  3. Controlling Blinds.com RF Dooya Motors with Arduino and Vera
90 Posts 29 Posters 112.5k Views 24 Watching
  • petewillP petewill
    @C.r.a.z.y. I am doing my best to understand but I think I'm still missing something. Basically what you want to do is to reproduce the pattern you recorded in Audacity. I did this somewhat crudely with blindAction function (someone smarter than me could code it much better but it works). You will need to modify (and probably rename) this function to meet your needs. In this function I call other functions (fourBits and eightBits) to actually send the RF signal out. I would start with these methods to get your timings right. You can then record what you send out in Audacity and compare. After you have got this working with one command you can work on interfacing it with Vera. I hope that helps a little.
    C
    C
    C.r.a.z.y.
    @petewill Thank you i know you are very helpful. I tried to copy my remote to an universal remote learner(which has no name chipset) but it didnt copy. It is hard to understand and solve for a newbie.
    I simply tried to send 10101010codes with this sketch https://code.google.com/p/rc-switch/wiki/HowTo_Send?tm=6 and didnt work.
    Something interesting i found while tranmitting,
    If i remove the delay () than signal is always sent. I made a jammer! :) Any of my 433 remotes didnt work!
    I want to learn if any universal remote learner with EV1527 Chipset works with RCSwitch?
    My plan is to copy some remote codes to EV1527 universal remote and read the code from serial with RCSwitch-rfSniffer.
    Now i will try IR SENDER-RECEIVER http://www.mysensors.org/build/ir maybe i can get new ideas for 433mhz things..
    • petewillP
      petewillP
      petewill
      @C.r.a.z.y. Yeah, I couldn't get the automatic "sniffers" to work for me either. Hopefully you're able to get it working. Remember, just focus on sending the 1's and 0's pattern. Start your code with that then expand when you get that part working. One thing that may help is to record what you're sending in Audacity again. That way you can compare the waveforms and see what needs to be modified with the code.
      C 1 Reply Last reply
        C
        C
        C.r.a.z.y.
        @petewill Comparing is great idea thanks i will try this!
        petewillP 1 Reply Last reply
        • C C.r.a.z.y.
          petewillP
          petewillP
          petewill
          @C.r.a.z.y. You have probably already figured out a solution but I finally was able to make a video of my MySensors "Smart Plug". Here is the link: http://forum.mysensors.org/topic/775/8-lamp-outlet-smart-plug-module
          Just another way of doing what you're trying to do, but this way you will get the status reported instead of just hoping the outlet turned on.
          • T
            tjay4x4
            I'm trying to do the same but my RF code is different. The number of bits is the same. I have first 20 bits witch I can set for remote 1;2;3 but the last 20 bits depands on command.
            I delete remote1Bits4, and channel (child_Id) and add eightBits action1;2;3 for up\down\stop But it dont work.
            Could you check this code changes, please?
            Remote 1
            1100 01111100 01001000 00110000 0011 01011110 up
            1100 01111100 01001000 10100000 0011 01010111 stop
            1100 01111100 01001000 10000000 0011 01010100 down
            Remote2
            0100 01110010 01001000 00110000 0011 01011110 up
            0100 01110010 01001000 10100000 0011 01010111 stop
            0100 01110010 01001000 10000000 0011 01010100 down
            Remote3
            1110 00100100 01001000 00110000 0011 11101000 up
            1110 00100100 01001000 10100000 0011 11100001 stop
            1110 00100100 01001000 10000000 0011 11100011 down
            //  This program is free software; you can redistribute it and/or
            //  modify it under the terms of the GNU General Public License
            //  version 2 as published by the Free Software Foundation.
            //  DESCRIPTION
            //  This sketch provides a way to control blinds from www.blinds.com using a 433MHz RF
            //  signal. The motors in the blinds are Dooya DV24CE motors.
            //  Watch a video of everything working together here: https://www.youtube.com/watch?v=EorIqw-9eJw
            //  The sketch is based on Henrik Ekblad's <henrik.ekblad@gmail.com> MySensors project
            //  (http://www.mysensors.org).  Credit also goes to Ray (http://rayshobby.net/?p=3381)
            //  for instruction on how to decode the RF signal from the remote as well as code for
            //  sending the RF signal.
            //  Developed by Pete B.
