  3. Vera
  4. deleted vera device
deleted vera device
11 Posts 2 Posters 4.1k Views 1 Watching
  • ferpandoF Offline
    ferpandoF Offline
    ferpando
    I accidentally deleted a device from one of my sensors and even pushing the start button on the plugin and reseting the node has no effect.
    The device won't show up any more.
    Is there a way to re-add the device?
    Thanks in advance
    • H Offline
      H Offline
      It might be buffered in Vera. Hard reset your controller and re-do inclusion.
      ferpandoF 1 Reply Last reply
      • H hek
        ferpandoF Offline
        ferpandoF Offline
        ferpando
        @hek
        I did with no luck.
        Any other tips?
        • H Offline
          H Offline
          No, it should work .. I do it all the time when testing.
          • H hek
            ferpandoF Offline
            ferpandoF Offline
            ferpando
            @hek
            Should I delete de node?
            H 1 Reply Last reply
            • ferpandoF ferpando
              @hek
              H Offline
              H Offline
              @ferpando
              No .. shouldn't be necessary.
              You should check the sensor log that it is really sending presentation. Also check the vera log if the problem persistent. There might be some problem there.
              • H hek
                @ferpando
                ferpandoF Offline
                ferpandoF Offline
                ferpando
                @hek
                How do I look at the node's log?
                • ferpandoF Offline
                  ferpandoF Offline
                  ferpando
                  I don't see anything on Vera's log
                    @hek
                    H Offline
                    H Offline
                    @ferpando
                    http://www.mysensors.org/build/debug#enabling-debug-logging
                    • H hek
                      @ferpando
                      ferpandoF Offline
                      ferpandoF Offline
                      ferpando
                      @hek
                      Yes, but the problem is that I can't have it connected to USB when in use. It is too far away from a computer.
                      • ferpandoF Offline
                        ferpandoF Offline
                        ferpando
                        I had to clear the eprom and reprogram. Now it's working again.
                        One of the times I was trying to add the sensor without the radio plugged in. My bad :-S
                        12.1k
