  3. Vera
  4. VeraEdge
VeraEdge
19 Posts 3 Posters 9.7k Views 2 Watching
  • L legaultf
    I have tested the hardware succesfully connecting the serial gateway on com5 and having a remote relay not connected to the computer with a led. I can turn the led wirelessly on and off wiht MYSController.
    I have then connected the serial USB to the VeraEdge and with some help from Vera managed to activate and configure the serial port.
    Here is the vera config for the serial port
    Serial Port configuration
    If you connected the USB/serial device and it's not displayed here, reload Luup.Reload Luup
    Name: ftdi_sio Path: /dev/ttyUSB0
    Device number: usb-101c1000.ohci-1
    IP address: Port: 3481
    Baud: 115200 Parity: none
    Data bits: 8 Stop bits: 1
    Used by device: MySensors Plugin [Living Room]
    At that stage I tried paring by pressing the pairing button on the Vera edge and resetting my sensor without succes.
    I the proceeded on creating a new device in the vera develop apps/Create device.
    this one I created a standard d_arduinoRelay1.xml as a child of the MySensors Plugin
    I then tried to discover my sensor without success.
    My next step maybe to add an ethernet gateway and see if the issue come from the serial interface on the vera.
    Hopefully you will see something I am doing wrong.
    Thank you
    Francois
    jeylitesJ
    jeylitesJ
    jeylites
    @legaultf
    Did you "Reset the Lupp"
    A trick I learned right after creating devises is to click on " Reload Luup". Then give it a couple of minutes and you should see the created devices on DEVICES on VERA.
    " Reload Luup". could be access from Apps -> Develop apps -> Serial Port configuration -> Reload Luup
    • L
      L
      legaultf
      I see all the devices but none have any controls. Does that mean they are not properly configured ?
      jeylitesJ 1 Reply Last reply
      • L legaultf
        jeylitesJ
        jeylitesJ
        jeylites
        @legaultf
        If your gateway is connected, it should look something like this.. See below. On my setup I have it connected via Serial. Initially I had it connected via Ethernet, but felt there was a delay. The serial route seem to be working great for me.
        Are you using the latest Vera version: 1.7.1089
        • L
          L
          legaultf
          Please find below the config screen for my device.
          Could you either copy paste your configuration screens or tell me what is not set properly ?
          Your help is greatly appreciated
          Francois
          • L legaultf
            Francois
            jeylitesJ
            jeylitesJ
            jeylites
            wrote on last edited by jeylites
            @legaultf
            Essentially, you don't have to do anything on this page unless you are using an Ethernet Gateway. If so you will have to copy the IP address with port No. into the ip column in Vera.
            • L
              L
              legaultf
              any idea why I can not pair any device or have a screen similar to yours showing the gateway ?
              • L legaultf
                jeylitesJ
                jeylitesJ
                jeylites
                @legaultf
                Can you take a screen shot of your devices on Vera. Try doing a power off / on reset. Or there could be something you didn't create after uploading the Lupp...
                • L
                  L
                  legaultf
                  I just made some progress
                  I now have the start stop control. I did not initially uploaded the .json file. Now I made sure I have the following d_arduino1.xml, d_arduino1.json, d_arduinorelay1.xml & json
                  jeylitesJ 2 Replies Last reply
                  • L legaultf
                    jeylitesJ
                    jeylitesJ
                    jeylites
                    @legaultf
                    The Error message is a normal because the vera need time to reload the new setting. I suggest to go to serial devices and reload the lupp. Hope it work after. I still fill you mist a couple of steps. I suggest doing through all steps again just to make sure.
                    • L legaultf
                      jeylitesJ
                      jeylitesJ
                      jeylites
                      @legaultf
                      Also make sure you are using UI7 files as linked https://github.com/mysensors/Vera/tree/UI7
                      • C4VetteC
                        C4VetteC
                        C4Vette
                        An uno as serial gateway?.
                        I think that is not supported and you should use a nano for that:
                        http://www.mysensors.org/build/serial_gateway
                        • L
                          L
                          legaultf
                          Major improvement with the latest version for the ui7 ! I now have the gateway being recognized.
                          When I press the start button it does work once after 10 tries and then I get the following ScreenHunter_69 Apr. 26 16.01.jpg
                          your help as got me this far thank you again I feel that I am making progress
                          • L
                            L
                            legaultf
                            Ok so I made a new gateway with an Arduino Nano and do not have any error anymore but I can not add any devices.
                            I contacted the people from Vera because my serial port option is gone.
                            They were able to reactive it but they told me "Arduino seems to be a replica (it should use FTDI) " which probably mean I have to order new one. Are you aware of this issue ? is this a show stopper as they seem to imply.
                            I will probably order what I need now and in the mean time I thank you all for your help.
                            Kindest regards,
                            Francois
                            • C4VetteC
                              C4VetteC
                              C4Vette
                              Thuis non-FTDI problem has been mentioned before:
                              http://forum.mysensors.org/topic/1024/serial-port-configuration-not-available