            //  REVISION HISTORY
            //  Version 1.0 - March 19, 2014 - Original Program
            //  Version 1.1 - April 17, 2014 - Added support for multiple remotes that are programmed from blinds.com
            //  Version 1.2 - May 16, 2014 - Added gw.send() to update Vera blinds up/down status
            //  Version 1.3 - Nov 21, 2014 - Upgraded code to work with MySensors v1.4
            //Include Vera related libraries
            #include <EEPROM.h>
            #include <RF24.h>
            //Define Constants
            #define SEND_DATA 3 //Data pin for RF Transmitter
            #define ZERO_HIGH 395 //Delay for the high part of a 0 in microseconds
            #define ZERO_LOW 687 //Delay for the low part of a 0 in microseconds
            #define ONE_HIGH 750 //Delay for the high part of a 1 in microseconds
            #define ONE_LOW 333//Delay for the low part of a 1 in microseconds
            //Vera related constants
            // Set NODE_ID to something unique in your sensor network (1-254)
            // or set to AUTO if you want gw to assign a NODE_ID for you.
            #define NODE_ID auto
            //List all your blinds here.  These will have to be added as child nodes in setup()
            //The numbers will be used to assign the different remotes in the remote() method
            //So, make a note of which blind uses which remote then add it to the if statement
            //in remote().  This is referred to as the blindNumber in remote().
            #define NUMBER_OF_BLINDS  3
            //Child Node Numbers
            //Family Room = Node 1, Remote 2, Channel 1
            //Kitchen = Node 2, Remote 2, Channel 2
            //Dining Room = Node 3, Remote 2, Channel 3
            //Kid's Room = Node 4, Remote 1, Channel 1
            //Kids's Room = Node 5, Remote 1, Channel 2
            //Guest Room = Node 6, Remote 1, Channel 3
            //Master Bedroom = Node 7, Remote 1, Channel 4
            //Master Closet = Node 8, Remote 1, Channel 5
            //Living Room = Node 9, Remote 2, Channel 4
            //These 28 standard bits appear at the beginning of each transmit sequence:
            //0111011100000101010111001011.  They are then followed by 12 other
            //bits depending on the command being sent to the blind.  These bits
            //distinguish between the different remotes.
            //Because I'm not good at Arduino coding I needed to use someone else's
            //code to send the bits.  They only used 8 bits and I couldn't get any
            //more to send.  Because if this I have broken up the 28 bits into 8 bit
            //sections.  Make sure to put 4 zeros at the beginning of the first
            //sequence.  They will be ignored later in the code.
            //I added support for multiple remotes so you don't have to reprogram
            //anything when you buy more blinds.  Just add the additional remote codes.
            //Remote One
            unsigned char remote1Bits1 = 0b00001100; //integer value of the 28 bit standard sequence referenced above. "0b" prefix is for ??
            unsigned char remote1Bits2 = 0b01111100;
            unsigned char remote1Bits3 = 0b01001000;
            //Remote Two
            unsigned char remote2Bits1 = 0b00000100; //integer value of the 28 bit standard sequence referenced above. "0b" prefix is for ??
            unsigned char remote2Bits2 = 0b01110010;
            unsigned char remote2Bits3 = 0b01001000;
            //Remote Three
            unsigned char remote3Bits1 = 0b00001110; //integer value of the 28 bit standard sequence referenced above. "0b" prefix is for ??
            unsigned char remote3Bits2 = 0b00100100;
            unsigned char remote3Bits3 = 0b01001000;
            //Remote codes will be put in standardBits with remote() method, depending on which remote is used
            unsigned char standardBits1 = 0b00000000;
            unsigned char standardBits2 = 0b00000000;
            unsigned char standardBits3 = 0b00000000;
            	gw.begin(incomingMessage, NODE_ID);
            	gw.sendSketchInfo("Blind Control", "1.3");
            	// Register sensors to gw (they will be created as child devices)
            	for (int i = 0; i < NUMBER_OF_BLINDS; i++)
            		gw.present(i + 1, S_COVER);
            void incomingMessage(const MyMessage &message)
            	Serial.print("Blind Channel: ");
            	Serial.print("Message Data: ");
            	Serial.println(message.data);
            	Serial.print("Message Type: ");
            	Serial.println(message.type);
            	int incomingBlindData = atoi(message.data);
            	if (message.type == V_STOP) //Stop
            		//unsigned char i;
            		for(uint8_t i = 0; i < 2; i++)
            			blindAction(message.sensor, 3); //blindAction(channel, action) action: 1=up, 2=down, 3=stop
            			delay(50);
            		Serial.println("STOP command");
            	else if(incomingBlindData == 100 || message.type == V_UP) //100 = Open/Up
            		//unsigned char i;
            			blindAction(message.sensor, 1);
            			delay(50);
            		Serial.println("UP command");
            		//gw.sendgw.send(message.sensor, V_DIMMER, 100); // Update Vera with status of blinds (up/down)
            		MyMessage blindMsg(message.sensor, V_DIMMER); //may need to assign message.sensor to a variable if this doesn't work
            		gw.send(blindMsg.set(100)); // Update Vera with status of blinds (up/down)
            	else if (incomingBlindData == 0 || message.type == V_DOWN) //0 = Closed/Down
            		//unsigned char i;
            			blindAction(message.sensor, 2);
            			delay(50);
            		Serial.println("DOWN command");
            		//gw.send(message.sensor, V_DIMMER, 0); // Update Vera with status of blinds (up/down)
            		gw.send(blindMsg.set(0)); // Update Vera with status of blinds (up/down)
            void remote(int remoteNum)
            	if (remoteNum == 1)  //Which remote will be used?
