  3. good karma
good karma
31 Posts 7 Posters 14.7k Views 2 Watching
  • epierreE
    epierreE
    epierre
    Well, I thought I would have to wait for 30 days to have hardware, but I received it under 9 days.... well recommended hardware seller here are worth 5 stars !
    Some soldering away and I'll have actual nodes !
    Best !
    z-wave - Vera -> Domoticz
      9 days is good. It happens sometimes when the post-office gods is in the right mood.
      • A
        aliasdoc
        Hi all, i try to use your library in my project with Raspberry Pi as Gateway, I start with your example "piGateway", all starting is done, here debug lines:
        Starting Gateway...
        Sensor-1Gateway created...
        Hej-begin-SPI device = /dev/spidev0.0
        SPI speed = 8000000
        CE GPIO = 25
        STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
        RX_ADDR_P0-1 = 0x7365727631 0xabcdabc000
        RX_ADDR_P2-5 = 0xff 0xe3 0xe4 0xe5
        TX_ADDR = 0x7365727631
        RX_PW_P0-6 = 0x20 0x20 0x20 0x20 0x20 0x20
        EN_AA = 0x3f
        EN_RXADDR = 0x3f
        RF_CH = 0x4c
        RF_SETUP = 0x07
        CONFIG = 0x0f
        DYNPD/FEATURE = 0x3f 0x04
        Data Rate = 1MBPS
        Model = nRF24L01+
        CRC Length = 16 bits
        PA Power = PA_MAX
        Radio setup complete-After setupRadio-After openReadingPipe-After startListening-After serial-Begin called
        but if I run my arduino with any examples (HumiditySensor, BatteryPoweredSensor, ...) They don't communicate. I double checked wiring, all is OK. Need help thanks.
        jendrushJ YveauxY 2 Replies Last reply
        • A aliasdoc
          Starting Gateway...
          SPI speed = 8000000
          CE GPIO = 25
          EN_AA = 0x3f
          EN_RXADDR = 0x3f
          RF_CH = 0x4c
          RF_SETUP = 0x07
          CONFIG = 0x0f
          Data Rate = 1MBPS
          Model = nRF24L01+
          PA Power = PA_MAX
          jendrushJ
          jendrushJ
          jendrush
          Do you have a capacitor between power, and ground? I have had same problem, and it helped.
          • A
            aliasdoc
            Hi jendrush, yes I have a capacitor of 10uF, transmission is ok with another framework (RF24network).
            • A
              aliasdoc
              I have one arduino uno loaded with DallasTemperatureSensor sketch and on rPi running PiGateway example
              • A aliasdoc
                Starting Gateway...
                SPI speed = 8000000
                CE GPIO = 25
                EN_AA = 0x3f
                EN_RXADDR = 0x3f
                RF_CH = 0x4c
                RF_SETUP = 0x07
                CONFIG = 0x0f
                Data Rate = 1MBPS
                Model = nRF24L01+
                PA Power = PA_MAX
                @aliasdoc Do the RX_ADDR_Px and TX_ADDR values match your configuration? If they are then communication seems to work ok.
                Some other trivial questions:
                • are both radio's on the same channel
                • same baudrate
                • both use CRC
                • have same packet length/use dynamic packet length
                • do you run the RPi code as root?
                • A
                  aliasdoc
                  wrote on last edited by aliasdoc
                  Hi Yveaux and thanks, effectively, config of my arduino is 2MBPS and RPi is 1MBPS, now it communicate but in RPI, I had "Unknown route from GW" error :
                  Dynamic payload size=7
                  Received: from=255, to=255, childId=79, mtype=9, type=0, crc=184, ''
                  Message crc ok.
                  header.type=0, header.to=255, radioId=0
                  and from arduino:
                  Tx: fr=255,to=255,la=255,ne=255,ci=255,mt=4,ty=9,cr=184:
                  No relay nodes was found. Trying again in 10 seconds.
