  3. Raspberry GPIO NRF24l01+ make error
21 Posts 8 Posters 13.8k Views 2 Watching
  • Vladut GrecuV
    Vladut GrecuV
    Vladut Grecu
    You have to setup your arduino with a static node id. Something like
    gw.begin(incomingMessage, 10, false);
    or
    gw.begin(null, 10, false);
    or
    gw.begin(null, 10);
    10 is the node id.
    From my knowledge the raspi lib for nrf does not support the automatic node id. (or is just pimatic)
    Anyways, I don't use sensors. I just command the Arduino from raspi and my way of verifying the connection is the serial monitor linked to the arduino node. If it's found by the raspi and if he found the raspi the end of each line will be
    st=ok;
    If you get
    st=fail;
    You either did not set up the right node id or you need a capacitor on the nrf.
    Before you test the lib you can test the link with a serial arduino gateway and see what is going on.
    • sj44kS
      sj44kS
      sj44k
      wrote on last edited by sj44k
      Ok Radio was allready connected correctly, and I have the 4u7 capicitors installed.
      So this is what I understood from your tips am I correct ?
       git clone https://github.com/mysensors/Raspberry
      cd Rasberry
      make
      cd librf24-bcm
      make
      make install
      cd ..
      ./PiGatewaySerial
      Starting PiGatewaySerial...
      Protocol version - 1.4
      Created PTY '/dev/pts/1'
      Gateway tty: /dev/ttyMySensorsGateway
      ================ SPI Configuration ================
      CSN Pin          = CE0 (PI Hardware Driven)
      CE Pin           = Custom GPIO25
      Clock Speed      = 8 Mhz
      ================ NRF Configuration ================
      STATUS           = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
      RX_ADDR_P0-1     = 0xe7e7e7e7e7 0xc2c2c2c2c2
      RX_ADDR_P2-5     = 0xff 0xc4 0xc5 0xc6
      TX_ADDR          = 0xe7e7e7e7e7
      RX_PW_P0-6       = 0x00 0x00 0x20 0x00 0x00 0x00
      EN_AA            = 0x3b
      EN_RXADDR        = 0x07
      RF_CH            = 0x4c
      RF_SETUP         = 0x23
      CONFIG           = 0x0e
      DYNPD/FEATURE    = 0x3f 0x06
      Data Rate        = 250KBPS
      Model            = nRF24L01+
      CRC Length       = 16 bits
      PA Power         = PA_LOW
      So now I want to receive my Sensor info from my Arduino on my Raspbery.
      I am using this build with a small addition on it as I am using an Arduino Mega so the pins are different :
      http://www.mysensors.org/build/temp
      I Changed :
      into
      MySensor gw(48,49)
      No I will do the figuring out about the node ID as I the tip about the auto ID does not work makes sense, the sensor now uses 0 and if I am correct that is the id of the gateway.
      By the way to even get that part done I needed to clear the EEProm of the Arduino (found it somewhere on some forum :) )
      I got the node secret also done now
      I needed to set :+1:
      `gw.begin(NULL,10,false,11);
      But still no communication / output on the Raspberry
      Output on de Arduino is :
      sensor started, id 10
      send: 10-10-11-0 s=255,c=0,t=17,pt=0,l=5,st=fail:1.4.1
      send: 10-10-11-0 s=255,c=3,t=6,pt=1,l=1,st=fail:11
      send: 10-10-11-0 s=255,c=3,t=11,pt=0,l=18,st=fail:Temperature Sensor
      send: 10-10-11-0 s=255,c=3,t=12,pt=0,l=3,st=fail:1.0
      send: 10-10-11-0 s=0,c=0,t=6,pt=0,l=5,st=fail:1.4.1
      send: 10-10-11-0 s=0,c=1,t=0,pt=7,l=5,st=fail:68.7```
      • Vladut GrecuV
        Vladut GrecuV
        Vladut Grecu
        wrote on last edited by Vladut Grecu
        @sj44k
        Tell me where did you connected the CE Pin on rPi..
        Do you have another Arduino so you can burn a serial gateway into it? So we can be sure that your Mega is sending and receiving properly?
        From your Arduino output he clearly does not link with the nrf on the Raspberry.
        • sj44kS
          sj44kS
          sj44k
          Checked the wires 5 times .. all looks well. CE is on pin 15
          Arduino should also be ok, I get error messages (Check wires) when it's connected differently
          (Heres the Arduino mega pinout as I used it
          http://forum.mysensors.org/topic/249/arduino-mega-sensor-shield-2/2 )
          I have an Uno ordered but at this moment I am stuck to 1 arduino
          I do have an extra Pi which I could use ..