            		standardBits1 = remote1Bits1;  //Assign remote specific codes to standardBits variable used throughout the code
            		standardBits2 = remote1Bits2;
            		standardBits3 = remote1Bits3;
            	else if
            		standardBits1 = remote2Bits1;  //Assign remote specific codes to standardBits variable used throughout the code
            		standardBits2 = remote2Bits2;
            		standardBits3 = remote2Bits3;
            		standardBits1 = remote3Bits1;  //Assign remote specific codes to standardBits variable used throughout the code
            		standardBits2 = remote3Bits2;
            		standardBits3 = remote3Bits3;
            void fourBits(unsigned char bits)
            	unsigned char i;
            	int delayTime;
            	for(i = 0; i < 4; i++)
            		int highTime;
            		int lowTime;
            		delayTime = ((bits >> (3 - i)) & 1 ? 1 : 0);
            		if (delayTime == 1)
            			highTime = ONE_HIGH;
            			lowTime = ONE_LOW;
            			highTime = ZERO_HIGH;
            			lowTime = ZERO_LOW;
            		digitalWrite(SEND_DATA, HIGH);
            		delayMicroseconds(highTime);
            		digitalWrite(SEND_DATA, LOW);
            		delayMicroseconds(lowTime);
            void eightBits(unsigned char bits)
            	unsigned char k;
            	int delayTime;
            	for(k = 0; k < 8; k++)
            		int highTime;
            		int lowTime;
            		delayTime = ((bits >> (7 - k)) & 1 ? 1 : 0);
            		if (delayTime == 1)
            			lowTime = ONE_LOW;
            			lowTime = ZERO_LOW;
            //Separator Delay Method (this is repeated frequently)
            void separatorDelay(boolean upDown)
            	if(upDown == true)
            		delayMicroseconds(8020);
            	delayMicroseconds(4812);
            	delayMicroseconds(1479);
            void endDelay()
            	delayMicroseconds(51895); //Time of delay at the end of each sequence
            void blindAction(int a)
            	//c or channel: Order on the remote from left to right 1-16 available
            	//a or action: 1=up, 2=down, 3=stop
            	unsigned char action;  //8 action bits.  Only the first 4 bits are used in the up/down end sequence
            	unsigned char action2; //Last 4 bits from the up/down end sequence
            	unsigned char action3; //Last 4 bits from the up/down end sequence
            	if(a == 1)
            		action = 0b00110000; //code for up
            		action2 = 0b00110101;
            		action3 = 0b00001110;
            	else if (a == 2)
            		action = 0b00010001; //code for down
            		action2 = 0b00001110;
            	else (a == 3)
            	int i = 0;
            	//first 6 transmissions are the same for each blind action (up, down & stop)
            	while(i < 6)
            		separatorDelay(false); //false unless in the last part of the up or down commands
            		fourBits(standardBits1);
            		eightBits(standardBits2);
            		eightBits(standardBits3);
            		eightBits(action);
            		fourBits(action2);
            		eightBits(action3);
            		i++;
            	if (a == 3) //If a stop command is issued just send the end delay then exit the method
            		endDelay();
            	else //No stop issued so run through the last sequence
            		separatorDelay(false); //send true because we are in the up/down end sequence so there is an additional delay
            		eightBits(standardBits4);
            		eightBits(action);
            		fourBits(action2);
            		eightBits(action3);
            		int j = 0;
            		while(j < 3)
            			separatorDelay(true);
            			eightBits(action);
            			fourBits(action1);
            			eightBits(action2);
            			j++;
            		endDelay();
            DwaltD 1 Reply Last reply
            • petewillP
              petewillP
              petewill
              @tjay4x4 sorry for the delayed reply. Are you using blinds.com blinds or something else? This code is written specifically for my blinds.com (dooya motors). They have a sequence of very specific codes that I reproduced with the blindAction method. If your remotes have different sequences you will need to modify the code there. If you are using blinds.com blinds, maybe they changed the sequences? Also, do your up/down/stop commands look the same as mine?
                tjay4x4
                @petewill Thank you for reply!
