firmware/type for node=34
                                    30-03-2015 15:03:40 RECV: 0;0;3;0;9;read: 34-34-0 s=255,c=3,t=12,pt=0,l=3:1.0
                                    30-03-2015 15:03:40 RECV: 34;255;3;0;12;1.0
                                    I think it works because when I disconnect it stops sending messages to MYSController so all communication to this is done via the repeater.
                                    Is it something to worry about???
                                    • M Mouridsen
                                      tekkaT
                                      tekkaT
                                      tekka
                                      @Mouridsen MYSController should work using Wine on Mac - for the serial communication, just type e.g. /dev/ttyUSB0 or whatever your GW is assigned to in the serial edit field. The "undefined firmware/type" message appears, if you use the standard arduino bootloader (e.g. optiboot). For OTA functionality, you can use MYSBootloader which will also transmit the firmware type/version to MYSController.
                                      • tekkaT tekka
                                        Mouridsen
                                        @tekka Thanks, it works perfect. That was a quite easy fix :)
                                        • tekkaT
                                          tekkaT
                                          tekka
                                          #101
                                          MYSController Version 0.1.2.278 released
                                          New features:
                                          • Support MYSBootloader 2.0 / SHA (signing bootloader) ==> will be released in the nearest future
                                          • Support 1.5 framework (dev branch)
                                          • Parse MySensors log/debug messages
                                          • Div. options
                                          Changelog:
                                          • Moved send message dialog to main window
                                          • Handler adjustments
                                          • Bugfix FW upload in GW debug mode
                                          • Bugfix message logging
                                          Update via update button in MYSController or download here.