          By the way, where would I receive the information on my pi in this example (in case it would work)
          in the screen where I started the
          ./PiGatewaySerial
          Or in a cat /dev/pts/1 ?
          • Vladut GrecuV
            Vladut GrecuV
            Vladut Grecu
            Move the pin on 22. The actual 22 pin not gpio22. Full restart the pi.
            I think you can cat the /dev/ttyMySensorsGateway. In the way I use it(with pimatic) all the commands are logged.
            • sj44kS
              sj44kS
              sj44k
              Tried that too, not working. But I now see why you asked that my output when starting PiGatewaySerial shows :
              So that needs to be harware pin 22
              This picture helped a lot and makes now that I am 100% sure my Rpi is hooked up correctly.
              :s: must be overseeing something realy simple / stupid .. :/s:
              Guess it must be the Arduino Mega causing the issue, back to my drawingboard .. will keep you posted
              [edit]
              Just found an interesting SPI reference picture for my Arduino Mega
              My Pinout seems to be ok on the SPI side, just need to check CE / SE in regard to the scketch/libraries I am using.
              Radio 1 GND Paars Arduino GND
              Radio 2 3v3 Blauw Arduino 3,3v
              Radio 3 CE Groen Arduino 48
              Radio 4 CS Geel Arduino 49
              Radio 5 SCK Oranje Arduino 52
              Radio 6 MOSI Rood Arduino 51
              Radio 7 MISO Bruin Arduino 50
              • sj44kS
                sj44kS
                sj44k
                YEAH !
                It works !! thanks for pointing me in the right direction !
                Arduino needed the right scketch uploade (I messed so much with it I needed to go back which I just did)
                As a reference for all who are trying to get this to work.
                Use this pinout for the RPI B+
                Radio 1 grijs GND Rpi 25
                Radio 2 paars 3v3 Rpi 17
                Radio 3 blauw CE Rpi 22
                Radio 4 groen CS Rpi 24
                Radio 5 Geel SCK Rpi 23
                Radio 6 oranje MOSI Rpi 19
                Radio 7 Rood MISO Rpi 21
                Arduino Mega
                I used the Libs mentioned in the post above by Vladut Grecu :
                I used this Temperature sketch :
                Before I did got the Temp sketch operational I needed to clear my EEprom :
                http://arduino.cc/en/Tutorial/EEPROMClear
                 * EEPROM Clear
                 * Sets all of the bytes of the EEPROM to 0.
                 * This example code is in the public domain.
                #include <EEPROM.h>
                  // write a 0 to all 512 bytes of the EEPROM
                  for (int i = 0; i < 512; i++)
                    EEPROM.write(i, 0);
                  // turn the LED on when we're done
                  digitalWrite(13, HIGH);
                Than we need to edit the sketch a bit due to the fact that the Rpi gateway DOES NOT hand out the Node ID's automaticly, and the Sketch is not Arduino Mega compatible so :
                Set the Node ID manualy add
                gw.begin(NULL,10,false);
                Make sure the sketch is compatible with the Arduino MEGA pins (as published abover here)
                Change Line 12 in the sketch :
                into
                MySensor gw(48,49)
                Than compile and hook everything up and upload the compiled sketch and start the Rpi (SPI enabled) and start
                ./PiGatewaySerial
                Output should show on your Pi when you
                Cat /dev/ttyMySensorsGateway
                Big Thank you to @Vladut-Grecu !
                  wrote on last edited by hek
                  Just received a great pull request for the Rapsberry created by @Holger-Meyers .
                  • SweebeeS
                    SweebeeS
                    Sweebee
                    I had it finally working on my Pi2, but its very unstable. sometimes weird values, crashes and fails.
                    switched to a usb serial arduino and that works great.
                    • A
                      Andreas Maurer
                      The original code on github is a bit buggy. Thats right. But the actual code after Holger has reworked it is running well.
                      I am using it for nearly a month now. Nothing has crashed after Holger has looked after the reason why.
                      Currently I am happy with the stability.
                      Sander TeunissenS 1 Reply Last reply
                      • A Andreas Maurer
                        Sander TeunissenS
                        Sander TeunissenS
                        Sander Teunissen
                        @Andreas-Maurer Could you tell me which controller you are using for your setup ?
                        Thanks !
                        • A
                          Andreas Maurer
                          I am using fhem on the same PI. connected over the pseudo serial port.
                          • B
                            B
                            blksun813
                            What is the CPU usage of PiGatewaySerial when you look at top? Mine is using 97%.
                            • A
                              Andreas Maurer
                              It isn´t on the list :)
                              • B
                                B
                                blksun813
                                Thanks.. Looked again today and it has calmed down.. Maybe it's just at start-up before there are any messages received or maybe something reading the Serial Port.
