  3. Arduino Mega + RelayWithButtonActuator sketch
11 Posts 5 Posters 5.0k Views 4 Watching
  • S Offline
    Szmalu
    Hi guys :)
    First of all, I thank u very much for such a briliant site !
    I do at home overhaul, so I decided a few things to automate. I have Mysensors serial gw (Arduino Uno) connected to Raspbery Pi with Domoticz on it. With simple sketches it works like a charm (with Arduino Nano nodes). But not with my Arduino Mega :(
    I'd like to make arduino mega node which will be connected to 16 channel (or more) relay board witch will controll lights all over my house. The perfect sketch for it is RelayWithButtonActuator (so I could control it both from standard buttons and Domoticz). And it works perfect with arduino nano board (I've tried unmodyfied sketch). I' cant even start with Mega because all I can get from it's serial port is "check wires" message...
    I know that Mega has diferent pinout then nano/uno/pro... but i've connected it like below
    pin D8-----------CE (chip enable in)
    SS pin D53----------CSN (chip select in)
    SCK pin D52----------SCK (SPI clock in)
    MOSI pin D51----------SDI (SPI Data in)
    MISO pin D50----------SDO (SPI data out)
    But what with IRQ pin ? And should I change sth . in sketch file? I'm just getting started with all that Arduino stuff so thank u in advance for guiding me :) And sry for my English.
    • hekH Offline
      hekH Offline
      Skip the IRQ if you want (we don't use it in the library currently).
      3v3 output on the mega is super junk. Try using a step down from the 5V rail to feed the radio.
      • S Offline
        Szmalu
        nothing has changed
        • S Offline
          Szmalu
          shouldn't I change sth in RF24_config.h ?
          • T Offline
            T Offline
            TimO
            Did you change the sketch according to the connected CSN/CE Pins?
            • S Offline
              Szmalu
              What exactly should i change?
              • T Offline
                T Offline
                TimO
                http://www.mysensors.org/download/sensor_api_14#gateway
                You have to add CSN/CE Pin with the initialization.
                Something like:
                MySensor gw(8, 53);
                • S Offline
                  Szmalu
                  Wow :) TimO thx a lot !!! it's alive :+1: I've connected humidity and temp sensor for testing,
                  • S Offline
                    Szmalu
                    Ok, so as temperature/humidity sensor it works ok :)
                    But I can't get it to work as relay node.
                    Rx led is blinking when I push the button but nothing else is happening (no affection @ relay).
                    repeater started, id 0
                    send: 0-0-0-0 s=255,c=0,t=18,pt=0,l=5,st=fail:1.4.1
                    send: 0-0-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
                    send: 0-0-0-0 s=255,c=3,t=11,pt=0,l=14,st=fail:Relay & Button
                    send: 0-0-0-0 s=255,c=3,t=12,pt=0,l=3,st=fail:1.0
                    send: 0-0-0-0 s=1,c=0,t=3,pt=0,l=5,st=fail:1.4.1
                    send: 0-0-0-0 s=1,c=1,t=2,pt=2,l=2,st=fail:0
                    send: 0-0-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
                    send: 0-0-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:```
                    • S Offline
                      sj44k
                      As you can see in your messages the code "st=fail" means there is an issue.
                      Did you install the decoupling capacitor like mentioned here
                      As @hek mentioned the 3v3v output of a mega is (and I quote) "super junk" this might be the cause of your issue, the decoupling capacitor might just solve this (by the way it is always advisable to install these) but also the usage of a step down regulator so you can use the 5v rail to feed the radio could be necessary (in combination with the capacitor).
                      I have had a Mega + radio running on it's 3v3 feed with only the capacitor installed but all depends of the quality of your components so hard to say that this is always a winning combination, but that would be my way to go.
                      • jnatherJ Offline
                        jnatherJ Offline
                        jnather
                        Please, could you post your code? I can´t make my arduino mega work.
