  3. Node freezing up
Node freezing up
29 Posts 9 Posters 20.0k Views 3 Watching
  • MagiskeM Magiske
    What are you powering it with ?? 5v usb or battery ??
    ferpandoF
    ferpandoF
    ferpando
    @Magiske
    12V power supply
    • AWIA AWI
      It happened frequently to me when using relays (inductive load). Spikes on the powerline can easily freeze the radio.
      ferpandoF
      ferpandoF
      ferpando
      @AWI
      Relays are isolated using opto-couplers so it should`t be a problem.
      The relay board is this or very similar:
      http://www.ebay.com/itm/Durable-New-16-Channel-12V-Relay-Module-Interface-Board-For-Arduino-PIC-ARM-DSP-/331477749403
      Power goes to the relay board and then it powers the arduino
      AWIA 1 Reply Last reply
      • MagiskeM
        MagiskeM
        Magiske
        And you have added a cap for the radio ?
        Try to add a blink, just to see if the board crashed/freezes. If not it's properly the radio.
        ferpandoF 1 Reply Last reply
        • GuyPG GuyP
          Can you give more details of what your node is? what hardware have you used? do you have a circuit diagram?
          ferpandoF
          ferpandoF
          ferpando
          @GuyP
          sorry no diagram, but the node is basically an arduino with radio connected to this relay board
          • MagiskeM Magiske
            ferpandoF
            ferpandoF
            ferpando
            @Magiske
            Yes it has a cap on the radio.
            What do you mean by add a blink?
            • MagiskeM
              MagiskeM
              Magiske
              wrote on last edited by Magiske
              Just add blink code or add an ekstra led to see if the code is running..
              • MagiskeM Magiske
                ferpandoF
                ferpandoF
                ferpando
                @Magiske
                Ok got it.
                I have a led on board, so I'll make it blink to see if it is still alive
                • ferpandoF ferpando
                  @AWI
                  AWIA
                  AWIA
                  AWI
                  @ferpando The optocoupler takes care of the load on the Arduino outputs. What I tried to say is that the inductive load of the relays on the power lines can be substantiall. I there is any sharing of power (same supply) of the relay and the radio it is very hard to avoid lock-ups.
                  below an excerpt from Jeelabs
                  upload-17c0f15c-c9de-4b00-9e21-80017497b551
                  • AWIA AWI
                    ferpandoF
                    ferpandoF
                    ferpando
                    wrote on last edited by ferpando
                    @AWI
                    I don't have an oscilloscope to test this.
                    I'll try to power both devices separately, but at least they always have a common ground. Could this also affect the radio?
                    Adding some capacitors could improve things?
                    • AWIA
                      AWIA
                      AWI
                      @ferpando A common ground is ok (and necessary).. A capacitor can improve things. Many times it is trial & error. What worked for me is having a seperate regulator and decoupling capacitor of 470uF for the feed to the relay. It is hard to read the schematic of the relay board on e-bay but measures like a diode over the relay-coil need to be in (and probably are). Switching inductive loads with the relay can also introduce EM problems.
                      It's science... using Solid State relays is a long term reliable (short term expensive) alternative. ... good luck, there may be experts around on the forum.
                      • AWIA AWI
                        ferpandoF
                        ferpandoF
                        ferpando
                        @AWI
                        Looks like it has a regulator and a 1000uF capacitor plus a smaller one.
                        I'll try to add a second regulator with capacitor just for the arduino and see what happens
                        AWIA vladimirV 2 Replies Last reply
                          @AWI
                          AWIA
                          AWIA
                          AWI
                          @ferpando That certainly looks like a power supply. Please keep me informed.
                          • T
                            TimO
                            I have exactly the same Problem. But I'm not sure the relays are the problem.
                            I've added a keep alive message to know when it stops working and implemented a watchdog.
                            ferpandoF AWIA 2 Replies Last reply
                            • T TimO
                              ferpandoF
                              ferpandoF
                              ferpando
                              @TimO
                              Could you elaborate a bit more about the watchdog?
                              MagiskeM 1 Reply Last reply
                                @TimO
                                MagiskeM
                                MagiskeM
                                Magiske
                                #21
                                @ferpando You can enable a watchdog timer on your Arduino. If your code hangs your Arduino, it should reset/reboot it. But not sure that would reset the radio.
                                Found good description -> http://www.megunolink.com/how-to-detect-lockups-using-the-arduino-watchdog/
                                  @AWI
                                  vladimirV
                                  vladimirV
                                  vladimir
                                  @ferpando, @Magiske, You solved this problem? I realized what the problem, but unfortunately, I do not understand how to solve it. Can you explain exactly how to change node?
                                  • T TimO
                                    AWIA
                                    AWIA
                                    AWI
                                    That sounds like you keep the motor running and accept that the car crashes every once in a while ;) Better to find the root cause of the "freeze" and eliminate it.
                                    • AWIA AWI
                                      TimO
                                      @AWI You're right of course! But ... if the Arduino is the root of all evil in this case, it will reset once in a while but still work. If it still freezes it could be the radio that crashes. So I'm still trying to solve the problem. :-)
                                      All parts use the same 5V source (which I already switched) but the radio of course is connected through a regulator. If the watchdog solves the problem (so the radio is not the problem) I will add a bigger capacitor which I already ordered.
                                      • ferpandoF
                                        ferpandoF
                                        ferpando
                                        I made this regulator based on this schematic to power the node independently, to see if it solves the problem.
                                        • RJ_MakeR
                                          RJ_MakeR
                                          RJ_Make
                                          Does this node by any chance have a temp. sensor also?
                                          My nightmare.. http://forum.mysensors.org/topic/338/reliability/3
                                          RJ_Make
