  3. Building an IR Blaster
60 Posts 10 Posters 43.2k Views 4 Watching
    @steets250 said:
    I think you have to create your own implementation of SendProntoCode.
    You must take care of and handle all actions in D_IrTransmitter1.xml. Edit the I_Arduino.xml where you will find the actions defined.
    <action>
        <serviceId>urn:micasaverde-com:serviceId:IrTransmitter1</serviceId>
       	<name>SendProntoCode</name>
       	<run>if (p ~= nil) then p.sendProntoCode(lul_device, lul_settings.ProntoCode) end</run>
     </action>
    And then implement sendProntoCode in L_Arduino.lua which sends the actual code using sendCommand to gateway for further processing.
    function sendProntoCode(device, prontoCode)
        sendCommand(luup.devices[device].id,"IR_SEND",prontoCode)
    end
    But as I said in an earlier post the normal ProntoCode is too large to fit in one message over the air. So either you have to send short codes or split them somehow.
    ProntoCode=0000 0068 0000 000D 0060 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0018 0018 0018 0018 0018 03EC
    BulldogLowellB
    BulldogLowellB
    BulldogLowell
    Yes, but I think creating a state machine on the Arduino and storing these long pronto chains in flash may work.
    If we can get it to send a single CHAR, that will allow is almost the entire ASCII set (minus the not useable) nearly 250 commands.
      steets250
      Hek - Thanks for the advice with the sendProntoCode! I will work on it today.
      Bulldoglowell and Hek - I was just testing to see if the code would go through. I plan to have the Vera send out a number that represents a larger code stored in the Arduino.
        steets250
        I changed the files, and am now testing it out. Log says:
        08 06/06/14 10:25:29.361 JobHandler_LuaUPnP::HandleActionRequest argument ProntoCode=0000 0071 0000 001A 0080 0080 0020 0020 0020 0020 0020 0020 0020 0060 0020 0020 0020 0060 0020 0020 0020 0020 0020 0020 0020 0020 0020 0020 0020 0060 0020 0060 0020 0060 0020 0060 0020 0020 0020 0060 0020 0020 0020 0060 0020 0060 0020 0060 0020 0060 0020 0060 0020 0020 0020 04DF <0x2ca29680>
        02 06/06/14 10:25:29.362 Device_LuaUPnP::HandleActionRequest 38 none of the 1 implementations handled it <0x2ca29680>
        01 06/06/14 10:25:29.551 ZZZ-A2 83 <0x2ca29680>
        01 06/06/14 10:25:29.551 ZZZ-1 83 <0x2ca29680>
        01 06/06/14 10:25:29.551 ZZZ-1b 0xe1b888 <0x2ca29680>
        08 06/06/14 10:25:29.552 JobHandler_LuaUPnP::HandleActionRequest device: 38 service: urn:micasaverde-com:serviceId:IrTransmitter1 action: SendProntoCode <0x2ca29680>
        Last line looks promising. I guess I will try a shorter code, and see what I get.
          steets250
          Still nothing... I changed the some of the TV's IR codes (channel number buttons 1-6) to single digit numbers so that it would not be too big for serial. I case anyone wants to give it a shot, I attached the modified files.
          I_Codeset_2.xml
          D_Codeset_2.xml
          I_Arduino1.xml
          L_Arduino.lua
          S_IR_Serial.ino
            Not sure if it matters but shouldn't deviceType be "urn:schemas-micasaverde-com:device:IrDevice:1" ?
            IR = 		  {20, "urn:schemas-micasaverde-com:device:IrDevice:1", "D_IrTransmitter1.xml", "IR "},
            And what is the difference between "D_IrDevice1.xml" and "D_IrTransmitter1.xml"? (source: http://wiki.micasaverde.com/index.php/Luup_UPNP_Files)
              steets250
              I believe that Ir device is the tV or DVD that is created , and transmittersend out the ir codes.
                steets250
                wrote on last edited by steets250
                #36
                Might this be the problem?
                The IR transmitter has no implementation file.
                How do I get MySensors to create a device with I_IrTransmitter1.xml?
                  If you create a IR device as a "child" to Arduino you must handle all implementation yourself (like we just did for sendprotocode in the Arduino plugin).
                  I would suggest you create a thread or PM guessed on the micsa-forum who has good experience with the IR-device and is a really nice chap.
                  • S steets250
                    IMPORTANT: After forum data loss deleting half of this topic I recreated a newer and updated topic intro. If you haven't read this topic before, I recommend starting here: http://forum.mysensors.org/topic/146/building-an-ir-blaster/50
                    After discovering that I could create an IR device using MySensors, I wondered if I would use this as a substitute to SQ Blaster, iTACH, or USB-UIRT.
                    I tossed together an Arduino Nano, the NRF24L01, and an IR LED. I then created a simple program based to see what I could do with the IR device, and if I could get the Vera to use the Arduino as an IR transmitter.