                  YveauxY hekH 2 Replies Last reply
                  • A aliasdoc
                    Message crc ok.
                    and from arduino:
                    @aliasdoc This one's for Hek ;-)
                    • A
                      aliasdoc
                      Sorry Yveaux but I don't understand "Hek", what is this ?? thanks :)
                      jendrushJ greglG 2 Replies Last reply
                      • A aliasdoc
                        jendrushJ
                        jendrushJ
                        jendrush
                        @aliasdoc Hek is founder/cofounder of mysensors:) I am right?:)
                        • A
                          aliasdoc
                          thanks jendrush, i'm so stupid :-1:
                          • A aliasdoc
                            Message crc ok.
                            and from arduino:
                            @aliasdoc
                            It looks like the gateway/controller don't know where to send/route message for node 255.
                            I haven't really analyzed the RPI code that deeply but it must mimic the EEPROM routing table that the serial/ethernet gateway has (by picking up incomings messages last node.id)... If that is missing then RPI-gw has no clue where to send outgoing messages to nodes.
                            • A aliasdoc
                              greglG
                              greglG
                              gregl
                              Hek is the son of HAL...and the secret sauce who made all this possible....
                              All Hail Hek!!!
                              • A
                                aliasdoc
                                Hi Hek :), thanks for your reply, my RPi is my gateway, i try to make my own "cloud support", for testing, I have 1 RPi running as gateway (with example on github) and 1 sensor running BatteryPowerSensor sketch (original) like this:
                                (my cloud system) <-------- RPi (as gateway) <------------ arduino sensor (with BatteryPowersensor sketch)
                                Do I need to start inclusion mode ?? If I understand well, this mode is for automatic ID attribution, is correct ?
                                And I don't see any EEPROM routing table in serial ethernet examples.
                                Sorry if my questions are stupid, I try to understand how it works.
                                  wrote on last edited by hek
                                  #22
                                  You really don't need to start include mode (that was more to help vera cope with things).
                                  A request for id will have messageType=4, type=5.
                                  What you got was:
                                  There actually is no mtype=9. Looks like your header is messed up. Probably due to usage of c-bifields for the header struct (which is assembled/disassembled differently for rpi/arduino compiler). This has been fixed in the upcoming version of the library (were we use normal bit operations to extract the part-8-bit header stuff). A quickfix could be to use full bytes for all header fields (on the arduin/rpi-side).
                                  Or you could have a look at the new development version: https://github.com/mysensors/Arduino/tree/development and make the corresponding changes to RPI code.
                                  If you do the (preferred) later approach, please make sure to create a github pull request so we don't duplicate any work. :)
                                  • A
                                    aliasdoc
                                    Thanks Hek, I'll try to port the new development version to RPi and create pull request soon ;).
                                    • A
                                      aliasdoc
                                      #24
                                      @hek any idea to port eeprom routing table to raspberry, I think I can use a binary file to this and redefine eeprom_*() functions. What do you think about it ?
                                      hekH 1 Reply Last reply
                                      • A aliasdoc
                                        @aliasdoc
                                        That would be a nice solution! The less we need to re-#define the better.
                                        • A
                                          aliasdoc
                                          Ok, now I ported the library to RPI and make tests but the first send command from node is ok, but after it fails
                                          RPI debug:
                                          0;0;4;9;Device startup complete.
                                          0;0;4;8;read: 255-255-255 s=255,c=4,t=7,cr=ec:
                                          0;0;4;8;read: 255-255-0 s=255,c=4,t=3,cr=ec:
                                          and arduino node debug:
                                          send: 255-255-255-255 s=255,c=4,t=7, st=ok:
                                          req node id
                                          send: 255-255-255-0 s=255,c=4,t=3, st=fail:
                                          sensor started, id 255
                                          req node id
                                          req node id
                                          req node id
                                          req node id
                                          req node id
                                          any idea ?
