  3. good karma
good karma
31 Posts 7 Posters 14.7k Views 2 Watching
    9 days is good. It happens sometimes when the post-office gods is in the right mood.
    • A
      aliasdoc
      Hi all, i try to use your library in my project with Raspberry Pi as Gateway, I start with your example "piGateway", all starting is done, here debug lines:
      Starting Gateway...
      Sensor-1Gateway created...
      Hej-begin-SPI device = /dev/spidev0.0
      SPI speed = 8000000
      CE GPIO = 25
      STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
      RX_ADDR_P0-1 = 0x7365727631 0xabcdabc000
      RX_ADDR_P2-5 = 0xff 0xe3 0xe4 0xe5
      TX_ADDR = 0x7365727631
      RX_PW_P0-6 = 0x20 0x20 0x20 0x20 0x20 0x20
      EN_AA = 0x3f
      EN_RXADDR = 0x3f
      RF_CH = 0x4c
      RF_SETUP = 0x07
      CONFIG = 0x0f
      DYNPD/FEATURE = 0x3f 0x04
      Data Rate = 1MBPS
      Model = nRF24L01+
      CRC Length = 16 bits
      PA Power = PA_MAX
      Radio setup complete-After setupRadio-After openReadingPipe-After startListening-After serial-Begin called
      but if I run my arduino with any examples (HumiditySensor, BatteryPoweredSensor, ...) They don't communicate. I double checked wiring, all is OK. Need help thanks.
      jendrushJ YveauxY 2 Replies Last reply
      • A aliasdoc
        Starting Gateway...
        SPI speed = 8000000
        CE GPIO = 25
        EN_AA = 0x3f
        EN_RXADDR = 0x3f
        RF_CH = 0x4c
        RF_SETUP = 0x07
        CONFIG = 0x0f
        Data Rate = 1MBPS
        Model = nRF24L01+
        PA Power = PA_MAX
        jendrushJ
        jendrushJ
        jendrush
        Do you have a capacitor between power, and ground? I have had same problem, and it helped.
        • A
          aliasdoc
          Hi jendrush, yes I have a capacitor of 10uF, transmission is ok with another framework (RF24network).
          • A
            aliasdoc
            I have one arduino uno loaded with DallasTemperatureSensor sketch and on rPi running PiGateway example
            • A aliasdoc
              Starting Gateway...
              SPI speed = 8000000
              CE GPIO = 25
              EN_AA = 0x3f
              EN_RXADDR = 0x3f
              RF_CH = 0x4c
              RF_SETUP = 0x07
              CONFIG = 0x0f
              Data Rate = 1MBPS
              Model = nRF24L01+
              PA Power = PA_MAX
              @aliasdoc Do the RX_ADDR_Px and TX_ADDR values match your configuration? If they are then communication seems to work ok.
              Some other trivial questions:
              • are both radio's on the same channel
              • same baudrate
              • both use CRC
              • have same packet length/use dynamic packet length
              • do you run the RPi code as root?
              • A
                aliasdoc
                wrote on last edited by aliasdoc
                Hi Yveaux and thanks, effectively, config of my arduino is 2MBPS and RPi is 1MBPS, now it communicate but in RPI, I had "Unknown route from GW" error :
                Dynamic payload size=7
                Received: from=255, to=255, childId=79, mtype=9, type=0, crc=184, ''
                Message crc ok.
                header.type=0, header.to=255, radioId=0
                and from arduino:
                Tx: fr=255,to=255,la=255,ne=255,ci=255,mt=4,ty=9,cr=184:
                No relay nodes was found. Trying again in 10 seconds.
                YveauxY hekH 2 Replies Last reply
                • A aliasdoc
                  Message crc ok.
                  and from arduino:
                  @aliasdoc This one's for Hek ;-)
                  • A
                    aliasdoc
                    Sorry Yveaux but I don't understand "Hek", what is this ?? thanks :)
                    jendrushJ greglG 2 Replies Last reply
                    • A aliasdoc
                      jendrushJ
                      jendrushJ
                      jendrush
                      @aliasdoc Hek is founder/cofounder of mysensors:) I am right?:)
                      • A
                        aliasdoc
                        thanks jendrush, i'm so stupid :-1:
                        • A aliasdoc
                          Message crc ok.
                          and from arduino:
                          @aliasdoc
                          It looks like the gateway/controller don't know where to send/route message for node 255.
                          I haven't really analyzed the RPI code that deeply but it must mimic the EEPROM routing table that the serial/ethernet gateway has (by picking up incomings messages last node.id)... If that is missing then RPI-gw has no clue where to send outgoing messages to nodes.
                          • A aliasdoc
                            greglG
                            greglG
                            gregl
                            Hek is the son of HAL...and the secret sauce who made all this possible....
                            All Hail Hek!!!
                            • A
                              aliasdoc
                              Hi Hek :), thanks for your reply, my RPi is my gateway, i try to make my own "cloud support", for testing, I have 1 RPi running as gateway (with example on github) and 1 sensor running BatteryPowerSensor sketch (original) like this:
                              (my cloud system) <-------- RPi (as gateway) <------------ arduino sensor (with BatteryPowersensor sketch)
                              Do I need to start inclusion mode ?? If I understand well, this mode is for automatic ID attribution, is correct ?
                              And I don't see any EEPROM routing table in serial ethernet examples.
                              Sorry if my questions are stupid, I try to understand how it works.
                                wrote on last edited by hek
                                #22
                                You really don't need to start include mode (that was more to help vera cope with things).
                                A request for id will have messageType=4, type=5.
                                What you got was:
                                There actually is no mtype=9. Looks like your header is messed up. Probably due to usage of c-bifields for the header struct (which is assembled/disassembled differently for rpi/arduino compiler). This has been fixed in the upcoming version of the library (were we use normal bit operations to extract the part-8-bit header stuff). A quickfix could be to use full bytes for all header fields (on the arduin/rpi-side).
                                Or you could have a look at the new development version: https://github.com/mysensors/Arduino/tree/development and make the corresponding changes to RPI code.
                                If you do the (preferred) later approach, please make sure to create a github pull request so we don't duplicate any work. :)
                                • A
                                  aliasdoc
                                  Thanks Hek, I'll try to port the new development version to RPi and create pull request soon ;).
                                  • A
                                    aliasdoc
                                    #24
                                    @hek any idea to port eeprom routing table to raspberry, I think I can use a binary file to this and redefine eeprom_*() functions. What do you think about it ?
                                    hekH 1 Reply Last reply
                                    • A aliasdoc
                                      @aliasdoc
                                      That would be a nice solution! The less we need to re-#define the better.
                                      • A
                                        aliasdoc
                                        Ok, now I ported the library to RPI and make tests but the first send command from node is ok, but after it fails
                                        RPI debug:
                                        0;0;4;9;Device startup complete.
                                        0;0;4;8;read: 255-255-255 s=255,c=4,t=7,cr=ec:
                                        0;0;4;8;read: 255-255-0 s=255,c=4,t=3,cr=ec:
                                        and arduino node debug:
                                        send: 255-255-255-255 s=255,c=4,t=7, st=ok:
                                        req node id
                                        send: 255-255-255-0 s=255,c=4,t=3, st=fail:
                                        sensor started, id 255
                                        req node id
                                        req node id
                                        req node id
                                        req node id
                                        req node id
                                        any idea ?
                                          Looks like you get crc-error. cr=ec
                                          Hmm.. guess you'll have to dig into that part to see what could be wrong.
                                          Not sure why the node reports transmission failure... Are you using the same RF24 library version on both ends (you should use the same as Arduino-side).