                I'm using not blinds.com and this is really big problem. :) I'm not a progarmmer, and now I have two ways
                1 solder relays to remote buttons. In this case I destroy remotes. Or order another 3 remotes for donation.
                2 ask somebody to change this sketch for a fee. It's better, but who can?
                • T tjay4x4
                  petewillP
                  petewillP
                  petewill
                  @tjay4x4 I think you will find many helpful people on this forum. If you are willing to learn a little about coding there will be people to help. I have been helped many times with coding questions.
                  Here is what you will need to do. First, you need to decode your signals. It seems you have done this already which is great. Once you have your signals decoded correctly you can test to make sure they work correctly by sending them without using anything but an arduino. This is done with this code:
                  SEND_DATA is the digital pin on the Arduino (defined above in the code) and the highTime/lowTime is how long it will remain high and low. You could literally do that for each 1 and 0 that is in your signal to make sure you have it correct. Once you have that down you can begin breaking it down into methods and patterns like I have..
                  Hopefully that helps.
                  Pete
                  • T tjay4x4
                    Remote 1
                    Remote2
                    Remote3
                    //  DESCRIPTION
                    //  REVISION HISTORY
                    #include <EEPROM.h>
                    #include <RF24.h>
                    //Define Constants
                    //Remote One
                    //Remote Two
                    //Remote Three
                    		//unsigned char i;
                    			delay(50);
                    		//unsigned char i;
                    			delay(50);
                    		//unsigned char i;
                    			delay(50);
                    	else if
                    	unsigned char i;
                    	int delayTime;
                    		int highTime;
                    		int lowTime;
                    		if (delayTime == 1)
                    			lowTime = ONE_LOW;
                    			lowTime = ZERO_LOW;
                    	unsigned char k;
                    	int delayTime;
                    		int highTime;
                    		int lowTime;
                    		if (delayTime == 1)
                    			lowTime = ONE_LOW;
                    			lowTime = ZERO_LOW;
                    	if(upDown == true)
                    void endDelay()
                    	if(a == 1)
                    	else if (a == 2)
                    	else (a == 3)
                    	int i = 0;
                    	while(i < 6)
                    		eightBits(action);
                    		fourBits(action2);
                    		eightBits(action3);
                    		i++;
                    		endDelay();
                    		eightBits(action);
                    		fourBits(action2);
                    		eightBits(action3);
                    		int j = 0;
                    		while(j < 3)
                    			eightBits(action);
                    			fourBits(action1);
                    			eightBits(action2);
                    			j++;
                    		endDelay();
                    DwaltD
                    DwaltD
                    Dwalt
                    @tjay4x4 How did you determine what your codes were? Did you use a RF library or did you 'sniff' them directly?
                      Pete
                      tjay4x4
                      @petewill Thank you! Actually I dont trying my code just on arduino. You mean it could be different high and low time for 1 and 0 on my code. Well, then I went to check.
                      • DwaltD Dwalt
                        tjay4x4
                        I used Audacity. As written in the instructions. For each button sequentially rewriting the code. Comparing them with Blinds.com it became clear that the differences in the combinations of digits. If in the original, the first 28 are the same, I have to differ for each controller first 12 digits and last 12 digits. UP, DOWN, STOP bits are the same for all remotes. The question is how to write it to this code? But first I need to check High and Low time.
                        • T tjay4x4
                          petewillP
                          petewillP
                          petewill
                          wrote on last edited by petewill
                          #31
                          @tjay4x4
                          Based on this it looks like you have 5 sets of 8 digits:
                          Remote 1
                          Remote2
                          Remote3
                          Here is some sample code that will allow you to test your sequence of 1s and 0s. It will run once each time the arduino is powered on. I haven't tested it but it should work ok.
                          Put your delay values that you are figuring out in the _HIGH defines (at the top). The RF sender should be connected to pin 3 on the arduino. Also, make sure to change the standardBits variables to what you have figured out from Audacity.
