  3. Need working example battery powered sensor
21 Posts 8 Posters 12.9k Views 7 Watching
  • rvendrameR rvendrame
    http://forum.mysensors.org/topic/486/my-2aa-battery-sensor/36
    J
    J
    jovo
    Yes, i have seen this discussion. it has great information and i should try some of them.
    To be more precise on my initial request, i think i should prioritize exploring the software options so it would be great if someone could clarify the best low-power options in the sketches. I am now just using the "sleep-time" option from the default mysensor sketches, but there are many more sleep options to choose for when checking the lowpower sketch. In particular, is there an difference between just sleep and power down. I guess so and since i like to work with a timer, if i can power down the node for a number of minutes, i guess that has great savings. a suggestion for a mysensors based power-down sketch would be great.
    • J
      J
      jovo
      wrote on last edited by jovo
      Spend some time today researching this topic.
      I concluded that I need a step-up anyway since the DHT-22 have a min Vcc of 3.3 which is easily reached when batteries are depleting, so I bought some of these.
      But this is not enough. I am fascinated by the extreme low power use of what we reported by EasyIoT in the low power guide by lowering the freq of the CPU.
      avrdude -c usbtiny -p m328p -U lfuse:w:0x62:m
      and
      avrdude -c usbtiny -p m328p -U efuse:w:0x07:m
      After some struggle I manage to burn the fuses (or at least AVRDUDE gave me a successful status). Then I edited the boards.txt and selected the EasyIoT board from the list. The problem I have now is that I cannot upload sketches anymore:
      avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x15
      I played a bit with the com speed setting in board.txt (as this resolved also my fuse burn issue earlier). Unfortunately, no success...
      Now my questions:
      • anybody similar experience after fuse buring and how to resolve this?
      • how can I revert back to the original fuse setting so I can use my arduino again?
      m26872M funky81F 2 Replies Last reply
      • J jovo
        and
        Now my questions:
        m26872M
        m26872M
        m26872
        wrote on last edited by m26872
        @jovo
        I don¨t have a straight answer. If you can't communicate with it, I think it's hard to do anything.
        Anyway I'll share my note since I researched this a while ago. I never got to the point when actually burn fuses. But I wrote this entry in my boards.txt:
        s328o1.name=ArduinoProMini-3.3V-8MHz(BOD 2.7V) FUSE-CHANGE to (int1MHz, BOD 1.8V)
        s328o1.upload.protocol=arduino
        s328o1.upload.maximum_size=30720
        s328o1.upload.speed=7200
        # http://www.gammon.com.au/forum/?id=11497
        # http://www.martyncurrey.com/?p=823
        s328o1.bootloader.low_fuses=0x62
        s328o1.bootloader.high_fuses=0xda
        s328o1.bootloader.extended_fuses=0x06
        #Omit .path and .file to simply burn the fuses. See https://code.google.com/p/arduino/wiki/Platforms
        #s328o1.bootloader.path=atmega
        #s328o1.bootloader.file=ATmegaBOOT_168_atmega328_pro_8MHz.hex
        s328o1.bootloader.unlock_bits=0x3F
        s328o1.bootloader.lock_bits=0x0F
        s328o1.build.mcu=atmega328p
        s328o1.build.f_cpu=1000000L
        s328o1.build.core=arduino
        s328o1.build.variant=standard
        Edit: Since I wrote that I've learn from here that BOD disabled saves 15-20uA. So now I would go for EasyIots setting with extended fuses 0x07.
        Edit2: It turned out that I had to use AvrStudio (v4.19+win7) with my avrispmkII to successfully burn fuses and bootloader (precompiled optiboot). Arduino IDE with avrdude just gave me trouble.
        • T
          TimO
          Is avrdude still working? Are you for example able to read out the fuses?
          Your fuses seem to be okay, I think there is an error in your board.txt. How are you trying to Upload the Sketch? Via ISP?
          • J jovo
            and
            Now my questions:
            funky81F
            funky81F
            funky81
            wrote on last edited by funky81
            @jovo my experiences quite different with you. I can successfully compiled and upload the sketches. Unfortunately, the packet from node, never reach gateway. Even though I pump the NRF24L01+ power with step up regulator, but still the same. Since then, I never try it with 1MHz again...
            To revert it again, burn your fuses again. Check this in Using the internal clock section
            • J
              J
              Jan Gatzke
              wrote on last edited by Jan Gatzke
              I think you need a modified Arduino bootloader for 1 Mhz operation. The bootloader does the serial communication wich is very timing critical. And when the bootloader is compiled with 8 mhz the baud value simply doesn't match.