                    Here is the program: I got rid of the # because it made the text a weird size in the forum.
                    include <Sensor.h>
                    include <SPI.h>
                    include <EEPROM.h>
                    include <RF24.h>
                    define ID 1
                    Sensor gw;
                    gw.begin();
                    gw.sendSensorPresentation(ID, S_IR);
                    delay(10000); // Wait 10 seconds
                    After adding the Arduino to the gateway, I encountered a problem. As soon as I add the IR device to Vera, the whole MySensors plugin glitches out, preventing all of my sensors from working. The first picture shows what the IR device looks like right after I add it, and then 20 seconds later, the second picture shows what happens until I delete the IR device from Vera.
                    Does anybody know what I am doing wrong? Thanks for your help!!
                    Steven
                    DvbitD
                    DvbitD
                    Dvbit
                    @steets250 Hi there
                    I did not notice this interesting topic til today.
                    This might help:
                    http://blog.univers-domotique.com/2013/10/plugin-vera-arduir/
                    Give it a google translate ;-)
                      steets250
                      Thanks for the suggestion, however, the project talked about is going the wrong way. I want signals from Vera to the transmitter, not transmitter to Vera.
                      I got an IR receiver and programmed my codes into an Arduino program. For anyone wondering, I had no storage issues (previously talked about).I haven't given up on this yet (saving $200 is a pretty good motivation)! Still trying to find out how to get Vera to send a message to Vera with Vera's IR remote UI. Seeing as how I have been trying with absolutely no luck for the past few days, I might have to make me own remote UI.
                      I haven't contacted guessed yet but I will soon, still playing around with it myself.
                      Has anyone tried this yet?? Instructions above.
                      • DvbitD
                        DvbitD
                        Dvbit
                        Ok. Please note that the guy in the post above talks about bidirectional signal "easily doable" in his post.
                        You may want to ask him ;-)
                        Tx for your wrk
                          steets250
                          @Dvbit I didn't see anything talking about a bidirectional signal. Where did you see that? I am going to check out what it says as well as the plugin files to see what I can find.
                          FWI: The IR receiver I ordered from RadioShack came, so I am able to program in the codes. It was mentioned earlier that the codes would take up a lot of space on the Arduino, but using the IRRemote library, receiving a remote signal gives me a hex that will work with some of my devices, so I don't see a storage issue. I have to remotes set up so far.
                          BulldogLowellB DvbitD 2 Replies Last reply
                          • S steets250
                            BulldogLowellB
                            BulldogLowellB
                            BulldogLowell
                            @steets250
                            If you need space, you could always attach external memory (SD card perhaps) .
                            Compressing the codes would be nice.
                            Cannot wait until you have this worked out!
                              steets250
                              So I got the Arduino side of it done! Did I make any mistakes?
                              MySensors_IR.ino
                              • S steets250
                                MySensors_IR.ino
                                BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                MySensors_IR.ino
                                the codes all do what they need to?
                                interesting that the length of the codes vary so much
                                TV 1 = B10000
                                TV 0 = B101110011101001
                                  steets250
                                  I was quite surprised when I saw that. All of the codes work properly when used with the send sony command. On my second remote, it uses the NEC protocol, and has a longer code. Another remote I tested was coming in as only raw code, so if someone tried to use remotes with only raw code it could be pretty space consuming.
                                  The sd card was a good idea! The program could also possible use multiple ir LEDs in different locations to get the signal to multiple devices, which is when the sd card might be needed.
                                  I'm now checking over what changes hek suggested earlier, and comparing it with some other mysensors devices. It seems like the vera is not sending a message through the send pronto code function that is described below.
                                  <action>
                                   </action>
                                  end
                                    steets250
                                    Trying to change the code that Vera transmits, I discover this: :angry::angry::angry::angry::angry:
                                    Right after selecting it here:
                                    I'm not sure why Vera refuses to accept the Arduino as an IR transmitter. I will give the SQ blaster plugin another look at to see what they have.
                                    • S steets250
                                      DvbitD
                                      DvbitD
                                      Dvbit
                                      @steets250
                                      La librairie IRremote permet la reception et l’émission de codes IR (Infrarouges) selon différents protocoles, la rendant compatible avec la plupart des télécommandes IR, et des appareils télécommandés par IR disponibles sur le marché.
                                      Dans ce plugin, seule la partie réception de la librairie est utilisée (rien n’empêche la réalisation d’une interface d’émission, sauf que je n’en ai pas l’usage J ).
                                      Irrlib supports input and output...then
                                      The last sentence is "nothing blocks from developing an output interface but I do not need it"
                                      hekH 1 Reply Last reply
                                      • DvbitD Dvbit
                                        @steets250
                                        @Dvbit
                                        The problem isn't really doing bi-directional sending of ir-codes between vera/arduino. The problem is getting a dynamic presentation on vera-side up and running. What @steets250 is trying to do is getting the built-in ir device working.. which probably is the most flexible solution.
                                        Cheerio
                                        • S steets250
                                          BulldogLowellB
                                          BulldogLowellB
                                          BulldogLowell
                                          you could try to look at the TiVo plugin, too.