                          //Define Variables
                          #define ZERO_HIGH 376 //Delay for the high part of a 0 in microseconds
                          #define ZERO_LOW 653 //Delay for the low part of a 0 in microseconds
                          #define ONE_HIGH 713 //Delay for the high part of a 1 in microseconds
                          #define ONE_LOW 317 //Delay for the low part of a 1 in microseconds
                          int startUp = 1;
                          unsigned char standardBits1 = 0b00000111; //integer value of the 28 bit standard sequence referenced above. "0b" prefix is for *******
                          unsigned char standardBits2 = 0b01110000;
                          unsigned char standardBits3 = 0b01010101;
                          unsigned char standardBits4 = 0b11001011;
                          unsigned char standardBits5 = 0b11001011;
                             Serial.begin(9600);
                            if(startUp ==1){
                            eightBits(standardBits1);
                            eightBits(standardBits5);
                            startUp = 0;
                          void eightBits(unsigned char bits){
                              unsigned char k;
                              int delayTime;
                              for(k=0;k<8;k++) {
                                int highTime;
                                int lowTime;
                                delayTime = ((bits>>(7-k)) & 1 ? 1 : 0);
                                if (delayTime == 1){
                                  lowTime = ONE_LOW;
                                else {
                                  lowTime = ZERO_LOW;
                          Also, when I was testing I recorded what was sent from my arduino (the above code) into Audacity so I could make sure my timings were correct.
                          • C
                            C
                            CalvinAndHobbes
                            This has been very useful, and I have been trying to use the same technique to see if I can control a Hunter Pacific fan that came with a Neoteric remote.
                            However, if anyone else is looking to sniff RF signals, you might find the discussions here very interesting:
                            http://www.princetronics.com/how-to-read-433-mhz-codes-w-arduino-433-mhz-receiver/
                            Basically, you can use a 433 MHz receiver to sniff the signal without having to use a sound card etc. Would have saved me a bunch of time (but I did have fun trying to figure it out).
                            However, I have now come unstuck as the signal from the remote I have appears to be encrypted in some way as the signal changes every time - each button press results in a different signal being sent. I will continue to see if I can figure it out, but I don't have too much hope.
                            Thanks again for a very interesting project, and taking the time to write it up.
                            Regards,
                            CalvinAndHobbes
                            • C CalvinAndHobbes
                              Regards,
                              CalvinAndHobbes
                              petewillP
                              petewillP
                              petewill
                              @CalvinAndHobbes Thanks for sharing! I had originally tried to use that library to decode my remotes but it did not work. That's why I had to use the sound card. I agree though, definitely try that option first! It would be much easier.
                              I didn't think Hunter fans communicated at 433MHz? I was trying to find a fan control last year that would allow me to integrate with MySensors but they all looked to be communicating at other frequencies (fans were down near 419MHz if memory serves correct). That's exciting that you were able to decode it though! What remote are you using?
                              • BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                Just a note that the Hunter remotes are relatively cheap and hackable if you just want to wire your arduino's outputs to the switches on the (cracked open) remote. you may even be able to fit a pro-miny and an RF radio into your existing remote and use it manually or via HA apps...
                                • C
                                  C
                                  CalvinAndHobbes
                                  @BulldogLowell I started out by opening the remote to see if I could find any useful information, and you are correct - they are very simple and should be very easy to wire up a pro-mini inside it. What I don't know is whether I can have 2 remotes on the same fan, as I don't think I will get away (by the rest of the family :-)) with hacking the one we have. It was also an interesting exercise to see if I could figure out what the remote was doing.
                                  @petewill I am using the Neoteric remote from Hunter Pacific. Unfortunately they don't have any controllers that you can integrate in to any home automation system. I am going to contact the manufacturer to see if they will help, but I doubt it.
                                  • petewillP
                                    petewillP
                                    petewill
                                    @BulldogLowell I may have to go that route. It will probably be easier and cheaper for me anyway! First I need to finish the rain gauge :)
                                    @CalvinAndHobbes Yes, that would be nice if they had some integration but doubtful. There is a z-wave controller from Leviton (Leviton VRF01-1LZ Vizia RF) but it's over $100 normally. Too much for me.
                                    • C
                                      C
                                      CalvinAndHobbes
                                      @petewill I looked at the Leviton controller - but I am in Australia, and they don't make an Australian version (for some reason, Z-Wave in Australia is on a different frequency).
                                      And the fans I am using are Hunter Pacific fans made by an Australian company, and that is probably why the remote works on a different frequency. I believe Hunter and Hunter Pacific are different companies - just in case anyone gets them confused.
                                      • petewillP
                                        petewillP
                                        petewill
                                        Yes, thanks for clarifying. I was thinking they were the same.
                                        Too many frequencies to worry about... I wish z-wave was all the same. It would simpler...
                                        • C
                                          C
                                          CalvinAndHobbes
                                          I contacted the manufacturer, and they confirmed the protocol is a proprietary one, but they suggested I hack the remote directly, and even offered to send me some remotes to play with, so I am going to go down that route. The remote is very easy to hack too.