              Regarding power consumption...did you remove the LEDs? The power LED alone needs about 2 mA. This would explain your values.
              funky81F 1 Reply Last reply
              • J Jan Gatzke
                funky81F
                funky81F
                funky81
                @Jan-Gatzke mind to share it how?
                • J
                  J
                  Jan Gatzke
                  I have never done this before. But basically you need the c code of the bootloader for your Arduino. Then open it with a text editor and change the f_cpu value. Then compile and flash it using avrdude.
                  I googled and found this:
                  http://angryelectron.com/how-to-update-the-bootloader-on-arduino-pro-mini-328/
                  I would use Atmel studio for these low level tasks if you are running on Windows.
                  J 1 Reply Last reply
                  • J Jan Gatzke
                    J
                    J
                    Jan Gatzke
                    I would use Atmel studio for these low level tasks if you are running in Windows.
                    Edit: Found already compiled bootloaders here: http://forum.arduino.cc/index.php?topic=160647.15
                    • J Jan Gatzke
                      funky81F
                      funky81F
                      funky81
                      @Jan-Gatzke Thank you very much Sir....Now this is getting excited :+1:
                      • J
                        J
                        jovo
                        I broke one Arduino by removing the power regulator
                        I broke another one while playing with the fuses (I think?) in an attempt to set the 1Mhz system clock.
                        I tried all suggested "low power/sleep/pwr_dwn sketches" I came across, but one of them was giving my a better power consumption then the default "sleep time" option used in the sketches of mysensors.
                        The only thing that was working as removing the LED. This saves approx. 1.2mA.
                        I am now at 3.3mA sleep consumption. Adding the DC-DC power booster to the config once received from China, so I expect to add another extra mA consumption.
                        Not sure if 4.5mA sleep pwr draw is sustainable for battery operators (only 26 days on a 2800mAh batterypack).
                        Since I believe that lowering the clock rate could be the solution for my project, I ordered some more mini-pro's to experiment more with the fuses setting.
                        Overall, despite the mixed results, still a very interesting project where I had great learning on my rusty hardware and programming skills....
                        Any further suggestions to improve pwr consumption remain always welcome :-)
                        AWIA 1 Reply Last reply
                        • J jovo
                          AWIA
                          AWIA
                          AWI
                          @jovo I had some problems with mini's I ordered which can be "switched" between 3.3 and 5v. These mini's use a voltage divider that consumes around 2 mA.! Apart from the led and regulator I alse needed to remove this divider to get to less consumption.
                          upload-4891e188-701a-4c2b-a302-afd4caa9b6b0
                          J hansiiiH 2 Replies Last reply
                          • AWIA AWI
                            J
                            J
                            jovo
                            @AWI: Tx for the feedback. I checked with my mini's. I got both versions: 5v and 3v3 (ordered from BEEStore). They seems not to be switchable. they 3v3 one have a 8Mhz crystal and the regulator (AMS 1117) for 3v3. the 5v one has 16Mhz crystal and a 5v version of this regulator.
                            I was wondering, in my design I plan to power the board directly from the VCC pin (not the raw). I suspect that the regulator doesn't consume much in this case. let me see if I can find a datasheet of this component.
                            • J
                              J
                              jovo
                              Humm, from the AMS1117 datasheet:
                              Quiescent Current AMS1117: 5-11mA.
                              It looks like to has some significant quiescent current.
                              Perhaps for me good idea to research a little further in this direction.
                              • funky81F funky81
                                funky81F
                                funky81F
                                funky81
                                @Jan-Gatzke i've tried this bootloader with several of my arduino pro mini.
                                most of them run @ 1 Mhz, thanks to you. but somehow the current consumption dont decrease. but i've check with my usbtiny for the fuse, it already @ 1MHz....
                                no clue what happen here
                                • AWIA AWI
                                  hansiiiH
                                  hansiiiH
                                  hansiii
                                  @AWI Hello AWI, sorry i know the topic is old, but i have exatly the same minis bought. Can you tell me what i have to remove or can you attach a photo. many thanks
                                  greetings
                                  hansiii
                                  • hansiiiH hansiii
                                    greetings
                                    hansiii
                                    AWIA
                                    AWIA
                                    AWI
                                    @hansiii that was certainly a while ago.. I removed all resistors near the voltage selector and the regulator (5 legs)
                                    hansiiiH 1 Reply Last reply
                                    • AWIA AWI
                                      hansiiiH
                                      hansiiiH
                                      hansiii
                                      @AWI Thank you!
                                      now i have removed the three resitors, before that I had only removed the regulator. Now the battery drain
                                      is away.
